Re: [U-Boot] [PATCH 4/9] armv8: layerscape: Rewrite memory reservation
On 02/14/2017 09:00 AM, york.sun@nxp.com wrote:
On 02/14/2017 07:31 AM, Alexander Graf wrote:
On 14/02/2017 04:45, York Sun wrote:
For ARMv8 Layerscape SoCs, secure memory and MC memorey are reserved at the end of DDR. DDR is spit into two or three banks. This patch reverts commit aabd7ddb and simplifies the calculation of reserved memory, and moves the code into common SoC file. Secure memory is carved out first. DDR bank size is reduced. Reserved memory is then allocated on the top of available memory. U-Boot still has access to reserved memory as data transferring is needed. Device tree is fixed with reduced memory size to hide the reserved memory from OS.
I haven't looked in detail, but could you please ensure that you also reserve those regions in the efi_loader memory map?
I missed efi reserved memory map. Will add in v2 patch.
Alex,
Is the misc_init_r() the best place to add such reservation under your code dealing with DP_DDR? It is per board code. As of now, we only have ls2080ardb with efi boot.
York
Alex,
Ideally I'd like to make sure efi boot works on all boards, not just individual ones. So if you find a more generic place that gets called after efi_memory_init(), that would be great.
Since you add a global kconfig define for reserved memory, you can even do it inside efi_memory_init() directly for the top-of-ram region.
Alex
Alex,
I think it will be a good idea to put into efi_memory_init(), where the memory is added.
York
Reduce CC list.
Alex,
Alex,
I am thinking to add a weak function efi_add_known_memory() to do the work you have at the beginning of efi_memory_init(). Then I will add this function to arch/arm/cpu/armv8/fsl-layerscape/cpu.c. Since the SoC file has the knowledge of DP-DDR and how memory is reserved, it can be easily added without risking breaking anything else.
By the way, I failed to run distro boot as I set up before. I am going to re-download the DVD ISO file and deploy it again to my USB thumb drive. Any tips on running it without installation, i.e. live CD mode? I remember last time I did some trick to drop to the shell.
York
On 15/02/2017 19:52, york sun wrote:
Reduce CC list.
Alex,
Alex,
That's certainly a possibility, yes :).
Grub should give you a rescue menu item which gets you into a shell, yes. Inside the installer you can also exit into a very minimalistic shell if you like, but it's not very powerful.
Alex
Alexander Graf
york sun
