[U-Boot-Users] [git patch] flat device tree
Please pull from 'ft_infr' branch of git.kernel.org:/pub/scm/boot/u-boot/u-boot.git
to receive the following updates:
CHANGELOG | 28 ++++++++++++++++++++++++++ README | 17 ++++++++++++++++ common/cmd_bootm.c | 16 +++++++++------ common/ft_build.c | 49 ++++++++++++++++++++++++++++++++++++----------- cpu/mpc83xx/cpu.c | 38 ++++++++++++++++++++++++++++++++++++ include/configs/stxxtc.h | 2 + include/ft_build.h | 4 ++- 7 files changed, 136 insertions(+), 18 deletions(-)
Kumar Gala: Added CONFIG_ options for bd_t and env in flat dev tree Allow board code to fixup the flat device tree before booting a Added OF_STDOUT_PATH and OF_SOC Add support for passing initrd information via flat device tree Add helper function for generic flat device tree fixups for mpc83xx
diff --git a/CHANGELOG b/CHANGELOG index c1da98f..1ad9bd3 100644 --- a/CHANGELOG +++ b/CHANGELOG @@ -2,6 +2,34 @@ Changes since U-Boot 1.1.4: ======================================================================
+* Add helper function for generic flat device tree fixups for mpc83xx + Patch by Kumar Gala 11 Jan 2006 + +* Add support for passing initrd information via flat device tree + Patch by Kumar Gala 11 Jan 2006 + +* Added OF_STDOUT_PATH and OF_SOC + + OF_STDOUT_PATH specifies the path to the device the kernel can use + for console output + + OF_SOC specifies the proper name of the SOC node if one exists. + Patch by Kumar Gala 11 Jan 2006 + +* Allow board code to fixup the flat device tree before booting a + kernel + Patch by Kumar Gala 11 Jan 2006 + +* Added CONFIG_ options for bd_t and env in flat dev tree + + CONFIG_OF_HAS_BD_T will put a copy of the bd_t + into the resulting flat device tree. + + CONFIG_OF_HAS_UBOOT_ENV will copy the environment + variables from u-boot into the flat device tree + + Patch by Kumar Gala 11 Jan 2006 + * Add support for 28F256J3A flah (=> 64 MB) on PM520 board
* Fix compiler problem with at91rm9200dk board. diff --git a/README b/README index 6f61008..ecaef9e 100644 --- a/README +++ b/README @@ -411,7 +411,24 @@ The following options need to be configu The maximum size of the constructed OF tree.
OF_CPU - The proper name of the cpus node. + OF_SOC - The proper name of the soc node. OF_TBCLK - The timebase frequency. + OF_STDOUT_PATH - The path to the console device + + CONFIG_OF_HAS_BD_T + + The resulting flat device tree will have a copy of the bd_t. + Space should be pre-allocated in the dts for the bd_t. + + CONFIG_OF_HAS_UBOOT_ENV + + The resulting flat device tree will have a copy of u-boot's + environment variables + + CONFIG_OF_BOARD_SETUP + + Board code has addition modification that it wants to make + to the flat device tree before handing it off to the kernel
- Serial Ports: CFG_PL010_SERIAL diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 8599a49..9562dbe 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -819,7 +819,7 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int fl (*kernel) (kbd, initrd_start, initrd_end, cmd_start, cmd_end);
#else - ft_setup(of_flat_tree, OF_FLAT_TREE_MAX_SIZE, kbd); + ft_setup(of_flat_tree, OF_FLAT_TREE_MAX_SIZE, kbd, initrd_start, initrd_end); /* ft_dump_blob(of_flat_tree); */
#if defined(CFG_INIT_RAM_LOCK) && !defined(CONFIG_E500) @@ -828,12 +828,16 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int fl /* * Linux Kernel Parameters: * r3: ptr to OF flat tree, followed by the board info data - * r4: initrd_start or 0 if no initrd - * r5: initrd_end - unused if r4 is 0 - * r6: Start of command line string - * r7: End of command line string + * r4: physical pointer to the kernel itself + * r5: NULL + * r6: NULL + * r7: NULL */ - (*kernel) ((bd_t *)of_flat_tree, initrd_start, initrd_end, cmd_start, cmd_end); + if (getenv("disable_of") != NULL) + (*kernel) ((bd_t *)of_flat_tree, initrd_start, initrd_end, + cmd_start, cmd_end); + else + (*kernel) ((bd_t *)of_flat_tree, (ulong)kernel, 0, 0, 0);
#endif } diff --git a/common/ft_build.c b/common/ft_build.c index 65a274f..9e9c906 100644 --- a/common/ft_build.c +++ b/common/ft_build.c @@ -163,7 +163,7 @@ void ft_add_rsvmap(struct ft_cxt *cxt, u ((u64 *) cxt->pres)[0] = cpu_to_be64(physaddr); /* phys = 0, size = 0, terminate */ ((u64 *) cxt->pres)[1] = cpu_to_be64(size);
- cxt->pres += 18; /* advance */ + cxt->pres += 16; /* advance */
((u64 *) cxt->pres)[0] = 0; /* phys = 0, size = 0, terminate */ ((u64 *) cxt->pres)[1] = 0; @@ -529,6 +529,7 @@ extern uchar(*env_get_char) (int);
#define BDM(x) { .name = #x, .offset = offsetof(bd_t, bi_ ##x ) }
+#ifdef CONFIG_OF_HAS_BD_T static const struct { const char *name; int offset; @@ -574,19 +575,24 @@ static const struct { #endif BDM(baudrate), }; +#endif
-void ft_setup(void *blob, int size, bd_t * bd) +void ft_setup(void *blob, int size, bd_t * bd, ulong initrd_start, ulong initrd_end) { - DECLARE_GLOBAL_DATA_PTR; - u8 *end; u32 *p; int len; struct ft_cxt cxt; - int i, k, nxt; - static char tmpenv[256]; - char *s, *lval, *rval; ulong clock; - uint32_t v; +#if defined(CONFIG_OF_HAS_UBOOT_ENV) + int k, nxt; +#endif +#if defined(CONFIG_OF_HAS_BD_T) + u8 *end; +#endif +#if defined(CONFIG_OF_HAS_UBOOT_ENV) || defined(CONFIG_OF_HAS_BD_T) + int i; + static char tmpenv[256]; +#endif
/* disable OF tree; booting old kernel */ if (getenv("disable_of") != NULL) { @@ -596,7 +602,8 @@ void ft_setup(void *blob, int size, bd_t
ft_begin(&cxt, blob, size);
- /* fs_add_rsvmap not used */ + if (initrd_start && initrd_end) + ft_add_rsvmap(&cxt, initrd_start, initrd_end - initrd_start + 1);
ft_begin_tree(&cxt);
@@ -610,9 +617,12 @@ void ft_setup(void *blob, int size, bd_t /* back into root */ ft_backtrack_node(&cxt);
+#ifdef CONFIG_OF_HAS_UBOOT_ENV ft_begin_node(&cxt, "u-boot-env");
for (i = 0; env_get_char(i) != '\0'; i = nxt + 1) { + char *s, *lval, *rval; + for (nxt = i; env_get_char(nxt) != '\0'; ++nxt) ; s = tmpenv; for (k = i; k < nxt && s < &tmpenv[sizeof(tmpenv) - 1]; ++k) @@ -629,12 +639,20 @@ void ft_setup(void *blob, int size, bd_t }
ft_end_node(&cxt); +#endif
ft_begin_node(&cxt, "chosen");
ft_prop_str(&cxt, "name", "chosen"); ft_prop_str(&cxt, "bootargs", getenv("bootargs")); ft_prop_int(&cxt, "linux,platform", 0x600); /* what is this? */ + if (initrd_start && initrd_end) { + ft_prop_int(&cxt, "linux,initrd-start", initrd_start); + ft_prop_int(&cxt, "linux,initrd-end", initrd_end); + } +#ifdef OF_STDOUT_PATH + ft_prop_str(&cxt, "linux,stdout-path", OF_STDOUT_PATH); +#endif
ft_end_node(&cxt);
@@ -647,14 +665,19 @@ void ft_setup(void *blob, int size, bd_t ft_dump_blob(blob); */
+#ifdef CONFIG_OF_HAS_BD_T /* paste the bd_t at the end of the flat tree */ end = (char *)blob + be32_to_cpu(((struct boot_param_header *)blob)->totalsize); memcpy(end, bd, sizeof(*bd)); +#endif
#ifdef CONFIG_PPC
+#ifdef CONFIG_OF_HAS_BD_T for (i = 0; i < sizeof(bd_map)/sizeof(bd_map[0]); i++) { + uint32_t v; + sprintf(tmpenv, "/bd_t/%s", bd_map[i].name); v = *(uint32_t *)((char *)bd + bd_map[i].offset);
@@ -670,6 +693,7 @@ void ft_setup(void *blob, int size, bd_t p = ft_get_prop(blob, "/bd_t/ethspeed", &len); if (p != NULL) *p = cpu_to_be32((uint32_t) bd->bi_ethspeed); +#endif
clock = bd->bi_intfreq; p = ft_get_prop(blob, "/cpus/" OF_CPU "/clock-frequency", &len); @@ -680,11 +704,14 @@ void ft_setup(void *blob, int size, bd_t clock = OF_TBCLK; p = ft_get_prop(blob, "/cpus/" OF_CPU "/timebase-frequency", &len); if (p != NULL) - *p = cpu_to_be32(OF_TBCLK); + *p = cpu_to_be32(clock); #endif - #endif /* __powerpc__ */
+#ifdef CONFIG_OF_BOARD_SETUP + ft_board_setup(blob, bd); +#endif + /* printf("final OF-tree\n"); ft_dump_blob(blob); diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index 8c9b515..e49e4fe 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -35,6 +35,7 @@ #include <watchdog.h> #include <command.h> #include <mpc83xx.h> +#include <ft_build.h> #include <asm/processor.h>
@@ -151,3 +152,40 @@ void watchdog_reset (void) hang(); /* FIXME: implement watchdog_reset()? */ } #endif /* CONFIG_WATCHDOG */ + +#if defined(CONFIG_OF_FLAT_TREE) +void +ft_cpu_setup(void *blob, bd_t *bd) +{ + u32 *p; + int len; + ulong clock; + + clock = bd->bi_busfreq; + p = ft_get_prop(blob, "/cpus/" OF_CPU "/bus-frequency", &len); + if (p != NULL) + *p = cpu_to_be32(clock); + + p = ft_get_prop(blob, "/" OF_SOC "/bus-frequency", &len); + if (p != NULL) + *p = cpu_to_be32(clock); + + p = ft_get_prop(blob, "/" OF_SOC "/serial@4500/clock-frequency", &len); + if (p != NULL) + *p = cpu_to_be32(clock); + + p = ft_get_prop(blob, "/" OF_SOC "/serial@4600/clock-frequency", &len); + if (p != NULL) + *p = cpu_to_be32(clock); + +#ifdef CONFIG_MPC83XX_TSEC1 + p = ft_get_prop(blob, "/" OF_SOC "/ethernet@24000/address", &len); + memcpy(p, bd->bi_enetaddr, 6); +#endif + +#ifdef CONFIG_MPC83XX_TSEC2 + p = ft_get_prop(blob, "/" OF_SOC "/ethernet@25000/address", &len); + memcpy(p, bd->bi_enet1addr, 6); +#endif +} +#endif diff --git a/include/configs/stxxtc.h b/include/configs/stxxtc.h index 3ffe6b2..be6c36c 100644 --- a/include/configs/stxxtc.h +++ b/include/configs/stxxtc.h @@ -584,5 +584,7 @@ typedef unsigned int led_id_t;
#define OF_CPU "PowerPC,MPC870@0" #define OF_TBCLK (MPC8XX_HZ / 16) +#define CONFIG_OF_HAS_BD_T 1 +#define CONFIG_OF_HAS_UBOOT_ENV 1
#endif /* __CONFIG_H */ diff --git a/include/ft_build.h b/include/ft_build.h index 9104b1a..47ca575 100644 --- a/include/ft_build.h +++ b/include/ft_build.h @@ -57,10 +57,12 @@ void ft_prop_int(struct ft_cxt *cxt, con void ft_begin(struct ft_cxt *cxt, void *blob, int max_size); void ft_add_rsvmap(struct ft_cxt *cxt, u64 physaddr, u64 size);
-void ft_setup(void *blob, int size, bd_t * bd); +void ft_setup(void *blob, int size, bd_t * bd, ulong initrd_start, ulong initrd_end);
void ft_dump_blob(const void *bphp); void ft_merge_blob(struct ft_cxt *cxt, void *blob); void *ft_get_prop(void *bphp, const char *propname, int *szp);
+void ft_board_setup(void *blob, bd_t *bd); + #endif
In message Pine.LNX.4.44.0601231745140.21555-100000@gate.crashing.org you wrote:
Done. Thanks.
Kumar Gala
