[U-Boot] [PATCH 1/2] exynos: Correct use of 64-bit division
The current code is causing errors like this on my toolchains:
/usr/x86_64-pc-linux-gnu/armv7a-cros-linux-gnueabi/binutils-bin/2.22/ ld.bfd.real: failed to merge target specific data of file /usr/lib/gcc/ armv7a-cros-linux-gnueabi/4.7.x-google/libgcc.a(_divdi3.o)
Use do_div() to avoid this.
Signed-off-by: Simon Glass sjg@chromium.org --- arch/arm/cpu/armv7/s5p-common/timer.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/s5p-common/timer.c b/arch/arm/cpu/armv7/s5p-common/timer.c index 6a0fa58..4adfaae 100644 --- a/arch/arm/cpu/armv7/s5p-common/timer.c +++ b/arch/arm/cpu/armv7/s5p-common/timer.c @@ -24,6 +24,7 @@ */
#include <common.h> +#include <div64.h> #include <asm/io.h> #include <asm/arch/pwm.h> #include <asm/arch/clk.h> @@ -76,6 +77,8 @@ int timer_init(void) */ unsigned long get_timer(unsigned long base) { + unsigned long long time_ms; + ulong now = timer_get_us_down();
/* @@ -87,7 +90,9 @@ unsigned long get_timer(unsigned long base) gd->arch.lastinc = now;
/* Divide by 1000 to convert from us to ms */ - return gd->arch.timer_reset_value / 1000 - base; + time_ms = gd->arch.timer_reset_value; + do_div(time_ms, 1000); + return time_ms - base; }
unsigned long timer_get_us(void)
Snow is missing a TMU node, and with TMU support this is not allowed, so it fails to boot. Add it.
Signed-off-by: Simon Glass sjg@chromium.org --- board/samsung/dts/exynos5250-snow.dts | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/board/samsung/dts/exynos5250-snow.dts b/board/samsung/dts/exynos5250-snow.dts index 8b303bf..24658c1 100644 --- a/board/samsung/dts/exynos5250-snow.dts +++ b/board/samsung/dts/exynos5250-snow.dts @@ -55,4 +55,18 @@ compatible = "maxim,max77686_pmic"; }; }; + + tmu@10060000 { + samsung,min-temp = <25>; + samsung,max-temp = <125>; + samsung,start-warning = <95>; + samsung,start-tripping = <105>; + samsung,hw-tripping = <110>; + samsung,efuse-min-value = <40>; + samsung,efuse-value = <55>; + samsung,efuse-max-value = <100>; + samsung,slope = <274761730>; + samsung,dc-value = <25>; + }; + };
- tmu@10060000 {
applied to u-boot-samsung
Thanks, Minkyu Kang.
- time_ms = gd->arch.timer_reset_value;
- do_div(time_ms, 1000);
- return time_ms - base;
Minkyu Kang
