[U-Boot] [PATCH] tools: fix cross-compiling tools when HOSTCC is overridden
Richard reported U-Boot tools issues in OpenEmbedded/Yocto project.
OE needs to be able to change the default compiler. If we pass in HOSTCC through the make command, it overwrites all HOSTCC instances, including ones in tools/Makefile and tools/env/Makefile, which breaks "make cross_tools" and "make env", respectively.
Add "override" directives to avoid overriding HOSTCC instances that really need to point to the cross-compiler.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reported-by: Richard Purdie richard.purdie@linuxfoundation.org ---
tools/Makefile | 2 +- tools/env/Makefile | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/Makefile b/tools/Makefile index 1c840d7..a894b5c 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -262,7 +262,7 @@ $(LOGO_DATA_H): $(obj)/bmp_logo $(LOGO_BMP) subdir- += env
ifneq ($(CROSS_BUILD_TOOLS),) -HOSTCC = $(CC) +override HOSTCC = $(CC)
quiet_cmd_crosstools_strip = STRIP $^ cmd_crosstools_strip = $(STRIP) $^; touch $@ diff --git a/tools/env/Makefile b/tools/env/Makefile index 38ad118..95b28c0 100644 --- a/tools/env/Makefile +++ b/tools/env/Makefile @@ -8,7 +8,7 @@ # fw_printenv is supposed to run on the target system, which means it should be # built with cross tools. Although it may look weird, we only replace "HOSTCC" # with "CC" here for the maximum code reuse of scripts/Makefile.host. -HOSTCC = $(CC) +override HOSTCC = $(CC)
# Compile for a hosted environment on the target HOST_EXTRACFLAGS = $(patsubst -I%,-idirafter%, $(filter -I%, $(UBOOTINCLUDE))) \
+CC Richard +CC Marek
2017-03-13 17:43 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
# Compile for a hosted environment on the target HOST_EXTRACFLAGS = $(patsubst -I%,-idirafter%, $(filter -I%, $(UBOOTINCLUDE))) \ -- 2.7.4
On 13 March 2017 at 02:49, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reported-by: Richard Purdie richard.purdie@linuxfoundation.org Reviewed-by: Simon Glass sjg@chromium.org
Masahiro Yamada
