[U-Boot] [PATCH v2] arm, imx, Makefile: fix u-boot-dtb.imx build in CONFIG_MULTI_DTB_FIT case
in case CONFIG_MULTI_DTB_FIT is set and u-boot-dtb.imx image is build, currently u-boot-dtb.bin is used for generating the u-boot-dtb.imx binary, which is wrong, as it contains only a dtb blob not the fit.blob
Use instead the u-boot-fit-dtb.bin for generating u-boot-dtb.imx which contains the fit.blob.
Signed-off-by: Heiko Schocher hs@denx.de --- clean travis build, see: https://travis-ci.org/hsdenx/u-boot-test/builds/537359339
Changes in v2: - reworded commit subject and commit message as Fabio recommended
Makefile | 4 ++++ arch/arm/mach-imx/Makefile | 11 ++++++++++- 2 files changed, 14 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 059978bfe6..8c05e5cff1 100644 --- a/Makefile +++ b/Makefile @@ -1077,6 +1077,10 @@ endif
u-boot.bin: u-boot-fit-dtb.bin FORCE $(call if_changed,copy) + +u-boot-dtb.bin: u-boot-nodtb.bin dts/dt.dtb FORCE + $(call if_changed,cat) + else ifeq ($(CONFIG_OF_SEPARATE),y) u-boot-dtb.bin: u-boot-nodtb.bin dts/dt.dtb FORCE $(call if_changed,cat) diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 37675d0558..3a65bd5b28 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -126,7 +126,16 @@ u-boot.imx: u-boot.bin u-boot.cfgout $(PLUGIN).bin FORCE $(call if_changed,mkimage) $(BOARD_SIZE_CHECK)
-ifeq ($(CONFIG_OF_SEPARATE),y) +ifeq ($(CONFIG_MULTI_DTB_FIT),y) +MKIMAGEFLAGS_u-boot-dtb.imx = -n $(filter-out $(PLUGIN).bin $< $(PHONY),$^) \ + -T $(IMAGE_TYPE) -e $(CONFIG_SYS_TEXT_BASE) +u-boot-dtb.imx: MKIMAGEOUTPUT = u-boot-dtb.imx.log + +u-boot-dtb.imx: u-boot-fit-dtb.bin u-boot-dtb.cfgout $(PLUGIN).bin FORCE +ifeq ($(DEPFILE_EXISTS),0) + $(call if_changed,mkimage) +endif +else ifeq ($(CONFIG_OF_SEPARATE),y) MKIMAGEFLAGS_u-boot-dtb.imx = -n $(filter-out $(PLUGIN).bin $< $(PHONY),$^) \ -T $(IMAGE_TYPE) -e $(CONFIG_SYS_TEXT_BASE) u-boot-dtb.imx: MKIMAGEOUTPUT = u-boot-dtb.imx.log
in case CONFIG_MULTI_DTB_FIT is set and u-boot-dtb.imx image is build, currently u-boot-dtb.bin is used for generating the u-boot-dtb.imx binary, which is wrong, as it contains only a dtb blob not the fit.blob Use instead the u-boot-fit-dtb.bin for generating u-boot-dtb.imx which contains the fit.blob. Signed-off-by: Heiko Schocher hs@denx.de
Best regards, Stefano Babic
Heiko Schocher
sbabic@denx.de
