[U-Boot] [PATCH] board: sama5d27_som1_ek: Fix the USB vbus power
According to the REVB schematic, fix the USB vbus power enable pin.
Based on original work by Wenyou Yang
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c index 80d7725..5eae111 100644 --- a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c +++ b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c @@ -20,7 +20,7 @@ DECLARE_GLOBAL_DATA_PTR;
static void board_usb_hw_init(void) { - atmel_pio4_set_pio_output(AT91_PIO_PORTB, 10, 1); + atmel_pio4_set_pio_output(AT91_PIO_PORTA, 27, 1); }
#ifdef CONFIG_BOARD_LATE_INIT
Eugen Hristev
