Re: [U-Boot] [PATCH v2] arm920t/at91: use new clock features from libat91-common
resent to right list ...
Dear Reinhard Meyer,
Am 09.06.2011 11:21, schrieb Reinhard Meyer:
Dear Andreas Bießmann,
This patch enables the new clock features from new libat91-common. This is a required step to get at91rm9200_usart replaced by atmel_usart driver.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com
Cc: Jens Scharsig js_at_ng@scharsoft.de Cc: Eric Bénard eric@eukrea.com
I think this should go into NEXT unleass it unbreaks that board right now. You mentioned in another mail that it would be ok to be in 2011.09. Is that OK?
I'm fine with that. The arm920t/at91 boards do build (with minor warnings in at91_emac and at91rm9200_usart) and work on real hardware since 9e8df9c4db7835152996c96cc432dc6dd70bb17c
The warnings are: - 'at91_emac.c:487:2: warning: dereferencing type-punned pointer will break strict-aliasing rules' in at91_emac -> you know about that ... it is the same as in macb driver and will also be fixed soon. - 'at91rm9200_usart.c:39:2: warning: #warning Please update to use C structur SoC access !' -> at91rm9200_usart will be removed soon
Therefore I do not see any reason to remove those arm920t/at91 boards.
I will do some more testing with atmel_usart driver on atrm9200 devices and send for review this weekend. The big removal of old-style at91rm9200 boards can begin after that cause the deprecated at91rm9200_usart driver needs some outdated stuff which will also be removed in that step.
Besides that, I found out cpu.c (in that commit) is missing a GPL header and copyright notice. So please do not add this version.
regards
Andreas Bießmann
Andreas Bießmann
