[U-Boot] [PATCH 1/2] Kconfig: Migrate CONFIG_BUILD_TARGET
Migrate CONFIG_BUILD_TARGET into Kconfig.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Kconfig | 13 +++++++++++++ README | 7 ------- arch/arm/mach-mvebu/include/mach/config.h | 5 ----- configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/sheevaplug_defconfig | 1 + include/configs/SBx81LIFKW.h | 1 - include/configs/SBx81LIFXCAT.h | 1 - include/configs/ib62x0.h | 3 --- include/configs/mv-plug-common.h | 3 --- include/configs/nsa310s.h | 3 --- include/configs/rcar-gen3-common.h | 1 - include/configs/socfpga_common.h | 3 --- include/configs/sunxi-common.h | 1 - scripts/config_whitelist.txt | 1 - 20 files changed, 21 insertions(+), 29 deletions(-)
diff --git a/Kconfig b/Kconfig index aff7b2e00a..3a3a8d4d5b 100644 --- a/Kconfig +++ b/Kconfig @@ -224,6 +224,19 @@ config BUILD_ROM which are not shipped in the U-Boot source tree. Please, see doc/README.x86 for details.
+config BUILD_TARGET + string "Build target special images" + default "u-boot-with-spl.sfp" if ARCH_SOCFPGA + default "u-boot-spl.kwb" if ARCH_MVEBU && SPL_BUILD + default "u-boot-elf.srec" if RCAR_GEN3 + default "u-boot.itb" if ARCH_SUNXI && ARM64 + help + Some SoCs need special image types (e.g. U-Boot binary + with a special header) as build targets. By defining + CONFIG_BUILD_TARGET in the SoC / board header, this + special image will be automatically built upon calling + make / buildman. + endmenu # General setup
menu "Boot images" diff --git a/README b/README index 17d56b8034..01ad69e926 100644 --- a/README +++ b/README @@ -1998,13 +1998,6 @@ The following options need to be configured: 200 ms.
- Configuration Management: - CONFIG_BUILD_TARGET - - Some SoCs need special image types (e.g. U-Boot binary - with a special header) as build targets. By defining - CONFIG_BUILD_TARGET in the SoC / board header, this - special image will be automatically built upon calling - make / buildman.
CONFIG_IDENT_STRING
diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index f165d10018..e3235fc67e 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -40,11 +40,6 @@ #define CONFIG_SYS_KWD_CONFIG arch/arm/mach-mvebu/kwbimage.cfg #endif /* CONFIG_SYS_KWD_CONFIG */
-/* Add target to build it automatically upon "make" */ -#ifdef CONFIG_SPL -#define CONFIG_BUILD_TARGET "u-boot-spl.kwb" -#endif - /* end of 16M scrubbed by training in bootrom */ #define CONFIG_SYS_INIT_SP_ADDR 0x00FF0000
diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index e0ce1595c5..52bb70ae8c 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SBx81LIFKW=y CONFIG_IDENT_STRING="\nSBx81LIFKW" # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_MISC_INIT_R=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 4a6e05844f..b322ab0959 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SBx81LIFXCAT=y CONFIG_IDENT_STRING="\nSBx81LIFXCAT" # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_MISC_INIT_R=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index d3263cf9cd..762521f97d 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING="\nMarvell-DreamPlug" CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 352403e573..b72174eada 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_DS109=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_HUSH_PARSER=y +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 9998e48ab9..7726f9a769 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING="\nMarvell-GuruPlug" CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 985d85e027..03987a4ff1 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_IB62X0=y CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ib62x0 => " diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index eb29a70157..971d33b33d 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NSA310S=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="nsa310s => " diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 04b00cdea9..33cced9c48 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -7,6 +7,7 @@ CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index 07b65f89f9..d62fd35e81 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -13,7 +13,6 @@ #define CONFIG_KW88F6281 1 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg -#define CONFIG_BUILD_TARGET "u-boot.kwb"
/* additions for new ARM relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index d73752c7f9..3c8c216d89 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -13,7 +13,6 @@ #define CONFIG_KW88F6281 1 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg -#define CONFIG_BUILD_TARGET "u-boot.kwb"
/* additions for new ARM relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index f8d3c3b63f..5e54441c73 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -15,9 +15,6 @@ #define CONFIG_KW88F6281 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
-/* Add target to build it automatically upon "make" */ -#define CONFIG_BUILD_TARGET "u-boot.kwb" - /* * Compression configuration */ diff --git a/include/configs/mv-plug-common.h b/include/configs/mv-plug-common.h index f424e2cc6c..486650f183 100644 --- a/include/configs/mv-plug-common.h +++ b/include/configs/mv-plug-common.h @@ -13,9 +13,6 @@ #define CONFIG_KW88F6281 1 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
-/* Add target to build it automatically upon "make" */ -#define CONFIG_BUILD_TARGET "u-boot.kwb" - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 1ca9a01754..eb465e0690 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -15,9 +15,6 @@ #define CONFIG_KW88F6702 1 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
-/* add target to build it automatically upon "make" */ -#define CONFIG_BUILD_TARGET "u-boot.kwb" - /* compression configuration */ #define CONFIG_BZIP2
diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 6c2fa6a63c..06d5d3219c 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -12,7 +12,6 @@ #include <asm/arch/rmobile.h>
#define CONFIG_REMAKE_ELF -#define CONFIG_BUILD_TARGET "u-boot-elf.srec"
/* boot option */
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bd8f5c8c41..d3dd2eabac 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -14,9 +14,6 @@
#define CONFIG_TIMESTAMP /* Print image info with timestamp */
-/* add target to build it automatically upon "make" */ -#define CONFIG_BUILD_TARGET "u-boot-with-spl.sfp" - /* * Memory configurations */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 9819d9980c..f0c8daad72 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -32,7 +32,6 @@ #endif
#ifdef CONFIG_ARM64 -#define CONFIG_BUILD_TARGET "u-boot.itb" #define CONFIG_SYS_BOOTM_LEN (32 << 20) #endif
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 527050de97..17c4b482c7 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -181,7 +181,6 @@ CONFIG_BS_SIZE CONFIG_BTB CONFIG_BUFNO_AUTO_INCR_BIT CONFIG_BUILD_ENVCRC -CONFIG_BUILD_TARGET CONFIG_BUS_WIDTH CONFIG_BZIP2 CONFIG_CADDY2
Thanks, Stefan
default "u-boot.kwb" if KIRKWOOD would also be good to add. I can do it if you don't send a v2.
+ help
make / buildman.
CONFIG_BUILD_TARGET
make / buildman. CONFIG_IDENT_STRING
- Compression configuration
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
/* boot option */
- Memory configurations
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 527050de97..17c4b482c7 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -181,7 +181,6 @@ CONFIG_BS_SIZE CONFIG_BTB CONFIG_BUFNO_AUTO_INCR_BIT CONFIG_BUILD_ENVCRC -CONFIG_BUILD_TARGET CONFIG_BUS_WIDTH CONFIG_BZIP2 CONFIG_CADDY2 -- 2.18.0.321.gffc6fa0e3
On Fri, Jan 18, 2019 at 12:18 PM Chris Packham judge.packham@gmail.com wrote:
Is it new change, if yes prepare another patch? if not let me know where do we need to change I mean which ARCH in above definition.
Yeah it'd be new to this Kconfig but it would have saved you having to update some of the defconfigs. Since you've already done the defconfig changes I can send a patch on top of this that adds a default and removes some of the defconfig changes.
Chris Packham
Jagan Teki
Stefan Roese
