[U-Boot] [PATCH] riscv: dts: Sync to Linux Kernel ae350 dts.
Use same dts to boot U-Boot and Kernel.
Following are the change notes : 1 Remove early printk bootargs. 2 Timer frequency are changed to 60MHz. 3 Add dma, snd, lcd, virtio nodes which are used in kernel drivers. They does not been used by U-Boot. 4 Change spi irq from 3 to 4.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com --- arch/riscv/dts/ae350.dts | 107 ++++++++++++++++++++++++++++++++++++++++------- 1 file changed, 92 insertions(+), 15 deletions(-)
diff --git a/arch/riscv/dts/ae350.dts b/arch/riscv/dts/ae350.dts index 4717ae8..e48c298 100644 --- a/arch/riscv/dts/ae350.dts +++ b/arch/riscv/dts/ae350.dts @@ -12,15 +12,14 @@ };
chosen { - bootargs = "console=ttyS0,38400n8 earlyprintk=uart8250-32bit,0xf0300000 debug loglevel=7"; + bootargs = "console=ttyS0,38400n8 debug loglevel=7"; stdout-path = "uart0:38400n8"; };
cpus { #address-cells = <1>; #size-cells = <0>; - timebase-frequency = <10000000>; - + timebase-frequency = <60000000>; CPU0: cpu@0 { device_type = "cpu"; reg = <0>; @@ -29,7 +28,8 @@ riscv,isa = "rv64imafdc"; mmu-type = "riscv,sv39"; clock-frequency = <60000000>; - + d-cache-size = <0x8000>; + d-cache-line-size = <32>; CPU0_intc: interrupt-controller { #interrupt-cells = <1>; interrupt-controller; @@ -48,13 +48,6 @@ #size-cells = <2>; compatible = "andestech,riscv-ae350-soc"; ranges; - }; - - plmt0@e6000000 { - compatible = "riscv,plmt0"; - interrupts-extended = <&CPU0_intc 7>; - reg = <0x0 0xe6000000 0x0 0x100000>; - };
plic0: interrupt-controller@e4000000 { compatible = "riscv,plic0"; @@ -62,7 +55,7 @@ #interrupt-cells = <2>; interrupt-controller; reg = <0x0 0xe4000000 0x0 0x2000000>; - riscv,ndev=<31>; + riscv,ndev=<71>; interrupts-extended = <&CPU0_intc 11 &CPU0_intc 9>; };
@@ -76,6 +69,13 @@ interrupts-extended = <&CPU0_intc 3>; };
+ plmt0@e6000000 { + compatible = "riscv,plmt0"; + interrupts-extended = <&CPU0_intc 7>; + reg = <0x0 0xe6000000 0x0 0x100000>; + }; + }; + spiclk: virt_100mhz { #clock-cells = <0>; compatible = "fixed-clock"; @@ -85,7 +85,7 @@ timer0: timer@f0400000 { compatible = "andestech,atcpit100"; reg = <0x0 0xf0400000 0x0 0x1000>; - clock-frequency = <40000000>; + clock-frequency = <60000000>; interrupts = <3 4>; interrupt-parent = <&plic0>; }; @@ -119,11 +119,89 @@ interrupt-parent = <&plic0>; };
+ dma0: dma@f0c00000 { + compatible = "andestech,atcdmac300"; + reg = <0x0 0xf0c00000 0x0 0x1000>; + interrupts = <10 4 64 4 65 4 66 4 67 4 68 4 69 4 70 4 71 4>; + dma-channels = <8>; + interrupt-parent = <&plic0>; + }; + + lcd0: lcd@e0200000 { + compatible = "andestech,atflcdc100"; + reg = <0x0 0xe0200000 0x0 0x1000>; + interrupts = <20 4>; + interrupt-parent = <&plic0>; + }; + smc0: smc@e0400000 { compatible = "andestech,atfsmc020"; reg = <0x0 0xe0400000 0x0 0x1000>; };
+ snd0: snd@f0d00000 { + compatible = "andestech,atfac97"; + reg = <0x0 0xf0d00000 0x0 0x1000>; + interrupts = <17 4>; + interrupt-parent = <&plic0>; + }; + + virtio_mmio@fe007000 { + interrupts = <0x17 0x4>; + interrupt-parent = <0x2>; + reg = <0x0 0xfe007000 0x0 0x1000>; + compatible = "virtio,mmio"; + }; + + virtio_mmio@fe006000 { + interrupts = <0x16 0x4>; + interrupt-parent = <0x2>; + reg = <0x0 0xfe006000 0x0 0x1000>; + compatible = "virtio,mmio"; + }; + + virtio_mmio@fe005000 { + interrupts = <0x15 0x4>; + interrupt-parent = <0x2>; + reg = <0x0 0xfe005000 0x0 0x1000>; + compatible = "virtio,mmio"; + }; + + virtio_mmio@fe004000 { + interrupts = <0x14 0x4>; + interrupt-parent = <0x2>; + reg = <0x0 0xfe004000 0x0 0x1000>; + compatible = "virtio,mmio"; + }; + + virtio_mmio@fe003000 { + interrupts = <0x13 0x4>; + interrupt-parent = <0x2>; + reg = <0x0 0xfe003000 0x0 0x1000>; + compatible = "virtio,mmio"; + }; + + virtio_mmio@fe002000 { + interrupts = <0x12 0x4>; + interrupt-parent = <0x2>; + reg = <0x0 0xfe002000 0x0 0x1000>; + compatible = "virtio,mmio"; + }; + + virtio_mmio@fe001000 { + interrupts = <0x11 0x4>; + interrupt-parent = <0x2>; + reg = <0x0 0xfe001000 0x0 0x1000>; + compatible = "virtio,mmio"; + }; + + virtio_mmio@fe000000 { + interrupts = <0x10 0x4>; + interrupt-parent = <0x2>; + reg = <0x0 0xfe000000 0x0 0x1000>; + compatible = "virtio,mmio"; + }; + nor@0,0 { compatible = "cfi-flash"; reg = <0x0 0x88000000 0x0 0x1000>; @@ -138,9 +216,8 @@ #size-cells = <0>; num-cs = <1>; clocks = <&spiclk>; - interrupts = <3 4>; + interrupts = <4 4>; interrupt-parent = <&plic0>; - flash@0 { compatible = "spi-flash"; spi-max-frequency = <50000000>;
Hi Rick,
chosen {
bootargs = "console=ttyS0,38400n8 debug loglevel=7"; stdout-path = "uart0:38400n8"; }; cpus { #address-cells = <1>; #size-cells = <0>;
plmt0@e6000000 {
}; plic0: interrupt-controller@e4000000 { compatible = "riscv,plic0";
riscv,ndev=<31>;
plmt0@e6000000 {
dma-channels = <8>;
Do these virtio devices exist on the real hardware?
interrupts = <3 4>;
Regards, Bin
Bin Meng bmeng.cn@gmail.com 於 2018年10月8日 週一 下午1:49寫道:
Hi Rick,
chosen {
plmt0@e6000000 {
riscv,ndev=<31>;
plmt0@e6000000 {
dma-channels = <8>;
Hi Bin
No. These virtio nodes does not exist on the read board. It is required on Andes' QEMU ae350 board.
Rick
interrupts = <3 4>;
Regards, Bin
Hi Rick,
Hi Rick,
chosen {
plmt0@e6000000 {
riscv,ndev=<31>;
plmt0@e6000000 {
dma-channels = <8>;
Hi Bin
So it is a special target, which matches some hardware components plus some "virtual" components like VirtIO?
BTW: where is the Linux AE350 DTS file? I do not see it in the Linux tree.
Regards, Bin
Bin Meng bmeng.cn@gmail.com 於 2018年10月16日 週二 上午9:43寫道:
Hi Rick,
Hi Rick,
chosen {
plmt0@e6000000 {
riscv,ndev=<31>;
plmt0@e6000000 {
dma-channels = <8>;
Hi Bin
Yes.
The dts has not been pushed into Linux tree yet.
Rick
Regards, Bin
Andes
Bin Meng
Rick Chen
