[U-Boot] [PATCH] arm: socfpga: Don't redefine CONFIG_PHYLIB
CONFIG_PHYLIB is already set by the config system, don't set it again. Avoids ton of warnings.
Signed-off-by: Pavel Machek pavel@denx.de
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index b3f65b6..86eccba 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -105,7 +105,6 @@ #define CONFIG_DW_ALTDESCRIPTOR #define CONFIG_MII #define CONFIG_AUTONEG_TIMEOUT (15 * CONFIG_SYS_HZ) -#define CONFIG_PHYLIB #define CONFIG_PHY_GIGE #endif
Where exactly is it set by the config system ?
Sorry, I don't seem to be able to replicate these warnings. Can you provide more details ?
Best regards, Marek Vasut
U-boot based on be30dfbabbee12770221f434d2aa08627e712b97 .
pavel@duo:~/amp/u-boot$ grep -ri PHYLIB `find . -name "Kconfig"` ./drivers/net/Kconfig:config PHYLIB ./drivers/net/Kconfig: select PHYLIB ./drivers/net/Kconfig: 100Mbit and 1 Gbit operation. You must enable CONFIG_PHYLIB to ./drivers/net/Kconfig: select PHYLIB
ALTERA_TSE selects it.
Let me know if you need more info. Pavel
Altera TSE is not selected on any socfpga platform to my knowledge. Could it be your patch which is causing the interference ?
Ok, that explains why you don't see it. I have ALTERA_TSE enabled. ... which is probably useless, but still should not cause ton of warnings.
Question is: how to solve it properly? Pavel
Ccing Joe.
Hi Marek and Pavel,
The CONFIG_PHYLIB in socfpga_common.h should be moved to Kconfig. I will send a patch.
Best regards, Thomas
Pavel Machek
Thomas Chou
