[U-Boot-Users] 85xxCDS: Add make targets for legacy systems.
From 8bd3d40edb36a8b480aa6f2fbc0c8b3f2be5aae8 Mon Sep 17 00:00:00 2001
From: Randy Vinson <rvinson@linuxbox.(none)> Date: Tue, 27 Feb 2007 19:42:22 -0700 Subject: [PATCH] 85xxCDS: Add make targets for legacy systems.
The PCI ID select values on the Arcadia main board differ depending on the version of the hardware. The standard configuration supports Rev 3.1. The legacy target supports Rev 2.x.
Signed-off-by Randy Vinson rvinson@mvista.com --- Makefile | 27 ++++++++++++++++++++++++--- board/cds/common/via.c | 2 +- board/cds/mpc8541cds/mpc8541cds.c | 15 +++++++++------ board/cds/mpc8548cds/mpc8548cds.c | 15 +++++++++------ board/cds/mpc8555cds/mpc8555cds.c | 15 +++++++++------ cpu/mpc85xx/pci.c | 2 +- include/configs/MPC8541CDS.h | 7 +++++++ include/configs/MPC8548CDS.h | 8 ++++++++ include/configs/MPC8555CDS.h | 7 +++++++ 9 files changed, 75 insertions(+), 23 deletions(-)
diff --git a/Makefile b/Makefile index dd017d6..beb8a36 100644 --- a/Makefile +++ b/Makefile @@ -1751,17 +1751,38 @@ MPC8540EVAL_66_slave_config: unconfig MPC8560ADS_config: unconfig @$(MKCONFIG) $(@:_config=) ppc mpc85xx mpc8560ads
+MPC8541CDS_legacy_config \ MPC8541CDS_config: unconfig - @$(MKCONFIG) $(@:_config=) ppc mpc85xx mpc8541cds cds + @mkdir -p $(obj)include + @echo "" >$(obj)include/config.h ; \ + if [ "$(findstring _legacy_,$@)" ] ; then \ + echo "#define CONFIG_LEGACY" >>$(obj)include/config.h ; \ + echo "... legacy" ; \ + fi + @$(MKCONFIG) -a MPC8541CDS ppc mpc85xx mpc8541cds cds
MPC8544DS_config: unconfig @$(MKCONFIG) $(@:_config=) ppc mpc85xx mpc8544ds freescale
+MPC8548CDS_legacy_config \ MPC8548CDS_config: unconfig - @$(MKCONFIG) $(@:_config=) ppc mpc85xx mpc8548cds cds + @mkdir -p $(obj)include + @echo "" >$(obj)include/config.h ; \ + if [ "$(findstring _legacy_,$@)" ] ; then \ + echo "#define CONFIG_LEGACY" >>$(obj)include/config.h ; \ + echo "... legacy" ; \ + fi + @$(MKCONFIG) -a MPC8548CDS ppc mpc85xx mpc8548cds cds
+MPC8555CDS_legacy_config \ MPC8555CDS_config: unconfig - @$(MKCONFIG) $(@:_config=) ppc mpc85xx mpc8555cds cds + @mkdir -p $(obj)include + @echo "" >$(obj)include/config.h ; \ + if [ "$(findstring _legacy_,$@)" ] ; then \ + echo "#define CONFIG_LEGACY" >>$(obj)include/config.h ; \ + echo "... legacy" ; \ + fi + @$(MKCONFIG) -a MPC8555CDS ppc mpc85xx mpc8555cds cds
MPC8568MDS_config: unconfig @$(MKCONFIG) $(@:_config=) ppc mpc85xx mpc8568mds diff --git a/board/cds/common/via.c b/board/cds/common/via.c index ba6cebe..d64701b 100644 --- a/board/cds/common/via.c +++ b/board/cds/common/via.c @@ -47,7 +47,7 @@ void mpc85xx_config_via(struct pci_controller *hose, * This allows legacy I/O (i8259, etc) on the VIA * southbridge to be accessed. */ - bridge = PCI_BDF(0,17,0); + bridge = PCI_BDF(0,BRIDGE_ID,0); pci_hose_write_config_byte(hose, bridge, PCI_IO_BASE, 0); pci_hose_write_config_word(hose, bridge, PCI_IO_BASE_UPPER16, 0); pci_hose_write_config_byte(hose, bridge, PCI_IO_LIMIT, 0x10); diff --git a/board/cds/mpc8541cds/mpc8541cds.c b/board/cds/mpc8541cds/mpc8541cds.c index 4192324..558ba99 100644 --- a/board/cds/mpc8541cds/mpc8541cds.c +++ b/board/cds/mpc8541cds/mpc8541cds.c @@ -476,14 +476,17 @@ void dummy_func(struct pci_controller* hose, pci_dev_t dev, struct pci_config_ta
static struct pci_config_table pci_mpc85xxcds_config_table[] = { {0x10e3, 0x0513, PCI_ANY_ID, 1, 3, PCI_ANY_ID, dummy_func, {0,0,0}}, - {0x1106, 0x0686, PCI_ANY_ID, 1, 2, 0, mpc85xx_config_via, {0,0,0}}, - {0x1106, 0x0571, PCI_ANY_ID, 1, 2, 1, + {0x1106, 0x0686, PCI_ANY_ID, 1, VIA_ID, 0, mpc85xx_config_via, {0,0,0}}, + {0x1106, 0x0571, PCI_ANY_ID, 1, VIA_ID, 1, mpc85xx_config_via_usbide, {0,0,0}}, - {0x1105, 0x3038, PCI_ANY_ID, 1, 2, 2, mpc85xx_config_via_usb, {0,0,0}}, - {0x1106, 0x3038, PCI_ANY_ID, 1, 2, 3, mpc85xx_config_via_usb2, {0,0,0}}, - {0x1106, 0x3058, PCI_ANY_ID, 1, 2, 5, + {0x1105, 0x3038, PCI_ANY_ID, 1, VIA_ID, 2, + mpc85xx_config_via_usb, {0,0,0}}, + {0x1106, 0x3038, PCI_ANY_ID, 1, VIA_ID, 3, + mpc85xx_config_via_usb2, {0,0,0}}, + {0x1106, 0x3058, PCI_ANY_ID, 1, VIA_ID, 5, mpc85xx_config_via_power, {0,0,0}}, - {0x1106, 0x3068, PCI_ANY_ID, 1, 2, 6, mpc85xx_config_via_ac97, {0,0,0}}, + {0x1106, 0x3068, PCI_ANY_ID, 1, VIA_ID, 6, + mpc85xx_config_via_ac97, {0,0,0}}, {}, };
diff --git a/board/cds/mpc8548cds/mpc8548cds.c b/board/cds/mpc8548cds/mpc8548cds.c index 929ff2e..6b78a92 100644 --- a/board/cds/mpc8548cds/mpc8548cds.c +++ b/board/cds/mpc8548cds/mpc8548cds.c @@ -309,14 +309,17 @@ void dummy_func(struct pci_controller* hose, pci_dev_t dev, struct pci_config_ta
diff --git a/board/cds/mpc8555cds/mpc8555cds.c b/board/cds/mpc8555cds/mpc8555cds.c index 704bf03..8f16421 100644 --- a/board/cds/mpc8555cds/mpc8555cds.c +++ b/board/cds/mpc8555cds/mpc8555cds.c @@ -473,14 +473,17 @@ void dummy_func(struct pci_controller* hose, pci_dev_t dev, struct pci_config_ta
diff --git a/cpu/mpc85xx/pci.c b/cpu/mpc85xx/pci.c index 3c1a323..db09e45 100644 --- a/cpu/mpc85xx/pci.c +++ b/cpu/mpc85xx/pci.c @@ -142,7 +142,7 @@ pci_mpc85xx_init(struct pci_controller *board_hose) u8 header_type;
pci_hose_read_config_byte(hose, - PCI_BDF(0,17,0), + PCI_BDF(0,BRIDGE_ID,0), PCI_HEADER_TYPE, &header_type); } diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index fb360d2..515f1f4 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -350,6 +350,13 @@ extern unsigned long get_clock_freq(void); #define CFG_PCI2_IO_PHYS 0xe2100000 #define CFG_PCI2_IO_SIZE 0x100000 /* 1M */
+#ifdef CONFIG_LEGACY +#define BRIDGE_ID 17 +#define VIA_ID 2 +#else +#define BRIDGE_ID 28 +#define VIA_ID 4 +#endif
#if defined(CONFIG_PCI)
diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 680009d..6519bf7 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -369,6 +369,14 @@ extern unsigned long get_clock_freq(void); #define CFG_RIO_MEM_BASE 0xC0000000 #define CFG_RIO_MEM_SIZE 0x20000000 /* 512M */
+#ifdef CONFIG_LEGACY +#define BRIDGE_ID 17 +#define VIA_ID 2 +#else +#define BRIDGE_ID 28 +#define VIA_ID 4 +#endif + #if defined(CONFIG_PCI)
#define CONFIG_NET_MULTI diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 4c8b4e7..bf256a0 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -350,6 +350,13 @@ extern unsigned long get_clock_freq(void); #define CFG_PCI2_IO_PHYS 0xe2100000 #define CFG_PCI2_IO_SIZE 0x00100000 /* 1M */
+#ifdef CONFIG_LEGACY +#define ARCADIA_BRIDGE_ID 17 +#define VIA_ID 2 +#else +#define ARCADIA_BRIDGE_ID 28 +#define VIA_ID 4 +#endif
On Jul 23, 2007, at 18:18, Randy Vinson wrote:
From 8bd3d40edb36a8b480aa6f2fbc0c8b3f2be5aae8 Mon Sep 17 00:00:00 2001 From: Randy Vinson <rvinson@linuxbox.(none)> Date: Tue, 27 Feb 2007 19:42:22 -0700 Subject: [PATCH] 85xxCDS: Add make targets for legacy systems.
Applied
Andy
Andy Fleming
Randy Vinson
