[U-Boot] [PATCH u-boot 0/2] Add MMD PHY helpers
Introduce phy_(read|write)_mmd() generic 802.3 clause 45 register accessors for Clause 22 PHYs, using the indirect method. Allow this behaviour to be overriden by PHY drivers where necessary.
Carlo Caione (2): net: phy: Add support for accessing MMD PHY registers cmd: mdio: Add new parameter to access MMD PHY registers
cmd/mdio.c | 33 ++++++++++++++++++----- drivers/net/phy/phy.c | 4 +++ include/phy.h | 62 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 93 insertions(+), 6 deletions(-)
Two new helper functions (phy_read_mmd() and phy_write_mmd()) are added to allow access to the MMD PHY registers.
The MMD PHY registers can be accessed by two means:
1. Using two new MMD access function hooks in the PHY driver. These functions can be implemented when the PHY driver does not support the standard IEEE Compatible clause 45 access mechanism described in clause 22 or if the PHY uses its own non-standard access mechanism.
2. The standard clause 45 access extensions to the MMD registers through the indirection registers (clause 22) in all the other cases.
Signed-off-by: Carlo Caione ccaione@baylibre.com --- drivers/net/phy/phy.c | 4 +++ include/phy.h | 62 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 66 insertions(+)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index cda4caa803..6769047407 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -549,6 +549,10 @@ int phy_register(struct phy_driver *drv) drv->readext += gd->reloc_off; if (drv->writeext) drv->writeext += gd->reloc_off; + if (drv->read_mmd) + drv->read_mmd += gd->reloc_off; + if (drv->write_mmd) + drv->write_mmd += gd->reloc_off; #endif return 0; } diff --git a/include/phy.h b/include/phy.h index b86fdfb2ce..0ce41661fa 100644 --- a/include/phy.h +++ b/include/phy.h @@ -101,6 +101,13 @@ struct phy_driver { int (*readext)(struct phy_device *phydev, int addr, int devad, int reg); int (*writeext)(struct phy_device *phydev, int addr, int devad, int reg, u16 val); + + /* Phy specific driver override for reading a MMD register */ + int (*read_mmd)(struct phy_device *phydev, int devad, int reg); + + /* Phy specific driver override for writing a MMD register */ + int (*write_mmd)(struct phy_device *phydev, int devad, int reg, u16 val); + struct list_head list; };
@@ -164,6 +171,61 @@ static inline int phy_write(struct phy_device *phydev, int devad, int regnum, return bus->write(bus, phydev->addr, devad, regnum, val); }
+static inline void phy_mmd_indirect(struct phy_device *phydev, int devad, + int regnum) +{ + /* Write the desired MMD Devad */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_MMD_CTRL, devad); + + /* Write the desired MMD register address */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_MMD_DATA, regnum); + + /* Select the Function : DATA with no post increment */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_MMD_CTRL, (devad | MII_MMD_CTRL_NOINCR)); +} + +static inline int phy_read_mmd(struct phy_device *phydev, int devad, + int regnum) +{ + int ret; + + if (regnum > (u16)~0 || devad > 32) + return -EINVAL; + + if (phydev->drv->read_mmd) { + ret = phydev->drv->read_mmd(phydev, devad, regnum); + } else { + phy_mmd_indirect(phydev, devad, regnum); + + /* Read the content of the MMD's selected register */ + ret = phy_read(phydev, MDIO_DEVAD_NONE, MII_MMD_DATA); + } + + return ret; +} + +static inline int phy_write_mmd(struct phy_device *phydev, int devad, + int regnum, u16 val) +{ + int ret; + + if (regnum > (u16)~0 || devad > 32) + return -EINVAL; + + if (phydev->drv->write_mmd) { + ret = phydev->drv->write_mmd(phydev, devad, regnum, val); + } else { + phy_mmd_indirect(phydev, devad, regnum); + + /* Write the data into MMD's selected register */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_MMD_DATA, val); + + ret = 0; + } + + return ret; +} + #ifdef CONFIG_PHYLIB_10G extern struct phy_driver gen10g_driver;
- Using two new MMD access function hooks in the PHY driver. These
- The standard clause 45 access extensions to the MMD registers through
This seems like a duplicate of https://patchwork.ozlabs.org/patch/1015782/
The command patch should probably be adapted to use that.
Thanks, -Joe
Well, I should have looked better. Interestingly I was going to use my patch to fix the exact same issue on a different PHY.
The problem I see with that patch is that it is assuming that all the PHY devices support clause 45 access extension using the clause 22 registers. This is not always true (see for example [0]). That's why I added two new hooks in the PHY driver.
On a side note looking at that patch it seems that 'addr' (documented as the PHY address in the same patch) is being passed to 'phy_write' where we should have the 'devad' parameter instead (MDIO_DEVAD_NONE)?
Let me know if you think it is valuable still to add the two hooks on top of that patch.
Thanks,
[0] https://patchwork.ozlabs.org/patch/351634/
Ah, I didn't realize there were other ways to access it.
That is peculiar... Vlad, that wasn't your intent, was it?
If we have to override the access then probably so. Maybe it would make more sense to have a v2 from you that removes the duplicate code from the ti phy driver and then have Vlad's smartEEE patch be rebased on that.
I have not yet pushed Vlad's patches so we have an opportunity to do it more cleanly potentially.
Thoughts from each of you?
Thanks,
-- Carlo Caione _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
I'll rebase that patch on top of my set and I'll let Vlad submit the smartEEE patch on top.
Hi Carlo, good if you could take care of the TI driver and I will resend the Atheros SmartEEE patch to use phy_read_mmd/phy_write_mmd.
Thanks, -Vladimir
On Wed, Jan 23, 2019 at 8:32 AM Vladimir Oltean vladimir.oltean@nxp.com wrote:
He's already sent a V1 that you could base off of. The changes I requested should not make it incompatible with your Atheros change.
Thanks, -Joe
Thanks, -Vladimir _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Two new parameters (rmmd and wmmd) are added to allow the `mdio` command to access the content of the MMD PHY registers.
Signed-off-by: Carlo Caione ccaione@baylibre.com --- cmd/mdio.c | 33 +++++++++++++++++++++++++++------ 1 file changed, 27 insertions(+), 6 deletions(-)
diff --git a/cmd/mdio.c b/cmd/mdio.c index 184868063a..010632b562 100644 --- a/cmd/mdio.c +++ b/cmd/mdio.c @@ -43,7 +43,7 @@ static int mdio_write_ranges(struct phy_device *phydev, struct mii_dev *bus, int addrlo, int addrhi, int devadlo, int devadhi, int reglo, int reghi, unsigned short data, - int extended) + int extended, int mmd) { int addr, devad, reg; int err = 0; @@ -51,7 +51,9 @@ static int mdio_write_ranges(struct phy_device *phydev, struct mii_dev *bus, for (addr = addrlo; addr <= addrhi; addr++) { for (devad = devadlo; devad <= devadhi; devad++) { for (reg = reglo; reg <= reghi; reg++) { - if (!extended) + if (mmd) + err = phy_write_mmd(phydev, devad, reg, data); + else if (!extended) err = bus->write(bus, addr, devad, reg, data); else @@ -71,7 +73,7 @@ err_out: static int mdio_read_ranges(struct phy_device *phydev, struct mii_dev *bus, int addrlo, int addrhi, int devadlo, int devadhi, - int reglo, int reghi, int extended) + int reglo, int reghi, int extended, int mmd) { int addr, devad, reg;
@@ -83,7 +85,9 @@ static int mdio_read_ranges(struct phy_device *phydev, struct mii_dev *bus, for (reg = reglo; reg <= reghi; reg++) { int val;
- if (!extended) + if (mmd) + val = phy_read_mmd(phydev, devad, reg); + else if (!extended) val = bus->read(bus, addr, devad, reg); else val = phydev->drv->readext(phydev, addr, @@ -189,6 +193,7 @@ static int do_mdio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) struct mii_dev *bus; struct phy_device *phydev = NULL; int extended = 0; + int mmd = 0;
if (argc < 2) return CMD_RET_USAGE; @@ -232,6 +237,18 @@ static int do_mdio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return -1; } } + if (op[1] == 'm') { + phydev = mdio_phydev_for_ethname(argv[2]); + + if (phydev) { + addrlo = phydev->addr; + addrhi = addrlo; + bus = phydev->bus; + mmd = 1; + } else { + return -1; + } + } }
switch (op[0]) { @@ -265,12 +282,12 @@ static int do_mdio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) switch (op[0]) { case 'w': mdio_write_ranges(phydev, bus, addrlo, addrhi, devadlo, devadhi, - reglo, reghi, data, extended); + reglo, reghi, data, extended, mmd); break;
case 'r': mdio_read_ranges(phydev, bus, addrlo, addrhi, devadlo, devadhi, - reglo, reghi, extended); + reglo, reghi, extended, mmd); break; }
@@ -303,6 +320,10 @@ U_BOOT_CMD( "read PHY's extended register at <devad>.<reg>\n" "mdio wx <phydev> [<devad>.]<reg> <data> - " "write PHY's extended register at <devad>.<reg>\n" + "mdio rmmd <phydev> [<devad>.]<reg> - " + "read PHY's extended register at <devad>.<reg>\n" + "mdio wmmd <phydev> [<devad>.]<reg> <data> - " + "write PHY's extended register at <devad>.<reg>\n" "<phydev> may be:\n" " <busname> <addr>\n" " <addr>\n"
Carlo Caione
Joe Hershberger
Vladimir Oltean
