[U-Boot] [PATCH] powerpc: Fix CamelCase checkpatch warning in DDR related code
Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h has various parameters with camelcase naming conventions due to which code checkpatch script generates "WARNING: Avoid CamelCase".
Convert those variable names to smallcase naming convention and modify all files which are using these structures with modified structures.
Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- .../powerpc/cpu/mpc8xxx/ddr/common_timing_params.h | 46 ++-- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 62 ++-- arch/powerpc/cpu/mpc8xxx/ddr/ddr.h | 2 +- arch/powerpc/cpu/mpc8xxx/ddr/ddr1_dimm_params.c | 52 ++-- arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c | 52 ++-- arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c | 54 ++-- arch/powerpc/cpu/mpc8xxx/ddr/interactive.c | 304 ++++++++++---------- .../cpu/mpc8xxx/ddr/lc_common_dimm_params.c | 214 +++++++------- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 6 +- arch/powerpc/cpu/mpc8xxx/ddr/options.c | 30 +- arch/powerpc/include/asm/fsl_ddr_dimm_params.h | 48 ++-- arch/powerpc/include/asm/fsl_ddr_sdram.h | 24 +- arch/powerpc/include/asm/immap_512x.h | 4 +- board/freescale/b4860qds/ddr.c | 26 +- board/freescale/bsc9131rdb/ddr.c | 26 +- board/freescale/bsc9132qds/ddr.c | 26 +- board/freescale/c29xpcie/ddr.c | 26 +- board/freescale/mpc8349emds/ddr.c | 2 +- board/freescale/p1010rdb/ddr.c | 26 +- board/freescale/p1023rdb/ddr.c | 26 +- board/freescale/p1_p2_rdb_pc/ddr.c | 130 +++++----- include/ddr_spd.h | 56 ++-- 22 files changed, 622 insertions(+), 620 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/common_timing_params.h b/arch/powerpc/cpu/mpc8xxx/ddr/common_timing_params.h index 06706ed..17d8d9f 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/common_timing_params.h +++ b/arch/powerpc/cpu/mpc8xxx/ddr/common_timing_params.h @@ -12,39 +12,39 @@ typedef struct { /* parameters to constrict */
- unsigned int tCKmin_X_ps; - unsigned int tCKmax_ps; - unsigned int tCKmax_max_ps; - unsigned int tRCD_ps; - unsigned int tRP_ps; - unsigned int tRAS_ps; - - unsigned int tWR_ps; /* maximum = 63750 ps */ - unsigned int tWTR_ps; /* maximum = 63750 ps */ - unsigned int tRFC_ps; /* maximum = 255 ns + 256 ns + .75 ns + unsigned int tckmin_x_ps; + unsigned int tckmax_ps; + unsigned int tckmax_max_ps; + unsigned int trcd_ps; + unsigned int trp_ps; + unsigned int tras_ps; + + unsigned int twr_ps; /* maximum = 63750 ps */ + unsigned int twtr_ps; /* maximum = 63750 ps */ + unsigned int trfc_ps; /* maximum = 255 ns + 256 ns + .75 ns = 511750 ps */
- unsigned int tRRD_ps; /* maximum = 63750 ps */ - unsigned int tRC_ps; /* maximum = 254 ns + .75 ns = 254750 ps */ + unsigned int trrd_ps; /* maximum = 63750 ps */ + unsigned int trc_ps; /* maximum = 254 ns + .75 ns = 254750 ps */
unsigned int refresh_rate_ps;
- unsigned int tIS_ps; /* byte 32, spd->ca_setup */ - unsigned int tIH_ps; /* byte 33, spd->ca_hold */ - unsigned int tDS_ps; /* byte 34, spd->data_setup */ - unsigned int tDH_ps; /* byte 35, spd->data_hold */ - unsigned int tRTP_ps; /* byte 38, spd->trtp */ - unsigned int tDQSQ_max_ps; /* byte 44, spd->tdqsq */ - unsigned int tQHS_ps; /* byte 45, spd->tqhs */ + unsigned int tis_ps; /* byte 32, spd->ca_setup */ + unsigned int tih_ps; /* byte 33, spd->ca_hold */ + unsigned int tds_ps; /* byte 34, spd->data_setup */ + unsigned int tdh_ps; /* byte 35, spd->data_hold */ + unsigned int trtp_ps; /* byte 38, spd->trtp */ + unsigned int tdqsq_max_ps; /* byte 44, spd->tdqsq */ + unsigned int tqhs_ps; /* byte 45, spd->tqhs */
unsigned int ndimms_present; unsigned int lowest_common_SPD_caslat; unsigned int highest_common_derated_caslat; unsigned int additive_latency; - unsigned int all_DIMMs_burst_lengths_bitmask; - unsigned int all_DIMMs_registered; - unsigned int all_DIMMs_unbuffered; - unsigned int all_DIMMs_ECC_capable; + unsigned int all_dimms_burst_lengths_bitmask; + unsigned int all_dimms_registered; + unsigned int all_dimms_unbuffered; + unsigned int all_dimms_ecc_capable;
unsigned long long total_mem; unsigned long long base_address; diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c index 242eb47..c8c9ea2 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -353,14 +353,14 @@ static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr, /* Control Adjust */ unsigned int cntl_adj = 0;
- ext_pretoact = picos_to_mclk(common_dimm->tRP_ps) >> 4; - ext_acttopre = picos_to_mclk(common_dimm->tRAS_ps) >> 4; - ext_acttorw = picos_to_mclk(common_dimm->tRCD_ps) >> 4; + ext_pretoact = picos_to_mclk(common_dimm->trp_ps) >> 4; + ext_acttopre = picos_to_mclk(common_dimm->tras_ps) >> 4; + ext_acttorw = picos_to_mclk(common_dimm->trcd_ps) >> 4; ext_caslat = (2 * cas_latency - 1) >> 4; - ext_refrec = (picos_to_mclk(common_dimm->tRFC_ps) - 8) >> 4; + ext_refrec = (picos_to_mclk(common_dimm->trfc_ps) - 8) >> 4; /* ext_wrrec only deals with 16 clock and above, or 14 with OTF */ - ext_wrrec = (picos_to_mclk(common_dimm->tWR_ps) + - (popts->OTF_burst_chop_en ? 2 : 0)) >> 4; + ext_wrrec = (picos_to_mclk(common_dimm->twr_ps) + + (popts->otf_burst_chop_en ? 2 : 0)) >> 4;
ddr->timing_cfg_3 = (0 | ((ext_pretoact & 0x1) << 28) @@ -400,9 +400,9 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, static const u8 wrrec_table[] = { 1, 2, 3, 4, 5, 6, 7, 8, 10, 10, 12, 12, 14, 14, 0, 0};
- pretoact_mclk = picos_to_mclk(common_dimm->tRP_ps); - acttopre_mclk = picos_to_mclk(common_dimm->tRAS_ps); - acttorw_mclk = picos_to_mclk(common_dimm->tRCD_ps); + pretoact_mclk = picos_to_mclk(common_dimm->trp_ps); + acttopre_mclk = picos_to_mclk(common_dimm->tras_ps); + acttorw_mclk = picos_to_mclk(common_dimm->trcd_ps);
/* * Translate CAS Latency to a DDR controller field value: @@ -433,17 +433,17 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, caslat_ctrl = 2 * cas_latency - 1; #endif
- refrec_ctrl = picos_to_mclk(common_dimm->tRFC_ps) - 8; - wrrec_mclk = picos_to_mclk(common_dimm->tWR_ps); + refrec_ctrl = picos_to_mclk(common_dimm->trfc_ps) - 8; + wrrec_mclk = picos_to_mclk(common_dimm->twr_ps);
if (wrrec_mclk > 16) printf("Error: WRREC doesn't support more than 16 clocks\n"); else wrrec_mclk = wrrec_table[wrrec_mclk - 1]; - if (popts->OTF_burst_chop_en) + if (popts->otf_burst_chop_en) wrrec_mclk += 2;
- acttoact_mclk = picos_to_mclk(common_dimm->tRRD_ps); + acttoact_mclk = picos_to_mclk(common_dimm->trrd_ps); /* * JEDEC has min requirement for tRRD */ @@ -451,7 +451,7 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, if (acttoact_mclk < 4) acttoact_mclk = 4; #endif - wrtord_mclk = picos_to_mclk(common_dimm->tWTR_ps); + wrtord_mclk = picos_to_mclk(common_dimm->twtr_ps); /* * JEDEC has some min requirements for tWTR */ @@ -462,7 +462,7 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, if (wrtord_mclk < 4) wrtord_mclk = 4; #endif - if (popts->OTF_burst_chop_en) + if (popts->otf_burst_chop_en) wrtord_mclk += 2;
ddr->timing_cfg_1 = (0 @@ -518,7 +518,7 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, wr_lat = compute_cas_write_latency(); #endif
- rd_to_pre = picos_to_mclk(common_dimm->tRTP_ps); + rd_to_pre = picos_to_mclk(common_dimm->trtp_ps); /* * JEDEC has some min requirements for tRTP */ @@ -531,12 +531,12 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, #endif if (additive_latency) rd_to_pre += additive_latency; - if (popts->OTF_burst_chop_en) + if (popts->otf_burst_chop_en) rd_to_pre += 2; /* according to UM */
wr_data_delay = popts->write_data_delay; - cke_pls = picos_to_mclk(popts->tCKE_clock_pulse_width_ps); - four_act = picos_to_mclk(popts->tFAW_window_four_activates_ps); + cke_pls = picos_to_mclk(popts->tcke_clock_pulse_width_ps); + four_act = picos_to_mclk(popts->tfaw_window_four_activates_ps);
ddr->timing_cfg_2 = (0 | ((add_lat_mclk & 0xf) << 28) @@ -555,8 +555,8 @@ static void set_ddr_sdram_rcw(fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm) { - if (common_dimm->all_DIMMs_registered - && !common_dimm->all_DIMMs_unbuffered) { + if (common_dimm->all_dimms_registered && + !common_dimm->all_dimms_unbuffered) { if (popts->rcw_override) { ddr->ddr_sdram_rcw_1 = popts->rcw_1; ddr->ddr_sdram_rcw_2 = popts->rcw_2; @@ -610,15 +610,15 @@ static void set_ddr_sdram_cfg(fsl_ddr_cfg_regs_t *ddr,
mem_en = 1; sren = popts->self_refresh_in_sleep; - if (common_dimm->all_DIMMs_ECC_capable) { + if (common_dimm->all_dimms_ecc_capable) { /* Allow setting of ECC only if all DIMMs are ECC. */ - ecc_en = popts->ECC_mode; + ecc_en = popts->ecc_mode; } else { ecc_en = 0; }
- if (common_dimm->all_DIMMs_registered - && !common_dimm->all_DIMMs_unbuffered) { + if (common_dimm->all_dimms_registered && + !common_dimm->all_dimms_unbuffered) { rd_en = 1; twoT_en = 0; } else { @@ -691,7 +691,7 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, int i;
dll_rst_dis = 1; /* Make this configurable */ - dqs_cfg = popts->DQS_config; + dqs_cfg = popts->dqs_config; for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { if (popts->cs_local_opts[i].odt_rd_cfg || popts->cs_local_opts[i].odt_wr_cfg) { @@ -710,7 +710,7 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, * << DDR_SDRAM_INTERVAL[REFINT] */ #if defined(CONFIG_FSL_DDR3) - obc_cfg = popts->OTF_burst_chop_en; + obc_cfg = popts->otf_burst_chop_en; #else obc_cfg = 0; #endif @@ -730,7 +730,7 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr,
#if defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) /* Use the DDR controller to auto initialize memory. */ - d_init = popts->ECC_init_using_memctl; + d_init = popts->ecc_init_using_memctl; ddr->ddr_data_init = CONFIG_MEM_INIT_VALUE; debug("DDR: ddr_data_init = 0x%08x\n", ddr->ddr_data_init); #else @@ -939,7 +939,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, */ dll_on = 1;
- wr_mclk = (common_dimm->tWR_ps + mclk_ps - 1) / mclk_ps; + wr_mclk = (common_dimm->twr_ps + mclk_ps - 1) / mclk_ps; if (wr_mclk <= 16) { wr = wr_table[wr_mclk - 5]; } else { @@ -1101,7 +1101,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, #if defined(CONFIG_FSL_DDR2) const unsigned int mclk_ps = get_memory_clk_period_ps(); #endif - dqs_en = !popts->DQS_config; + dqs_en = !popts->dqs_config; rtt = fsl_ddr_get_rtt();
al = additive_latency; @@ -1130,7 +1130,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, #if defined(CONFIG_FSL_DDR1) wr = 0; /* Historical */ #elif defined(CONFIG_FSL_DDR2) - wr = (common_dimm->tWR_ps + mclk_ps - 1) / mclk_ps - 1; + wr = (common_dimm->twr_ps + mclk_ps - 1) / mclk_ps - 1; #endif dll_res = 0; mode = 0; diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h b/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h index c173a5a..e3b414e 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h @@ -72,7 +72,7 @@ unsigned int compute_lowest_common_dimm_parameters( const dimm_params_t *dimm_params, common_timing_params_t *outpdimm, unsigned int number_of_dimms); -unsigned int populate_memctl_options(int all_DIMMs_registered, +unsigned int populate_memctl_options(int all_dimms_registered, memctl_options_t *popts, dimm_params_t *pdimm, unsigned int ctrl_num); diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr1_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/ddr1_dimm_params.c index 376be2f..f137fce 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr1_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr1_dimm_params.c @@ -287,57 +287,57 @@ ddr_compute_dimm_parameters(const ddr1_spd_eeprom_t *spd, * The SPD clk_cycle field (tCKmin) is measured in tenths of * nanoseconds and represented as BCD. */ - pdimm->tCKmin_X_ps + pdimm->tckmin_x_ps = convert_bcd_tenths_to_cycle_time_ps(spd->clk_cycle); - pdimm->tCKmin_X_minus_1_ps + pdimm->tckmin_x_minus_1_ps = convert_bcd_tenths_to_cycle_time_ps(spd->clk_cycle2); - pdimm->tCKmin_X_minus_2_ps + pdimm->tckmin_x_minus_2_ps = convert_bcd_tenths_to_cycle_time_ps(spd->clk_cycle3);
- pdimm->tCKmax_ps = compute_tckmax_from_spd_ps(spd->tckmax); + pdimm->tckmax_ps = compute_tckmax_from_spd_ps(spd->tckmax);
/* * Compute CAS latencies defined by SPD - * The SPD caslat_X should have at least 1 and at most 3 bits set. + * The SPD caslat_x should have at least 1 and at most 3 bits set. * * If cas_lat after masking is 0, the __ilog2 function returns * 255 into the variable. This behavior is abused once. */ - pdimm->caslat_X = __ilog2(spd->cas_lat); - pdimm->caslat_X_minus_1 = __ilog2(spd->cas_lat - & ~(1 << pdimm->caslat_X)); - pdimm->caslat_X_minus_2 = __ilog2(spd->cas_lat - & ~(1 << pdimm->caslat_X) - & ~(1 << pdimm->caslat_X_minus_1)); + pdimm->caslat_x = __ilog2(spd->cas_lat); + pdimm->caslat_x_minus_1 = __ilog2(spd->cas_lat + & ~(1 << pdimm->caslat_x)); + pdimm->caslat_x_minus_2 = __ilog2(spd->cas_lat + & ~(1 << pdimm->caslat_x) + & ~(1 << pdimm->caslat_x_minus_1));
/* Compute CAS latencies below that defined by SPD */ pdimm->caslat_lowest_derated = compute_derated_DDR1_CAS_latency(get_memory_clk_period_ps());
/* Compute timing parameters */ - pdimm->tRCD_ps = spd->trcd * 250; - pdimm->tRP_ps = spd->trp * 250; - pdimm->tRAS_ps = spd->tras * 1000; + pdimm->trcd_ps = spd->trcd * 250; + pdimm->trp_ps = spd->trp * 250; + pdimm->tras_ps = spd->tras * 1000;
- pdimm->tWR_ps = mclk_to_picos(3); - pdimm->tWTR_ps = mclk_to_picos(1); - pdimm->tRFC_ps = compute_trfc_ps_from_spd(0, spd->trfc); + pdimm->twr_ps = mclk_to_picos(3); + pdimm->twtr_ps = mclk_to_picos(1); + pdimm->trfc_ps = compute_trfc_ps_from_spd(0, spd->trfc);
- pdimm->tRRD_ps = spd->trrd * 250; - pdimm->tRC_ps = compute_trc_ps_from_spd(0, spd->trc); + pdimm->trrd_ps = spd->trrd * 250; + pdimm->trc_ps = compute_trc_ps_from_spd(0, spd->trc);
pdimm->refresh_rate_ps = determine_refresh_rate_ps(spd->refresh);
- pdimm->tIS_ps = convert_bcd_hundredths_to_cycle_time_ps(spd->ca_setup); - pdimm->tIH_ps = convert_bcd_hundredths_to_cycle_time_ps(spd->ca_hold); - pdimm->tDS_ps + pdimm->tis_ps = convert_bcd_hundredths_to_cycle_time_ps(spd->ca_setup); + pdimm->tih_ps = convert_bcd_hundredths_to_cycle_time_ps(spd->ca_hold); + pdimm->tds_ps = convert_bcd_hundredths_to_cycle_time_ps(spd->data_setup); - pdimm->tDH_ps + pdimm->tdh_ps = convert_bcd_hundredths_to_cycle_time_ps(spd->data_hold);
- pdimm->tRTP_ps = mclk_to_picos(2); /* By the book. */ - pdimm->tDQSQ_max_ps = spd->tdqsq * 10; - pdimm->tQHS_ps = spd->tqhs * 10; + pdimm->trtp_ps = mclk_to_picos(2); /* By the book. */ + pdimm->tdqsq_max_ps = spd->tdqsq * 10; + pdimm->tqhs_ps = spd->tqhs * 10;
return 0; } diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c index f637f3d..e4d02e8 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c @@ -286,57 +286,57 @@ ddr_compute_dimm_parameters(const ddr2_spd_eeprom_t *spd, * The SPD clk_cycle field (tCKmin) is measured in tenths of * nanoseconds and represented as BCD. */ - pdimm->tCKmin_X_ps + pdimm->tckmin_x_ps = convert_bcd_tenths_to_cycle_time_ps(spd->clk_cycle); - pdimm->tCKmin_X_minus_1_ps + pdimm->tckmin_x_minus_1_ps = convert_bcd_tenths_to_cycle_time_ps(spd->clk_cycle2); - pdimm->tCKmin_X_minus_2_ps + pdimm->tckmin_x_minus_2_ps = convert_bcd_tenths_to_cycle_time_ps(spd->clk_cycle3);
- pdimm->tCKmax_ps = convert_bcd_tenths_to_cycle_time_ps(spd->tckmax); + pdimm->tckmax_ps = convert_bcd_tenths_to_cycle_time_ps(spd->tckmax);
/* Compute CAS latencies below that defined by SPD */ pdimm->caslat_lowest_derated = compute_derated_DDR2_CAS_latency(get_memory_clk_period_ps());
- pdimm->tWR_ps = spd->twr * 250; - pdimm->tWTR_ps = spd->twtr * 250; - pdimm->tRFC_ps = compute_trfc_ps_from_spd(spd->trctrfc_ext, spd->trfc); + pdimm->twr_ps = spd->twr * 250; + pdimm->twtr_ps = spd->twtr * 250; + pdimm->trfc_ps = compute_trfc_ps_from_spd(spd->trctrfc_ext, spd->trfc);
- pdimm->tRRD_ps = spd->trrd * 250; - pdimm->tRC_ps = compute_trc_ps_from_spd(spd->trctrfc_ext, spd->trc); + pdimm->trrd_ps = spd->trrd * 250; + pdimm->trc_ps = compute_trc_ps_from_spd(spd->trctrfc_ext, spd->trc);
- pdimm->tRTP_ps = spd->trtp * 250; - pdimm->tDQSQ_max_ps = spd->tdqsq * 10; - pdimm->tQHS_ps = spd->tqhs * 10; + pdimm->trtp_ps = spd->trtp * 250; + pdimm->tdqsq_max_ps = spd->tdqsq * 10; + pdimm->tqhs_ps = spd->tqhs * 10;
return 0; } diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c index b67158c..d82eb67 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c @@ -210,12 +210,12 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, * sdram minimum cycle time * we assume the MTB is 0.125ns * eg: - * tCK_min=15 MTB (1.875ns) ->DDR3-1066 + * tck_min=15 MTB (1.875ns) ->DDR3-1066 * =12 MTB (1.5ns) ->DDR3-1333 * =10 MTB (1.25ns) ->DDR3-1600 */ - pdimm->tCKmin_X_ps = spd->tCK_min * mtb_ps + - (spd->fine_tCK_min * ftb_10th_ps) / 10; + pdimm->tckmin_x_ps = spd->tck_min * mtb_ps + + (spd->fine_tck_min * ftb_10th_ps) / 10;
/* * CAS latency supported @@ -223,55 +223,55 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, * bit5 - CL5 * bit18 - CL18 */ - pdimm->caslat_X = ((spd->caslat_msb << 8) | spd->caslat_lsb) << 4; + pdimm->caslat_x = ((spd->caslat_msb << 8) | spd->caslat_lsb) << 4;
/* * min CAS latency time - * eg: tAA_min = + * eg: taa_min = * DDR3-800D 100 MTB (12.5ns) * DDR3-1066F 105 MTB (13.125ns) * DDR3-1333H 108 MTB (13.5ns) * DDR3-1600H 90 MTB (11.25ns) */ - pdimm->tAA_ps = spd->tAA_min * mtb_ps + - (spd->fine_tAA_min * ftb_10th_ps) / 10; + pdimm->taa_ps = spd->taa_min * mtb_ps + + (spd->fine_taa_min * ftb_10th_ps) / 10;
/* * min write recovery time * eg: - * tWR_min = 120 MTB (15ns) -> all speed grades. + * twr_min = 120 MTB (15ns) -> all speed grades. */ - pdimm->tWR_ps = spd->tWR_min * mtb_ps; + pdimm->twr_ps = spd->twr_min * mtb_ps;
/* * min RAS to CAS delay time - * eg: tRCD_min = + * eg: trcd_min = * DDR3-800 100 MTB (12.5ns) * DDR3-1066F 105 MTB (13.125ns) * DDR3-1333H 108 MTB (13.5ns) * DDR3-1600H 90 MTB (11.25) */ - pdimm->tRCD_ps = spd->tRCD_min * mtb_ps + - (spd->fine_tRCD_min * ftb_10th_ps) / 10; + pdimm->trcd_ps = spd->trcd_min * mtb_ps + + (spd->fine_trcd_min * ftb_10th_ps) / 10;
/* * min row active to row active delay time - * eg: tRRD_min = + * eg: trrd_min = * DDR3-800(1KB page) 80 MTB (10ns) * DDR3-1333(1KB page) 48 MTB (6ns) */ - pdimm->tRRD_ps = spd->tRRD_min * mtb_ps; + pdimm->trrd_ps = spd->trrd_min * mtb_ps;
/* * min row precharge delay time - * eg: tRP_min = + * eg: trp_min = * DDR3-800D 100 MTB (12.5ns) * DDR3-1066F 105 MTB (13.125ns) * DDR3-1333H 108 MTB (13.5ns) * DDR3-1600H 90 MTB (11.25ns) */ - pdimm->tRP_ps = spd->tRP_min * mtb_ps + - (spd->fine_tRP_min * ftb_10th_ps) / 10; + pdimm->trp_ps = spd->trp_min * mtb_ps + + (spd->fine_trp_min * ftb_10th_ps) / 10;
/* min active to precharge delay time * eg: tRAS_min = @@ -280,7 +280,7 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, * DDR3-1333H 288 MTB (36ns) * DDR3-1600H 280 MTB (35ns) */ - pdimm->tRAS_ps = (((spd->tRAS_tRC_ext & 0xf) << 8) | spd->tRAS_min_lsb) + pdimm->tras_ps = (((spd->tras_trc_ext & 0xf) << 8) | spd->tras_min_lsb) * mtb_ps; /* * min active to actice/refresh delay time @@ -290,8 +290,8 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, * DDR3-1333H 396 MTB (49.5ns) * DDR3-1600H 370 MTB (46.25ns) */ - pdimm->tRC_ps = (((spd->tRAS_tRC_ext & 0xf0) << 4) | spd->tRC_min_lsb) - * mtb_ps + (spd->fine_tRC_min * ftb_10th_ps) / 10; + pdimm->trc_ps = (((spd->tras_trc_ext & 0xf0) << 4) | spd->trc_min_lsb) + * mtb_ps + (spd->fine_trc_min * ftb_10th_ps) / 10; /* * min refresh recovery delay time * eg: tRFC_min = @@ -299,21 +299,21 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, * 1Gb 880 MTB (110ns) * 2Gb 1280 MTB (160ns) */ - pdimm->tRFC_ps = ((spd->tRFC_min_msb << 8) | spd->tRFC_min_lsb) + pdimm->trfc_ps = ((spd->trfc_min_msb << 8) | spd->trfc_min_lsb) * mtb_ps; /* * min internal write to read command delay time - * eg: tWTR_min = 40 MTB (7.5ns) - all speed bins. + * eg: twtr_min = 40 MTB (7.5ns) - all speed bins. * tWRT is at least 4 mclk independent of operating freq. */ - pdimm->tWTR_ps = spd->tWTR_min * mtb_ps; + pdimm->twtr_ps = spd->twtr_min * mtb_ps;
/* * min internal read to precharge command delay time - * eg: tRTP_min = 40 MTB (7.5ns) - all speed bins. + * eg: trtp_min = 40 MTB (7.5ns) - all speed bins. * tRTP is at least 4 mclk independent of operating freq. */ - pdimm->tRTP_ps = spd->tRTP_min * mtb_ps; + pdimm->trtp_ps = spd->trtp_min * mtb_ps;
/* * Average periodic refresh interval @@ -324,13 +324,13 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd,
/* * min four active window delay time - * eg: tFAW_min = + * eg: tfaw_min = * DDR3-800(1KB page) 320 MTB (40ns) * DDR3-1066(1KB page) 300 MTB (37.5ns) * DDR3-1333(1KB page) 240 MTB (30ns) * DDR3-1600(1KB page) 240 MTB (30ns) */ - pdimm->tFAW_ps = (((spd->tFAW_msb & 0xf) << 8) | spd->tFAW_min) + pdimm->tfaw_ps = (((spd->tfaw_msb & 0xf) << 8) | spd->tfaw_min) * mtb_ps;
return 0; diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c b/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c index 260fce5..a152d19 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c @@ -150,33 +150,33 @@ static void lowest_common_dimm_parameters_edit(fsl_ddr_info_t *pinfo, common_timing_params_t *p = &pinfo->common_timing_params[ctrl_num];
static const struct options_string options[] = { - COMMON_TIMING(tCKmin_X_ps), - COMMON_TIMING(tCKmax_ps), - COMMON_TIMING(tCKmax_max_ps), - COMMON_TIMING(tRCD_ps), - COMMON_TIMING(tRP_ps), - COMMON_TIMING(tRAS_ps), - COMMON_TIMING(tWR_ps), - COMMON_TIMING(tWTR_ps), - COMMON_TIMING(tRFC_ps), - COMMON_TIMING(tRRD_ps), - COMMON_TIMING(tRC_ps), + COMMON_TIMING(tckmin_x_ps), + COMMON_TIMING(tckmax_ps), + COMMON_TIMING(tckmax_max_ps), + COMMON_TIMING(trcd_ps), + COMMON_TIMING(trp_ps), + COMMON_TIMING(tras_ps), + COMMON_TIMING(twr_ps), + COMMON_TIMING(twtr_ps), + COMMON_TIMING(trfc_ps), + COMMON_TIMING(trrd_ps), + COMMON_TIMING(trc_ps), COMMON_TIMING(refresh_rate_ps), - COMMON_TIMING(tIS_ps), - COMMON_TIMING(tIH_ps), - COMMON_TIMING(tDS_ps), - COMMON_TIMING(tDH_ps), - COMMON_TIMING(tRTP_ps), - COMMON_TIMING(tDQSQ_max_ps), - COMMON_TIMING(tQHS_ps), + COMMON_TIMING(tis_ps), + COMMON_TIMING(tih_ps), + COMMON_TIMING(tds_ps), + COMMON_TIMING(tdh_ps), + COMMON_TIMING(trtp_ps), + COMMON_TIMING(tdqsq_max_ps), + COMMON_TIMING(tqhs_ps), COMMON_TIMING(ndimms_present), COMMON_TIMING(lowest_common_SPD_caslat), COMMON_TIMING(highest_common_derated_caslat), COMMON_TIMING(additive_latency), - COMMON_TIMING(all_DIMMs_burst_lengths_bitmask), - COMMON_TIMING(all_DIMMs_registered), - COMMON_TIMING(all_DIMMs_unbuffered), - COMMON_TIMING(all_DIMMs_ECC_capable), + COMMON_TIMING(all_dimms_burst_lengths_bitmask), + COMMON_TIMING(all_dimms_registered), + COMMON_TIMING(all_dimms_unbuffered), + COMMON_TIMING(all_dimms_ecc_capable), COMMON_TIMING(total_mem), COMMON_TIMING(base_address), }; @@ -214,34 +214,34 @@ static void fsl_ddr_dimm_parameters_edit(fsl_ddr_info_t *pinfo, DIMM_PARM(burst_lengths_bitmask), DIMM_PARM(row_density),
- DIMM_PARM(tCKmin_X_ps), - DIMM_PARM(tCKmin_X_minus_1_ps), - DIMM_PARM(tCKmin_X_minus_2_ps), - DIMM_PARM(tCKmax_ps), + DIMM_PARM(tckmin_x_ps), + DIMM_PARM(tckmin_x_minus_1_ps), + DIMM_PARM(tckmin_x_minus_2_ps), + DIMM_PARM(tckmax_ps),
- DIMM_PARM(caslat_X), - DIMM_PARM(caslat_X_minus_1), - DIMM_PARM(caslat_X_minus_2), + DIMM_PARM(caslat_x), + DIMM_PARM(caslat_x_minus_1), + DIMM_PARM(caslat_x_minus_2),
DIMM_PARM(caslat_lowest_derated),
- DIMM_PARM(tRCD_ps), - DIMM_PARM(tRP_ps), - DIMM_PARM(tRAS_ps), - DIMM_PARM(tWR_ps), - DIMM_PARM(tWTR_ps), - DIMM_PARM(tRFC_ps), - DIMM_PARM(tRRD_ps), - DIMM_PARM(tRC_ps), + DIMM_PARM(trcd_ps), + DIMM_PARM(trp_ps), + DIMM_PARM(tras_ps), + DIMM_PARM(twr_ps), + DIMM_PARM(twtr_ps), + DIMM_PARM(trfc_ps), + DIMM_PARM(trrd_ps), + DIMM_PARM(trc_ps), DIMM_PARM(refresh_rate_ps),
- DIMM_PARM(tIS_ps), - DIMM_PARM(tIH_ps), - DIMM_PARM(tDS_ps), - DIMM_PARM(tDH_ps), - DIMM_PARM(tRTP_ps), - DIMM_PARM(tDQSQ_max_ps), - DIMM_PARM(tQHS_ps), + DIMM_PARM(tis_ps), + DIMM_PARM(tih_ps), + DIMM_PARM(tds_ps), + DIMM_PARM(tdh_ps), + DIMM_PARM(trtp_ps), + DIMM_PARM(tdqsq_max_ps), + DIMM_PARM(tqhs_ps),
DIMM_PARM(rank_density), DIMM_PARM(capacity), @@ -271,34 +271,34 @@ static void print_dimm_parameters(const dimm_params_t *pdimm) DIMM_PARM(edc_config), DIMM_PARM(n_banks_per_sdram_device),
- DIMM_PARM(caslat_X), - DIMM_PARM(tAA_ps), - DIMM_PARM(caslat_X_minus_1), - DIMM_PARM(caslat_X_minus_2), + DIMM_PARM(caslat_x), + DIMM_PARM(taa_ps), + DIMM_PARM(caslat_x_minus_1), + DIMM_PARM(caslat_x_minus_2), DIMM_PARM(caslat_lowest_derated),
- DIMM_PARM(tIS_ps), - DIMM_PARM(tIH_ps), - DIMM_PARM(tDS_ps), - DIMM_PARM(tDH_ps), - DIMM_PARM(tRTP_ps), - DIMM_PARM(tDQSQ_max_ps), - DIMM_PARM(tQHS_ps), + DIMM_PARM(tis_ps), + DIMM_PARM(tih_ps), + DIMM_PARM(tds_ps), + DIMM_PARM(tdh_ps), + DIMM_PARM(trtp_ps), + DIMM_PARM(tdqsq_max_ps), + DIMM_PARM(tqhs_ps), }; static const unsigned int n_opts = ARRAY_SIZE(options);
@@ -325,41 +325,41 @@ static void print_lowest_common_dimm_parameters( const common_timing_params_t *plcd_dimm_params) { static const struct options_string options[] = { - COMMON_TIMING(tCKmax_max_ps), - COMMON_TIMING(tRCD_ps), - COMMON_TIMING(tRP_ps), - COMMON_TIMING(tRAS_ps), - COMMON_TIMING(tWR_ps), - COMMON_TIMING(tWTR_ps), - COMMON_TIMING(tRFC_ps), - COMMON_TIMING(tRRD_ps), - COMMON_TIMING(tRC_ps), + COMMON_TIMING(tckmax_max_ps), + COMMON_TIMING(trcd_ps), + COMMON_TIMING(trp_ps), + COMMON_TIMING(tras_ps), + COMMON_TIMING(twr_ps), + COMMON_TIMING(twtr_ps), + COMMON_TIMING(trfc_ps), + COMMON_TIMING(trrd_ps), + COMMON_TIMING(trc_ps), COMMON_TIMING(refresh_rate_ps), - COMMON_TIMING(tIS_ps), - COMMON_TIMING(tDS_ps), - COMMON_TIMING(tDH_ps), - COMMON_TIMING(tRTP_ps), - COMMON_TIMING(tDQSQ_max_ps), - COMMON_TIMING(tQHS_ps), + COMMON_TIMING(tis_ps), + COMMON_TIMING(tds_ps), + COMMON_TIMING(tdh_ps), + COMMON_TIMING(trtp_ps), + COMMON_TIMING(tdqsq_max_ps), + COMMON_TIMING(tqhs_ps), COMMON_TIMING(lowest_common_SPD_caslat), COMMON_TIMING(highest_common_derated_caslat), COMMON_TIMING(additive_latency), COMMON_TIMING(ndimms_present), - COMMON_TIMING(all_DIMMs_registered), - COMMON_TIMING(all_DIMMs_unbuffered), - COMMON_TIMING(all_DIMMs_ECC_capable), + COMMON_TIMING(all_dimms_registered), + COMMON_TIMING(all_dimms_unbuffered), + COMMON_TIMING(all_dimms_ecc_capable), }; static const unsigned int n_opts = ARRAY_SIZE(options);
/* Clock frequencies */ - printf("tCKmin_X_ps = %u (%u MHz)\n", - plcd_dimm_params->tCKmin_X_ps, - picos_to_mhz(plcd_dimm_params->tCKmin_X_ps)); - printf("tCKmax_ps = %u (%u MHz)\n", - plcd_dimm_params->tCKmax_ps, - picos_to_mhz(plcd_dimm_params->tCKmax_ps)); - printf("all_DIMMs_burst_lengths_bitmask = %02X\n", - plcd_dimm_params->all_DIMMs_burst_lengths_bitmask); + printf("tckmin_x_ps = %u (%u MHz)\n", + plcd_dimm_params->tckmin_x_ps, + picos_to_mhz(plcd_dimm_params->tckmin_x_ps)); + printf("tckmax_ps = %u (%u MHz)\n", + plcd_dimm_params->tckmax_ps, + picos_to_mhz(plcd_dimm_params->tckmax_ps)); + printf("all_dimms_burst_lengths_bitmask = %02X\n", + plcd_dimm_params->all_dimms_burst_lengths_bitmask);
print_option_table(options, n_opts, plcd_dimm_params);
@@ -421,9 +421,9 @@ static void fsl_ddr_options_edit(fsl_ddr_info_t *pinfo, CTRL_OPTIONS(memctl_interleaving), CTRL_OPTIONS(memctl_interleaving_mode), CTRL_OPTIONS(ba_intlv_ctl), - CTRL_OPTIONS(ECC_mode), - CTRL_OPTIONS(ECC_init_using_memctl), - CTRL_OPTIONS(DQS_config), + CTRL_OPTIONS(ecc_mode), + CTRL_OPTIONS(ecc_init_using_memctl), + CTRL_OPTIONS(dqs_config), CTRL_OPTIONS(self_refresh_in_sleep), CTRL_OPTIONS(dynamic_power), CTRL_OPTIONS(data_bus_width), @@ -455,8 +455,8 @@ static void fsl_ddr_options_edit(fsl_ddr_info_t *pinfo, CTRL_OPTIONS(rcw_2), CTRL_OPTIONS(ddr_cdr1), CTRL_OPTIONS(ddr_cdr2), - CTRL_OPTIONS(tCKE_clock_pulse_width_ps), - CTRL_OPTIONS(tFAW_window_four_activates_ps), + CTRL_OPTIONS(tcke_clock_pulse_width_ps), + CTRL_OPTIONS(tfaw_window_four_activates_ps), CTRL_OPTIONS(trwt_override), CTRL_OPTIONS(trwt), }; @@ -666,9 +666,9 @@ static void print_memctl_options(const memctl_options_t *popts) CTRL_OPTIONS(memctl_interleaving), CTRL_OPTIONS(memctl_interleaving_mode), CTRL_OPTIONS_HEX(ba_intlv_ctl), - CTRL_OPTIONS(ECC_mode), - CTRL_OPTIONS(ECC_init_using_memctl), - CTRL_OPTIONS(DQS_config), + CTRL_OPTIONS(ecc_mode), + CTRL_OPTIONS(ecc_init_using_memctl), + CTRL_OPTIONS(dqs_config), CTRL_OPTIONS(self_refresh_in_sleep), CTRL_OPTIONS(dynamic_power), CTRL_OPTIONS(data_bus_width), @@ -700,8 +700,8 @@ static void print_memctl_options(const memctl_options_t *popts) CTRL_OPTIONS(rcw_2), CTRL_OPTIONS_HEX(ddr_cdr1), CTRL_OPTIONS_HEX(ddr_cdr2), - CTRL_OPTIONS(tCKE_clock_pulse_width_ps), - CTRL_OPTIONS(tFAW_window_four_activates_ps), + CTRL_OPTIONS(tcke_clock_pulse_width_ps), + CTRL_OPTIONS(tfaw_window_four_activates_ps), CTRL_OPTIONS(trwt_override), CTRL_OPTIONS(trwt), }; @@ -958,10 +958,10 @@ void ddr2_spd_dump(const ddr2_spd_eeprom_t *spd) " spd->tqhs, * 45 Max Read DataHold skew tQHS *"); printf("%-3d : %02x %s\n", 46, spd->pll_relock, " spd->pll_relock, * 46 PLL Relock time *"); - printf("%-3d : %02x %s\n", 47, spd->Tcasemax, - " spd->Tcasemax, * 47 Tcasemax *"); - printf("%-3d : %02x %s\n", 48, spd->psiTAdram, - " spd->psiTAdram, * 48 Thermal Resistance of DRAM Package " + printf("%-3d : %02x %s\n", 47, spd->t_casemax, + " spd->t_casemax, * 47 t_casemax *"); + printf("%-3d : %02x %s\n", 48, spd->psi_ta_dram, + " spd->psi_ta_dram, * 48 Thermal Resistance of DRAM Package " "from Top (Case) to Ambient (Psi T-A DRAM) *"); printf("%-3d : %02x %s\n", 49, spd->dt0_mode, " spd->dt0_mode, * 49 DRAM Case Temperature Rise from " @@ -996,11 +996,11 @@ void ddr2_spd_dump(const ddr2_spd_eeprom_t *spd) " spd->dt7, * 57 DRAM Case Temperature Rise from " "Ambient due to Bank Interleave Reads with " "Auto-Precharge (DT7) *"); - printf("%-3d : %02x %s\n", 58, spd->psiTApll, - " spd->psiTApll, * 58 Thermal Resistance of PLL Package form" + printf("%-3d : %02x %s\n", 58, spd->psi_ta_pll, + " spd->psi_ta_pll, * 58 Thermal Resistance of PLL Package form" " Top (Case) to Ambient (Psi T-A PLL) *"); - printf("%-3d : %02x %s\n", 59, spd->psiTAreg, - " spd->psiTAreg, * 59 Thermal Reisitance of Register Package" + printf("%-3d : %02x %s\n", 59, spd->psi_ta_reg, + " spd->psi_ta_reg, * 59 Thermal Reisitance of Register Package" " from Top (Case) to Ambient (Psi T-A Register) *"); printf("%-3d : %02x %s\n", 60, spd->dtpllactive, " spd->dtpllactive, * 60 PLL Case Temperature Rise from " @@ -1087,43 +1087,43 @@ void ddr3_spd_dump(const ddr3_spd_eeprom_t *spd) "mtb_dividend Medium Timebase (MTB) Dividend"); PRINT_NXS(11, spd->mtb_divisor, "mtb_divisor Medium Timebase (MTB) Divisor"); - PRINT_NXS(12, spd->tCK_min, - "tCK_min SDRAM Minimum Cycle Time"); + PRINT_NXS(12, spd->tck_min, + "tck_min SDRAM Minimum Cycle Time"); PRINT_NXS(13, spd->res_13, "res_13 Reserved"); PRINT_NXS(14, spd->caslat_lsb, "caslat_lsb CAS Latencies Supported, LSB"); PRINT_NXS(15, spd->caslat_msb, "caslat_msb CAS Latencies Supported, MSB"); - PRINT_NXS(16, spd->tAA_min, - "tAA_min Min CAS Latency Time"); - PRINT_NXS(17, spd->tWR_min, - "tWR_min Min Write REcovery Time"); - PRINT_NXS(18, spd->tRCD_min, - "tRCD_min Min RAS# to CAS# Delay Time"); - PRINT_NXS(19, spd->tRRD_min, - "tRRD_min Min Row Active to Row Active Delay Time"); - PRINT_NXS(20, spd->tRP_min, - "tRP_min Min Row Precharge Delay Time"); - PRINT_NXS(21, spd->tRAS_tRC_ext, - "tRAS_tRC_ext Upper Nibbles for tRAS and tRC"); - PRINT_NXS(22, spd->tRAS_min_lsb, - "tRAS_min_lsb Min Active to Precharge Delay Time, LSB"); - PRINT_NXS(23, spd->tRC_min_lsb, - "tRC_min_lsb Min Active to Active/Refresh Delay Time, LSB"); - PRINT_NXS(24, spd->tRFC_min_lsb, - "tRFC_min_lsb Min Refresh Recovery Delay Time LSB"); - PRINT_NXS(25, spd->tRFC_min_msb, - "tRFC_min_msb Min Refresh Recovery Delay Time MSB"); - PRINT_NXS(26, spd->tWTR_min, - "tWTR_min Min Internal Write to Read Command Delay Time"); - PRINT_NXS(27, spd->tRTP_min, - "tRTP_min " - "Min Internal Read to Precharge Command Delay Time"); - PRINT_NXS(28, spd->tFAW_msb, - "tFAW_msb Upper Nibble for tFAW"); - PRINT_NXS(29, spd->tFAW_min, - "tFAW_min Min Four Activate Window Delay Time"); + PRINT_NXS(16, spd->taa_min, + "taa_min Min CAS Latency Time"); + PRINT_NXS(17, spd->twr_min, + "twr_min Min Write REcovery Time"); + PRINT_NXS(18, spd->trcd_min, + "trcd_min Min RAS# to CAS# Delay Time"); + PRINT_NXS(19, spd->trrd_min, + "trrd_min Min Row Active to Row Active Delay Time"); + PRINT_NXS(20, spd->trp_min, + "trp_min Min Row Precharge Delay Time"); + PRINT_NXS(21, spd->tras_trc_ext, + "tras_trc_ext Upper Nibbles for tRAS and tRC"); + PRINT_NXS(22, spd->tras_min_lsb, + "tras_min_lsb Min Active to Precharge Delay Time, LSB"); + PRINT_NXS(23, spd->trc_min_lsb, + "trc_min_lsb Min Active to Active/Refresh Delay Time, LSB"); + PRINT_NXS(24, spd->trfc_min_lsb, + "trfc_min_lsb Min Refresh Recovery Delay Time LSB"); + PRINT_NXS(25, spd->trfc_min_msb, + "trfc_min_msb Min Refresh Recovery Delay Time MSB"); + PRINT_NXS(26, spd->twtr_min, + "twtr_min Min Internal Write to Read Command Delay Time"); + PRINT_NXS(27, spd->trtp_min, + "trtp_min " + "Min Internal Read to Precharge Command Delay Time"); + PRINT_NXS(28, spd->tfaw_msb, + "tfaw_msb Upper Nibble for tFAW"); + PRINT_NXS(29, spd->tfaw_min, + "tfaw_min Min Four Activate Window Delay Time"); PRINT_NXS(30, spd->opt_features, "opt_features SDRAM Optional Features"); PRINT_NXS(31, spd->therm_ref_opt, @@ -1132,16 +1132,16 @@ void ddr3_spd_dump(const ddr3_spd_eeprom_t *spd) "therm_sensor SDRAM Thermal Sensor"); PRINT_NXS(33, spd->device_type, "device_type SDRAM Device Type"); - PRINT_NXS(34, spd->fine_tCK_min, - "fine_tCK_min Fine offset for tCKmin"); - PRINT_NXS(35, spd->fine_tAA_min, - "fine_tAA_min Fine offset for tAAmin"); - PRINT_NXS(36, spd->fine_tRCD_min, - "fine_tRCD_min Fine offset for tRCDmin"); - PRINT_NXS(37, spd->fine_tRP_min, - "fine_tRP_min Fine offset for tRPmin"); - PRINT_NXS(38, spd->fine_tRC_min, - "fine_tRC_min Fine offset for tRCmin"); + PRINT_NXS(34, spd->fine_tck_min, + "fine_tck_min Fine offset for tCKmin"); + PRINT_NXS(35, spd->fine_taa_min, + "fine_taa_min Fine offset for tAAmin"); + PRINT_NXS(36, spd->fine_trcd_min, + "fine_trcd_min Fine offset for tRCDmin"); + PRINT_NXS(37, spd->fine_trp_min, + "fine_trp_min Fine offset for tRPmin"); + PRINT_NXS(38, spd->fine_trc_min, + "fine_trc_min Fine offset for tRCmin");
printf("%-3d-%3d: ", 39, 59); /* Reserved, General Section */
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/lc_common_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/lc_common_dimm_params.c index 56128a7..3affcee 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/lc_common_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/lc_common_dimm_params.c @@ -18,8 +18,8 @@ compute_cas_latency_ddr3(const dimm_params_t *dimm_params, unsigned int number_of_dimms) { unsigned int i; - unsigned int tAAmin_ps = 0; - unsigned int tCKmin_X_ps = 0; + unsigned int taamin_ps = 0; + unsigned int tckmin_x_ps = 0; unsigned int common_caslat; unsigned int caslat_actual; unsigned int retry = 16; @@ -27,26 +27,26 @@ compute_cas_latency_ddr3(const dimm_params_t *dimm_params, const unsigned int mclk_ps = get_memory_clk_period_ps();
/* compute the common CAS latency supported between slots */ - tmp = dimm_params[0].caslat_X; + tmp = dimm_params[0].caslat_x; for (i = 1; i < number_of_dimms; i++) { if (dimm_params[i].n_ranks) - tmp &= dimm_params[i].caslat_X; + tmp &= dimm_params[i].caslat_x; } common_caslat = tmp;
/* compute the max tAAmin tCKmin between slots */ for (i = 0; i < number_of_dimms; i++) { - tAAmin_ps = max(tAAmin_ps, dimm_params[i].tAA_ps); - tCKmin_X_ps = max(tCKmin_X_ps, dimm_params[i].tCKmin_X_ps); + taamin_ps = max(taamin_ps, dimm_params[i].taa_ps); + tckmin_x_ps = max(tckmin_x_ps, dimm_params[i].tckmin_x_ps); } /* validate if the memory clk is in the range of dimms */ - if (mclk_ps < tCKmin_X_ps) { + if (mclk_ps < tckmin_x_ps) { printf("DDR clock (MCLK cycle %u ps) is faster than " "the slowest DIMM(s) (tCKmin %u ps) can support.\n", - mclk_ps, tCKmin_X_ps); + mclk_ps, tckmin_x_ps); } /* determine the acutal cas latency */ - caslat_actual = (tAAmin_ps + mclk_ps - 1) / mclk_ps; + caslat_actual = (taamin_ps + mclk_ps - 1) / mclk_ps; /* check if the dimms support the CAS latency */ while (!(common_caslat & (1 << caslat_actual)) && retry > 0) { caslat_actual++; @@ -80,25 +80,25 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, { unsigned int i, j;
- unsigned int tCKmin_X_ps = 0; - unsigned int tCKmax_ps = 0xFFFFFFFF; - unsigned int tCKmax_max_ps = 0; - unsigned int tRCD_ps = 0; - unsigned int tRP_ps = 0; - unsigned int tRAS_ps = 0; - unsigned int tWR_ps = 0; - unsigned int tWTR_ps = 0; - unsigned int tRFC_ps = 0; - unsigned int tRRD_ps = 0; - unsigned int tRC_ps = 0; + unsigned int tckmin_x_ps = 0; + unsigned int tckmax_ps = 0xFFFFFFFF; + unsigned int tckmax_max_ps = 0; + unsigned int trcd_ps = 0; + unsigned int trp_ps = 0; + unsigned int tras_ps = 0; + unsigned int twr_ps = 0; + unsigned int twtr_ps = 0; + unsigned int trfc_ps = 0; + unsigned int trrd_ps = 0; + unsigned int trc_ps = 0; unsigned int refresh_rate_ps = 0; - unsigned int tIS_ps = 0; - unsigned int tIH_ps = 0; - unsigned int tDS_ps = 0; - unsigned int tDH_ps = 0; - unsigned int tRTP_ps = 0; - unsigned int tDQSQ_max_ps = 0; - unsigned int tQHS_ps = 0; + unsigned int tis_ps = 0; + unsigned int tih_ps = 0; + unsigned int tds_ps = 0; + unsigned int tdh_ps = 0; + unsigned int trtp_ps = 0; + unsigned int tdqsq_max_ps = 0; + unsigned int tqhs_ps = 0;
unsigned int temp1, temp2; unsigned int additive_latency = 0; @@ -141,39 +141,39 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, } #endif /* - * Find minimum tCKmax_ps to find fastest slow speed, + * Find minimum tckmax_ps to find fastest slow speed, * i.e., this is the slowest the whole system can go. */ - tCKmax_ps = min(tCKmax_ps, dimm_params[i].tCKmax_ps); + tckmax_ps = min(tckmax_ps, dimm_params[i].tckmax_ps);
/* Either find maximum value to determine slowest * speed, delay, time, period, etc */ - tCKmin_X_ps = max(tCKmin_X_ps, dimm_params[i].tCKmin_X_ps); - tCKmax_max_ps = max(tCKmax_max_ps, dimm_params[i].tCKmax_ps); - tRCD_ps = max(tRCD_ps, dimm_params[i].tRCD_ps); - tRP_ps = max(tRP_ps, dimm_params[i].tRP_ps); - tRAS_ps = max(tRAS_ps, dimm_params[i].tRAS_ps); - tWR_ps = max(tWR_ps, dimm_params[i].tWR_ps); - tWTR_ps = max(tWTR_ps, dimm_params[i].tWTR_ps); - tRFC_ps = max(tRFC_ps, dimm_params[i].tRFC_ps); - tRRD_ps = max(tRRD_ps, dimm_params[i].tRRD_ps); - tRC_ps = max(tRC_ps, dimm_params[i].tRC_ps); - tIS_ps = max(tIS_ps, dimm_params[i].tIS_ps); - tIH_ps = max(tIH_ps, dimm_params[i].tIH_ps); - tDS_ps = max(tDS_ps, dimm_params[i].tDS_ps); - tDH_ps = max(tDH_ps, dimm_params[i].tDH_ps); - tRTP_ps = max(tRTP_ps, dimm_params[i].tRTP_ps); - tQHS_ps = max(tQHS_ps, dimm_params[i].tQHS_ps); + tckmin_x_ps = max(tckmin_x_ps, dimm_params[i].tckmin_x_ps); + tckmax_max_ps = max(tckmax_max_ps, dimm_params[i].tckmax_ps); + trcd_ps = max(trcd_ps, dimm_params[i].trcd_ps); + trp_ps = max(trp_ps, dimm_params[i].trp_ps); + tras_ps = max(tras_ps, dimm_params[i].tras_ps); + twr_ps = max(twr_ps, dimm_params[i].twr_ps); + twtr_ps = max(twtr_ps, dimm_params[i].twtr_ps); + trfc_ps = max(trfc_ps, dimm_params[i].trfc_ps); + trrd_ps = max(trrd_ps, dimm_params[i].trrd_ps); + trc_ps = max(trc_ps, dimm_params[i].trc_ps); + tis_ps = max(tis_ps, dimm_params[i].tis_ps); + tih_ps = max(tih_ps, dimm_params[i].tih_ps); + tds_ps = max(tds_ps, dimm_params[i].tds_ps); + tdh_ps = max(tdh_ps, dimm_params[i].tdh_ps); + trtp_ps = max(trtp_ps, dimm_params[i].trtp_ps); + tqhs_ps = max(tqhs_ps, dimm_params[i].tqhs_ps); refresh_rate_ps = max(refresh_rate_ps, dimm_params[i].refresh_rate_ps);
/* - * Find maximum tDQSQ_max_ps to find slowest. + * Find maximum tdqsq_max_ps to find slowest. * * FIXME: is finding the slowest value the correct * strategy for this parameter? */ - tDQSQ_max_ps = max(tDQSQ_max_ps, dimm_params[i].tDQSQ_max_ps); + tdqsq_max_ps = max(tdqsq_max_ps, dimm_params[i].tdqsq_max_ps); }
outpdimm->ndimms_present = number_of_dimms - temp1; @@ -183,25 +183,25 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, return 0; }
- outpdimm->tCKmin_X_ps = tCKmin_X_ps; - outpdimm->tCKmax_ps = tCKmax_ps; - outpdimm->tCKmax_max_ps = tCKmax_max_ps; - outpdimm->tRCD_ps = tRCD_ps; - outpdimm->tRP_ps = tRP_ps; - outpdimm->tRAS_ps = tRAS_ps; - outpdimm->tWR_ps = tWR_ps; - outpdimm->tWTR_ps = tWTR_ps; - outpdimm->tRFC_ps = tRFC_ps; - outpdimm->tRRD_ps = tRRD_ps; - outpdimm->tRC_ps = tRC_ps; + outpdimm->tckmin_x_ps = tckmin_x_ps; + outpdimm->tckmax_ps = tckmax_ps; + outpdimm->tckmax_max_ps = tckmax_max_ps; + outpdimm->trcd_ps = trcd_ps; + outpdimm->trp_ps = trp_ps; + outpdimm->tras_ps = tras_ps; + outpdimm->twr_ps = twr_ps; + outpdimm->twtr_ps = twtr_ps; + outpdimm->trfc_ps = trfc_ps; + outpdimm->trrd_ps = trrd_ps; + outpdimm->trc_ps = trc_ps; outpdimm->refresh_rate_ps = refresh_rate_ps; - outpdimm->tIS_ps = tIS_ps; - outpdimm->tIH_ps = tIH_ps; - outpdimm->tDS_ps = tDS_ps; - outpdimm->tDH_ps = tDH_ps; - outpdimm->tRTP_ps = tRTP_ps; - outpdimm->tDQSQ_max_ps = tDQSQ_max_ps; - outpdimm->tQHS_ps = tQHS_ps; + outpdimm->tis_ps = tis_ps; + outpdimm->tih_ps = tih_ps; + outpdimm->tds_ps = tds_ps; + outpdimm->tdh_ps = tdh_ps; + outpdimm->trtp_ps = trtp_ps; + outpdimm->tdqsq_max_ps = tdqsq_max_ps; + outpdimm->tqhs_ps = tqhs_ps;
/* Determine common burst length for all DIMMs. */ temp1 = 0xff; @@ -210,7 +210,7 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, temp1 &= dimm_params[i].burst_lengths_bitmask; } } - outpdimm->all_DIMMs_burst_lengths_bitmask = temp1; + outpdimm->all_dimms_burst_lengths_bitmask = temp1;
/* Determine if all DIMMs registered buffered. */ temp1 = temp2 = 0; @@ -232,19 +232,19 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, } }
- outpdimm->all_DIMMs_registered = 0; - outpdimm->all_DIMMs_unbuffered = 0; + outpdimm->all_dimms_registered = 0; + outpdimm->all_dimms_unbuffered = 0; if (temp1 && !temp2) { - outpdimm->all_DIMMs_registered = 1; + outpdimm->all_dimms_registered = 1; } else if (!temp1 && temp2) { - outpdimm->all_DIMMs_unbuffered = 1; + outpdimm->all_dimms_unbuffered = 1; } else { printf("ERROR: Mix of registered buffered and unbuffered " "DIMMs detected!\n"); }
temp1 = 0; - if (outpdimm->all_DIMMs_registered) + if (outpdimm->all_dimms_registered) for (j = 0; j < 16; j++) { outpdimm->rcw[j] = dimm_params[0].rcw[j]; for (i = 1; i < number_of_dimms; i++) { @@ -279,13 +279,13 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, for (i = 0; i < number_of_dimms; i++) { if (dimm_params[i].n_ranks) { temp2 = 0; - temp2 |= 1 << dimm_params[i].caslat_X; - temp2 |= 1 << dimm_params[i].caslat_X_minus_1; - temp2 |= 1 << dimm_params[i].caslat_X_minus_2; + temp2 |= 1 << dimm_params[i].caslat_x; + temp2 |= 1 << dimm_params[i].caslat_x_minus_1; + temp2 |= 1 << dimm_params[i].caslat_x_minus_2; /* * FIXME: If there was no entry for X-2 (X-1) in - * the SPD, then caslat_X_minus_2 - * (caslat_X_minus_1) contains either 255 or + * the SPD, then caslat_x_minus_2 + * (caslat_x_minus_1) contains either 255 or * 0xFFFFFFFF because that's what the glorious * __ilog2 function returns for an input of 0. * On 32-bit PowerPC, left shift counts with bit @@ -313,42 +313,42 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, if (!dimm_params[i].n_ranks) { continue; } - if (dimm_params[i].caslat_X == temp2) { - if (mclk_ps >= dimm_params[i].tCKmin_X_ps) { + if (dimm_params[i].caslat_x == temp2) { + if (mclk_ps >= dimm_params[i].tckmin_x_ps) { debug("CL = %u ok on DIMM %u at tCK=%u" " ps with its tCKmin_X_ps of %u\n", temp2, i, mclk_ps, - dimm_params[i].tCKmin_X_ps); + dimm_params[i].tckmin_x_ps); continue; } else { not_ok++; } }
- if (dimm_params[i].caslat_X_minus_1 == temp2) { - unsigned int tCKmin_X_minus_1_ps - = dimm_params[i].tCKmin_X_minus_1_ps; - if (mclk_ps >= tCKmin_X_minus_1_ps) { + if (dimm_params[i].caslat_x_minus_1 == temp2) { + unsigned int tckmin_x_minus_1_ps + = dimm_params[i].tckmin_x_minus_1_ps; + if (mclk_ps >= tckmin_x_minus_1_ps) { debug("CL = %u ok on DIMM %u at " "tCK=%u ps with its " - "tCKmin_X_minus_1_ps of %u\n", + "tckmin_x_minus_1_ps of %u\n", temp2, i, mclk_ps, - tCKmin_X_minus_1_ps); + tckmin_x_minus_1_ps); continue; } else { not_ok++; } }
- if (dimm_params[i].caslat_X_minus_2 == temp2) { - unsigned int tCKmin_X_minus_2_ps - = dimm_params[i].tCKmin_X_minus_2_ps; - if (mclk_ps >= tCKmin_X_minus_2_ps) { + if (dimm_params[i].caslat_x_minus_2 == temp2) { + unsigned int tckmin_x_minus_2_ps + = dimm_params[i].tckmin_x_minus_2_ps; + if (mclk_ps >= tckmin_x_minus_2_ps) { debug("CL = %u ok on DIMM %u at " "tCK=%u ps with its " - "tCKmin_X_minus_2_ps of %u\n", + "tckmin_x_minus_2_ps of %u\n", temp2, i, mclk_ps, - tCKmin_X_minus_2_ps); + tckmin_x_minus_2_ps); continue; } else { not_ok++; @@ -397,11 +397,11 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, } else { debug("Warning: not all DIMMs ECC capable, cant enable ECC\n"); } - outpdimm->all_DIMMs_ECC_capable = temp1; + outpdimm->all_dimms_ecc_capable = temp1;
#ifndef CONFIG_FSL_DDR3 /* FIXME: move to somewhere else to validate. */ - if (mclk_ps > tCKmax_max_ps) { + if (mclk_ps > tckmax_max_ps) { printf("Warning: some of the installed DIMMs " "can not operate this slowly.\n"); return 1; @@ -464,10 +464,10 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params,
#if defined(CONFIG_FSL_DDR2) if (lowest_good_caslat < 4) { - additive_latency = (picos_to_mclk(tRCD_ps) > lowest_good_caslat) - ? picos_to_mclk(tRCD_ps) - lowest_good_caslat : 0; - if (mclk_to_picos(additive_latency) > tRCD_ps) { - additive_latency = picos_to_mclk(tRCD_ps); + additive_latency = (picos_to_mclk(trcd_ps) > lowest_good_caslat) + ? picos_to_mclk(trcd_ps) - lowest_good_caslat : 0; + if (mclk_to_picos(additive_latency) > trcd_ps) { + additive_latency = picos_to_mclk(trcd_ps); debug("setting additive_latency to %u because it was " " greater than tRCD_ps\n", additive_latency); } @@ -487,7 +487,7 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, * * AL <= tRCD(min) */ - if (mclk_to_picos(additive_latency) > tRCD_ps) { + if (mclk_to_picos(additive_latency) > trcd_ps) { printf("Error: invalid additive latency exceeds tRCD(min).\n"); return 1; } @@ -507,15 +507,15 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, */ outpdimm->additive_latency = additive_latency;
- debug("tCKmin_ps = %u\n", outpdimm->tCKmin_X_ps); - debug("tRCD_ps = %u\n", outpdimm->tRCD_ps); - debug("tRP_ps = %u\n", outpdimm->tRP_ps); - debug("tRAS_ps = %u\n", outpdimm->tRAS_ps); - debug("tWR_ps = %u\n", outpdimm->tWR_ps); - debug("tWTR_ps = %u\n", outpdimm->tWTR_ps); - debug("tRFC_ps = %u\n", outpdimm->tRFC_ps); - debug("tRRD_ps = %u\n", outpdimm->tRRD_ps); - debug("tRC_ps = %u\n", outpdimm->tRC_ps); + debug("tCKmin_ps = %u\n", outpdimm->tckmin_x_ps); + debug("trcd_ps = %u\n", outpdimm->trcd_ps); + debug("trp_ps = %u\n", outpdimm->trp_ps); + debug("tras_ps = %u\n", outpdimm->tras_ps); + debug("twr_ps = %u\n", outpdimm->twr_ps); + debug("twtr_ps = %u\n", outpdimm->twtr_ps); + debug("trfc_ps = %u\n", outpdimm->trfc_ps); + debug("trrd_ps = %u\n", outpdimm->trrd_ps); + debug("trc_ps = %u\n", outpdimm->trc_ps);
return 0; } diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/main.c b/arch/powerpc/cpu/mpc8xxx/ddr/main.c index 842bf19..b9ae950 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/main.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/main.c @@ -457,7 +457,7 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, * which is currently STEP_ASSIGN_ADDRESSES. */ populate_memctl_options( - timing_params[i].all_DIMMs_registered, + timing_params[i].all_dimms_registered, &pinfo->memctl_opts[i], pinfo->dimm_params[i], i); /* @@ -466,7 +466,7 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, * using fixed parameters, this function should be * be called from board init file. */ - if (timing_params[i].all_DIMMs_registered) + if (timing_params[i].all_dimms_registered) assert_reset = 1; } if (assert_reset) { @@ -589,7 +589,7 @@ phys_size_t fsl_ddr_sdram(void) */ deassert_reset = board_need_mem_reset(); for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { - if (info.common_timing_params[i].all_DIMMs_registered) + if (info.common_timing_params[i].all_dimms_registered) deassert_reset = 1; } for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/options.c b/arch/powerpc/cpu/mpc8xxx/ddr/options.c index 30cdca4..2b8a1e4 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/options.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/options.c @@ -499,7 +499,7 @@ static inline unsigned int auto_bank_intlv(dimm_params_t *pdimm) return 0; }
-unsigned int populate_memctl_options(int all_DIMMs_registered, +unsigned int populate_memctl_options(int all_dimms_registered, memctl_options_t *popts, dimm_params_t *pdimm, unsigned int ctrl_num) @@ -635,20 +635,20 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, popts->ba_intlv_ctl = 0;
/* Memory Organization Parameters */ - popts->registered_dimm_en = all_DIMMs_registered; + popts->registered_dimm_en = all_dimms_registered;
/* Operational Mode Paramters */
/* Pick ECC modes */ - popts->ECC_mode = 0; /* 0 = disabled, 1 = enabled */ + popts->ecc_mode = 0; /* 0 = disabled, 1 = enabled */ #ifdef CONFIG_DDR_ECC if (hwconfig_sub_f("fsl_ddr", "ecc", buf)) { if (hwconfig_subarg_cmp_f("fsl_ddr", "ecc", "on", buf)) - popts->ECC_mode = 1; + popts->ecc_mode = 1; } else - popts->ECC_mode = 1; + popts->ecc_mode = 1; #endif - popts->ECC_init_using_memctl = 1; /* 0 = use DMA, 1 = use memctl */ + popts->ecc_init_using_memctl = 1; /* 0 = use DMA, 1 = use memctl */
/* * Choose DQS config @@ -656,9 +656,9 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, * 1 for DDR2 */ #if defined(CONFIG_FSL_DDR1) - popts->DQS_config = 0; + popts->dqs_config = 0; #elif defined(CONFIG_FSL_DDR2) || defined(CONFIG_FSL_DDR3) - popts->DQS_config = 1; + popts->dqs_config = 1; #endif
/* Choose self-refresh during sleep. */ @@ -705,15 +705,15 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, /* Choose burst length. */ #if defined(CONFIG_FSL_DDR3) #if defined(CONFIG_E500MC) - popts->OTF_burst_chop_en = 0; /* on-the-fly burst chop disable */ + popts->otf_burst_chop_en = 0; /* on-the-fly burst chop disable */ popts->burst_length = DDR_BL8; /* Fixed 8-beat burst len */ #else if ((popts->data_bus_width == 1) || (popts->data_bus_width == 2)) { /* 32-bit or 16-bit bus */ - popts->OTF_burst_chop_en = 0; + popts->otf_burst_chop_en = 0; popts->burst_length = DDR_BL8; } else { - popts->OTF_burst_chop_en = 1; /* on-the-fly burst chop */ + popts->otf_burst_chop_en = 1; /* on-the-fly burst chop */ popts->burst_length = DDR_OTF; /* on-the-fly BC4 and BL8 */ } #endif @@ -775,7 +775,7 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, popts->bstopre = 0x100;
/* Minimum CKE pulse width -- tCKE(MIN) */ - popts->tCKE_clock_pulse_width_ps + popts->tcke_clock_pulse_width_ps = mclk_to_picos(FSL_DDR_MIN_TCKE_PULSE_WIDTH_DDR);
/* @@ -786,17 +786,17 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, * FIXME: width, was considering looking at pdimm->primary_sdram_width */ #if defined(CONFIG_FSL_DDR1) - popts->tFAW_window_four_activates_ps = mclk_to_picos(1); + popts->tfaw_window_four_activates_ps = mclk_to_picos(1);
#elif defined(CONFIG_FSL_DDR2) /* * x4/x8; some datasheets have 35000 * x16 wide columns only? Use 50000? */ - popts->tFAW_window_four_activates_ps = 37500; + popts->tfaw_window_four_activates_ps = 37500;
#elif defined(CONFIG_FSL_DDR3) - popts->tFAW_window_four_activates_ps = pdimm[0].tFAW_ps; + popts->tfaw_window_four_activates_ps = pdimm[0].tfaw_ps; #endif popts->zq_en = 0; popts->wrlvl_en = 0; diff --git a/arch/powerpc/include/asm/fsl_ddr_dimm_params.h b/arch/powerpc/include/asm/fsl_ddr_dimm_params.h index bd312ad..2cad6e2 100644 --- a/arch/powerpc/include/asm/fsl_ddr_dimm_params.h +++ b/arch/powerpc/include/asm/fsl_ddr_dimm_params.h @@ -45,48 +45,48 @@ typedef struct dimm_params_s {
unsigned int mtb_ps; /* medium timebase ps, only for ddr3 */ unsigned int ftb_10th_ps; /* fine timebase, in 1/10 ps, only for ddr3 */ - unsigned int tAA_ps; /* minimum CAS latency time, only for ddr3 */ - unsigned int tFAW_ps; /* four active window delay, only for ddr3 */ + unsigned int taa_ps; /* minimum CAS latency time, only for ddr3 */ + unsigned int tfaw_ps; /* four active window delay, only for ddr3 */
/* * SDRAM clock periods * The range for these are 1000-10000 so a short should be sufficient */ - unsigned int tCKmin_X_ps; - unsigned int tCKmin_X_minus_1_ps; - unsigned int tCKmin_X_minus_2_ps; - unsigned int tCKmax_ps; + unsigned int tckmin_x_ps; + unsigned int tckmin_x_minus_1_ps; + unsigned int tckmin_x_minus_2_ps; + unsigned int tckmax_ps;
/* SPD-defined CAS latencies */ - unsigned int caslat_X; - unsigned int caslat_X_minus_1; - unsigned int caslat_X_minus_2; + unsigned int caslat_x; + unsigned int caslat_x_minus_1; + unsigned int caslat_x_minus_2;
unsigned int caslat_lowest_derated; /* Derated CAS latency */
/* basic timing parameters */ - unsigned int tRCD_ps; - unsigned int tRP_ps; - unsigned int tRAS_ps; + unsigned int trcd_ps; + unsigned int trp_ps; + unsigned int tras_ps;
- unsigned int tWR_ps; /* maximum = 63750 ps */ - unsigned int tWTR_ps; /* maximum = 63750 ps */ - unsigned int tRFC_ps; /* max = 255 ns + 256 ns + .75 ns + unsigned int twr_ps; /* maximum = 63750 ps */ + unsigned int twtr_ps; /* maximum = 63750 ps */ + unsigned int trfc_ps; /* max = 255 ns + 256 ns + .75 ns = 511750 ps */
/* DDR3 doesn't need these as below */ - unsigned int tIS_ps; /* byte 32, spd->ca_setup */ - unsigned int tIH_ps; /* byte 33, spd->ca_hold */ - unsigned int tDS_ps; /* byte 34, spd->data_setup */ - unsigned int tDH_ps; /* byte 35, spd->data_hold */ - unsigned int tRTP_ps; /* byte 38, spd->trtp */ - unsigned int tDQSQ_max_ps; /* byte 44, spd->tdqsq */ - unsigned int tQHS_ps; /* byte 45, spd->tqhs */ + unsigned int tis_ps; /* byte 32, spd->ca_setup */ + unsigned int tih_ps; /* byte 33, spd->ca_hold */ + unsigned int tds_ps; /* byte 34, spd->data_setup */ + unsigned int tdh_ps; /* byte 35, spd->data_hold */ + unsigned int trtp_ps; /* byte 38, spd->trtp */ + unsigned int tdqsq_max_ps; /* byte 44, spd->tdqsq */ + unsigned int tqhs_ps; /* byte 45, spd->tqhs */
/* DDR3 RDIMM */ unsigned char rcw[16]; /* Register Control Word 0-15 */ diff --git a/arch/powerpc/include/asm/fsl_ddr_sdram.h b/arch/powerpc/include/asm/fsl_ddr_sdram.h index f4eec82..1199832 100644 --- a/arch/powerpc/include/asm/fsl_ddr_sdram.h +++ b/arch/powerpc/include/asm/fsl_ddr_sdram.h @@ -219,13 +219,13 @@ typedef struct fsl_ddr_cfg_regs_s { } fsl_ddr_cfg_regs_t;
typedef struct memctl_options_partial_s { - unsigned int all_DIMMs_ECC_capable; - unsigned int all_DIMMs_tCKmax_ps; - unsigned int all_DIMMs_burst_lengths_bitmask; - unsigned int all_DIMMs_registered; - unsigned int all_DIMMs_unbuffered; + unsigned int all_dimms_ecc_capable; + unsigned int all_dimms_tckmax_ps; + unsigned int all_dimms_burst_lengths_bitmask; + unsigned int all_dimms_registered; + unsigned int all_dimms_unbuffered; /* unsigned int lowest_common_SPD_caslat; */ - unsigned int all_DIMMs_minimum_tRCD_ps; + unsigned int all_dimms_minimum_trcd_ps; } memctl_options_partial_t;
#define DDR_DATA_BUS_WIDTH_64 0 @@ -261,10 +261,10 @@ typedef struct memctl_options_s { unsigned int addr_hash;
/* Operational mode parameters */ - unsigned int ECC_mode; /* Use ECC? */ + unsigned int ecc_mode; /* Use ECC? */ /* Initialize ECC using memory controller? */ - unsigned int ECC_init_using_memctl; - unsigned int DQS_config; /* Use DQS? maybe only with DDR2? */ + unsigned int ecc_init_using_memctl; + unsigned int dqs_config; /* Use DQS? maybe only with DDR2? */ /* SREN - self-refresh during sleep */ unsigned int self_refresh_in_sleep; unsigned int dynamic_power; /* DYN_PWR */ @@ -272,7 +272,7 @@ typedef struct memctl_options_s { unsigned int data_bus_width; unsigned int burst_length; /* BL4, OTF and BL8 */ /* On-The-Fly Burst Chop enable */ - unsigned int OTF_burst_chop_en; + unsigned int otf_burst_chop_en; /* mirrior DIMMs for DDR3 */ unsigned int mirrored_dimm; unsigned int quad_rank_present; @@ -300,8 +300,8 @@ typedef struct memctl_options_s { unsigned int twoT_en; unsigned int threeT_en; unsigned int bstopre; - unsigned int tCKE_clock_pulse_width_ps; /* tCKE */ - unsigned int tFAW_window_four_activates_ps; /* tFAW -- FOUR_ACT */ + unsigned int tcke_clock_pulse_width_ps; /* tCKE */ + unsigned int tfaw_window_four_activates_ps; /* tFAW -- FOUR_ACT */
/* Rtt impedance */ unsigned int rtt_override; /* rtt_override enable */ diff --git a/arch/powerpc/include/asm/immap_512x.h b/arch/powerpc/include/asm/immap_512x.h index 01c9eff..814a535 100644 --- a/arch/powerpc/include/asm/immap_512x.h +++ b/arch/powerpc/include/asm/immap_512x.h @@ -279,8 +279,8 @@ typedef struct ddr512x { u32 self_refresh_cmd_5; /* Enter/Exit Self Refresh Registers */ u32 self_refresh_cmd_6; /* Enter/Exit Self Refresh Registers */ u32 self_refresh_cmd_7; /* Enter/Exit Self Refresh Registers */ - u32 DQS_config_offset_count; /* DQS Config Offset Count */ - u32 DQS_config_offset_time; /* DQS Config Offset Time */ + u32 dqs_config_offset_count; /* DQS Config Offset Count */ + u32 dqs_config_offset_time; /* DQS Config Offset Time */ u32 DQS_delay_status; /* DQS Delay Status */ u32 res0[0xF]; u32 prioman_config1; /* Priority Manager Configuration */ diff --git a/board/freescale/b4860qds/ddr.c b/board/freescale/b4860qds/ddr.c index b82b3d4..7fce763 100644 --- a/board/freescale/b4860qds/ddr.c +++ b/board/freescale/b4860qds/ddr.c @@ -31,20 +31,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 2, /* ECC */ .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1071, - .caslat_X = 0x2fe << 4, /* 5,6,7,8,9,10,11,13 */ - .tAA_ps = 13910, - .tWR_ps = 15000, - .tRCD_ps = 13910, - .tRRD_ps = 6000, - .tRP_ps = 13910, - .tRAS_ps = 34000, - .tRC_ps = 48910, - .tRFC_ps = 260000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1071, + .caslat_x = 0x2fe << 4, /* 5,6,7,8,9,10,11,13 */ + .taa_ps = 13910, + .twr_ps = 15000, + .trcd_ps = 13910, + .trrd_ps = 6000, + .trp_ps = 13910, + .tras_ps = 34000, + .trc_ps = 48910, + .trfc_ps = 260000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 35000, + .tfaw_ps = 35000, };
int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, diff --git a/board/freescale/bsc9131rdb/ddr.c b/board/freescale/bsc9131rdb/ddr.c index c82fe0a..a9e92f2 100644 --- a/board/freescale/bsc9131rdb/ddr.c +++ b/board/freescale/bsc9131rdb/ddr.c @@ -114,20 +114,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1870, - .caslat_X = 0x1e << 4, /* 5,6,7,8 */ - .tAA_ps = 13125, - .tWR_ps = 15000, - .tRCD_ps = 13125, - .tRRD_ps = 7500, - .tRP_ps = 13125, - .tRAS_ps = 37500, - .tRC_ps = 50625, - .tRFC_ps = 160000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1870, + .caslat_x = 0x1e << 4, /* 5,6,7,8 */ + .taa_ps = 13125, + .twr_ps = 15000, + .trcd_ps = 13125, + .trrd_ps = 7500, + .trp_ps = 13125, + .tras_ps = 37500, + .trc_ps = 50625, + .trfc_ps = 160000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 37500, + .tfaw_ps = 37500, };
int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, diff --git a/board/freescale/bsc9132qds/ddr.c b/board/freescale/bsc9132qds/ddr.c index fdea193..b3130be 100644 --- a/board/freescale/bsc9132qds/ddr.c +++ b/board/freescale/bsc9132qds/ddr.c @@ -136,20 +136,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, diff --git a/board/freescale/c29xpcie/ddr.c b/board/freescale/c29xpcie/ddr.c index b017cfd..478e0b5 100644 --- a/board/freescale/c29xpcie/ddr.c +++ b/board/freescale/c29xpcie/ddr.c @@ -26,20 +26,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 2, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1650, - .caslat_X = 0x7e << 4, /* 5,6,7,8,9,10 */ - .tAA_ps = 14050, - .tWR_ps = 15000, - .tRCD_ps = 13500, - .tRRD_ps = 75000, - .tRP_ps = 13500, - .tRAS_ps = 40000, - .tRC_ps = 49500, - .tRFC_ps = 160000, - .tWTR_ps = 75000, - .tRTP_ps = 75000, + .tckmin_x_ps = 1650, + .caslat_x = 0x7e << 4, /* 5,6,7,8,9,10 */ + .taa_ps = 14050, + .twr_ps = 15000, + .trcd_ps = 13500, + .trrd_ps = 75000, + .trp_ps = 13500, + .tras_ps = 40000, + .trc_ps = 49500, + .trfc_ps = 160000, + .twtr_ps = 75000, + .trtp_ps = 75000, .refresh_rate_ps = 7800000, - .tFAW_ps = 30000, + .tfaw_ps = 30000, };
int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, diff --git a/board/freescale/mpc8349emds/ddr.c b/board/freescale/mpc8349emds/ddr.c index c66750e..ab1d1ce 100644 --- a/board/freescale/mpc8349emds/ddr.c +++ b/board/freescale/mpc8349emds/ddr.c @@ -97,5 +97,5 @@ found: * - number of DIMMs installed */ popts->half_strength_driver_enable = 0; - popts->DQS_config = 0; /* only true DQS signal is used on board */ + popts->dqs_config = 0; /* only true DQS signal is used on board */ } diff --git a/board/freescale/p1010rdb/ddr.c b/board/freescale/p1010rdb/ddr.c index 681f052..ab1b41d 100644 --- a/board/freescale/p1010rdb/ddr.c +++ b/board/freescale/p1010rdb/ddr.c @@ -172,20 +172,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1875, - .caslat_X = 0x1e << 4, /* 5,6,7,8 */ - .tAA_ps = 13125, - .tWR_ps = 15000, - .tRCD_ps = 13125, - .tRRD_ps = 7500, - .tRP_ps = 13125, - .tRAS_ps = 37500, - .tRC_ps = 50625, - .tRFC_ps = 160000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1875, + .caslat_x = 0x1e << 4, /* 5,6,7,8 */ + .taa_ps = 13125, + .twr_ps = 15000, + .trcd_ps = 13125, + .trrd_ps = 7500, + .trp_ps = 13125, + .tras_ps = 37500, + .trc_ps = 50625, + .trfc_ps = 160000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 37500, + .tfaw_ps = 37500, };
int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, diff --git a/board/freescale/p1023rdb/ddr.c b/board/freescale/p1023rdb/ddr.c index ce406b2..ea21f08 100644 --- a/board/freescale/p1023rdb/ddr.c +++ b/board/freescale/p1023rdb/ddr.c @@ -33,20 +33,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1875, - .caslat_X = 0x1e << 4, /* 5,6,7,8 */ - .tAA_ps = 13125, - .tWR_ps = 18000, - .tRCD_ps = 13125, - .tRRD_ps = 7500, - .tRP_ps = 13125, - .tRAS_ps = 37500, - .tRC_ps = 50625, - .tRFC_ps = 160000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1875, + .caslat_x = 0x1e << 4, /* 5,6,7,8 */ + .taa_ps = 13125, + .twr_ps = 18000, + .trcd_ps = 13125, + .trrd_ps = 7500, + .trp_ps = 13125, + .tras_ps = 37500, + .trc_ps = 50625, + .trfc_ps = 160000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 37500, + .tfaw_ps = 37500, };
int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, diff --git a/board/freescale/p1_p2_rdb_pc/ddr.c b/board/freescale/p1_p2_rdb_pc/ddr.c index c0b72e0..81cc093 100644 --- a/board/freescale/p1_p2_rdb_pc/ddr.c +++ b/board/freescale/p1_p2_rdb_pc/ddr.c @@ -34,20 +34,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1870, - .caslat_X = 0x1e << 4, /* 5,6,7,8 */ - .tAA_ps = 13125, - .tWR_ps = 15000, - .tRCD_ps = 13125, - .tRRD_ps = 7500, - .tRP_ps = 13125, - .tRAS_ps = 37500, - .tRC_ps = 50625, - .tRFC_ps = 160000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1870, + .caslat_x = 0x1e << 4, /* 5,6,7,8 */ + .taa_ps = 13125, + .twr_ps = 15000, + .trcd_ps = 13125, + .trrd_ps = 7500, + .trp_ps = 13125, + .tras_ps = 37500, + .trc_ps = 50625, + .trfc_ps = 160000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 37500, + .tfaw_ps = 37500, }; #elif defined(CONFIG_P2020RDB) /* Micron MT41J128M16_15E */ @@ -65,20 +65,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1500, - .caslat_X = 0x7e << 4, /* 5,6,7,8,9,10 */ - .tAA_ps = 13500, - .tWR_ps = 15000, - .tRCD_ps = 13500, - .tRRD_ps = 6000, - .tRP_ps = 13500, - .tRAS_ps = 36000, - .tRC_ps = 49500, - .tRFC_ps = 160000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1500, + .caslat_x = 0x7e << 4, /* 5,6,7,8,9,10 */ + .taa_ps = 13500, + .twr_ps = 15000, + .trcd_ps = 13500, + .trrd_ps = 6000, + .trp_ps = 13500, + .tras_ps = 36000, + .trc_ps = 49500, + .trfc_ps = 160000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 30000, + .tfaw_ps = 30000, }; #elif (defined(CONFIG_P1020MBG) || defined(CONFIG_P1020RDB_PD)) /* Micron MT41J512M8_187E */ @@ -96,20 +96,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1870, - .caslat_X = 0x1e << 4, /* 5,6,7,8 */ - .tAA_ps = 13125, - .tWR_ps = 15000, - .tRCD_ps = 13125, - .tRRD_ps = 7500, - .tRP_ps = 13125, - .tRAS_ps = 37500, - .tRC_ps = 50625, - .tRFC_ps = 160000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1870, + .caslat_x = 0x1e << 4, /* 5,6,7,8 */ + .taa_ps = 13125, + .twr_ps = 15000, + .trcd_ps = 13125, + .trrd_ps = 7500, + .trp_ps = 13125, + .tras_ps = 37500, + .trc_ps = 50625, + .trfc_ps = 160000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 37500, + .tfaw_ps = 37500, }; #elif defined(CONFIG_P1020RDB_PC) /* @@ -133,20 +133,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1875, - .caslat_X = 0x1e << 4, /* 5,6,7,8 */ - .tAA_ps = 13125, - .tWR_ps = 15000, - .tRCD_ps = 13125, - .tRRD_ps = 7500, - .tRP_ps = 13125, - .tRAS_ps = 37500, - .tRC_ps = 50625, - .tRFC_ps = 160000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1875, + .caslat_x = 0x1e << 4, /* 5,6,7,8 */ + .taa_ps = 13125, + .twr_ps = 15000, + .trcd_ps = 13125, + .trrd_ps = 7500, + .trp_ps = 13125, + .tras_ps = 37500, + .trc_ps = 50625, + .trfc_ps = 160000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 37500, + .tfaw_ps = 37500, }; #elif defined(CONFIG_P1024RDB) || \ defined(CONFIG_P1025RDB) @@ -171,20 +171,20 @@ dimm_params_t ddr_raw_timing = { .edc_config = 0, .burst_lengths_bitmask = 0x0c,
- .tCKmin_X_ps = 1500, - .caslat_X = 0x3e << 4, /* 5,6,7,8,9 */ - .tAA_ps = 13125, - .tWR_ps = 15000, - .tRCD_ps = 13125, - .tRRD_ps = 6000, - .tRP_ps = 13125, - .tRAS_ps = 36000, - .tRC_ps = 49125, - .tRFC_ps = 160000, - .tWTR_ps = 7500, - .tRTP_ps = 7500, + .tckmin_x_ps = 1500, + .caslat_x = 0x3e << 4, /* 5,6,7,8,9 */ + .taa_ps = 13125, + .twr_ps = 15000, + .trcd_ps = 13125, + .trrd_ps = 6000, + .trp_ps = 13125, + .tras_ps = 36000, + .trc_ps = 49125, + .trfc_ps = 160000, + .twtr_ps = 7500, + .trtp_ps = 7500, .refresh_rate_ps = 7800000, - .tFAW_ps = 30000, + .tfaw_ps = 30000, }; #else #error Missing raw timing data for this board diff --git a/include/ddr_spd.h b/include/ddr_spd.h index 9e74d87..a9fbb73 100644 --- a/include/ddr_spd.h +++ b/include/ddr_spd.h @@ -126,9 +126,10 @@ typedef struct ddr2_spd_eeprom_s { unsigned char tdqsq; /* 44 Max DQS to DQ skew (tDQSQ max) */ unsigned char tqhs; /* 45 Max Read DataHold skew (tQHS) */ unsigned char pll_relock; /* 46 PLL Relock time */ - unsigned char Tcasemax; /* 47 Tcasemax */ - unsigned char psiTAdram; /* 48 Thermal Resistance of DRAM Package from - Top (Case) to Ambient (Psi T-A DRAM) */ + unsigned char t_casemax; /* 47 t_casemax */ + unsigned char psi_ta_dram; /* 48 Thermal Resistance of DRAM Package + from Top (Case) to Ambient + (Psi T-A DRAM) */ unsigned char dt0_mode; /* 49 DRAM Case Temperature Rise from Ambient due to Activate-Precharge/Mode Bits (DT0/Mode Bits) */ @@ -153,10 +154,11 @@ typedef struct ddr2_spd_eeprom_s { unsigned char dt7; /* 57 DRAM Case Temperature Rise from Ambient due to Bank Interleave Reads with Auto-Precharge (DT7) */ - unsigned char psiTApll; /* 58 Thermal Resistance of PLL Package form - Top (Case) to Ambient (Psi T-A PLL) */ - unsigned char psiTAreg; /* 59 Thermal Reisitance of Register Package - from Top (Case) to Ambient + unsigned char psi_ta_pll; /* 58 Thermal Resistance of PLL Package + from Top (Case) to Ambient + (Psi T-A PLL) */ + unsigned char psi_ta_reg; /* 59 Thermal Resistance of Register + Package from Top (Case) to Ambient (Psi T-A Register) */ unsigned char dtpllactive; /* 60 PLL Case Temperature Rise from Ambient due to PLL Active (DT PLL Active) */ @@ -191,41 +193,41 @@ typedef struct ddr3_spd_eeprom_s { Dividend / Divisor */ unsigned char mtb_dividend; /* 10 Medium Timebase (MTB) Dividend */ unsigned char mtb_divisor; /* 11 Medium Timebase (MTB) Divisor */ - unsigned char tCK_min; /* 12 SDRAM Minimum Cycle Time */ + unsigned char tck_min; /* 12 SDRAM Minimum Cycle Time */ unsigned char res_13; /* 13 Reserved */ unsigned char caslat_lsb; /* 14 CAS Latencies Supported, Least Significant Byte */ unsigned char caslat_msb; /* 15 CAS Latencies Supported, Most Significant Byte */ - unsigned char tAA_min; /* 16 Min CAS Latency Time */ - unsigned char tWR_min; /* 17 Min Write REcovery Time */ - unsigned char tRCD_min; /* 18 Min RAS# to CAS# Delay Time */ - unsigned char tRRD_min; /* 19 Min Row Active to + unsigned char taa_min; /* 16 Min CAS Latency Time */ + unsigned char twr_min; /* 17 Min Write REcovery Time */ + unsigned char trcd_min; /* 18 Min RAS# to CAS# Delay Time */ + unsigned char trrd_min; /* 19 Min Row Active to Row Active Delay Time */ - unsigned char tRP_min; /* 20 Min Row Precharge Delay Time */ - unsigned char tRAS_tRC_ext; /* 21 Upper Nibbles for tRAS and tRC */ - unsigned char tRAS_min_lsb; /* 22 Min Active to Precharge + unsigned char trp_min; /* 20 Min Row Precharge Delay Time */ + unsigned char tras_trc_ext; /* 21 Upper Nibbles for tRAS and tRC */ + unsigned char tras_min_lsb; /* 22 Min Active to Precharge Delay Time */ - unsigned char tRC_min_lsb; /* 23 Min Active to Active/Refresh + unsigned char trc_min_lsb; /* 23 Min Active to Active/Refresh Delay Time, LSB */ - unsigned char tRFC_min_lsb; /* 24 Min Refresh Recovery Delay Time */ - unsigned char tRFC_min_msb; /* 25 Min Refresh Recovery Delay Time */ - unsigned char tWTR_min; /* 26 Min Internal Write to + unsigned char trfc_min_lsb; /* 24 Min Refresh Recovery Delay Time */ + unsigned char trfc_min_msb; /* 25 Min Refresh Recovery Delay Time */ + unsigned char twtr_min; /* 26 Min Internal Write to Read Command Delay Time */ - unsigned char tRTP_min; /* 27 Min Internal Read to Precharge + unsigned char trtp_min; /* 27 Min Internal Read to Precharge Command Delay Time */ - unsigned char tFAW_msb; /* 28 Upper Nibble for tFAW */ - unsigned char tFAW_min; /* 29 Min Four Activate Window + unsigned char tfaw_msb; /* 28 Upper Nibble for tFAW */ + unsigned char tfaw_min; /* 29 Min Four Activate Window Delay Time*/ unsigned char opt_features; /* 30 SDRAM Optional Features */ unsigned char therm_ref_opt; /* 31 SDRAM Thermal and Refresh Opts */ unsigned char therm_sensor; /* 32 Module Thermal Sensor */ unsigned char device_type; /* 33 SDRAM device type */ - int8_t fine_tCK_min; /* 34 Fine offset for tCKmin */ - int8_t fine_tAA_min; /* 35 Fine offset for tAAmin */ - int8_t fine_tRCD_min; /* 36 Fine offset for tRCDmin */ - int8_t fine_tRP_min; /* 37 Fine offset for tRPmin */ - int8_t fine_tRC_min; /* 38 Fine offset for tRCmin */ + int8_t fine_tck_min; /* 34 Fine offset for tCKmin */ + int8_t fine_taa_min; /* 35 Fine offset for tAAmin */ + int8_t fine_trcd_min; /* 36 Fine offset for tRCDmin */ + int8_t fine_trp_min; /* 37 Fine offset for tRPmin */ + int8_t fine_trc_min; /* 38 Fine offset for tRCmin */ unsigned char res_39_59[21]; /* 39-59 Reserved, General Section */
/* Module-Specific Section: Bytes 60-116 */
Priyanka Jain
