[U-Boot] [PATCH 1/1] ARM: Update mach types
This commit updates the mach-types to sync with ARM Linux based on the following commit by Russell King commit 4a683a2c5e7cabe91218db28e56dc25e1b134ce3
Signed-off-by: Jason Liu r64343@freescale.com --- arch/arm/include/asm/mach-types.h | 1293 ++++++++++++++++++++++++++++++++++++- 1 files changed, 1277 insertions(+), 16 deletions(-)
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index d95e6d6..26fb866 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -1,5 +1,5 @@ /* - * This was automagically generated from arch/arm/tools/mach-types! + * This was automagically generated from /home/r64343/work_space/linux-2.6/arch/arm/tools/mach-types! * Do NOT edit */
@@ -2236,7 +2236,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_VS_V210 2252 #define MACH_TYPE_VS_V212 2253 #define MACH_TYPE_HMT 2254 -#define MACH_TYPE_SUEN3 2255 +#define MACH_TYPE_KM_KIRKWOOD 2255 #define MACH_TYPE_VESPER 2256 #define MACH_TYPE_STR9 2257 #define MACH_TYPE_OMAP3_WL_FF 2258 @@ -2983,7 +2983,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_EA20 3002 #define MACH_TYPE_AWM2 3003 #define MACH_TYPE_TI8148EVM 3004 -#define MACH_TYPE_TEGRA_SEABOARD 3005 +#define MACH_TYPE_SEABOARD 3005 #define MACH_TYPE_LINKSTATION_CHLV2 3006 #define MACH_TYPE_TERA_PRO2_RACK 3007 #define MACH_TYPE_RUBYS 3008 @@ -3186,7 +3186,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_ICS_IF_VOIP 3206 #define MACH_TYPE_WLF_CRAGG_6410 3207 #define MACH_TYPE_PUNICA 3208 -#define MACH_TYPE_SBC_NT250 3209 +#define MACH_TYPE_TRIMSLICE 3209 #define MACH_TYPE_MX27_WMULTRA 3210 #define MACH_TYPE_MACKEREL 3211 #define MACH_TYPE_FA9X27 3213 @@ -3215,6 +3215,103 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_PCM048 3236 #define MACH_TYPE_DDS 3237 #define MACH_TYPE_CHALTEN_XA1 3238 +#define MACH_TYPE_TS48XX 3239 +#define MACH_TYPE_TONGA2_TFTTIMER 3240 +#define MACH_TYPE_WHISTLER 3241 +#define MACH_TYPE_ASL_PHOENIX 3242 +#define MACH_TYPE_AT91SAM9263OTLITE 3243 +#define MACH_TYPE_DDPLUG 3244 +#define MACH_TYPE_D2PLUG 3245 +#define MACH_TYPE_KZM9D 3246 +#define MACH_TYPE_VERDI_LTE 3247 +#define MACH_TYPE_NANOZOOM 3248 +#define MACH_TYPE_DM3730_SOM_LV 3249 +#define MACH_TYPE_DM3730_TORPEDO 3250 +#define MACH_TYPE_ANCHOVY 3251 +#define MACH_TYPE_RE2REV20 3253 +#define MACH_TYPE_RE2REV21 3254 +#define MACH_TYPE_CNS21XX 3255 +#define MACH_TYPE_RIDER 3257 +#define MACH_TYPE_NSK330 3258 +#define MACH_TYPE_CNS2133EVB 3259 +#define MACH_TYPE_Z3_816X_MOD 3260 +#define MACH_TYPE_Z3_814X_MOD 3261 +#define MACH_TYPE_BEECT 3262 +#define MACH_TYPE_DMA_THUNDERBUG 3263 +#define MACH_TYPE_OMN_AT91SAM9G20 3264 +#define MACH_TYPE_MX25_E2S_UC 3265 +#define MACH_TYPE_MIONE 3266 +#define MACH_TYPE_TOP9000_TCU 3267 +#define MACH_TYPE_TOP9000_BSL 3268 +#define MACH_TYPE_KINGDOM 3269 +#define MACH_TYPE_ARMADILLO460 3270 +#define MACH_TYPE_LQ2 3271 +#define MACH_TYPE_SWEDA_TMS2 3272 +#define MACH_TYPE_MX53_LOCO 3273 +#define MACH_TYPE_ACER_A8 3275 +#define MACH_TYPE_ACER_GAUGUIN 3276 +#define MACH_TYPE_GUPPY 3277 +#define MACH_TYPE_MX61_ARD 3278 +#define MACH_TYPE_TX53 3279 +#define MACH_TYPE_OMAPL138_CASE_A3 3280 +#define MACH_TYPE_UEMD 3281 +#define MACH_TYPE_CCWMX51MUT 3282 +#define MACH_TYPE_ROCKHOPPER 3283 +#define MACH_TYPE_NOOKCOLOR 3284 +#define MACH_TYPE_HKDKC100 3285 +#define MACH_TYPE_TS42XX 3286 +#define MACH_TYPE_AEBL 3287 +#define MACH_TYPE_WARIO 3288 +#define MACH_TYPE_GFS_SPM 3289 +#define MACH_TYPE_CM_T3730 3290 +#define MACH_TYPE_ISC3 3291 +#define MACH_TYPE_RASCAL 3292 +#define MACH_TYPE_HREFV60 3293 +#define MACH_TYPE_TPT_2_0 3294 +#define MACH_TYPE_PYRAMID_TD 3295 +#define MACH_TYPE_SPLENDOR 3296 +#define MACH_TYPE_GUF_PLANET 3297 +#define MACH_TYPE_MSM8X60_QT 3298 +#define MACH_TYPE_HTC_HD_MINI 3299 +#define MACH_TYPE_ATHENE 3300 +#define MACH_TYPE_DEEP_R_EK_1 3301 +#define MACH_TYPE_VIVOW_CT 3302 +#define MACH_TYPE_NERY_1000 3303 +#define MACH_TYPE_RFL109145_SSRV 3304 +#define MACH_TYPE_NMH 3305 +#define MACH_TYPE_WN802T 3306 +#define MACH_TYPE_DRAGONET 3307 +#define MACH_TYPE_GENEVA_B 3308 +#define MACH_TYPE_AT91SAM9263DESK16L 3309 +#define MACH_TYPE_BCMHANA_SV 3310 +#define MACH_TYPE_BCMHANA_TABLET 3311 +#define MACH_TYPE_KOI 3312 +#define MACH_TYPE_TS4800 3313 +#define MACH_TYPE_TQMA9263 3314 +#define MACH_TYPE_HOLIDAY 3315 +#define MACH_TYPE_DMA6410 3316 +#define MACH_TYPE_PCATS_OVERLAY 3317 +#define MACH_TYPE_HWGW6410 3318 +#define MACH_TYPE_SHENZHOU 3319 +#define MACH_TYPE_CWME9210 3320 +#define MACH_TYPE_CWME9210JS 3321 +#define MACH_TYPE_PGS_SITARA 3322 +#define MACH_TYPE_COLIBRI_TEGRA2 3323 +#define MACH_TYPE_W21 3324 +#define MACH_TYPE_POLYSAT1 3325 +#define MACH_TYPE_DATAWAY 3326 +#define MACH_TYPE_COBRAL138 3327 +#define MACH_TYPE_ROVERPCS8 3328 +#define MACH_TYPE_MARVELC 3329 +#define MACH_TYPE_NAVEFIHID 3330 +#define MACH_TYPE_DM365_CV100 3331 +#define MACH_TYPE_ABLE 3332 +#define MACH_TYPE_LEGACY 3333 +#define MACH_TYPE_ICONG 3334 +#define MACH_TYPE_ROVER_G8 3335 +#define MACH_TYPE_T5388P 3336 +#define MACH_TYPE_DINGO 3337 +#define MACH_TYPE_GOFLEXHOME 3338
#ifdef CONFIG_ARCH_EBSA110 # ifdef machine_arch_type @@ -29904,16 +30001,16 @@ extern unsigned int __machine_arch_type; # define machine_is_hmt() (0) #endif
-#ifdef CONFIG_MACH_SUEN3 +#ifdef CONFIG_MACH_KM_KIRKWOOD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SUEN3 +# define machine_arch_type MACH_TYPE_KM_KIRKWOOD # endif -# define machine_is_suen3() (machine_arch_type == MACH_TYPE_SUEN3) +# define machine_is_km_kirkwood() (machine_arch_type == MACH_TYPE_KM_KIRKWOOD) #else -# define machine_is_suen3() (0) +# define machine_is_km_kirkwood() (0) #endif
#ifdef CONFIG_MACH_VESPER @@ -38868,16 +38965,16 @@ extern unsigned int __machine_arch_type; # define machine_is_ti8148evm() (0) #endif
-#ifdef CONFIG_MACH_TEGRA_SEABOARD +#ifdef CONFIG_MACH_SEABOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TEGRA_SEABOARD +# define machine_arch_type MACH_TYPE_SEABOARD # endif -# define machine_is_tegra_seaboard() (machine_arch_type == MACH_TYPE_TEGRA_SEABOARD) +# define machine_is_seaboard() (machine_arch_type == MACH_TYPE_SEABOARD) #else -# define machine_is_tegra_seaboard() (0) +# define machine_is_seaboard() (0) #endif
#ifdef CONFIG_MACH_LINKSTATION_CHLV2 @@ -41304,16 +41401,16 @@ extern unsigned int __machine_arch_type; # define machine_is_punica() (0) #endif
-#ifdef CONFIG_MACH_SBC_NT250 +#ifdef CONFIG_MACH_TRIMSLICE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SBC_NT250 +# define machine_arch_type MACH_TYPE_TRIMSLICE # endif -# define machine_is_sbc_nt250() (machine_arch_type == MACH_TYPE_SBC_NT250) +# define machine_is_trimslice() (machine_arch_type == MACH_TYPE_TRIMSLICE) #else -# define machine_is_sbc_nt250() (0) +# define machine_is_trimslice() (0) #endif
#ifdef CONFIG_MACH_MX27_WMULTRA @@ -41652,6 +41749,1170 @@ extern unsigned int __machine_arch_type; # define machine_is_chalten_xa1() (0) #endif
+#ifdef CONFIG_MACH_TS48XX +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TS48XX +# endif +# define machine_is_ts48xx() (machine_arch_type == MACH_TYPE_TS48XX) +#else +# define machine_is_ts48xx() (0) +#endif + +#ifdef CONFIG_MACH_TONGA2_TFTTIMER +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TONGA2_TFTTIMER +# endif +# define machine_is_tonga2_tfttimer() (machine_arch_type == MACH_TYPE_TONGA2_TFTTIMER) +#else +# define machine_is_tonga2_tfttimer() (0) +#endif + +#ifdef CONFIG_MACH_WHISTLER +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_WHISTLER +# endif +# define machine_is_whistler() (machine_arch_type == MACH_TYPE_WHISTLER) +#else +# define machine_is_whistler() (0) +#endif + +#ifdef CONFIG_MACH_ASL_PHOENIX +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ASL_PHOENIX +# endif +# define machine_is_asl_phoenix() (machine_arch_type == MACH_TYPE_ASL_PHOENIX) +#else +# define machine_is_asl_phoenix() (0) +#endif + +#ifdef CONFIG_MACH_AT91SAM9263OTLITE +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_AT91SAM9263OTLITE +# endif +# define machine_is_at91sam9263otlite() (machine_arch_type == MACH_TYPE_AT91SAM9263OTLITE) +#else +# define machine_is_at91sam9263otlite() (0) +#endif + +#ifdef CONFIG_MACH_DDPLUG +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DDPLUG +# endif +# define machine_is_ddplug() (machine_arch_type == MACH_TYPE_DDPLUG) +#else +# define machine_is_ddplug() (0) +#endif + +#ifdef CONFIG_MACH_D2PLUG +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_D2PLUG +# endif +# define machine_is_d2plug() (machine_arch_type == MACH_TYPE_D2PLUG) +#else +# define machine_is_d2plug() (0) +#endif + +#ifdef CONFIG_MACH_KZM9D +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_KZM9D +# endif +# define machine_is_kzm9d() (machine_arch_type == MACH_TYPE_KZM9D) +#else +# define machine_is_kzm9d() (0) +#endif + +#ifdef CONFIG_MACH_VERDI_LTE +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_VERDI_LTE +# endif +# define machine_is_verdi_lte() (machine_arch_type == MACH_TYPE_VERDI_LTE) +#else +# define machine_is_verdi_lte() (0) +#endif + +#ifdef CONFIG_MACH_NANOZOOM +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_NANOZOOM +# endif +# define machine_is_nanozoom() (machine_arch_type == MACH_TYPE_NANOZOOM) +#else +# define machine_is_nanozoom() (0) +#endif + +#ifdef CONFIG_MACH_DM3730_SOM_LV +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DM3730_SOM_LV +# endif +# define machine_is_dm3730_som_lv() (machine_arch_type == MACH_TYPE_DM3730_SOM_LV) +#else +# define machine_is_dm3730_som_lv() (0) +#endif + +#ifdef CONFIG_MACH_DM3730_TORPEDO +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DM3730_TORPEDO +# endif +# define machine_is_dm3730_torpedo() (machine_arch_type == MACH_TYPE_DM3730_TORPEDO) +#else +# define machine_is_dm3730_torpedo() (0) +#endif + +#ifdef CONFIG_MACH_ANCHOVY +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ANCHOVY +# endif +# define machine_is_anchovy() (machine_arch_type == MACH_TYPE_ANCHOVY) +#else +# define machine_is_anchovy() (0) +#endif + +#ifdef CONFIG_MACH_RE2REV20 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_RE2REV20 +# endif +# define machine_is_re2rev20() (machine_arch_type == MACH_TYPE_RE2REV20) +#else +# define machine_is_re2rev20() (0) +#endif + +#ifdef CONFIG_MACH_RE2REV21 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_RE2REV21 +# endif +# define machine_is_re2rev21() (machine_arch_type == MACH_TYPE_RE2REV21) +#else +# define machine_is_re2rev21() (0) +#endif + +#ifdef CONFIG_MACH_CNS21XX +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CNS21XX +# endif +# define machine_is_cns21xx() (machine_arch_type == MACH_TYPE_CNS21XX) +#else +# define machine_is_cns21xx() (0) +#endif + +#ifdef CONFIG_MACH_RIDER +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_RIDER +# endif +# define machine_is_rider() (machine_arch_type == MACH_TYPE_RIDER) +#else +# define machine_is_rider() (0) +#endif + +#ifdef CONFIG_MACH_NSK330 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_NSK330 +# endif +# define machine_is_nsk330() (machine_arch_type == MACH_TYPE_NSK330) +#else +# define machine_is_nsk330() (0) +#endif + +#ifdef CONFIG_MACH_CNS2133EVB +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CNS2133EVB +# endif +# define machine_is_cns2133evb() (machine_arch_type == MACH_TYPE_CNS2133EVB) +#else +# define machine_is_cns2133evb() (0) +#endif + +#ifdef CONFIG_MACH_Z3_816X_MOD +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_Z3_816X_MOD +# endif +# define machine_is_z3_816x_mod() (machine_arch_type == MACH_TYPE_Z3_816X_MOD) +#else +# define machine_is_z3_816x_mod() (0) +#endif + +#ifdef CONFIG_MACH_Z3_814X_MOD +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_Z3_814X_MOD +# endif +# define machine_is_z3_814x_mod() (machine_arch_type == MACH_TYPE_Z3_814X_MOD) +#else +# define machine_is_z3_814x_mod() (0) +#endif + +#ifdef CONFIG_MACH_BEECT +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_BEECT +# endif +# define machine_is_beect() (machine_arch_type == MACH_TYPE_BEECT) +#else +# define machine_is_beect() (0) +#endif + +#ifdef CONFIG_MACH_DMA_THUNDERBUG +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DMA_THUNDERBUG +# endif +# define machine_is_dma_thunderbug() (machine_arch_type == MACH_TYPE_DMA_THUNDERBUG) +#else +# define machine_is_dma_thunderbug() (0) +#endif + +#ifdef CONFIG_MACH_OMN_AT91SAM9G20 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_OMN_AT91SAM9G20 +# endif +# define machine_is_omn_at91sam9g20() (machine_arch_type == MACH_TYPE_OMN_AT91SAM9G20) +#else +# define machine_is_omn_at91sam9g20() (0) +#endif + +#ifdef CONFIG_MACH_MX25_E2S_UC +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MX25_E2S_UC +# endif +# define machine_is_mx25_e2s_uc() (machine_arch_type == MACH_TYPE_MX25_E2S_UC) +#else +# define machine_is_mx25_e2s_uc() (0) +#endif + +#ifdef CONFIG_MACH_MIONE +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MIONE +# endif +# define machine_is_mione() (machine_arch_type == MACH_TYPE_MIONE) +#else +# define machine_is_mione() (0) +#endif + +#ifdef CONFIG_MACH_TOP9000_TCU +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TOP9000_TCU +# endif +# define machine_is_top9000_tcu() (machine_arch_type == MACH_TYPE_TOP9000_TCU) +#else +# define machine_is_top9000_tcu() (0) +#endif + +#ifdef CONFIG_MACH_TOP9000_BSL +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TOP9000_BSL +# endif +# define machine_is_top9000_bsl() (machine_arch_type == MACH_TYPE_TOP9000_BSL) +#else +# define machine_is_top9000_bsl() (0) +#endif + +#ifdef CONFIG_MACH_KINGDOM +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_KINGDOM +# endif +# define machine_is_kingdom() (machine_arch_type == MACH_TYPE_KINGDOM) +#else +# define machine_is_kingdom() (0) +#endif + +#ifdef CONFIG_MACH_ARMADILLO460 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ARMADILLO460 +# endif +# define machine_is_armadillo460() (machine_arch_type == MACH_TYPE_ARMADILLO460) +#else +# define machine_is_armadillo460() (0) +#endif + +#ifdef CONFIG_MACH_LQ2 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_LQ2 +# endif +# define machine_is_lq2() (machine_arch_type == MACH_TYPE_LQ2) +#else +# define machine_is_lq2() (0) +#endif + +#ifdef CONFIG_MACH_SWEDA_TMS2 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_SWEDA_TMS2 +# endif +# define machine_is_sweda_tms2() (machine_arch_type == MACH_TYPE_SWEDA_TMS2) +#else +# define machine_is_sweda_tms2() (0) +#endif + +#ifdef CONFIG_MACH_MX53_LOCO +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MX53_LOCO +# endif +# define machine_is_mx53_loco() (machine_arch_type == MACH_TYPE_MX53_LOCO) +#else +# define machine_is_mx53_loco() (0) +#endif + +#ifdef CONFIG_MACH_ACER_A8 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ACER_A8 +# endif +# define machine_is_acer_a8() (machine_arch_type == MACH_TYPE_ACER_A8) +#else +# define machine_is_acer_a8() (0) +#endif + +#ifdef CONFIG_MACH_ACER_GAUGUIN +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ACER_GAUGUIN +# endif +# define machine_is_acer_gauguin() (machine_arch_type == MACH_TYPE_ACER_GAUGUIN) +#else +# define machine_is_acer_gauguin() (0) +#endif + +#ifdef CONFIG_MACH_GUPPY +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GUPPY +# endif +# define machine_is_guppy() (machine_arch_type == MACH_TYPE_GUPPY) +#else +# define machine_is_guppy() (0) +#endif + +#ifdef CONFIG_MACH_MX61_ARD +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MX61_ARD +# endif +# define machine_is_mx61_ard() (machine_arch_type == MACH_TYPE_MX61_ARD) +#else +# define machine_is_mx61_ard() (0) +#endif + +#ifdef CONFIG_MACH_TX53 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TX53 +# endif +# define machine_is_tx53() (machine_arch_type == MACH_TYPE_TX53) +#else +# define machine_is_tx53() (0) +#endif + +#ifdef CONFIG_MACH_OMAPL138_CASE_A3 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_OMAPL138_CASE_A3 +# endif +# define machine_is_omapl138_case_a3() (machine_arch_type == MACH_TYPE_OMAPL138_CASE_A3) +#else +# define machine_is_omapl138_case_a3() (0) +#endif + +#ifdef CONFIG_MACH_UEMD +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_UEMD +# endif +# define machine_is_uemd() (machine_arch_type == MACH_TYPE_UEMD) +#else +# define machine_is_uemd() (0) +#endif + +#ifdef CONFIG_MACH_CCWMX51MUT +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CCWMX51MUT +# endif +# define machine_is_ccwmx51mut() (machine_arch_type == MACH_TYPE_CCWMX51MUT) +#else +# define machine_is_ccwmx51mut() (0) +#endif + +#ifdef CONFIG_MACH_ROCKHOPPER +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ROCKHOPPER +# endif +# define machine_is_rockhopper() (machine_arch_type == MACH_TYPE_ROCKHOPPER) +#else +# define machine_is_rockhopper() (0) +#endif + +#ifdef CONFIG_MACH_NOOKCOLOR +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_NOOKCOLOR +# endif +# define machine_is_nookcolor() (machine_arch_type == MACH_TYPE_NOOKCOLOR) +#else +# define machine_is_nookcolor() (0) +#endif + +#ifdef CONFIG_MACH_HKDKC100 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_HKDKC100 +# endif +# define machine_is_hkdkc100() (machine_arch_type == MACH_TYPE_HKDKC100) +#else +# define machine_is_hkdkc100() (0) +#endif + +#ifdef CONFIG_MACH_TS42XX +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TS42XX +# endif +# define machine_is_ts42xx() (machine_arch_type == MACH_TYPE_TS42XX) +#else +# define machine_is_ts42xx() (0) +#endif + +#ifdef CONFIG_MACH_AEBL +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_AEBL +# endif +# define machine_is_aebl() (machine_arch_type == MACH_TYPE_AEBL) +#else +# define machine_is_aebl() (0) +#endif + +#ifdef CONFIG_MACH_WARIO +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_WARIO +# endif +# define machine_is_wario() (machine_arch_type == MACH_TYPE_WARIO) +#else +# define machine_is_wario() (0) +#endif + +#ifdef CONFIG_MACH_GFS_SPM +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GFS_SPM +# endif +# define machine_is_gfs_spm() (machine_arch_type == MACH_TYPE_GFS_SPM) +#else +# define machine_is_gfs_spm() (0) +#endif + +#ifdef CONFIG_MACH_CM_T3730 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CM_T3730 +# endif +# define machine_is_cm_t3730() (machine_arch_type == MACH_TYPE_CM_T3730) +#else +# define machine_is_cm_t3730() (0) +#endif + +#ifdef CONFIG_MACH_ISC3 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ISC3 +# endif +# define machine_is_isc3() (machine_arch_type == MACH_TYPE_ISC3) +#else +# define machine_is_isc3() (0) +#endif + +#ifdef CONFIG_MACH_RASCAL +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_RASCAL +# endif +# define machine_is_rascal() (machine_arch_type == MACH_TYPE_RASCAL) +#else +# define machine_is_rascal() (0) +#endif + +#ifdef CONFIG_MACH_HREFV60 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_HREFV60 +# endif +# define machine_is_hrefv60() (machine_arch_type == MACH_TYPE_HREFV60) +#else +# define machine_is_hrefv60() (0) +#endif + +#ifdef CONFIG_MACH_TPT_2_0 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TPT_2_0 +# endif +# define machine_is_tpt_2_0() (machine_arch_type == MACH_TYPE_TPT_2_0) +#else +# define machine_is_tpt_2_0() (0) +#endif + +#ifdef CONFIG_MACH_PYRAMID_TD +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_PYRAMID_TD +# endif +# define machine_is_pyramid_td() (machine_arch_type == MACH_TYPE_PYRAMID_TD) +#else +# define machine_is_pyramid_td() (0) +#endif + +#ifdef CONFIG_MACH_SPLENDOR +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_SPLENDOR +# endif +# define machine_is_splendor() (machine_arch_type == MACH_TYPE_SPLENDOR) +#else +# define machine_is_splendor() (0) +#endif + +#ifdef CONFIG_MACH_GUF_PLANET +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GUF_PLANET +# endif +# define machine_is_guf_planet() (machine_arch_type == MACH_TYPE_GUF_PLANET) +#else +# define machine_is_guf_planet() (0) +#endif + +#ifdef CONFIG_MACH_MSM8X60_QT +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MSM8X60_QT +# endif +# define machine_is_msm8x60_qt() (machine_arch_type == MACH_TYPE_MSM8X60_QT) +#else +# define machine_is_msm8x60_qt() (0) +#endif + +#ifdef CONFIG_MACH_HTC_HD_MINI +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_HTC_HD_MINI +# endif +# define machine_is_htc_hd_mini() (machine_arch_type == MACH_TYPE_HTC_HD_MINI) +#else +# define machine_is_htc_hd_mini() (0) +#endif + +#ifdef CONFIG_MACH_ATHENE +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ATHENE +# endif +# define machine_is_athene() (machine_arch_type == MACH_TYPE_ATHENE) +#else +# define machine_is_athene() (0) +#endif + +#ifdef CONFIG_MACH_DEEP_R_EK_1 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DEEP_R_EK_1 +# endif +# define machine_is_deep_r_ek_1() (machine_arch_type == MACH_TYPE_DEEP_R_EK_1) +#else +# define machine_is_deep_r_ek_1() (0) +#endif + +#ifdef CONFIG_MACH_VIVOW_CT +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_VIVOW_CT +# endif +# define machine_is_vivow_ct() (machine_arch_type == MACH_TYPE_VIVOW_CT) +#else +# define machine_is_vivow_ct() (0) +#endif + +#ifdef CONFIG_MACH_NERY_1000 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_NERY_1000 +# endif +# define machine_is_nery_1000() (machine_arch_type == MACH_TYPE_NERY_1000) +#else +# define machine_is_nery_1000() (0) +#endif + +#ifdef CONFIG_MACH_RFL109145_SSRV +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_RFL109145_SSRV +# endif +# define machine_is_rfl109145_ssrv() (machine_arch_type == MACH_TYPE_RFL109145_SSRV) +#else +# define machine_is_rfl109145_ssrv() (0) +#endif + +#ifdef CONFIG_MACH_NMH +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_NMH +# endif +# define machine_is_nmh() (machine_arch_type == MACH_TYPE_NMH) +#else +# define machine_is_nmh() (0) +#endif + +#ifdef CONFIG_MACH_WN802T +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_WN802T +# endif +# define machine_is_wn802t() (machine_arch_type == MACH_TYPE_WN802T) +#else +# define machine_is_wn802t() (0) +#endif + +#ifdef CONFIG_MACH_DRAGONET +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DRAGONET +# endif +# define machine_is_dragonet() (machine_arch_type == MACH_TYPE_DRAGONET) +#else +# define machine_is_dragonet() (0) +#endif + +#ifdef CONFIG_MACH_GENEVA_B +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GENEVA_B +# endif +# define machine_is_geneva_b() (machine_arch_type == MACH_TYPE_GENEVA_B) +#else +# define machine_is_geneva_b() (0) +#endif + +#ifdef CONFIG_MACH_AT91SAM9263DESK16L +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_AT91SAM9263DESK16L +# endif +# define machine_is_at91sam9263desk16l() (machine_arch_type == MACH_TYPE_AT91SAM9263DESK16L) +#else +# define machine_is_at91sam9263desk16l() (0) +#endif + +#ifdef CONFIG_MACH_BCMHANA_SV +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_BCMHANA_SV +# endif +# define machine_is_bcmhana_sv() (machine_arch_type == MACH_TYPE_BCMHANA_SV) +#else +# define machine_is_bcmhana_sv() (0) +#endif + +#ifdef CONFIG_MACH_BCMHANA_TABLET +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_BCMHANA_TABLET +# endif +# define machine_is_bcmhana_tablet() (machine_arch_type == MACH_TYPE_BCMHANA_TABLET) +#else +# define machine_is_bcmhana_tablet() (0) +#endif + +#ifdef CONFIG_MACH_KOI +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_KOI +# endif +# define machine_is_koi() (machine_arch_type == MACH_TYPE_KOI) +#else +# define machine_is_koi() (0) +#endif + +#ifdef CONFIG_MACH_TS4800 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TS4800 +# endif +# define machine_is_ts4800() (machine_arch_type == MACH_TYPE_TS4800) +#else +# define machine_is_ts4800() (0) +#endif + +#ifdef CONFIG_MACH_TQMA9263 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TQMA9263 +# endif +# define machine_is_tqma9263() (machine_arch_type == MACH_TYPE_TQMA9263) +#else +# define machine_is_tqma9263() (0) +#endif + +#ifdef CONFIG_MACH_HOLIDAY +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_HOLIDAY +# endif +# define machine_is_holiday() (machine_arch_type == MACH_TYPE_HOLIDAY) +#else +# define machine_is_holiday() (0) +#endif + +#ifdef CONFIG_MACH_DMA6410 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DMA6410 +# endif +# define machine_is_dma_6410() (machine_arch_type == MACH_TYPE_DMA6410) +#else +# define machine_is_dma_6410() (0) +#endif + +#ifdef CONFIG_MACH_PCATS_OVERLAY +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_PCATS_OVERLAY +# endif +# define machine_is_pcats_overlay() (machine_arch_type == MACH_TYPE_PCATS_OVERLAY) +#else +# define machine_is_pcats_overlay() (0) +#endif + +#ifdef CONFIG_MACH_HWGW6410 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_HWGW6410 +# endif +# define machine_is_hwgw6410() (machine_arch_type == MACH_TYPE_HWGW6410) +#else +# define machine_is_hwgw6410() (0) +#endif + +#ifdef CONFIG_MACH_SHENZHOU +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_SHENZHOU +# endif +# define machine_is_shenzhou() (machine_arch_type == MACH_TYPE_SHENZHOU) +#else +# define machine_is_shenzhou() (0) +#endif + +#ifdef CONFIG_MACH_CWME9210 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CWME9210 +# endif +# define machine_is_cwme9210() (machine_arch_type == MACH_TYPE_CWME9210) +#else +# define machine_is_cwme9210() (0) +#endif + +#ifdef CONFIG_MACH_CWME9210JS +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CWME9210JS +# endif +# define machine_is_cwme9210js() (machine_arch_type == MACH_TYPE_CWME9210JS) +#else +# define machine_is_cwme9210js() (0) +#endif + +#ifdef CONFIG_MACH_PGS_SITARA +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_PGS_SITARA +# endif +# define machine_is_pgs_v1() (machine_arch_type == MACH_TYPE_PGS_SITARA) +#else +# define machine_is_pgs_v1() (0) +#endif + +#ifdef CONFIG_MACH_COLIBRI_TEGRA2 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_COLIBRI_TEGRA2 +# endif +# define machine_is_colibri_tegra2() (machine_arch_type == MACH_TYPE_COLIBRI_TEGRA2) +#else +# define machine_is_colibri_tegra2() (0) +#endif + +#ifdef CONFIG_MACH_W21 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_W21 +# endif +# define machine_is_w21() (machine_arch_type == MACH_TYPE_W21) +#else +# define machine_is_w21() (0) +#endif + +#ifdef CONFIG_MACH_POLYSAT1 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_POLYSAT1 +# endif +# define machine_is_polysat1() (machine_arch_type == MACH_TYPE_POLYSAT1) +#else +# define machine_is_polysat1() (0) +#endif + +#ifdef CONFIG_MACH_DATAWAY +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DATAWAY +# endif +# define machine_is_dataway() (machine_arch_type == MACH_TYPE_DATAWAY) +#else +# define machine_is_dataway() (0) +#endif + +#ifdef CONFIG_MACH_COBRAL138 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_COBRAL138 +# endif +# define machine_is_cobral138() (machine_arch_type == MACH_TYPE_COBRAL138) +#else +# define machine_is_cobral138() (0) +#endif + +#ifdef CONFIG_MACH_ROVERPCS8 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ROVERPCS8 +# endif +# define machine_is_roverpcs8() (machine_arch_type == MACH_TYPE_ROVERPCS8) +#else +# define machine_is_roverpcs8() (0) +#endif + +#ifdef CONFIG_MACH_MARVELC +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MARVELC +# endif +# define machine_is_marvelc() (machine_arch_type == MACH_TYPE_MARVELC) +#else +# define machine_is_marvelc() (0) +#endif + +#ifdef CONFIG_MACH_NAVEFIHID +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_NAVEFIHID +# endif +# define machine_is_navefihid() (machine_arch_type == MACH_TYPE_NAVEFIHID) +#else +# define machine_is_navefihid() (0) +#endif + +#ifdef CONFIG_MACH_DM365_CV100 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DM365_CV100 +# endif +# define machine_is_dm365_cv100() (machine_arch_type == MACH_TYPE_DM365_CV100) +#else +# define machine_is_dm365_cv100() (0) +#endif + +#ifdef CONFIG_MACH_ABLE +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ABLE +# endif +# define machine_is_able() (machine_arch_type == MACH_TYPE_ABLE) +#else +# define machine_is_able() (0) +#endif + +#ifdef CONFIG_MACH_LEGACY +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_LEGACY +# endif +# define machine_is_legacy() (machine_arch_type == MACH_TYPE_LEGACY) +#else +# define machine_is_legacy() (0) +#endif + +#ifdef CONFIG_MACH_ICONG +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ICONG +# endif +# define machine_is_icong() (machine_arch_type == MACH_TYPE_ICONG) +#else +# define machine_is_icong() (0) +#endif + +#ifdef CONFIG_MACH_ROVER_G8 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ROVER_G8 +# endif +# define machine_is_rover_g8() (machine_arch_type == MACH_TYPE_ROVER_G8) +#else +# define machine_is_rover_g8() (0) +#endif + +#ifdef CONFIG_MACH_T5388P +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_T5388P +# endif +# define machine_is_t5388p() (machine_arch_type == MACH_TYPE_T5388P) +#else +# define machine_is_t5388p() (0) +#endif + +#ifdef CONFIG_MACH_DINGO +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DINGO +# endif +# define machine_is_dingo() (machine_arch_type == MACH_TYPE_DINGO) +#else +# define machine_is_dingo() (0) +#endif + +#ifdef CONFIG_MACH_GOFLEXHOME +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GOFLEXHOME +# endif +# define machine_is_goflexhome() (machine_arch_type == MACH_TYPE_GOFLEXHOME) +#else +# define machine_is_goflexhome() (0) +#endif + /* * These have not yet been registered */
device tree for uboot arm support has already been enabled in the master branch. This patch enable device tree support for mx51/53 evk board for DT test.
Signed-off-by: Jason Liu r64343@freescale.com --- include/configs/mx51evk.h | 3 +++ include/configs/mx53evk.h | 3 +++ 2 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 591d6e1..57186aa 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -222,4 +222,7 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
+#define CONFIG_OF_LIBFDT +#define CONFIG_SYS_BOOTMAPSZ 0x800000 + #endif diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index f2a5752..6ac910b 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -190,4 +190,7 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
+#define CONFIG_OF_LIBFDT +#define CONFIG_SYS_BOOTMAPSZ 0x800000 + #endif /* __CONFIG_H */
Hi, Stefano,
2011/2/21 Jason Liu r64343@freescale.com:
ping.
already done
http://git.denx.de/?p=u-boot/u-boot-arm.git;a=commitdiff;h=c7977858dcf1f656c...
--Sandeep
Hi Jason,
--- On Mon, 2/21/11, Jason Liu r64343@freescale.com wrote:
From: Jason Liu r64343@freescale.com Subject: [U-Boot] [PATCH 1/1] ARM: Update mach types To: u-boot@lists.denx.de Date: Monday, February 21, 2011, 8:14 AM This commit updates the mach-types to sync with ARM Linux based on the following commit by Russell King commit 4a683a2c5e7cabe91218db28e56dc25e1b134ce3
The machine update patch is already in U-boot ARM tree: http://git.denx.de/?p=u-boot/u-boot-arm.git;a=commitdiff;h=c7977858dcf1f656c...
Regards,
Fabio Estevam
Hi, Fabio,
Best Regards, Jason Liu
-----Original Message----- From: Fabio Estevam [mailto:fabioestevam@yahoo.com] Sent: Tuesday, February 22, 2011 1:36 AM To: u-boot@lists.denx.de; Liu Hui-R64343 Subject: Re: [U-Boot] [PATCH 1/1] ARM: Update mach types
Hi Jason,
The machine update patch is already in U-boot ARM tree: http://git.denx.de/?p=u-boot/u-boot- arm.git;a=commitdiff;h=c7977858dcf1f656cbe91ea0dc3cb9139c6a8cc8
Yes, I just see it now but not when I submit patches.
Regards,
Fabio Estevam
Already submitted and accepted
--Sandeep
participants (5)
Fabio Estevam
Jason Liu
Jason Liu
Liu Hui-R64343
Paulraj, Sandeep
