[U-Boot] [PATCH 1/2] LCD: drawing 32bpp uncompressed bitmap image
This patch supports drawing 32bpp uncompressed bitmap image.
Signed-off-by: Donghwa Lee dh09.lee@samsung.com Signed-off-by: Kyungmin.park kyungmin.park@samsung.com --- common/lcd.c | 26 ++++++++++++++++++++++---- 1 files changed, 22 insertions(+), 4 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index bf1a6a9..a7b04d2 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -645,14 +645,14 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y)
bpix = NBITS(panel_info.vl_bpix);
- if ((bpix != 1) && (bpix != 8) && (bpix != 16)) { + if ((bpix != 1) && (bpix != 8) && (bpix != 16) && (bpix != 32)) { printf ("Error: %d bit/pixel mode, but BMP has %d bit/pixel\n", bpix, bmp_bpix); return 1; }
/* We support displaying 8bpp BMPs on 16bpp LCDs */ - if (bpix != bmp_bpix && (bmp_bpix != 8 || bpix != 16)) { + if (bpix != bmp_bpix && (bmp_bpix != 8 || bpix != 16 || bpix != 32)) { printf ("Error: %d bit/pixel mode, but BMP has %d bit/pixel\n", bpix, le16_to_cpu(bmp->header.bit_count)); @@ -669,7 +669,7 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) cmap = (ushort *)fbi->palette; #elif defined(CONFIG_MPC823) cmap = (ushort *)&(cp->lcd_cmap[255*sizeof(ushort)]); -#elif !defined(CONFIG_ATMEL_LCD) +#elif !defined(CONFIG_ATMEL_LCD) && !defined(CONFIG_EXYNOS_FB) cmap = panel_info.cmap; #endif
@@ -739,8 +739,14 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) height = panel_info.vl_row - y;
bmap = (uchar *)bmp + le32_to_cpu (bmp->header.data_offset); + +#ifndef CONFIG_EXYNOS_FB fb = (uchar *) (lcd_base + (y + height - 1) * lcd_line_length + x * bpix / 8); +#else + fb = (uchar *) (lcd_base + (y + height) * + (panel_info.vl_col * (bpix / 8)) + x * (bpix / 8)); +#endif
switch (bmp_bpix) { case 1: /* pass through */ @@ -788,9 +794,21 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) bmap += (padded_line - width) * 2; fb -= (width * 2 + lcd_line_length); } + break; #endif /* CONFIG_BMP_16BPP */ - + case 32: + for (i = 0; i < height; ++i) { + for (j = 0; j < width; j++) { + *(fb++) = *(bmap++); + *(fb++) = *(bmap++); + *(fb++) = *(bmap++); + *(fb++) = *(bmap++); + } + fb -= ((panel_info.vl_col * + (bpix / 8)) + width * (bpix / 8)); + } + break; default: break; };
- fb = (uchar *) (lcd_base + (y + height) *
This ifndef shouldn't be needed. Better pass needed 'y' position to the lcd_display_bitmap() function.
Please do not add this empty line here.
break;
- case 32:
you can use lcd_line_lenght instead of (panel_info.vl_col * (bpix / 8)) here, i think.
break;
Please surround by #ifdef CONFIG_BMP_32BPP ... #endif
so that boards not using 32bpp do not suffer from code size increase.
Thanks, Anatolij
Anatolij Gustschin
Donghwa Lee
