[U-Boot] [PATCH] rockchip: Fix rkimage format for SPL boot over USB
The 'rkimage' format used for booting rockchip boards over USB seems to have been broken since commit 7bf274b9caab ("rockchip: mkimage: use imagename to select spl hdr & spl size"). That commit adds an offset of RK_SPL_HDR_START(=2048) to the location the 'RKxx' header is written at. However the bootrom expects this header to be the first four bytes of the image, not at offset 2048. This appears to have been a copy paste error since the 'rksd' and 'rkspi' image types do require this offset.
Furthermore commit 111bcc4fb6cb ("rockchip: mkimage: pad the header to 8-bytes (using a 'nop') for RK3399"), commit 3d54eabcafec9 ("rockchip: spl: RK3399: use boot0 hook to create space for SPL magic") and commit 308277569229 ("rockchip: mkimage: update rkimage to support pre-padded payloads") changed the way the space for the 'RKxx' header is allocated and written to the image without adjusting 'rkimage'.
This commit fixes those mistakes and makes it possible to load u-boot SPL over USB once more.
(Tested on RK3399)
Signed-off-by: Daniel Gröber daniel@dps.uibk.ac.at ---
tools/rkimage.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/tools/rkimage.c b/tools/rkimage.c index a0a3185370..ae50de55c9 100644 --- a/tools/rkimage.c +++ b/tools/rkimage.c @@ -15,8 +15,7 @@ static uint32_t header; static void rkimage_set_header(void *buf, struct stat *sbuf, int ifd, struct image_tool_params *params) { - memcpy(buf + RK_SPL_HDR_START, rkcommon_get_spl_hdr(params), - RK_SPL_HDR_SIZE); + memcpy(buf, rkcommon_get_spl_hdr(params), RK_SPL_HDR_SIZE);
if (rkcommon_need_rc4_spl(params)) rkcommon_rc4_encode_spl(buf, 4, params->file_size); @@ -36,7 +35,7 @@ static int rkimage_check_image_type(uint8_t type) U_BOOT_IMAGE_TYPE( rkimage, "Rockchip Boot Image support", - 4, + 0, &header, rkcommon_check_params, NULL,
(Tested on RK3399)
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
I’ll try to include this into rc2.
Thanks, Philipp.
(Tested on RK3399)
Signed-off-by: Daniel Gröber daniel@dps.uibk.ac.at Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Daniel Gröber
Philipp Tomsich
