[U-Boot] [PATCH v3 0/3] Tegra: MMC: Add DT support for MMC to T20 boards
This patchset adds device-tree support to the Tegra MMC driver. All device config is done via properties in the DT files instead of hard-coded config options/function arguments.
I've tested this on my Seaboard and everything works fine, including card detect. For the other T20 boards, I've used the Linux kernel DTS files for the sdhci nodes where there wasn't one already, or expanded the info that was already there. Everything builds fine, but I haven't tested anything but Seaboard.
v2: Changes as per Stephen's & Simon's review v3: Changes as per Stephen/Lucas/Thierry/Simon's feedback
Tom Warren (3): Tegra: fdt: Add/enhance sdhci (mmc) nodes for all T20 DT files Tegra: fdt: tamonten: Add common tamonten.dtsi file from linux Tegra: MMC: Add DT support to MMC driver for all T20 boards
arch/arm/dts/tegra20.dtsi | 16 +- arch/arm/include/asm/arch-tegra/mmc.h | 2 +- arch/arm/include/asm/arch-tegra/tegra_mmc.h | 13 +- board/avionic-design/common/tamonten.c | 19 +- board/avionic-design/dts/tegra20-medcom-wide.dts | 3 +- board/avionic-design/dts/tegra20-plutux.dts | 3 +- board/avionic-design/dts/tegra20-tamonten.dtsi | 489 +++++++++++++++++++++ board/avionic-design/dts/tegra20-tec.dts | 3 +- board/compal/dts/tegra20-paz00.dts | 19 +- board/compal/paz00/paz00.c | 26 +- board/compulab/dts/tegra20-trimslice.dts | 14 + board/compulab/trimslice/trimslice.c | 25 +- board/nvidia/common/board.c | 26 +- board/nvidia/dts/tegra20-harmony.dts | 18 + board/nvidia/dts/tegra20-seaboard.dts | 10 +- board/nvidia/dts/tegra20-ventana.dts | 15 + board/nvidia/dts/tegra20-whistler.dts | 13 + board/nvidia/harmony/harmony.c | 26 +- board/nvidia/seaboard/seaboard.c | 25 +- board/nvidia/whistler/whistler.c | 30 +- board/toradex/colibri_t20_iris/colibri_t20_iris.c | 11 +- board/toradex/dts/tegra20-colibri_t20_iris.dts | 7 + drivers/mmc/tegra_mmc.c | 259 +++++++---- dts/Makefile | 2 +- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 26 files changed, 815 insertions(+), 261 deletions(-) create mode 100644 board/avionic-design/dts/tegra20-tamonten.dtsi
Linux dts files were used for those boards that didn't already have sdhci info populated. Tamonten has their own dtsi file with common sdhci nodes (sourced from Linux).
Signed-off-by: Tom Warren twarren@nvidia.com Tested-by: Thierry Reding thierry.reding@avionic-design.de --- v2: - cleanup comments in dts files/match w/kernel files - add sdhci aliases in all dts files - use tegra20-tamonten.dtsi from the kernel for AD boards v3: - include tamonten.dtsi file directly in AD dts files - fix Seaboard power-gpios flags - add cd-gpios for Colibri T20 Iris - add include paths to DTC command
arch/arm/dts/tegra20.dtsi | 16 ++++++++++++---- board/avionic-design/dts/tegra20-medcom-wide.dts | 3 ++- board/avionic-design/dts/tegra20-plutux.dts | 3 ++- board/avionic-design/dts/tegra20-tec.dts | 3 ++- board/compal/dts/tegra20-paz00.dts | 19 +++++++++++++++++-- board/compulab/dts/tegra20-trimslice.dts | 14 ++++++++++++++ board/nvidia/dts/tegra20-harmony.dts | 18 ++++++++++++++++++ board/nvidia/dts/tegra20-seaboard.dts | 10 +++++++--- board/nvidia/dts/tegra20-ventana.dts | 15 +++++++++++++++ board/nvidia/dts/tegra20-whistler.dts | 13 +++++++++++++ board/toradex/dts/tegra20-colibri_t20_iris.dts | 7 +++++++ dts/Makefile | 2 +- 12 files changed, 110 insertions(+), 13 deletions(-)
diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index 9a89685..982a070 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -318,24 +318,32 @@ sdhci@c8000000 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000000 0x200>; - interrupts = < 46 >; + interrupts = <0 14 0x04>; + clocks = <&tegra_car 14>; + status = "disabled"; };
sdhci@c8000200 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000200 0x200>; - interrupts = < 47 >; + interrupts = <0 15 0x04>; + clocks = <&tegra_car 9>; + status = "disabled"; };
sdhci@c8000400 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000400 0x200>; - interrupts = < 51 >; + interrupts = <0 19 0x04>; + clocks = <&tegra_car 69>; + status = "disabled"; };
sdhci@c8000600 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000600 0x200>; - interrupts = < 63 >; + interrupts = <0 31 0x04>; + clocks = <&tegra_car 15>; + status = "disabled"; }; }; diff --git a/board/avionic-design/dts/tegra20-medcom-wide.dts b/board/avionic-design/dts/tegra20-medcom-wide.dts index e46afbe..01a4451 100644 --- a/board/avionic-design/dts/tegra20-medcom-wide.dts +++ b/board/avionic-design/dts/tegra20-medcom-wide.dts @@ -1,6 +1,6 @@ /dts-v1/;
-/include/ ARCH_CPU_DTS +/include/ "tegra20-tamonten.dtsi"
/ { model = "Avionic Design Medcom-Wide"; @@ -8,6 +8,7 @@
aliases { usb0 = "/usb@c5008000"; + sdhci0 = "/sdhci@c8000600"; };
memory { diff --git a/board/avionic-design/dts/tegra20-plutux.dts b/board/avionic-design/dts/tegra20-plutux.dts index 3e6cce0..f574542 100644 --- a/board/avionic-design/dts/tegra20-plutux.dts +++ b/board/avionic-design/dts/tegra20-plutux.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Avionic Design Plutux"; @@ -8,6 +8,7 @@
memory { diff --git a/board/avionic-design/dts/tegra20-tec.dts b/board/avionic-design/dts/tegra20-tec.dts index bf3ff1d..376d279 100644 --- a/board/avionic-design/dts/tegra20-tec.dts +++ b/board/avionic-design/dts/tegra20-tec.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Avionic Design Tamonten Evaluation Carrier"; @@ -8,6 +8,7 @@
memory { diff --git a/board/compal/dts/tegra20-paz00.dts b/board/compal/dts/tegra20-paz00.dts index 31b064d..6476940 100644 --- a/board/compal/dts/tegra20-paz00.dts +++ b/board/compal/dts/tegra20-paz00.dts @@ -3,11 +3,13 @@ /include/ ARCH_CPU_DTS
/ { - model = "Toshiba AC100 / Dynabook AZ"; - compatible = "compal,paz00", "nvidia,tegra20"; + model = "Toshiba AC100 / Dynabook AZ"; + compatible = "compal,paz00", "nvidia,tegra20";
aliases { usb0 = "/usb@c5008000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000000"; };
memory { @@ -53,6 +55,19 @@ status = "disabled"; };
+ sdhci@c8000000 { + status = "okay"; + cd-gpios = <&gpio 173 0>; /* gpio PV5 */ + wp-gpios = <&gpio 57 0>; /* gpio PH1 */ + power-gpios = <&gpio 169 0>; /* gpio PV1 */ + bus-width = <4>; + }; + + sdhci@c8000600 { + status = "okay"; + bus-width = <8>; + }; + lcd_panel: panel { /* PAZ00 has 1024x600 */ clock = <54030000>; diff --git a/board/compulab/dts/tegra20-trimslice.dts b/board/compulab/dts/tegra20-trimslice.dts index 7aeed67..2957f45 100644 --- a/board/compulab/dts/tegra20-trimslice.dts +++ b/board/compulab/dts/tegra20-trimslice.dts @@ -9,6 +9,8 @@ aliases { usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000000"; };
memory { @@ -47,4 +49,16 @@ usb@c5004000 { status = "disabled"; }; + + sdhci@c8000000 { + status = "okay"; + bus-width = <4>; + }; + + sdhci@c8000600 { + status = "okay"; + cd-gpios = <&gpio 121 0>; /* gpio PP1 */ + wp-gpios = <&gpio 122 0>; /* gpio PP2 */ + bus-width = <4>; + }; }; diff --git a/board/nvidia/dts/tegra20-harmony.dts b/board/nvidia/dts/tegra20-harmony.dts index aeda3a1..593885d 100644 --- a/board/nvidia/dts/tegra20-harmony.dts +++ b/board/nvidia/dts/tegra20-harmony.dts @@ -9,6 +9,8 @@ aliases { usb0 = "/usb@c5008000"; usb1 = "/usb@c5004000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000200"; };
memory { @@ -52,4 +54,20 @@ usb@c5004000 { nvidia,phy-reset-gpio = <&gpio 169 0>; /* gpio PV1 */ }; + + sdhci@c8000200 { + status = "okay"; + cd-gpios = <&gpio 69 0>; /* gpio PI5 */ + wp-gpios = <&gpio 57 0>; /* gpio PH1 */ + power-gpios = <&gpio 155 0>; /* gpio PT3 */ + bus-width = <4>; + }; + + sdhci@c8000600 { + status = "okay"; + cd-gpios = <&gpio 58 0>; /* gpio PH2 */ + wp-gpios = <&gpio 59 0>; /* gpio PH3 */ + power-gpios = <&gpio 70 0>; /* gpio PI6 */ + bus-width = <8>; + }; }; diff --git a/board/nvidia/dts/tegra20-seaboard.dts b/board/nvidia/dts/tegra20-seaboard.dts index 527a296..4c10631 100644 --- a/board/nvidia/dts/tegra20-seaboard.dts +++ b/board/nvidia/dts/tegra20-seaboard.dts @@ -12,14 +12,15 @@ };
aliases { - /* This defines the order of our USB ports */ + /* This defines the order of our ports */ usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; - i2c0 = "/i2c@7000d000"; i2c1 = "/i2c@7000c000"; i2c2 = "/i2c@7000c400"; i2c3 = "/i2c@7000c500"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000400"; };
memory { @@ -156,13 +157,16 @@ };
sdhci@c8000400 { + status = "okay"; cd-gpios = <&gpio 69 0>; /* gpio PI5 */ wp-gpios = <&gpio 57 0>; /* gpio PH1 */ power-gpios = <&gpio 70 0>; /* gpio PI6 */ + bus-width = <4>; };
sdhci@c8000600 { - support-8bit; + status = "okay"; + bus-width = <8>; };
lcd_panel: panel { diff --git a/board/nvidia/dts/tegra20-ventana.dts b/board/nvidia/dts/tegra20-ventana.dts index 3e5e39d..0423595 100644 --- a/board/nvidia/dts/tegra20-ventana.dts +++ b/board/nvidia/dts/tegra20-ventana.dts @@ -8,6 +8,8 @@
aliases { usb0 = "/usb@c5008000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000400"; };
memory { @@ -41,4 +43,17 @@ usb@c5004000 { status = "disabled"; }; + + sdhci@c8000400 { + status = "okay"; + cd-gpios = <&gpio 69 0>; /* gpio PI5 */ + wp-gpios = <&gpio 57 0>; /* gpio PH1 */ + power-gpios = <&gpio 70 0>; /* gpio PI6 */ + bus-width = <4>; + }; + + sdhci@c8000600 { + status = "okay"; + bus-width = <8>; + }; }; diff --git a/board/nvidia/dts/tegra20-whistler.dts b/board/nvidia/dts/tegra20-whistler.dts index 4579557..2d0a2ab 100644 --- a/board/nvidia/dts/tegra20-whistler.dts +++ b/board/nvidia/dts/tegra20-whistler.dts @@ -9,6 +9,8 @@ aliases { i2c0 = "/i2c@7000d000"; usb0 = "/usb@c5008000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000400"; };
memory { @@ -57,4 +59,15 @@ usb@c5004000 { status = "disabled"; }; + + sdhci@c8000400 { + status = "okay"; + wp-gpios = <&gpio 173 0>; /* gpio PV5 */ + bus-width = <8>; + }; + + sdhci@c8000600 { + status = "okay"; + bus-width = <8>; + }; }; diff --git a/board/toradex/dts/tegra20-colibri_t20_iris.dts b/board/toradex/dts/tegra20-colibri_t20_iris.dts index c29b43a..a2c5a0e 100644 --- a/board/toradex/dts/tegra20-colibri_t20_iris.dts +++ b/board/toradex/dts/tegra20-colibri_t20_iris.dts @@ -10,6 +10,7 @@ usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; usb2 = "/usb@c5004000"; + sdhci0 = "/sdhci@c8000600"; };
usb@c5000000 { @@ -35,4 +36,10 @@ compatible = "nand-flash"; }; }; + + sdhci@c8000600 { + status = "okay"; + cd-gpios = <&gpio 23 0>; /* gpio PC7 */ + bus-width = <4>; + }; }; diff --git a/dts/Makefile b/dts/Makefile index 922c78c..2ef31e9 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -50,7 +50,7 @@ DT_BIN := $(obj)dt.dtb $(DT_BIN): $(TOPDIR)/board/$(VENDOR)/dts/$(DEVICE_TREE).dts rc=$$( \ cat $< | $(CPP) -P $(DTS_CPPFLAGS) - | \ - { { $(DTC) -R 4 -p 0x1000 -O dtb -o ${DT_BIN} - 2>&1 ; \ + { { $(DTC) -R 4 -p 0x1000 -i $(TOPDIR)/board/$(VENDOR)/dts -i $(TOPDIR)/arch/$(ARCH)/dts -O dtb -o ${DT_BIN} - 2>&1 ; \ echo $$? >&3 ; } | \ grep -v '^DTC: dts->dtb on file' ; \ } 3>&1 1>&2 ) ; \
echo $$? >&3 ; } | \ grep -v '^DTC: dts->dtb on file' ; \ } 3>&1 1>&2 ) ; \{ { $(DTC) -R 4 -p 0x1000 -i $(TOPDIR)/board/$(VENDOR)/dts -i $(TOPDIR)/arch/$(ARCH)/dts -O dtb -o ${DT_BIN} - 2>&1 ; \
Shouldn't this be a separate patch?
The one issue with this is that only newer versions of dtc support the -i option. The version packaged with most distros won't support it. That'll mean something like "MAKEALL -a arm" is going to fail for a lot of people without some kind of explicit action (i.e. manually installing a newer version of dtc).
That's why I suggested switching from /include/ to #include, and adding the include path to the cpp command rather than dtc.
Stephen,
I can move it into a separate patch in v4.
I tried using '#include, and added the 2 dts paths to the DTS_CPPFLAGS so gcc could find the files, but I got a 'couldn't open 'skeleton.dtsi' error. I didn't want to change tegra20.dtsi to #include "skeleton.dtsi', and all the other board dts files to #include ARCH_CPU_DTS, just so we can support the common tamonten dtsi, so I went back to the DTC include path changes.
There was talk at one time of putting an up-to-date DTC binary in the U-Boot tools area so everyone would have a consistent level of DT support. With the small number of boards using DT at this time, I think we can live with letting people know where to find the latest DTC release until then.
If someone has a better approach, let me know. Otherwise, I want to get this into a v4 patch (with the DTC include path changes in it's own patch so it can be reworked later if needed) today as I'll be gone until next Weds.
Tom
On 02/14/2013 09:14 AM, Tom Warren wrote:
Stephen,
I think that's exactly where we should end up though. It's certainly the way the kernel is also heading.
Right now, the Avionic Design boards might be the only place this problem crops up, but as we support more features on Cardhu, we'll hit exactly the same issue, so have to solve it there too.
I think Wolfgang nak'd that.
But he also nak'd the idea of relying on a newer dtc:-(
I think we had better raise the question again.
Am Donnerstag, den 14.02.2013, 13:24 -0700 schrieb Stephen Warren: [...]
Right now the AD boards might be the only ones with this problem, but it will certainly hit the Toradex Tegra designs also.
I'm planning on doing support for the Colibri Evaluation Carrier for the next release cycle. So I need to split up the DTS between Colibri and Carrier board, same as is done in the Linux Kernel dts.
Yes, this has to be resolved one way or the other.
Lucas/Stephen/etc.
OK, I'll change all of the Tegra .DTS an .DTSI files to use #include "xyz", and put the include path in the DTS_CPPFLAGS in dts/Makefile instead of adding the include path to the DTC tool. This'll be in v5 of the patchset.
Tom
Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings.
Signed-off-by: Tom Warren twarren@nvidia.com Acked-by: Thierry Reding thierry.reding@avionic-design.de --- v3: new
board/avionic-design/dts/tegra20-tamonten.dtsi | 489 ++++++++++++++++++++++++ 1 files changed, 489 insertions(+), 0 deletions(-) create mode 100644 board/avionic-design/dts/tegra20-tamonten.dtsi
diff --git a/board/avionic-design/dts/tegra20-tamonten.dtsi b/board/avionic-design/dts/tegra20-tamonten.dtsi new file mode 100644 index 0000000..4766aba --- /dev/null +++ b/board/avionic-design/dts/tegra20-tamonten.dtsi @@ -0,0 +1,489 @@ +/include/ "tegra20.dtsi" + +/ { + model = "Avionic Design Tamonten SOM"; + compatible = "ad,tamonten", "nvidia,tegra20"; + + memory { + reg = <0x00000000 0x20000000>; + }; + + host1x { + hdmi { + vdd-supply = <&hdmi_vdd_reg>; + pll-supply = <&hdmi_pll_reg>; + + nvidia,ddc-i2c-bus = <&hdmi_ddc>; + nvidia,hpd-gpio = <&gpio 111 0>; /* PN7 */ + }; + }; + + pinmux { + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pinmux { + ata { + nvidia,pins = "ata"; + nvidia,function = "ide"; + }; + atb { + nvidia,pins = "atb", "gma", "gme"; + nvidia,function = "sdio4"; + }; + atc { + nvidia,pins = "atc"; + nvidia,function = "nand"; + }; + atd { + nvidia,pins = "atd", "ate", "gmb", "gmd", "gpu", + "spia", "spib", "spic"; + nvidia,function = "gmi"; + }; + cdev1 { + nvidia,pins = "cdev1"; + nvidia,function = "plla_out"; + }; + cdev2 { + nvidia,pins = "cdev2"; + nvidia,function = "pllp_out4"; + }; + crtp { + nvidia,pins = "crtp"; + nvidia,function = "crt"; + }; + csus { + nvidia,pins = "csus"; + nvidia,function = "vi_sensor_clk"; + }; + dap1 { + nvidia,pins = "dap1"; + nvidia,function = "dap1"; + }; + dap2 { + nvidia,pins = "dap2"; + nvidia,function = "dap2"; + }; + dap3 { + nvidia,pins = "dap3"; + nvidia,function = "dap3"; + }; + dap4 { + nvidia,pins = "dap4"; + nvidia,function = "dap4"; + }; + dta { + nvidia,pins = "dta", "dtd"; + nvidia,function = "sdio2"; + }; + dtb { + nvidia,pins = "dtb", "dtc", "dte"; + nvidia,function = "rsvd1"; + }; + dtf { + nvidia,pins = "dtf"; + nvidia,function = "i2c3"; + }; + gmc { + nvidia,pins = "gmc"; + nvidia,function = "uartd"; + }; + gpu7 { + nvidia,pins = "gpu7"; + nvidia,function = "rtck"; + }; + gpv { + nvidia,pins = "gpv", "slxa", "slxk"; + nvidia,function = "pcie"; + }; + hdint { + nvidia,pins = "hdint"; + nvidia,function = "hdmi"; + }; + i2cp { + nvidia,pins = "i2cp"; + nvidia,function = "i2cp"; + }; + irrx { + nvidia,pins = "irrx", "irtx"; + nvidia,function = "uarta"; + }; + kbca { + nvidia,pins = "kbca", "kbcb", "kbcc", "kbcd", + "kbce", "kbcf"; + nvidia,function = "kbc"; + }; + lcsn { + nvidia,pins = "lcsn", "ld0", "ld1", "ld2", + "ld3", "ld4", "ld5", "ld6", "ld7", + "ld8", "ld9", "ld10", "ld11", "ld12", + "ld13", "ld14", "ld15", "ld16", "ld17", + "ldc", "ldi", "lhp0", "lhp1", "lhp2", + "lhs", "lm0", "lm1", "lpp", "lpw0", + "lpw1", "lpw2", "lsc0", "lsc1", "lsck", + "lsda", "lsdi", "lspi", "lvp0", "lvp1", + "lvs"; + nvidia,function = "displaya"; + }; + owc { + nvidia,pins = "owc", "spdi", "spdo", "uac"; + nvidia,function = "rsvd2"; + }; + pmc { + nvidia,pins = "pmc"; + nvidia,function = "pwr_on"; + }; + rm { + nvidia,pins = "rm"; + nvidia,function = "i2c1"; + }; + sdb { + nvidia,pins = "sdb", "sdc", "sdd"; + nvidia,function = "pwm"; + }; + sdio1 { + nvidia,pins = "sdio1"; + nvidia,function = "sdio1"; + }; + slxc { + nvidia,pins = "slxc", "slxd"; + nvidia,function = "spdif"; + }; + spid { + nvidia,pins = "spid", "spie", "spif"; + nvidia,function = "spi1"; + }; + spig { + nvidia,pins = "spig", "spih"; + nvidia,function = "spi2_alt"; + }; + uaa { + nvidia,pins = "uaa", "uab", "uda"; + nvidia,function = "ulpi"; + }; + uad { + nvidia,pins = "uad"; + nvidia,function = "irda"; + }; + uca { + nvidia,pins = "uca", "ucb"; + nvidia,function = "uartc"; + }; + conf_ata { + nvidia,pins = "ata", "atb", "atc", "atd", "ate", + "cdev1", "cdev2", "dap1", "dtb", "gma", + "gmb", "gmc", "gmd", "gme", "gpu7", + "gpv", "i2cp", "pta", "rm", "slxa", + "slxk", "spia", "spib", "uac"; + nvidia,pull = <0>; + nvidia,tristate = <0>; + }; + conf_ck32 { + nvidia,pins = "ck32", "ddrc", "pmca", "pmcb", + "pmcc", "pmcd", "pmce", "xm2c", "xm2d"; + nvidia,pull = <0>; + }; + conf_csus { + nvidia,pins = "csus", "spid", "spif"; + nvidia,pull = <1>; + nvidia,tristate = <1>; + }; + conf_crtp { + nvidia,pins = "crtp", "dap2", "dap3", "dap4", + "dtc", "dte", "dtf", "gpu", "sdio1", + "slxc", "slxd", "spdi", "spdo", "spig", + "uda"; + nvidia,pull = <0>; + nvidia,tristate = <1>; + }; + conf_ddc { + nvidia,pins = "ddc", "dta", "dtd", "kbca", + "kbcb", "kbcc", "kbcd", "kbce", "kbcf", + "sdc"; + nvidia,pull = <2>; + nvidia,tristate = <0>; + }; + conf_hdint { + nvidia,pins = "hdint", "lcsn", "ldc", "lm1", + "lpw1", "lsc1", "lsck", "lsda", "lsdi", + "lvp0", "owc", "sdb"; + nvidia,tristate = <1>; + }; + conf_irrx { + nvidia,pins = "irrx", "irtx", "sdd", "spic", + "spie", "spih", "uaa", "uab", "uad", + "uca", "ucb"; + nvidia,pull = <2>; + nvidia,tristate = <1>; + }; + conf_lc { + nvidia,pins = "lc", "ls"; + nvidia,pull = <2>; + }; + conf_ld0 { + nvidia,pins = "ld0", "ld1", "ld2", "ld3", "ld4", + "ld5", "ld6", "ld7", "ld8", "ld9", + "ld10", "ld11", "ld12", "ld13", "ld14", + "ld15", "ld16", "ld17", "ldi", "lhp0", + "lhp1", "lhp2", "lhs", "lm0", "lpp", + "lpw0", "lpw2", "lsc0", "lspi", "lvp1", + "lvs", "pmc"; + nvidia,tristate = <0>; + }; + conf_ld17_0 { + nvidia,pins = "ld17_0", "ld19_18", "ld21_20", + "ld23_22"; + nvidia,pull = <1>; + }; + }; + + state_i2cmux_ddc: pinmux_i2cmux_ddc { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "i2c2"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "rsvd4"; + }; + }; + + state_i2cmux_pta: pinmux_i2cmux_pta { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "rsvd4"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "i2c2"; + }; + }; + + state_i2cmux_idle: pinmux_i2cmux_idle { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "rsvd4"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "rsvd4"; + }; + }; + }; + + i2s@70002800 { + status = "okay"; + }; + + serial@70006300 { + status = "okay"; + }; + + i2c@7000c000 { + clock-frequency = <400000>; + status = "okay"; + }; + + i2c@7000c400 { + clock-frequency = <100000>; + status = "okay"; + }; + + i2cmux { + compatible = "i2c-mux-pinctrl"; + #address-cells = <1>; + #size-cells = <0>; + + i2c-parent = <&{/i2c@7000c400}>; + + pinctrl-names = "ddc", "pta", "idle"; + pinctrl-0 = <&state_i2cmux_ddc>; + pinctrl-1 = <&state_i2cmux_pta>; + pinctrl-2 = <&state_i2cmux_idle>; + + hdmi_ddc: i2c@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + i2c@7000d000 { + clock-frequency = <400000>; + status = "okay"; + + pmic: tps6586x@34 { + compatible = "ti,tps6586x"; + reg = <0x34>; + interrupts = <0 86 0x4>; + + ti,system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + sys-supply = <&vdd_5v0_reg>; + vin-sm0-supply = <&sys_reg>; + vin-sm1-supply = <&sys_reg>; + vin-sm2-supply = <&sys_reg>; + vinldo01-supply = <&sm2_reg>; + vinldo23-supply = <&sm2_reg>; + vinldo4-supply = <&sm2_reg>; + vinldo678-supply = <&sm2_reg>; + vinldo9-supply = <&sm2_reg>; + + regulators { + sys_reg: sys { + regulator-name = "vdd_sys"; + regulator-always-on; + }; + + sm0 { + regulator-name = "vdd_sys_sm0,vdd_core"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + sm1 { + regulator-name = "vdd_sys_sm1,vdd_cpu"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + sm2_reg: sm2 { + regulator-name = "vdd_sys_sm2,vin_ldo*"; + regulator-min-microvolt = <3700000>; + regulator-max-microvolt = <3700000>; + regulator-always-on; + }; + + ldo0 { + regulator-name = "vdd_ldo0,vddio_pex_clk"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + ldo1 { + regulator-name = "vdd_ldo1,avdd_pll*"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + ldo2 { + regulator-name = "vdd_ldo2,vdd_rtc"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + ldo3 { + regulator-name = "vdd_ldo3,avdd_usb*"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + ldo4 { + regulator-name = "vdd_ldo4,avdd_osc,vddio_sys"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + ldo5 { + regulator-name = "vdd_ldo5,vcore_mmc"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + }; + + ldo6 { + regulator-name = "vdd_ldo6,avdd_vdac"; + /* + * According to the Tegra 2 Automotive + * DataSheet, a typical value for this + * would be 2.8V, but the PMIC only + * supports 2.85V. + */ + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + }; + + hdmi_vdd_reg: ldo7 { + regulator-name = "vdd_ldo7,avdd_hdmi"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + hdmi_pll_reg: ldo8 { + regulator-name = "vdd_ldo8,avdd_hdmi_pll"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo9 { + regulator-name = "vdd_ldo9,vdd_ddr_rx,avdd_cam"; + /* + * According to the Tegra 2 Automotive + * DataSheet, a typical value for this + * would be 2.8V, but the PMIC only + * supports 2.85V. + */ + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + }; + + ldo_rtc { + regulator-name = "vdd_rtc_out"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + temperature-sensor@4c { + compatible = "onnn,nct1008"; + reg = <0x4c>; + }; + }; + + pmc { + nvidia,invert-interrupt; + }; + + usb@c5008000 { + status = "okay"; + }; + + sdhci@c8000600 { + cd-gpios = <&gpio 58 0>; /* gpio PH2 */ + wp-gpios = <&gpio 59 0>; /* gpio PH3 */ + bus-width = <4>; + status = "okay"; + }; + + regulators { + compatible = "simple-bus"; + + #address-cells = <1>; + #size-cells = <0>; + + vdd_5v0_reg: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "vdd_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + }; +};
v3: new
If this was new in v3, how did Thierry ack it already?
v3: new
It's a bit unfortunate that this can't use ARCH_CPU_DTS anymore because it isn't run through the preprocessor. With the Tegra30 Tamonten coming up I thought it might have been nice to share some parts of it, but given the amount of changes between Tegra20 and Tegra30 Tamonten I don't think that will be much of an option anyway.
So this is fine with me.
Thierry
tegra_mmc_init() now parses the DT info for bus width, WP/CD GPIOs, etc. Tested on Seaboard, fully functional.
Signed-off-by: Tom Warren twarren@nvidia.com Signed-off-by: Thierry Reding thierry.reding@avionic-design.de --- v2: - all boards now call tegra_mmc_init once, w/no params - count MMC controllers, not aliases - AD boards (medcom/plutux/tec) use common tegra20-tamonten.dtsi v3: - move any power init inside board's pin_mux_mmc function, and/or create pin_mux_mmc function if necessary. - move board_mmc_init out of each board file and into ../common/board.c
arch/arm/include/asm/arch-tegra/mmc.h | 2 +- arch/arm/include/asm/arch-tegra/tegra_mmc.h | 13 +- board/avionic-design/common/tamonten.c | 19 +-- board/compal/paz00/paz00.c | 26 +-- board/compulab/trimslice/trimslice.c | 25 +-- board/nvidia/common/board.c | 26 ++- board/nvidia/harmony/harmony.c | 26 +-- board/nvidia/seaboard/seaboard.c | 25 +-- board/nvidia/whistler/whistler.c | 30 +-- board/toradex/colibri_t20_iris/colibri_t20_iris.c | 11 +- drivers/mmc/tegra_mmc.c | 259 +++++++++++++-------- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 13 files changed, 216 insertions(+), 248 deletions(-)
diff --git a/arch/arm/include/asm/arch-tegra/mmc.h b/arch/arm/include/asm/arch-tegra/mmc.h index 5c95047..71ad407 100644 --- a/arch/arm/include/asm/arch-tegra/mmc.h +++ b/arch/arm/include/asm/arch-tegra/mmc.h @@ -22,6 +22,6 @@ #ifndef _TEGRA_MMC_H_ #define _TEGRA_MMC_H_
-int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio); +void tegra_mmc_init(void);
#endif /* _TEGRA_MMC_H_ */ diff --git a/arch/arm/include/asm/arch-tegra/tegra_mmc.h b/arch/arm/include/asm/arch-tegra/tegra_mmc.h index dd746ca..bd18f5f 100644 --- a/arch/arm/include/asm/arch-tegra/tegra_mmc.h +++ b/arch/arm/include/asm/arch-tegra/tegra_mmc.h @@ -27,6 +27,8 @@ #define TEGRA_SDMMC3_BASE 0xC8000400 #define TEGRA_SDMMC4_BASE 0xC8000600
+#define MAX_HOSTS 4 /* Max number of 'hosts'/controllers */ + #ifndef __ASSEMBLY__ struct tegra_mmc { unsigned int sysad; /* _SYSTEM_ADDRESS_0 */ @@ -119,12 +121,15 @@ struct tegra_mmc {
struct mmc_host { struct tegra_mmc *reg; + int id; /* device id/number, 0-3 */ + int enabled; /* 1 to enable, 0 to disable */ + int width; /* Bus Width, 1, 4 or 8 */ + enum periph_id mmc_id; /* Peripheral ID: PERIPH_ID_... */ + struct fdt_gpio_state cd_gpio; /* Change Detect GPIO */ + struct fdt_gpio_state pwr_gpio; /* Power GPIO */ + struct fdt_gpio_state wp_gpio; /* Write Protect GPIO */ unsigned int version; /* SDHCI spec. version */ unsigned int clock; /* Current clock (MHz) */ - unsigned int base; /* Base address, SDMMC1/2/3/4 */ - enum periph_id mmc_id; /* Peripheral ID: PERIPH_ID_... */ - int pwr_gpio; /* Power GPIO */ - int cd_gpio; /* Change Detect GPIO */ };
#endif /* __ASSEMBLY__ */ diff --git a/board/avionic-design/common/tamonten.c b/board/avionic-design/common/tamonten.c index e6a932e..ea95e43 100644 --- a/board/avionic-design/common/tamonten.c +++ b/board/avionic-design/common/tamonten.c @@ -33,13 +33,8 @@ #include <asm/arch/tegra.h> #include <asm/arch-tegra/board.h> #include <asm/arch-tegra/clk_rst.h> -#include <asm/arch-tegra/mmc.h> #include <asm/arch-tegra/sys_proto.h> #include <asm/arch-tegra/uart.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif -
#ifdef CONFIG_BOARD_EARLY_INIT_F void gpio_early_init(void) @@ -54,7 +49,7 @@ void gpio_early_init(void) * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_GME_8_BIT); /* for write-protect GPIO PI6 */ @@ -62,16 +57,4 @@ static void pin_mux_mmc(void) /* for CD GPIO PH2 */ pinmux_tristate_disable(PINGRP_ATD); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - /* init dev 0, SD slot, with 4-bit bus */ - tegra_mmc_init(0, 4, GPIO_PI6, GPIO_PH2); - - return 0; -} #endif diff --git a/board/compal/paz00/paz00.c b/board/compal/paz00/paz00.c index 1447f47..d6e5c37 100644 --- a/board/compal/paz00/paz00.c +++ b/board/compal/paz00/paz00.c @@ -18,19 +18,14 @@ #include <asm/io.h> #include <asm/arch/tegra.h> #include <asm/arch/pinmux.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif -
#ifdef CONFIG_TEGRA_MMC /* * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { /* SDMMC4: config 3, x8 on 2nd set of pins */ pinmux_set_func(PINGRP_ATB, PMUX_FUNC_SDIO4); @@ -51,25 +46,6 @@ static void pin_mux_mmc(void) /* For CD GPIO PV5 */ pinmux_tristate_disable(PINGRP_GPV); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - debug("board_mmc_init called\n"); - - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - debug("board_mmc_init: init eMMC\n"); - /* init dev 0, eMMC chip, with 8-bit bus */ - tegra_mmc_init(0, 8, -1, -1); - - debug("board_mmc_init: init SD slot\n"); - /* init dev 3, SD slot, with 4-bit bus */ - tegra_mmc_init(3, 4, GPIO_PV1, GPIO_PV5); - - return 0; -} #endif
#ifdef CONFIG_LCD diff --git a/board/compulab/trimslice/trimslice.c b/board/compulab/trimslice/trimslice.c index 8f4dd09..244a2a1 100644 --- a/board/compulab/trimslice/trimslice.c +++ b/board/compulab/trimslice/trimslice.c @@ -27,12 +27,8 @@ #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> #include <i2c.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif
void pin_mux_usb(void) { @@ -48,11 +44,12 @@ void pin_mux_spi(void) funcmux_select(PERIPH_ID_SPI1, FUNCMUX_SPI1_GMC_GMD); }
+#ifdef CONFIG_TEGRA_MMC /* * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC1, FUNCMUX_SDMMC1_SDIO1_4BIT); funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_4_BIT); @@ -60,20 +57,4 @@ static void pin_mux_mmc(void) /* For CD GPIO PP1 */ pinmux_tristate_disable(PINGRP_DAP3); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - debug("board_mmc_init called\n"); - - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - /* init dev 0 (SDMMC4), (micro-SD slot) with 4-bit bus */ - tegra_mmc_init(0, 4, -1, GPIO_PP1); - - /* init dev 3 (SDMMC1), (SD slot) with 4-bit bus */ - tegra_mmc_init(3, 4, -1, -1); - - return 0; -} +#endif diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index d1d8a29..db0b5bd 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -48,6 +48,9 @@ #ifdef CONFIG_USB_EHCI_TEGRA #include <asm/arch/usb.h> #endif +#ifdef CONFIG_TEGRA_MMC +#include <asm/arch-tegra/mmc.h> +#endif #include <i2c.h> #include <spi.h> #include "emc.h" @@ -184,7 +187,6 @@ int board_init(void) /* prepare the WB code to LP0 location */ warmboot_prepare_code(TEGRA_LP0_ADDR, TEGRA_LP0_SIZE); #endif - return 0; }
@@ -221,3 +223,25 @@ int board_late_init(void) #endif return 0; } + +#if defined(CONFIG_TEGRA_MMC) +void __pin_mux_mmc(void) +{ +} + +void pin_mux_mmc(void) __attribute__((weak, alias("__pin_mux_mmc"))); + +/* this is a weak define that we are overriding */ +int board_mmc_init(bd_t *bd) +{ + debug("%s called\n", __func__); + + /* Enable muxes, etc. for SDMMC controllers */ + pin_mux_mmc(); + + debug("%s: init MMC\n", __func__); + tegra_mmc_init(); + + return 0; +} +#endif diff --git a/board/nvidia/harmony/harmony.c b/board/nvidia/harmony/harmony.c index 93430ed..3122441 100644 --- a/board/nvidia/harmony/harmony.c +++ b/board/nvidia/harmony/harmony.c @@ -27,19 +27,14 @@ #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> #include <asm/arch/tegra.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif -
#ifdef CONFIG_TEGRA_MMC /* * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_GME_8_BIT); funcmux_select(PERIPH_ID_SDMMC2, FUNCMUX_SDMMC2_DTA_DTD_8BIT); @@ -54,25 +49,6 @@ static void pin_mux_mmc(void) /* For CD GPIO PI5 */ pinmux_tristate_disable(PINGRP_ATC); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - debug("board_mmc_init called\n"); - - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - debug("board_mmc_init: init SD slot J26\n"); - /* init dev 0, SD slot J26, with 8-bit bus */ - tegra_mmc_init(0, 8, GPIO_PI6, GPIO_PH2); - - debug("board_mmc_init: init SD slot J5\n"); - /* init dev 2, SD slot J5, with 4-bit bus */ - tegra_mmc_init(2, 4, GPIO_PT3, GPIO_PI5); - - return 0; -} #endif
void pin_mux_usb(void) diff --git a/board/nvidia/seaboard/seaboard.c b/board/nvidia/seaboard/seaboard.c index 3e33da0..e581fdd 100644 --- a/board/nvidia/seaboard/seaboard.c +++ b/board/nvidia/seaboard/seaboard.c @@ -28,11 +28,7 @@ #include <asm/arch/funcmux.h> #include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif
/* TODO: Remove this code when the SPI switch is working */ #if !defined(CONFIG_SPI_UART_SWITCH) && (CONFIG_MACH_TYPE != MACH_TYPE_VENTANA) @@ -51,7 +47,7 @@ void gpio_early_init_uart(void) * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_GME_8_BIT); funcmux_select(PERIPH_ID_SDMMC3, FUNCMUX_SDMMC3_SDB_4BIT); @@ -61,25 +57,6 @@ static void pin_mux_mmc(void) /* For CD GPIO PI5 */ pinmux_tristate_disable(PINGRP_ATC); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - debug("board_mmc_init called\n"); - - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - debug("board_mmc_init: init eMMC\n"); - /* init dev 0, eMMC chip, with 8-bit bus */ - tegra_mmc_init(0, 8, -1, -1); - - debug("board_mmc_init: init SD slot\n"); - /* init dev 1, SD slot, with 4-bit bus */ - tegra_mmc_init(1, 4, GPIO_PI6, GPIO_PI5); - - return 0; -} #endif
void pin_mux_usb(void) diff --git a/board/nvidia/whistler/whistler.c b/board/nvidia/whistler/whistler.c index 592cd6b..f18aa27 100644 --- a/board/nvidia/whistler/whistler.c +++ b/board/nvidia/whistler/whistler.c @@ -27,32 +27,19 @@ #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> #include <i2c.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif -
+#ifdef CONFIG_TEGRA_MMC /* * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) -{ - funcmux_select(PERIPH_ID_SDMMC3, FUNCMUX_SDMMC3_SDB_SLXA_8BIT); - funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATC_ATD_8BIT); -} - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) +void pin_mux_mmc(void) { uchar val; int ret;
- debug("board_mmc_init called\n"); - /* Turn on MAX8907B LDO12 to 2.8V for J40 power */ ret = i2c_set_bus_num(0); if (ret) @@ -70,17 +57,10 @@ int board_mmc_init(bd_t *bd) if (ret) printf("i2c_write 0 0x3c 0x44 failed: %d\n", ret);
- /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - /* init dev 0 (SDMMC4), (J29 "HSMMC") with 8-bit bus */ - tegra_mmc_init(0, 8, -1, -1); - - /* init dev 1 (SDMMC3), (J40 "SDIO3") with 8-bit bus */ - tegra_mmc_init(1, 8, -1, -1); - - return 0; + funcmux_select(PERIPH_ID_SDMMC3, FUNCMUX_SDMMC3_SDB_SLXA_8BIT); + funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATC_ATD_8BIT); } +#endif
/* this is a weak define that we are overriding */ void pin_mux_usb(void) diff --git a/board/toradex/colibri_t20_iris/colibri_t20_iris.c b/board/toradex/colibri_t20_iris/colibri_t20_iris.c index e40a986..aa76f65 100644 --- a/board/toradex/colibri_t20_iris/colibri_t20_iris.c +++ b/board/toradex/colibri_t20_iris/colibri_t20_iris.c @@ -19,7 +19,6 @@ #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> #include <asm/arch-tegra/board.h> -#include <asm/arch-tegra/mmc.h>
#include "../colibri_t20-common/colibri_t20-common.h"
@@ -34,13 +33,13 @@ void pin_mux_usb(void) #endif
#ifdef CONFIG_TEGRA_MMC -int board_mmc_init(bd_t *bd) +/* + * Routine: pin_mux_mmc + * Description: setup the pin muxes/tristate values for the SDMMC(s) + */ +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_4_BIT); pinmux_tristate_disable(PINGRP_GMB); - - tegra_mmc_init(0, 4, -1, GPIO_PC7); - - return 0; } #endif diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index d749ab0..e8e8512 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -21,6 +21,7 @@
#include <bouncebuf.h> #include <common.h> +#include <fdtdec.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/clock.h> @@ -28,54 +29,23 @@ #include <asm/arch-tegra/tegra_mmc.h> #include <mmc.h>
-/* support 4 mmc hosts */ -struct mmc mmc_dev[4]; -struct mmc_host mmc_host[4]; +DECLARE_GLOBAL_DATA_PTR;
+struct mmc mmc_dev[MAX_HOSTS]; +struct mmc_host mmc_host[MAX_HOSTS];
-/** - * Get the host address and peripheral ID for a device. Devices are numbered - * from 0 to 3. - * - * @param host Structure to fill in (base, reg, mmc_id) - * @param dev_index Device index (0-3) - */ -static void tegra_get_setup(struct mmc_host *host, int dev_index) -{ - debug("tegra_get_setup: dev_index = %d\n", dev_index); - - switch (dev_index) { - case 1: - host->base = TEGRA_SDMMC3_BASE; - host->mmc_id = PERIPH_ID_SDMMC3; - break; - case 2: - host->base = TEGRA_SDMMC2_BASE; - host->mmc_id = PERIPH_ID_SDMMC2; - break; - case 3: - host->base = TEGRA_SDMMC1_BASE; - host->mmc_id = PERIPH_ID_SDMMC1; - break; - case 0: - default: - host->base = TEGRA_SDMMC4_BASE; - host->mmc_id = PERIPH_ID_SDMMC4; - break; - } - - host->reg = (struct tegra_mmc *)host->base; -} +#ifndef CONFIG_OF_CONTROL +#error "Please enable device tree support to use this driver" +#endif
static void mmc_prepare_data(struct mmc_host *host, struct mmc_data *data, struct bounce_buffer *bbstate) { unsigned char ctrl;
- - debug("buf: %p (%p), data->blocks: %u, data->blocksize: %u\n", - bbstate->bounce_buffer, bbstate->user_buffer, data->blocks, - data->blocksize); + debug("%s: buf: %p (%p), data->blocks: %u, data->blocksize: %u\n", + __func__, bbstate->bounce_buffer, bbstate->user_buffer, + data->blocks, data->blocksize);
writel((u32)bbstate->bounce_buffer, &host->reg->sysad); /* @@ -98,7 +68,7 @@ static void mmc_prepare_data(struct mmc_host *host, struct mmc_data *data, static void mmc_set_transfer_mode(struct mmc_host *host, struct mmc_data *data) { unsigned short mode; - debug(" mmc_set_transfer_mode called\n"); + debug("%s called\n", __func__); /* * TRNMOD * MUL1SIN0[5] : Multi/Single Block Select @@ -121,10 +91,8 @@ static void mmc_set_transfer_mode(struct mmc_host *host, struct mmc_data *data) writew(mode, &host->reg->trnmod); }
-static int mmc_wait_inhibit(struct mmc_host *host, - struct mmc_cmd *cmd, - struct mmc_data *data, - unsigned int timeout) +static int mmc_wait_inhibit(struct mmc_host *host, struct mmc_cmd *cmd, + struct mmc_data *data, unsigned int timeout) { /* * PRNSTS @@ -148,19 +116,18 @@ static int mmc_wait_inhibit(struct mmc_host *host, timeout--; udelay(1000); } - return 0; }
static int mmc_send_cmd_bounced(struct mmc *mmc, struct mmc_cmd *cmd, - struct mmc_data *data, struct bounce_buffer *bbstate) + struct mmc_data *data, struct bounce_buffer *bbstate) { struct mmc_host *host = (struct mmc_host *)mmc->priv; int flags, i; int result; unsigned int mask = 0; unsigned int retry = 0x100000; - debug(" mmc_send_cmd called\n"); + debug("%s called\n", __func__);
result = mmc_wait_inhibit(host, cmd, data, 10 /* ms */);
@@ -170,7 +137,7 @@ static int mmc_send_cmd_bounced(struct mmc *mmc, struct mmc_cmd *cmd, if (data) mmc_prepare_data(host, data, bbstate);
- debug("cmd->arg: %08x\n", cmd->cmdarg); + debug("%s: cmd->arg: %08x\n", __func__, cmd->cmdarg); writel(cmd->cmdarg, &host->reg->argument);
if (data) @@ -207,7 +174,7 @@ static int mmc_send_cmd_bounced(struct mmc *mmc, struct mmc_cmd *cmd, if (data) flags |= TEGRA_MMC_TRNMOD_DATA_PRESENT_SELECT_DATA_TRANSFER;
- debug("cmd: %d\n", cmd->cmdidx); + debug("%s: cmd: %d\n", __func__, cmd->cmdidx);
writew((cmd->cmdidx << 8) | flags, &host->reg->cmdreg);
@@ -229,12 +196,14 @@ static int mmc_send_cmd_bounced(struct mmc *mmc, struct mmc_cmd *cmd,
if (mask & TEGRA_MMC_NORINTSTS_CMD_TIMEOUT) { /* Timeout Error */ - debug("timeout: %08x cmd %d\n", mask, cmd->cmdidx); + debug("%s: timeout: %08x cmd %d\n", __func__, mask, + cmd->cmdidx); writel(mask, &host->reg->norintsts); return TIMEOUT; } else if (mask & TEGRA_MMC_NORINTSTS_ERR_INTERRUPT) { /* Error Interrupt */ - debug("error: %08x cmd %d\n", mask, cmd->cmdidx); + debug("%s: error: %08x cmd %d\n", __func__, mask, + cmd->cmdidx); writel(mask, &host->reg->norintsts); return -1; } @@ -251,8 +220,8 @@ static int mmc_send_cmd_bounced(struct mmc *mmc, struct mmc_cmd *cmd, cmd->response[i] |= readb(offset - 1); } - debug("cmd->resp[%d]: %08x\n", - i, cmd->response[i]); + debug("%s: cmd->resp[%d]: %08x\n", + __func__, i, cmd->response[i]); } } else if (cmd->resp_type & MMC_RSP_BUSY) { for (i = 0; i < retry; i++) { @@ -269,10 +238,12 @@ static int mmc_send_cmd_bounced(struct mmc *mmc, struct mmc_cmd *cmd, }
cmd->response[0] = readl(&host->reg->rspreg0); - debug("cmd->resp[0]: %08x\n", cmd->response[0]); + debug("%s: cmd->resp[0]: %08x\n", + __func__, cmd->response[0]); } else { cmd->response[0] = readl(&host->reg->rspreg0); - debug("cmd->resp[0]: %08x\n", cmd->response[0]); + debug("%s: cmd->resp[0]: %08x\n", + __func__, cmd->response[0]); } }
@@ -295,13 +266,13 @@ static int mmc_send_cmd_bounced(struct mmc *mmc, struct mmc_cmd *cmd, */ unsigned int address = readl(&host->reg->sysad);
- debug("DMA end\n"); + debug("%s: DMA end\n", __func__); writel(TEGRA_MMC_NORINTSTS_DMA_INTERRUPT, - &host->reg->norintsts); + &host->reg->norintsts); writel(address, &host->reg->sysad); } else if (mask & TEGRA_MMC_NORINTSTS_XFER_COMPLETE) { /* Transfer Complete */ - debug("r/w is done\n"); + debug("%s: r/w is done\n", __func__); break; } else if (get_timer(start) > 2000UL) { writel(mask, &host->reg->norintsts); @@ -325,13 +296,14 @@ static int mmc_send_cmd_bounced(struct mmc *mmc, struct mmc_cmd *cmd, }
static int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, - struct mmc_data *data) + struct mmc_data *data) { void *buf; unsigned int bbflags; size_t len; struct bounce_buffer bbstate; int ret; + debug("%s: called\n", __func__);
if (data) { if (data->flags & MMC_DATA_READ) { @@ -359,8 +331,7 @@ static void mmc_change_clock(struct mmc_host *host, uint clock) int div; unsigned short clk; unsigned long timeout; - - debug(" mmc_change_clock called\n"); + debug("%s called\n", __func__);
/* * Change Tegra SDMMCx clock divisor here. Source is 216MHz, @@ -368,9 +339,8 @@ static void mmc_change_clock(struct mmc_host *host, uint clock) */ if (clock == 0) goto out; - clock_adjust_periph_pll_div(host->mmc_id, CLOCK_ID_PERIPH, clock, - &div); - debug("div = %d\n", div); + clock_adjust_periph_pll_div(host->mmc_id, CLOCK_ID_PERIPH, clock, &div); + debug("%s: div = %d\n", __func__, div);
writew(0, &host->reg->clkcon);
@@ -383,7 +353,7 @@ static void mmc_change_clock(struct mmc_host *host, uint clock) */ div >>= 1; clk = ((div << TEGRA_MMC_CLKCON_SDCLK_FREQ_SEL_SHIFT) | - TEGRA_MMC_CLKCON_INTERNAL_CLOCK_ENABLE); + TEGRA_MMC_CLKCON_INTERNAL_CLOCK_ENABLE); writew(clk, &host->reg->clkcon);
/* Wait max 10 ms */ @@ -401,7 +371,7 @@ static void mmc_change_clock(struct mmc_host *host, uint clock) clk |= TEGRA_MMC_CLKCON_SD_CLOCK_ENABLE; writew(clk, &host->reg->clkcon);
- debug("mmc_change_clock: clkcon = %08X\n", clk); + debug("%s: clkcon = %08X\n", __func__, clk);
out: host->clock = clock; @@ -411,9 +381,8 @@ static void mmc_set_ios(struct mmc *mmc) { struct mmc_host *host = mmc->priv; unsigned char ctrl; - debug(" mmc_set_ios called\n"); - - debug("bus_width: %x, clock: %d\n", mmc->bus_width, mmc->clock); + debug("%s: bus_width: %x, clock: %d\n", __func__, mmc->bus_width, + mmc->clock);
/* Change clock first */ mmc_change_clock(host, mmc->clock); @@ -436,13 +405,13 @@ static void mmc_set_ios(struct mmc *mmc) ctrl &= ~(1 << 1);
writeb(ctrl, &host->reg->hostctl); - debug("mmc_set_ios: hostctl = %08X\n", ctrl); + debug("%s: hostctl = %08X\n", __func__, ctrl); }
static void mmc_reset(struct mmc_host *host) { unsigned int timeout; - debug(" mmc_reset called\n"); + debug("%s called\n", __func__);
/* * RSTALL[0] : Software reset for all @@ -471,12 +440,11 @@ static int mmc_core_init(struct mmc *mmc) { struct mmc_host *host = (struct mmc_host *)mmc->priv; unsigned int mask; - debug(" mmc_core_init called\n");
mmc_reset(host);
host->version = readw(&host->reg->hcver); - debug("host version = %x\n", host->version); + debug("%s: host version = %x\n", __func__, host->version);
/* mask all */ writel(0xffffffff, &host->reg->norintstsen); @@ -515,44 +483,47 @@ static int mmc_core_init(struct mmc *mmc) int tegra_mmc_getcd(struct mmc *mmc) { struct mmc_host *host = (struct mmc_host *)mmc->priv; + debug("%s called, host->cd_gpio = 0x%08X\n", __func__, + (unsigned)&host->cd_gpio);
- debug("tegra_mmc_getcd called\n"); - - if (host->cd_gpio >= 0) - return !gpio_get_value(host->cd_gpio); + if (fdt_gpio_isvalid(&host->cd_gpio)) + return !fdtdec_get_gpio(&host->cd_gpio);
return 1; }
-int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio) +static int do_mmc_init(int dev_index) { struct mmc_host *host; char gpusage[12]; /* "SD/MMCn PWR" or "SD/MMCn CD" */ struct mmc *mmc; + int card_det = 0;
- debug(" tegra_mmc_init: index %d, bus width %d " - "pwr_gpio %d cd_gpio %d\n", - dev_index, bus_width, pwr_gpio, cd_gpio); - + /* DT should have been read & host config filled in */ host = &mmc_host[dev_index]; + if (!host->enabled) + return -1;
- host->clock = 0; - host->pwr_gpio = pwr_gpio; - host->cd_gpio = cd_gpio; - tegra_get_setup(host, dev_index); + debug("%s: index %d, bus width %d pwr_gpio %d cd_gpio %d\n", + __func__, dev_index, host->width, + host->pwr_gpio.gpio, host->cd_gpio.gpio);
+ host->clock = 0; clock_start_periph_pll(host->mmc_id, CLOCK_ID_PERIPH, 20000000);
- if (host->pwr_gpio >= 0) { + if (fdt_gpio_isvalid(&host->pwr_gpio)) { sprintf(gpusage, "SD/MMC%d PWR", dev_index); - gpio_request(host->pwr_gpio, gpusage); - gpio_direction_output(host->pwr_gpio, 1); + gpio_request(host->pwr_gpio.gpio, gpusage); + fdtdec_set_gpio(&host->pwr_gpio, 1); + debug(" Power GPIO name = %s\n", host->pwr_gpio.name); }
- if (host->cd_gpio >= 0) { + if (fdt_gpio_isvalid(&host->cd_gpio)) { sprintf(gpusage, "SD/MMC%d CD", dev_index); - gpio_request(host->cd_gpio, gpusage); - gpio_direction_input(host->cd_gpio); + gpio_request(host->cd_gpio.gpio, gpusage); + card_det = fdtdec_get_gpio(&host->cd_gpio); + debug(" CD GPIO name = %s\n", host->cd_gpio.name); + debug("%s: CD state = %d\n", __func__, card_det); }
mmc = &mmc_dev[dev_index]; @@ -566,9 +537,10 @@ int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio)
mmc->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; mmc->host_caps = 0; - if (bus_width == 8) + debug("%s: bus width = %d\n", __func__, host->width); + if (host->width == 8) mmc->host_caps |= MMC_MODE_8BIT; - if (bus_width >= 4) + if (host->width >= 4) mmc->host_caps |= MMC_MODE_4BIT; mmc->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_HC;
@@ -577,8 +549,6 @@ int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio) * low-speed SDIO card frequency (actually 400KHz) * max freq is highest HS eMMC clock as per the SD/MMC spec * (actually 52MHz) - * Both of these are the closest equivalents w/216MHz source - * clock and Tegra SDMMC divisors. */ mmc->f_min = 375000; mmc->f_max = 48000000; @@ -587,3 +557,98 @@ int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio)
return 0; } + +/** + * Get the host address and peripheral ID for a node. + * + * @param blob fdt blob + * @param node Device index (0-3) + * @param host Structure to fill in (reg, width, mmc_id) + */ +static int mmc_get_config(const void *blob, int node, struct mmc_host *host) +{ + debug("%s: node = %d\n", __func__, node); + + host->enabled = fdtdec_get_is_enabled(blob, node); + + host->reg = (struct tegra_mmc *)fdtdec_get_addr(blob, node, "reg"); + if ((fdt_addr_t)host->reg == FDT_ADDR_T_NONE) { + debug("%s: no sdmmc base reg info found\n", __func__); + return -FDT_ERR_NOTFOUND; + } + + host->mmc_id = clock_decode_periph_id(blob, node); + if (host->mmc_id == PERIPH_ID_NONE) { + debug("%s: could not decode periph id\n", __func__); + return -FDT_ERR_NOTFOUND; + } + + /* + * NOTE: mmc->bus_width is determined by mmc.c dynamically. + * TBD: Override it with this value? + */ + host->width = fdtdec_get_int(blob, node, "bus-width", 0); + if (!host->width) + debug("%s: no sdmmc width found\n", __func__); + + /* These GPIOs are optional */ + fdtdec_decode_gpio(blob, node, "cd-gpios", &host->cd_gpio); + fdtdec_decode_gpio(blob, node, "wp-gpios", &host->wp_gpio); + fdtdec_decode_gpio(blob, node, "power-gpios", &host->pwr_gpio); + + debug("%s: found controller at %p, width = %d, periph_id = %d\n", + __func__, host->reg, host->width, host->mmc_id); + return 0; +} + +/* + * Process a list of nodes, adding them to our list of SDMMC ports. + * + * @param blob fdt blob + * @param node_list list of nodes to process (any <=0 are ignored) + * @param count number of nodes to process + * @return 0 if ok, -1 on error + */ +static int process_nodes(const void *blob, int node_list[], int count) +{ + struct mmc_host *host; + int i, node; + + debug("%s: count = %d\n", __func__, count); + + /* build mmc_host[] for each controller */ + for (i = 0; i < count; i++) { + node = node_list[i]; + if (node <= 0) + continue; + + host = &mmc_host[i]; + host->id = i; + + if (mmc_get_config(blob, node, host)) { + printf("%s: failed to decode dev %d\n", __func__, i); + return -1; + } + do_mmc_init(i); + + /* Mark position as used */ + node_list[i] = -1; + } + return 0; +} + +void tegra_mmc_init(void) +{ + int node_list[MAX_HOSTS], count; + const void *blob = gd->fdt_blob; + debug("%s entry\n", __func__); + + count = fdtdec_find_aliases_for_id(blob, "sdhci", + COMPAT_NVIDIA_TEGRA20_SDMMC, node_list, MAX_HOSTS); + debug("%s: count of sdhci nodes is %d\n", __func__, count); + + if (process_nodes(blob, node_list, count)) { + printf("%s: Error processing mmc node(s)!\n", __func__); + return; + } +} diff --git a/include/fdtdec.h b/include/fdtdec.h index 77f244f..4f9dbcf 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -70,6 +70,7 @@ enum fdt_compat_id { COMPAT_NVIDIA_TEGRA20_NAND, /* Tegra2 NAND controller */ COMPAT_NVIDIA_TEGRA20_PWM, /* Tegra 2 PWM controller */ COMPAT_NVIDIA_TEGRA20_DC, /* Tegra 2 Display controller */ + COMPAT_NVIDIA_TEGRA20_SDMMC, /* Tegra SDMMC controller */ COMPAT_NVIDIA_TEGRA20_SFLASH, /* Tegra 2 SPI flash controller */ COMPAT_NVIDIA_TEGRA20_SLINK, /* Tegra 2 SPI SLINK controller */ COMPAT_SMSC_LAN9215, /* SMSC 10/100 Ethernet LAN9215 */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 3ae348d..57e552c 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -45,6 +45,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(NVIDIA_TEGRA20_NAND, "nvidia,tegra20-nand"), COMPAT(NVIDIA_TEGRA20_PWM, "nvidia,tegra20-pwm"), COMPAT(NVIDIA_TEGRA20_DC, "nvidia,tegra20-dc"), + COMPAT(NVIDIA_TEGRA20_SDMMC, "nvidia,tegra20-sdhci"), COMPAT(NVIDIA_TEGRA20_SFLASH, "nvidia,tegra20-sflash"), COMPAT(NVIDIA_TEGRA20_SLINK, "nvidia,tegra20-slink"), COMPAT(SMSC_LAN9215, "smsc,lan9215"),
It seems a little odd to add this ifdef when it's know that config option is enabled in the trimslice config file. I can somewhat understand leaving the ifdef in any other board files that already had it, but actively adding it here seems strange.
Unrelated change?
diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c +static int process_nodes(const void *blob, int node_list[], int count)
node_list[i] = -1;
Is this actually necessary?
I'll try and test these patches on all the Tegra20 boards I have tomorrow.
Unrelated change?
node_list[i] = -1;
I don't think it is in this case. It is useful when adding aliases from multiple compatible IDs, to mark those positions that are already taken. We don't do that here.
I'll try and test these patches on all the Tegra20 boards I have tomorrow. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Stephen,
Well, I was trying to be consistent when check all the board files for a pin_mux_mmc() function, and thought that adding the ifdef to the only board file that didn't have it would be the correct thing to do. In the original code (before moving to DT MMC), if you disabled SD/MMC in the trimslice config file, you'd get a build error. That's no longer true w/these patches, but I'm a better-safe-than-sorry guy.
I'll remove it in v4
Unrelated change?
Yep, due to fast-and-furious cut&pasting. I'll clean it up in v4.
node_list[i] = -1;
As Simon says in his response, it's used when there're multiple compatible IDs, like the I2C code I pulled it from. I'll remove it for MMC in v4.
Thanks
Tom
The series,
on TEC and Medcom-Wide. I don't currently have access to a Plutux, but it should be fine too.
Thierry
Thanks!
On Thu, Feb 14, 2013 at 12:19 AM, Thierry Reding thierry.reding@avionic-design.de wrote:
The series,
Thierry
The series,
I managed to talk a co-worker into trying this out on Plutux and there were no issues there either. All Tamonten-boards work fine with these patches applied.
Thierry
With the incremental patch below applied,
Tested-by: Stephen Warren swarren@nvidia.com On: Harmony, Seaboard(really Springbank), Ventana, Whistler, Paz00/AC100, TrimSlice.
commit a5be5907d77eb4ca18dd9a11dd09183148c9d1b2 Author: Stephen Warren swarren@nvidia.com Date: Thu Feb 14 16:02:24 2013 -0700
Fix MMC DT rework
diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index e8e8512..630f6bd 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -497,7 +497,6 @@ static int do_mmc_init(int dev_index) struct mmc_host *host; char gpusage[12]; /* "SD/MMCn PWR" or "SD/MMCn CD" */ struct mmc *mmc;
int card_det = 0; /* DT should have been read & host config filled in */ host = &mmc_host[dev_index];
@@ -514,16 +513,15 @@ static int do_mmc_init(int dev_index) if (fdt_gpio_isvalid(&host->pwr_gpio)) { sprintf(gpusage, "SD/MMC%d PWR", dev_index); gpio_request(host->pwr_gpio.gpio, gpusage);
gpio_direction_output(host->pwr_gpio.gpio, 1); debug(" Power GPIO name = %s\n", host->pwr_gpio.name); } if (fdt_gpio_isvalid(&host->cd_gpio)) { sprintf(gpusage, "SD/MMC%d CD", dev_index); gpio_request(host->cd_gpio.gpio, gpusage);
gpio_direction_input(host->cd_gpio.gpio); debug(" CD GPIO name = %s\n", host->cd_gpio.name);
debug("%s: CD state = %d\n", __func__, card_det); } mmc = &mmc_dev[dev_index];
Stephen,
Fix MMC DT rework
Thanks. I'll look at merging this w/my v4 patchset when I get back from Kansas on Weds.
Tom
participants (5)
Lucas Stach
Stephen Warren
Thierry Reding
Tom Warren
