Re: [U-Boot] Travis CI
On 11/30/2016 01:43 PM, york.sun@nxp.com wrote:
On 11/30/2016 01:35 PM, Stephen Warren wrote:
On 11/30/2016 12:47 PM, york sun wrote:
Guys,
I noticed you have been improving .travis.yml. Can you share some performance data when using it? I am still using Jenkins to verify my branches for every commit. Due to the limitation of computing power, I don't cover all targets. This has caused several "oops". Please share your experience. Thanks.
The Travis results are all public. For example, you can look at the URL below to see the build for Tom's github clone of the main u-boot.git:
https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftravis-ci...
The last test run appears to have taken about 49 minutes total. IIRC Tom mentioned 1-2 hours total in the past.
Travis uses github hooks to detect pushes, so I typically see it start builds almost immediately after a push to an enabled branch.
Stephen,
Thanks for the pointer. I am getting myself familiar with Travis CI. I have been using Jenkins. Compiling 100 commits for powerpc (418 targets) takes many hours to finish.
I took a test run and found without the "-b", buildman only builds current source tree, not for each commit. It is a good tool but maybe this is not for my purpose.
York
Guys,
Note that the "elapsed time" can become quite wrong if you go to a failed build, see that one of the sub-jobs failed for bad reasons (for example, sometimes we get a failure with the ppa we use for qemu), and restart just that part and it completes. Most recently I see one took around 2.5 hours as I've added in more build targets since I gave the initial time.
That said, those 2.5 hours build just about every buildable target in U-Boot, and run test.py via qemu for a few. And it's totally free. To me it's a great "last test" before sending out a PR or a big series. I use it as part of my pre-pushing tests.
Stephen,
Yes, this is not a tool for building every part of a series. I still use a different machine to build before/after for just about everything and look at size changes for example.
Guys,
Stephen,
Thanks, Tom. I noticed Travis CI runs on low powered servers. It takes quite long to finish everything. But as you said, it is good to compile everything before pushing.
York
york sun
