[U-Boot] [PATCH] ppc/85xx: Fix LCRR_CLKDIV defines
For some reason the CLKDIV field varies between SoC in how it interprets the bit values.
All 83xx and early (e500v1) PQ3 devices support: clk/2: CLKDIV = 2 clk/4: CLKDIV = 4 clk/8: CLKDIV = 8
Newer PQ3 (e500v2) and MPC86xx support: clk/4: CLKDIV = 2 clk/8: CLKDIV = 4 clk/16: CLKDIV = 8
Ensure that the MPC86xx and MPC85xx still get the same behavior and make the the defines reflect their logical view (not the value of the field).
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/asm-ppc/fsl_lbc.h | 8 ++++++++ include/configs/XPEDITE5170.h | 2 +- include/configs/XPEDITE5200.h | 2 +- include/configs/XPEDITE5370.h | 2 +- 4 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/include/asm-ppc/fsl_lbc.h b/include/asm-ppc/fsl_lbc.h index a28082e..08d31e1 100644 --- a/include/asm-ppc/fsl_lbc.h +++ b/include/asm-ppc/fsl_lbc.h @@ -311,9 +311,17 @@ */ #define LCRR_CLKDIV 0x0000001F #define LCRR_CLKDIV_SHIFT 0 +#if defined(CONFIG_MPC83xx) || defined (CONFIG_MPC8540) || \ + defined(CONFIG_MPC8541) || defined (CONFIG_MPC8555) || \ + defined(CONFIG_MPC8560) #define LCRR_CLKDIV_2 0x00000002 #define LCRR_CLKDIV_4 0x00000004 #define LCRR_CLKDIV_8 0x00000008 +#else +#define LCRR_CLKDIV_4 0x00000002 +#define LCRR_CLKDIV_8 0x00000004 +#define LCRR_CLKDIV_16 0x00000008 +#endif
/* LTEDR - Transfer Error Check Disable Register */ diff --git a/include/configs/XPEDITE5170.h b/include/configs/XPEDITE5170.h index 242466a..30642cd 100644 --- a/include/configs/XPEDITE5170.h +++ b/include/configs/XPEDITE5170.h @@ -122,7 +122,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * 0xf800_0000 0xffff_ffff NOR Flash 1 128M non-cacheable */
-#define CONFIG_SYS_LBC_LCRR (LCRR_CLKDIV_2 | LCRR_EADC_3) +#define CONFIG_SYS_LBC_LCRR (LCRR_CLKDIV_4 | LCRR_EADC_3)
/* * NAND flash configuration diff --git a/include/configs/XPEDITE5200.h b/include/configs/XPEDITE5200.h index deda208..d79231b 100644 --- a/include/configs/XPEDITE5200.h +++ b/include/configs/XPEDITE5200.h @@ -103,7 +103,7 @@ * 0xfc00_0000 0xffff_ffff NOR Flash 1 64M non-cacheable */
-#define CONFIG_SYS_LBC_LCRR (LCRR_CLKDIV_4 | LCRR_EADC_3) +#define CONFIG_SYS_LBC_LCRR (LCRR_CLKDIV_8 | LCRR_EADC_3)
/* * NAND flash configuration diff --git a/include/configs/XPEDITE5370.h b/include/configs/XPEDITE5370.h index 3c58ebe..65e1afd 100644 --- a/include/configs/XPEDITE5370.h +++ b/include/configs/XPEDITE5370.h @@ -116,7 +116,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); * 0xf800_0000 0xffff_ffff NOR Flash 1 128M non-cacheable */
Acked-by: Peter Tyser ptyser@xes-inc.com
Thanks
Peter,
I did notice that we dont actually set LCRR anywhere :)
- k
Peter,
Lol, that's great:) CONFIG_SYS_LBC_LCRR does affect the value of sysinfo.freqLocalBus and thus gd->lbc_clk. And sysinfo.freqLocalBus is used to print the LBC frequency on bootup which added to the delusion that I was speeding it up:)
A few other boards seem to define CONFIG_SYS_LBC_LCRR, but don't implement a board-specific modification of the LBCC register, so they should have the same "bug".
I'll take a closer look tomorrow.
Peter
[snip]
Nit picking: I just noticed that there is a duplicate "the" here. Also I prefer "behaviour" but this is a US/UK issue :-( <troll>Why can't Americans write English ;-) ?</troll>
Chris Moore
Kumar Gala
Peter Tyser
