[U-Boot] [PATCH] Add code for spi half duplex operation for enc28j60
The current code assumes full duplex spi operation. But there are processors like imx23 which only permit half duplex operation. This fix does half duplex operation based on the definition of CONFIG_SPI_HALF_DUPLEX
Signed-off-by: Asok Subramanian <asok at vyassoft.com> --- drivers/net/enc28j60.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/drivers/net/enc28j60.c b/drivers/net/enc28j60.c index ec33764..753fe26 100644 --- a/drivers/net/enc28j60.c +++ b/drivers/net/enc28j60.c @@ -157,9 +157,17 @@ static u8 enc_r8(enc_dev_t *enc, const u16 reg) enc_set_bank(enc, reg); dout[0] = CMD_RCR(reg); +#ifndef CONFIG_SPI_HALF_DUPLEX spi_xfer(enc->slave, nbytes * 8, dout, din, SPI_XFER_BEGIN | SPI_XFER_END); return din[nbytes-1]; +#else + spi_xfer(enc->slave, (nbytes -1) * 8, dout, NULL, + SPI_XFER_BEGIN ); + spi_xfer(enc->slave, 8, NULL, din, + SPI_XFER_END ); + return din[0]; +#endif } /* @@ -175,6 +183,7 @@ static u16 enc_r16(enc_dev_t *enc, const u16 reg) enc_set_bank(enc, reg); dout[0] = CMD_RCR(reg); +#ifndef CONFIG_SPI_HALF_DUPLEX spi_xfer(enc->slave, nbytes * 8, dout, din, SPI_XFER_BEGIN | SPI_XFER_END); result = din[nbytes-1]; @@ -183,6 +192,20 @@ static u16 enc_r16(enc_dev_t *enc, const u16 reg) SPI_XFER_BEGIN | SPI_XFER_END); result |= din[nbytes-1] << 8; return result; +#else + spi_xfer(enc->slave, (nbytes -1) * 8, dout, NULL, + SPI_XFER_BEGIN ); + spi_xfer(enc->slave, 8, NULL, din, + SPI_XFER_END ); + result = din[0]; + dout[0]++; /* next register */ + spi_xfer(enc->slave, (nbytes -1) * 8, dout, NULL, + SPI_XFER_BEGIN ); + spi_xfer(enc->slave, 8, NULL, din, + SPI_XFER_END ); + result |= din[0] << 8; + return result; +#endif } /*
Hi
Seems like some issues with checkpatch.pl and use proper commit msg header.
Please fix and use u-boot-spi.git repo with master-probe branch. Please test the same on your hw and let me know for any issues.
SPI_XFER_BEGIN );
SPI_XFER_END );
return din[0];
+#endif }
SPI_XFER_BEGIN );
SPI_XFER_END );
result = din[0];
SPI_XFER_BEGIN );
SPI_XFER_END );
return result;
+#endif }
1.7.9.5
On Fri, Oct 4, 2013 at 4:43 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi
SPI_XFER_BEGIN );
SPI_XFER_END );
return din[0];
+#endif }
SPI_XFER_BEGIN );
SPI_XFER_END );
result = din[0];
SPI_XFER_BEGIN );
SPI_XFER_END );
return result;
+#endif }
Ping
Hi
SPI_XFER_BEGIN );
SPI_XFER_END );
return din[0];
+#endif }
SPI_XFER_BEGIN );
SPI_XFER_END );
result = din[0];
SPI_XFER_BEGIN );
SPI_XFER_END );
return result;
+#endif }
Ping
Ping.!
Asok Subramanian
Jagan Teki
