[PULL] u-boot-at91-2024.01-b
Hello Tom,
Please pull tag u-boot-at91-2024.01-b , the second set of at91 features for 2024.01 cycle.
This feature set a new board named Conclusive KSTR sama5d27 with some small prerequisites patches.
Thanks, Eugen
The following changes since commit 9a3a58396b78b1f9d0c14580dc03f81d29207dd2:
Merge https://source.denx.de/u-boot/custodians/u-boot-marvell (2023-10-20 12:54:33 -0400)
https://source.denx.de/u-boot/custodians/u-boot-at91.git tags/u-boot-at91-2024.01-b
for you to fetch changes up to 27347893f02d4457b80357a38c194a726a43533a:
board: Add support for Conclusive KSTR-SAMA5D27 (2023-10-23 17:07:06 +0300)
---------------------------------------------------------------- Second set of u-boot-at91 features for the 2024.01 cycle
---------------------------------------------------------------- Artur Rojek (4): common: add prototype & rename populate_serial_number() event: add new EVT_SETTINGS_R event arm: dts: at91: sama5: Add flexcom4 node board: Add support for Conclusive KSTR-SAMA5D27
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-kstr-sama5d27-u-boot.dtsi | 42 +++++ arch/arm/dts/at91-kstr-sama5d27.dts | 127 +++++++++++++ arch/arm/dts/sama5d2.dtsi | 20 +++ arch/arm/mach-at91/Kconfig | 12 ++ board/conclusive/kstr-sama5d27/Kconfig | 15 ++ board/conclusive/kstr-sama5d27/MAINTAINERS | 9 + board/conclusive/kstr-sama5d27/Makefile | 5 + board/conclusive/kstr-sama5d27/kstr-sama5d27.c | 239 +++++++++++++++++++++++++ cmd/tlv_eeprom.c | 14 +- common/board_r.c | 1 + common/event.c | 1 + configs/kstr_sama5d27_defconfig | 73 ++++++++ include/configs/kstr-sama5d27.h | 15 ++ include/event.h | 9 + include/init.h | 14 ++ 16 files changed, 586 insertions(+), 13 deletions(-) create mode 100644 arch/arm/dts/at91-kstr-sama5d27-u-boot.dtsi create mode 100644 arch/arm/dts/at91-kstr-sama5d27.dts create mode 100644 board/conclusive/kstr-sama5d27/Kconfig create mode 100644 board/conclusive/kstr-sama5d27/MAINTAINERS create mode 100644 board/conclusive/kstr-sama5d27/Makefile create mode 100644 board/conclusive/kstr-sama5d27/kstr-sama5d27.c create mode 100644 configs/kstr_sama5d27_defconfig create mode 100644 include/configs/kstr-sama5d27.h
On Mon, Oct 23, 2023 at 06:23:38PM +0300, Eugen Hristev wrote:
Hello Tom,
Thanks, Eugen
Eugen Hristev
