[PATCH] mmc: rpmb: Fix driver routing memory alignment with tmp buffer
Fix mmc_rpmb_route_frames() implementation to comply with most MMC drivers that expect some alignment of MMC data frames in memory.
When called from drivers/tee/optee/rpmb.c, the address passed is not aligned properly. OP-TEE OS inserts a 6-byte header before a raw RPMB frame which makes RPMB data buffer not 32bit aligned. To prevent breaking ABI with OPTEE-OS RPC memrefs, allocate a temporary buffer to copy the data into an aligned memory.
Many RPMB drivers implicitly expect 32bit alignment of the eMMC frame including arm_pl180_mmci.c, sandbox_mmc.c and stm32_sdmmc2.c
Signed-off-by: Timothée Cercueil timothee.cercueil@st.com Signed-off-by: Timothée Cercueil litchi.pi@protonmail.com --- drivers/mmc/rpmb.c | 18 ++++++++++++++++-- 1 file changed, 16 insertions(+), 2 deletions(-)
Changes since v1: - Fixed the Signed-off-by errors from previous patch. - This patch follows the subject discussed at: https://lists.denx.de/pipermail/u-boot/2021-June/451687.html - Changed the commit log 1st line
diff --git a/drivers/mmc/rpmb.c b/drivers/mmc/rpmb.c index ea7e506666..b68d98573c 100644 --- a/drivers/mmc/rpmb.c +++ b/drivers/mmc/rpmb.c @@ -480,10 +480,24 @@ int mmc_rpmb_route_frames(struct mmc *mmc, void *req, unsigned long reqlen, * and possibly just delay an eventual error which will be harder * to track down. */ + void *rpmb_data = NULL; + int ret;
if (reqlen % sizeof(struct s_rpmb) || rsplen % sizeof(struct s_rpmb)) return -EINVAL;
- return rpmb_route_frames(mmc, req, reqlen / sizeof(struct s_rpmb), - rsp, rsplen / sizeof(struct s_rpmb)); + if (!IS_ALIGNED((uintptr_t)req, ARCH_DMA_MINALIGN)) { + /* Memory alignment is required by MMC driver */ + rpmb_data = malloc(reqlen); + if (!rpmb_data) + return -ENOMEM; + + memcpy(rpmb_data, req, reqlen); + req = rpmb_data; + } + + ret = rpmb_route_frames(mmc, req, reqlen / sizeof(struct s_rpmb), + rsp, rsplen / sizeof(struct s_rpmb)); + free(rpmb_data); + return ret; } -- 2.17.1
Hello, Does anyone have a feedback on that fix ? I think the location of the fix is important to be discussed too as it needs to be generic but not overlap with existing checks. Have a nice day, Timothée Cercueil
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Tuesday, June 15th, 2021 at 10:53 AM, Timothée Cercueil litchi.pi@protonmail.com wrote:
Changes since v1:
to track down.
int ret;
return -EINVAL;
if (!rpmb_data)
return -ENOMEM;
req = rpmb_data;
free(rpmb_data);
return ret;
2.17.1
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Timothée Cercueil
Changes since v1:
This patch follows the subject discussed at: https://protect2.fireeye.com/v1/url?k=f4826206-ab195acc-f483e949-0cc47a31bee...
to track down.
int ret;
return -EINVAL;
if (!rpmb_data)
return -ENOMEM;
req = rpmb_data;
free(rpmb_data);
return ret;
2.17.1
Jaehoon Chung
litchi.pi
Timothée Cercueil
