[U-Boot] [v2] net/fman: Support both new and legacy FMan Compatibles
Recently the FMan Port and MAC compatibles were changed. This patch aligns the FMan Port and MAC compatibles to the new FMan device tree binding document. The FMan device tree binding document can be found in the Linux kernel: ./Documentation/devicetree/bindings/powerpc/fsl/fman.txt
This patch doesn't affect legacy compatibles support.
Signed-off-by: Igal Liberman igal.liberman@freescale.com
v1 --- v2: - Changed the subject of the patch v1: https://patchwork.ozlabs.org/patch/473501/ - Added Support to both new and legacy FMan compatibles
--- arch/powerpc/cpu/mpc85xx/b4860_ids.c | 2 +- arch/powerpc/cpu/mpc85xx/liodn.c | 64 +++++++++++++++++++++++++++++++--- arch/powerpc/cpu/mpc85xx/p2041_ids.c | 2 +- arch/powerpc/cpu/mpc85xx/p3041_ids.c | 2 +- arch/powerpc/cpu/mpc85xx/p4080_ids.c | 4 +-- arch/powerpc/cpu/mpc85xx/p5020_ids.c | 2 +- arch/powerpc/cpu/mpc85xx/p5040_ids.c | 4 +-- arch/powerpc/cpu/mpc85xx/t1024_ids.c | 2 +- arch/powerpc/cpu/mpc85xx/t1040_ids.c | 2 +- arch/powerpc/cpu/mpc85xx/t2080_ids.c | 2 +- arch/powerpc/cpu/mpc85xx/t4240_ids.c | 4 +-- arch/powerpc/include/asm/fsl_liodn.h | 53 ++++++++++++++++++++++------ drivers/net/fm/init.c | 27 ++++++++++---- 13 files changed, 135 insertions(+), 35 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/b4860_ids.c b/arch/powerpc/cpu/mpc85xx/b4860_ids.c index fd7f5fa..85eba0b 100644 --- a/arch/powerpc/cpu/mpc85xx/b4860_ids.c +++ b/arch/powerpc/cpu/mpc85xx/b4860_ids.c @@ -74,7 +74,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 88), SET_FMAN_RX_1G_LIODN(1, 1, 89), SET_FMAN_RX_1G_LIODN(1, 2, 90), diff --git a/arch/powerpc/cpu/mpc85xx/liodn.c b/arch/powerpc/cpu/mpc85xx/liodn.c index 7a2d4be..7a4465f 100644 --- a/arch/powerpc/cpu/mpc85xx/liodn.c +++ b/arch/powerpc/cpu/mpc85xx/liodn.c @@ -57,6 +57,23 @@ static void set_liodn(struct liodn_id_table *tbl, int size) } }
+#ifdef CONFIG_SYS_DPAA_FMAN +static void set_fman_liodn(struct fman_liodn_id_table *tbl, int size) +{ + int i; + + for (i = 0; i < size; i++) { + u32 liodn; + if (tbl[i].num_ids == 2) + liodn = (tbl[i].id[0] << 16) | tbl[i].id[1]; + else + liodn = tbl[i].id[0]; + + out_be32((volatile u32 *)(tbl[i].reg_offset), liodn); + } +} +#endif + static void setup_sec_liodn_base(void) { ccsr_sec_t *sec = (void *)CONFIG_SYS_FSL_SEC_ADDR; @@ -76,7 +93,7 @@ static void setup_sec_liodn_base(void)
#ifdef CONFIG_SYS_DPAA_FMAN static void setup_fman_liodn_base(enum fsl_dpaa_dev dev, - struct liodn_id_table *tbl, int size) + struct fman_liodn_id_table *tbl, int size) { int i; ccsr_fman_t *fm; @@ -180,12 +197,12 @@ void set_liodns(void)
/* setup FMAN block(s) liodn bases & offsets if we have one */ #ifdef CONFIG_SYS_DPAA_FMAN - set_liodn(fman1_liodn_tbl, fman1_liodn_tbl_sz); + set_fman_liodn(fman1_liodn_tbl, fman1_liodn_tbl_sz); setup_fman_liodn_base(FSL_HW_PORTAL_FMAN1, fman1_liodn_tbl, fman1_liodn_tbl_sz);
#if (CONFIG_SYS_NUM_FMAN == 2) - set_liodn(fman2_liodn_tbl, fman2_liodn_tbl_sz); + set_fman_liodn(fman2_liodn_tbl, fman2_liodn_tbl_sz); setup_fman_liodn_base(FSL_HW_PORTAL_FMAN2, fman2_liodn_tbl, fman2_liodn_tbl_sz); #endif @@ -315,6 +332,43 @@ static void fdt_fixup_liodn_tbl(void *blob, struct liodn_id_table *tbl, int sz) } }
+#ifdef CONFIG_SYS_DPAA_FMAN +static void fdt_fixup_liodn_tbl_fman(void *blob, + struct fman_liodn_id_table *tbl, + int sz) +{ + int i; + + for (i = 0; i < sz; i++) { + int off; + + if (tbl[i].compat == NULL) + continue; + + /* Try the new compatible first. + * If the node is missing, try the old. + */ + off = fdt_node_offset_by_compat_reg(blob, + tbl[i].compat[0], tbl[i].compat_offset); + if (off < 0) + off = fdt_node_offset_by_compat_reg(blob, + tbl[i].compat[1], tbl[i].compat_offset); + + if (off >= 0) { + off = fdt_setprop(blob, off, "fsl,liodn", + &tbl[i].id[0], + sizeof(u32) * tbl[i].num_ids); + if (off > 0) + printf("WARNING unable to set fsl,liodn for FMan Port: %s\n", + fdt_strerror(off)); + } else { + debug("WARNING: could not set fsl,liodn for FMan Portport: %s.\n", + fdt_strerror(off)); + } + } +} +#endif + void fdt_fixup_liodn(void *blob) { #ifdef CONFIG_SYS_SRIO @@ -323,9 +377,9 @@ void fdt_fixup_liodn(void *blob)
fdt_fixup_liodn_tbl(blob, liodn_tbl, liodn_tbl_sz); #ifdef CONFIG_SYS_DPAA_FMAN - fdt_fixup_liodn_tbl(blob, fman1_liodn_tbl, fman1_liodn_tbl_sz); + fdt_fixup_liodn_tbl_fman(blob, fman1_liodn_tbl, fman1_liodn_tbl_sz); #if (CONFIG_SYS_NUM_FMAN == 2) - fdt_fixup_liodn_tbl(blob, fman2_liodn_tbl, fman2_liodn_tbl_sz); + fdt_fixup_liodn_tbl_fman(blob, fman2_liodn_tbl, fman2_liodn_tbl_sz); #endif #endif fdt_fixup_liodn_tbl(blob, sec_liodn_tbl, sec_liodn_tbl_sz); diff --git a/arch/powerpc/cpu/mpc85xx/p2041_ids.c b/arch/powerpc/cpu/mpc85xx/p2041_ids.c index 6e3cddd..8b6d274 100644 --- a/arch/powerpc/cpu/mpc85xx/p2041_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p2041_ids.c @@ -61,7 +61,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 10), SET_FMAN_RX_1G_LIODN(1, 1, 11), SET_FMAN_RX_1G_LIODN(1, 2, 12), diff --git a/arch/powerpc/cpu/mpc85xx/p3041_ids.c b/arch/powerpc/cpu/mpc85xx/p3041_ids.c index 2b57703..ff8216b 100644 --- a/arch/powerpc/cpu/mpc85xx/p3041_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p3041_ids.c @@ -62,7 +62,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 10), SET_FMAN_RX_1G_LIODN(1, 1, 11), SET_FMAN_RX_1G_LIODN(1, 2, 12), diff --git a/arch/powerpc/cpu/mpc85xx/p4080_ids.c b/arch/powerpc/cpu/mpc85xx/p4080_ids.c index 94a5143..174eb04 100644 --- a/arch/powerpc/cpu/mpc85xx/p4080_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p4080_ids.c @@ -54,7 +54,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 11), SET_FMAN_RX_1G_LIODN(1, 1, 12), SET_FMAN_RX_1G_LIODN(1, 2, 13), @@ -64,7 +64,7 @@ struct liodn_id_table fman1_liodn_tbl[] = { int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl);
#if (CONFIG_SYS_NUM_FMAN == 2) -struct liodn_id_table fman2_liodn_tbl[] = { +struct fman_liodn_id_table fman2_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(2, 0, 16), SET_FMAN_RX_1G_LIODN(2, 1, 17), SET_FMAN_RX_1G_LIODN(2, 2, 18), diff --git a/arch/powerpc/cpu/mpc85xx/p5020_ids.c b/arch/powerpc/cpu/mpc85xx/p5020_ids.c index 0f292cf..99e3e91 100644 --- a/arch/powerpc/cpu/mpc85xx/p5020_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p5020_ids.c @@ -62,7 +62,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 10), SET_FMAN_RX_1G_LIODN(1, 1, 11), SET_FMAN_RX_1G_LIODN(1, 2, 12), diff --git a/arch/powerpc/cpu/mpc85xx/p5040_ids.c b/arch/powerpc/cpu/mpc85xx/p5040_ids.c index 98a568f..1c99f9f 100644 --- a/arch/powerpc/cpu/mpc85xx/p5040_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p5040_ids.c @@ -48,7 +48,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 11), SET_FMAN_RX_1G_LIODN(1, 1, 12), SET_FMAN_RX_1G_LIODN(1, 2, 13), @@ -59,7 +59,7 @@ struct liodn_id_table fman1_liodn_tbl[] = { int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl);
#if (CONFIG_SYS_NUM_FMAN == 2) -struct liodn_id_table fman2_liodn_tbl[] = { +struct fman_liodn_id_table fman2_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(2, 0, 17), SET_FMAN_RX_1G_LIODN(2, 1, 18), SET_FMAN_RX_1G_LIODN(2, 2, 19), diff --git a/arch/powerpc/cpu/mpc85xx/t1024_ids.c b/arch/powerpc/cpu/mpc85xx/t1024_ids.c index 8a1092e..8f95e33 100644 --- a/arch/powerpc/cpu/mpc85xx/t1024_ids.c +++ b/arch/powerpc/cpu/mpc85xx/t1024_ids.c @@ -50,7 +50,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_10G_TYPE2_LIODN(1, 0, 88), SET_FMAN_RX_1G_LIODN(1, 1, 89), SET_FMAN_RX_1G_LIODN(1, 2, 90), diff --git a/arch/powerpc/cpu/mpc85xx/t1040_ids.c b/arch/powerpc/cpu/mpc85xx/t1040_ids.c index 8091722..b98c7bc 100644 --- a/arch/powerpc/cpu/mpc85xx/t1040_ids.c +++ b/arch/powerpc/cpu/mpc85xx/t1040_ids.c @@ -55,7 +55,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 88), SET_FMAN_RX_1G_LIODN(1, 1, 89), SET_FMAN_RX_1G_LIODN(1, 2, 90), diff --git a/arch/powerpc/cpu/mpc85xx/t2080_ids.c b/arch/powerpc/cpu/mpc85xx/t2080_ids.c index eda7f59..868f2d5 100644 --- a/arch/powerpc/cpu/mpc85xx/t2080_ids.c +++ b/arch/powerpc/cpu/mpc85xx/t2080_ids.c @@ -83,7 +83,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 88), SET_FMAN_RX_1G_LIODN(1, 1, 89), SET_FMAN_RX_1G_LIODN(1, 2, 90), diff --git a/arch/powerpc/cpu/mpc85xx/t4240_ids.c b/arch/powerpc/cpu/mpc85xx/t4240_ids.c index 470b080..14ada9e 100644 --- a/arch/powerpc/cpu/mpc85xx/t4240_ids.c +++ b/arch/powerpc/cpu/mpc85xx/t4240_ids.c @@ -112,7 +112,7 @@ struct liodn_id_table liodn_tbl[] = { int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { +struct fman_liodn_id_table fman1_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(1, 0, 88), SET_FMAN_RX_1G_LIODN(1, 1, 89), SET_FMAN_RX_1G_LIODN(1, 2, 90), @@ -124,7 +124,7 @@ struct liodn_id_table fman1_liodn_tbl[] = { }; int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl); #if (CONFIG_SYS_NUM_FMAN == 2) -struct liodn_id_table fman2_liodn_tbl[] = { +struct fman_liodn_id_table fman2_liodn_tbl[] = { SET_FMAN_RX_1G_LIODN(2, 0, 88), SET_FMAN_RX_1G_LIODN(2, 1, 89), SET_FMAN_RX_1G_LIODN(2, 2, 90), diff --git a/arch/powerpc/include/asm/fsl_liodn.h b/arch/powerpc/include/asm/fsl_liodn.h index 6206bee..8c91e72 100644 --- a/arch/powerpc/include/asm/fsl_liodn.h +++ b/arch/powerpc/include/asm/fsl_liodn.h @@ -44,6 +44,18 @@ struct liodn_id_table { unsigned long reg_offset; };
+struct fman_liodn_id_table { + /* Freescale FMan Device Tree binding was updated for FMan. + * We need to support both new and old compatibles in order not to + * break backward compatibility. + */ + const char *compat[2]; + u32 id[2]; + u8 num_ids; + phys_addr_t compat_offset; + unsigned long reg_offset; +}; + extern u32 get_ppid_liodn(int ppid_tbl_idx, int ppid); extern void set_liodns(void); extern void fdt_fixup_liodn(void *blob); @@ -54,6 +66,14 @@ extern void fdt_fixup_liodn(void *blob); #define SET_LIODN_BASE_2(idA, idB) \ { .id = { idA, idB }, .num_ids = 2 }
+#define SET_FMAN_LIODN_ENTRY(name1, name2, idA, off, compatoff)\ + { .compat[0] = name1, \ + .compat[1] = name2, \ + .id = { idA }, .num_ids = 1, \ + .reg_offset = off + CONFIG_SYS_CCSRBAR, \ + .compat_offset = compatoff + CONFIG_SYS_CCSRBAR_PHYS, \ + } + #define SET_LIODN_ENTRY_1(name, idA, off, compatoff) \ { .compat = name, \ .id = { idA }, .num_ids = 1, \ @@ -133,24 +153,37 @@ extern void fdt_fixup_liodn(void *blob); CONFIG_SYS_FSL_FM##fmNum##_OFFSET + \ offsetof(struct ccsr_fman, fm_bmi_common.fmbm_ppid[portID - 1])
+#ifdef CONFIG_SYS_FMAN_V3 /* enetNum is 0, 1, 2... so we + 8 for 1g to get to HW Port ID */ #define SET_FMAN_RX_1G_LIODN(fmNum, enetNum, liodn) \ - SET_LIODN_ENTRY_1("fsl,fman-port-1g-rx", liodn, \ - FM_PPID_RX_PORT_OFFSET(fmNum, enetNum + 8), \ - CONFIG_SYS_FSL_FM##fmNum##_RX##enetNum##_1G_OFFSET) \ + SET_FMAN_LIODN_ENTRY("fsl,fman-v3-port-rx", "fsl,fman-port-1g-rx", \ + liodn, FM_PPID_RX_PORT_OFFSET(fmNum, enetNum + 8), \ + CONFIG_SYS_FSL_FM##fmNum##_RX##enetNum##_1G_OFFSET)
/* enetNum is 0, 1, 2... so we + 16 for 10g to get to HW Port ID */ #define SET_FMAN_RX_10G_LIODN(fmNum, enetNum, liodn) \ - SET_LIODN_ENTRY_1("fsl,fman-port-10g-rx", liodn, \ - FM_PPID_RX_PORT_OFFSET(fmNum, enetNum + 16), \ - CONFIG_SYS_FSL_FM##fmNum##_RX##enetNum##_10G_OFFSET) \ + SET_FMAN_LIODN_ENTRY("fsl,fman-v3-port-rx", "fsl,fman-port-10g-rx", \ + liodn, FM_PPID_RX_PORT_OFFSET(fmNum, enetNum + 16), \ + CONFIG_SYS_FSL_FM##fmNum##_RX##enetNum##_10G_OFFSET)
/* enetNum is 0, 1, 2... so we + 8 for type-2 10g to get to HW Port ID */ #define SET_FMAN_RX_10G_TYPE2_LIODN(fmNum, enetNum, liodn) \ - SET_LIODN_ENTRY_1("fsl,fman-port-10g-rx", liodn, \ - FM_PPID_RX_PORT_OFFSET(fmNum, enetNum + 8), \ - CONFIG_SYS_FSL_FM##fmNum##_RX##enetNum##_1G_OFFSET) \ + SET_FMAN_LIODN_ENTRY("fsl,fman-v3-port-rx", "fsl,fman-port-10g-rx", \ + liodn, FM_PPID_RX_PORT_OFFSET(fmNum, enetNum + 8), \ + CONFIG_SYS_FSL_FM##fmNum##_RX##enetNum##_1G_OFFSET) +#else +/* enetNum is 0, 1, 2... so we + 8 for 1g to get to HW Port ID */ +#define SET_FMAN_RX_1G_LIODN(fmNum, enetNum, liodn) \ + SET_FMAN_LIODN_ENTRY("fsl,fman-v2-port-rx", "fsl,fman-port-1g-rx", \ + liodn, FM_PPID_RX_PORT_OFFSET(fmNum, enetNum + 8), \ + CONFIG_SYS_FSL_FM##fmNum##_RX##enetNum##_1G_OFFSET)
+/* enetNum is 0, 1, 2... so we + 16 for 10g to get to HW Port ID */ +#define SET_FMAN_RX_10G_LIODN(fmNum, enetNum, liodn) \ + SET_FMAN_LIODN_ENTRY("fsl,fman-v2-port-rx", "fsl,fman-port-10g-rx", \ + liodn, FM_PPID_RX_PORT_OFFSET(fmNum, enetNum + 16), \ + CONFIG_SYS_FSL_FM##fmNum##_RX##enetNum##_10G_OFFSET) +#endif /* * handle both old and new versioned SEC properties: * "fsl,secX.Y" became "fsl,sec-vX.Y" during development @@ -199,7 +232,7 @@ extern void fdt_fixup_liodn(void *blob);
extern struct liodn_id_table liodn_tbl[], liodn_bases[], sec_liodn_tbl[]; extern struct liodn_id_table raide_liodn_tbl[]; -extern struct liodn_id_table fman1_liodn_tbl[], fman2_liodn_tbl[]; +extern struct fman_liodn_id_table fman1_liodn_tbl[], fman2_liodn_tbl[]; #ifdef CONFIG_SYS_SRIO extern struct srio_liodn_id_table srio_liodn_tbl[]; extern int srio_liodn_tbl_sz; diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index 9a8a007..b3ff4c5 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -3,6 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ */ +#include <errno.h> #include <common.h> #include <asm/io.h> #include <asm/fsl_serdes.h> @@ -230,7 +231,7 @@ void board_ft_fman_fixup_port(void *blob, char * prop, phys_addr_t pa, enum fm_port port, int offset) __attribute__((weak, alias("__def_board_ft_fman_fixup_port")));
-static void ft_fixup_port(void *blob, struct fm_eth_info *info, char *prop) +int ft_fixup_port(void *blob, struct fm_eth_info *info, char *prop) { int off; uint32_t ph; @@ -239,11 +240,13 @@ static void ft_fixup_port(void *blob, struct fm_eth_info *info, char *prop) CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET;
off = fdt_node_offset_by_compat_reg(blob, prop, paddr); + if (off == -FDT_ERR_NOTFOUND) + return -EINVAL;
if (info->enabled) { fdt_fixup_phy_connection(blob, off, info->enet_if); board_ft_fman_fixup_port(blob, prop, paddr, info->port, off); - return ; + return 0; }
#ifdef CONFIG_SYS_FMAN_V3 @@ -281,7 +284,7 @@ static void ft_fixup_port(void *blob, struct fm_eth_info *info, char *prop) ((info->port == FM1_10GEC4) && (PORT_IS_ENABLED(FM1_DTSEC4))) #endif ) - return; + return 0; #endif /* board code might have caused offset to change */ off = fdt_node_offset_by_compat_reg(blob, prop, paddr); @@ -294,6 +297,8 @@ static void ft_fixup_port(void *blob, struct fm_eth_info *info, char *prop) ph = fdt_get_phandle(blob, off); do_fixup_by_prop(blob, "fsl,fman-mac", &ph, sizeof(ph), "status", "disabled", strlen("disabled") + 1, 1); + + return 0; }
void fdt_fixup_fman_ethernet(void *blob) @@ -305,10 +310,18 @@ void fdt_fixup_fman_ethernet(void *blob) ft_fixup_port(blob, &fm_info[i], "fsl,fman-memac"); #else for (i = 0; i < ARRAY_SIZE(fm_info); i++) { - if (fm_info[i].type == FM_ETH_1G_E) - ft_fixup_port(blob, &fm_info[i], "fsl,fman-1g-mac"); - else - ft_fixup_port(blob, &fm_info[i], "fsl,fman-10g-mac"); + /* Try the new compatible first. + * If the node is missing, try the old. + */ + if (fm_info[i].type == FM_ETH_1G_E) { + if (ft_fixup_port(blob, &fm_info[i], "fsl,fman-dtsec")) + ft_fixup_port(blob, &fm_info[i], + "fsl,fman-1g-mac"); + } else { + if (ft_fixup_port(blob, &fm_info[i], "fsl,fman-tgec")) + ft_fixup_port(blob, &fm_info[i], + "fsl,fman-10g-mac"); + } } #endif }
On Tue, Aug 18, 2015 at 6:47 AM, Igal.Liberman igal.liberman@freescale.com wrote:
I'm guessing York should be taking this in since it's 85xx specific.
-Joe
v1 --- v2:
Applied to u-boot-mpc85xx master. Awaiting upstream.
York
Igal.Liberman
Joe Hershberger
York Sun
