[U-Boot] [PATCH] env: Properly check for BLK support
Use CONFIG_IS_ENABLED to see if CONFIG_BLK is enabled. Otherwise SPL compilation breaks on boards which do have CONFIG_BLK enabled but not DM_MMC for the SPL as follows:
env/mmc.c: In function ‘init_mmc_for_env’: env/mmc.c:164:6: warning: implicit declaration of function ‘blk_get_from_parent’; did you mean ‘efi_get_ram_base’? [-Wimplicit-function-declaration] if (blk_get_from_parent(mmc->dev, &dev)) ^~~~~~~~~~~~~~~~~~~ efi_get_ram_base env/mmc.c:164:29: error: ‘struct mmc’ has no member named ‘dev’ if (blk_get_from_parent(mmc->dev, &dev)) ^~
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk ---
env/mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/env/mmc.c b/env/mmc.c index 6f11deccb1..bf7015cd14 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -158,7 +158,7 @@ static const char *init_mmc_for_env(struct mmc *mmc) if (!mmc) return "!No MMC card found";
-#ifdef CONFIG_BLK +#if CONFIG_IS_ENABLED(BLK) struct udevice *dev;
On 23 March 2018 at 05:53, Sjoerd Simons sjoerd.simons@collabora.co.uk wrote:
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Reviewed-by: Simon Glass sjg@chromium.org
Sjoerd Simons
