[U-Boot] FW: [PATCH v3] PCIe:change the method to get the address of a requested capability in configuration space.
Hi Tom,
Please keep an eye on this patch http://patchwork.ozlabs.org/patch/275173/
Regards Zhao Qiang
-----Original Message----- From: Zhao Qiang-B45475 Sent: Monday, September 30, 2013 11:10 AM To: 'trini@ti.com' Cc: u-boot@lists.denx.de Subject: RE: [PATCH v3] PCIe:change the method to get the address of a requested capability in configuration space.
Hi Tom,
I'd like you to pay attention on this patch http://patchwork.ozlabs.org/patch/275173/
Regards Zhao Qiang
-----Original Message----- From: Zhao Qiang-B45475 Sent: Monday, September 16, 2013 5:28 PM To: u-boot@lists.denx.de Cc: Zhao Qiang-B45475 Subject: [PATCH v3] PCIe:change the method to get the address of a requested capability in configuration space.
Previously, the address of a requested capability is define like that "#define PCI_DCR 0x78" But, the addresses of capabilities is different with regard to PCIe
revs.
So this method is not flexible.
Now a function to get the address of a requested capability is added and used. It can get the address dynamically by capability ID. The step of this function:
- Read Status register in PCIe configuration space to confirm that Capabilities List is valid.
- Find the address of Capabilities Pointer Register.
- Find the address of requested capability from the first
capability.
Signed-off-by: Zhao Qiang B45475@freescale.com
Changes for v2: -Put an variable into "#ifdef" and "#endif" Changes for v3: -Modify the patch description
arch/powerpc/include/asm/fsl_pci.h | 13 +------- drivers/pci/fsl_pci_init.c | 44 +++++++++++++++++++------- drivers/pci/pci.c | 65 ++++++++++++++++++++++++++++++++++++++ include/pci.h | 10 ++++++ 4 files changed, 108 insertions(+), 24 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_pci.h b/arch/powerpc/include/asm/fsl_pci.h index 90b0a2f..6b12afa 100644 --- a/arch/powerpc/include/asm/fsl_pci.h +++ b/arch/powerpc/include/asm/fsl_pci.h @@ -32,22 +32,11 @@ /* Freescale-specific PCI config registers */ #define FSL_PCI_PBFR 0x44
-#ifdef CONFIG_SYS_FSL_PCI_VER_3_X +#ifndef CONFIG_SYS_FSL_PCI_VER_3_X /* Currently only the PCIe capability is used, so hardcode the offset.
- if more capabilities need to be justified, the capability link
method
- should be applied here
*/ -#define FSL_PCIE_CAP_ID 0x70 -#define PCI_DCR 0x78 /* PCIe Device Control Register */ -#define PCI_DSR 0x7a /* PCIe Device Status Register */ -#define PCI_LSR 0x82 /* PCIe Link Status Register */ -#define PCI_LCR 0x80 /* PCIe Link Control Register */ -#else -#define FSL_PCIE_CAP_ID 0x4c -#define PCI_DCR 0x54 /* PCIe Device Control Register */ -#define PCI_DSR 0x56 /* PCIe Device Status Register */ -#define PCI_LSR 0x5e /* PCIe Link Status Register */ -#define PCI_LCR 0x5c /* PCIe Link Control Register */ #define FSL_PCIE_CFG_RDY 0x4b0 #endif #define FSL_PCI_CFG_READY 1 /* Endpoint: allow inbound configuration */ diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 76337fe..492efcf 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -308,6 +308,15 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) int enabled, r, inbound = 0; u16 ltssm; u8 temp8, pcie_cap;
- int pcie_cap_pos;
- int pci_dcr;
- int pci_dsr;
- int pci_lsr;
+#if defined(CONFIG_FSL_PCIE_DISABLE_ASPM)
- int pci_lcr;
- volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *)cfg_addr; struct pci_region *reg = hose->regions + hose->region_count; pci_dev_t dev = PCI_BDF(hose->first_busno, 0, 0); @@ -380,7 +389,12
@@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) hose->region_count++;
/* see if we are a PCIe or PCI controller */
- pci_hose_read_config_byte(hose, dev, FSL_PCIE_CAP_ID, &pcie_cap);
- pcie_cap_pos = pci_hose_find_capability(hose, dev, PCI_CAP_ID_EXP);
- pci_dcr = pcie_cap_pos + 0x08;
- pci_dsr = pcie_cap_pos + 0x0a;
- pci_lsr = pcie_cap_pos + 0x12;
- pci_hose_read_config_byte(hose, dev, pcie_cap_pos, &pcie_cap);
#ifdef CONFIG_SRIO_PCIE_BOOT_MASTER /* boot from PCIE --master */ @@ -419,15 +433,16 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) * - Master PERR (pci) * - ICCA (PCIe) */
- pci_hose_read_config_dword(hose, dev, PCI_DCR, &temp32);
- pci_hose_read_config_dword(hose, dev, pci_dcr, &temp32); temp32 |= 0xf000e; /* set URR, FER, NFER (but not CER)
- pci_hose_write_config_dword(hose, dev, PCI_DCR, temp32);
- pci_hose_write_config_dword(hose, dev, pci_dcr, temp32);
- pci_lcr = pcie_cap_pos + 0x10; temp32 = 0;
- pci_hose_read_config_dword(hose, dev, PCI_LCR, &temp32);
- pci_hose_read_config_dword(hose, dev, pci_lcr, &temp32); temp32 &= ~0x03; /* Disable ASPM */
- pci_hose_write_config_dword(hose, dev, PCI_LCR, temp32);
- pci_hose_write_config_dword(hose, dev, pci_lcr, temp32); udelay(1);
#endif if (pcie_cap == PCI_CAP_ID_EXP) { @@ -507,7 +522,7 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) out_be32(&pci->pme_msg_int_en, 0xffffffff);
/* Print the negotiated PCIe link width */
pci_hose_read_config_word(hose, dev, PCI_LSR, &temp16);
printf("x%d, regs @ 0x%lx\n", (temp16 & 0x3f0 ) >> 4, pci_info->regs);pci_hose_read_config_word(hose, dev, pci_lsr, &temp16);
@@ -554,9 +569,9 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) out_be32(&pci->pme_msg_det, 0xffffffff); out_be32(&pci->pedr, 0xffffffff);
- pci_hose_read_config_word (hose, dev, PCI_DSR, &temp16);
- pci_hose_read_config_word(hose, dev, pci_dsr, &temp16); if (temp16) {
pci_hose_write_config_word(hose, dev, PCI_DSR, 0xffff);
pci_hose_write_config_word(hose, dev, pci_dsr, 0xffff);
pci_hose_read_config_word (hose, dev, PCI_SEC_STATUS, &temp16); @@
-567,10 +582,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info)
int fsl_is_pci_agent(struct pci_controller *hose) {
- int pcie_cap_pos; u8 pcie_cap; pci_dev_t dev = PCI_BDF(hose->first_busno, 0, 0);
- pci_hose_read_config_byte(hose, dev, pcie_cap_pos, &pcie_cap); if (pcie_cap == PCI_CAP_ID_EXP) { u8 header_type;
@@ -595,6 +612,7 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info, volatile ccsr_fsl_pci_t *pci; struct pci_region *r; pci_dev_t dev = PCI_BDF(busno,0,0);
pci = (ccsr_fsl_pci_t *) pci_info->regs; @@ -644,7 +662,8 @@ int
fsl_pci_init_port(struct fsl_pci_info *pci_info, #endif }
- pci_hose_read_config_byte(hose, dev, pcie_cap_pos, &pcie_cap); printf("PCI%s%x: Bus %02x - %02x\n", pcie_cap == PCI_CAP_ID_EXP ? "e" : "", pci_info->pci_num, hose->first_busno, hose->last_busno); @@ -656,13 +675,14 @@
int
fsl_pci_init_port(struct fsl_pci_info *pci_info, void fsl_pci_config_unlock(struct pci_controller *hose) { pci_dev_t dev = PCI_BDF(hose->first_busno,0,0);
int pcie_cap_pos; u8 pcie_cap; u16 pbfr;
if (!fsl_is_pci_agent(hose)) return;
- pci_hose_read_config_byte(hose, dev, pcie_cap_pos, &pcie_cap); if (pcie_cap != 0x0) { /* PCIe - set CFG_READY bit of Configuration Ready Register
#ifdef CONFIG_SYS_FSL_PCI_VER_3_X diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index d864f13..c57ea6f 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -738,3 +738,68 @@ void pci_init(void) /* now call board specific pci_init()... */ pci_init_board(); }
+/* Returns the address of the requested capability structure within +the
- device's PCI configuration space or 0 in case the device does not
- support it.
+int pci_hose_find_capability(struct pci_controller *hose, pci_dev_t
dev,
int cap)
- int pos;
- u8 hdr_type;
- pci_hose_read_config_byte(hose, dev, PCI_HEADER_TYPE, &hdr_type);
- pos = pci_hose_find_cap_start(hose, dev, hdr_type & 0x7F);
- if (pos)
pos = pci_find_cap(hose, dev, pos, cap);
- return pos;
+/* Find the header pointer to the Capabilities*/ int +pci_hose_find_cap_start(struct pci_controller *hose, pci_dev_t dev,
u8 hdr_type)
- u16 status;
- pci_hose_read_config_word(hose, dev, PCI_STATUS, &status);
- if (!(status & PCI_STATUS_CAP_LIST))
- switch (hdr_type) {
- case PCI_HEADER_TYPE_NORMAL:
- case PCI_HEADER_TYPE_BRIDGE:
return PCI_CAPABILITY_LIST;
- case PCI_HEADER_TYPE_CARDBUS:
return PCI_CB_CAPABILITY_LIST;
- default:
+int pci_find_cap(struct pci_controller *hose, pci_dev_t dev, int pos, +int cap) {
- int ttl = PCI_FIND_CAP_TTL;
- u8 id;
- u8 next_pos;
- while (ttl--) {
pci_hose_read_config_byte(hose, dev, pos, &next_pos);
if (next_pos < CAP_START_POS)
break;
next_pos &= ~3;
pos = (int) next_pos;
pos + PCI_CAP_LIST_ID, &id);
if (id == 0xff)
break;
if (id == cap)
return pos;
pos += PCI_CAP_LIST_NEXT;
+} diff --git a/include/pci.h b/include/pci.h index 7e3b3b6..477835e 100644 --- a/include/pci.h +++ b/include/pci.h @@ -426,6 +426,9 @@ #define PCI_MAX_PCI_DEVICES 32 #define PCI_MAX_PCI_FUNCTIONS 8
+#define PCI_FIND_CAP_TTL 0x48 +#define CAP_START_POS 0x40
/* Include the ID list */
#include <pci_ids.h> @@ -663,6 +666,13 @@ extern int pci_hose_config_device(struct pci_controller *hose, pci_addr_t mem, unsigned long command);
+extern int pci_hose_find_capability(struct pci_controller *hose, pci_dev_t dev,
int cap);
+extern int pci_hose_find_cap_start(struct pci_controller *hose, pci_dev_t dev,
u8 hdr_type);
+extern int pci_find_cap(struct pci_controller *hose, pci_dev_t dev, +int pos,
int cap);
const char * pci_class_str(u8 class); int pci_last_busno(void);
-- 1.8.0
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 10/09/2013 09:39 PM, Zhao Qiang-B45475 wrote:
Hi Tom,
Regards Zhao Qiang
Hi Tom,
[snip]
York? I'd like this to come via your tree, thanks!
- -- Tom
Zhao Qiang-B45475
