[U-Boot] [PATCH 1/3] mtd: rawnand: denali-spl: Add missing hardware init
While the Denali NAND is initialized by the BootROM in SPL, there are still a couple of settings which are missing. These can trigger subtle corruption of the data read out of the NAND. Fill these settings in just like they are filled in by the full Denali NAND driver in denali_hw_init().
Signed-off-by: Marek Vasut marex@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mtd/nand/raw/denali_spl.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/mtd/nand/raw/denali_spl.c b/drivers/mtd/nand/raw/denali_spl.c index dbaba3cab2..b8b29812aa 100644 --- a/drivers/mtd/nand/raw/denali_spl.c +++ b/drivers/mtd/nand/raw/denali_spl.c @@ -173,6 +173,13 @@ void nand_init(void) page_size = readl(denali_flash_reg + DEVICE_MAIN_AREA_SIZE); oob_size = readl(denali_flash_reg + DEVICE_SPARE_AREA_SIZE); pages_per_block = readl(denali_flash_reg + PAGES_PER_BLOCK); + + /* Do as denali_hw_init() does. */ + writel(CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES, + denali_flash_reg + SPARE_AREA_SKIP_BYTES); + writel(0x0F, denali_flash_reg + RB_PIN_ENABLED); + writel(CHIP_EN_DONT_CARE__FLAG, denali_flash_reg + CHIP_ENABLE_DONT_CARE); + writel(0xffff, denali_flash_reg + SPARE_AREA_MARKER); }
int nand_spl_load_image(uint32_t offs, unsigned int size, void *dst)
The SoCFPGA Gen5 does not have a clock driver yet, let the NAND driver work without a clock driver by falling back to the default frequencies.
Signed-off-by: Marek Vasut marex@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mtd/nand/raw/denali_dt.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/denali_dt.c b/drivers/mtd/nand/raw/denali_dt.c index 0ce81324b9..2c9e249ab6 100644 --- a/drivers/mtd/nand/raw/denali_dt.c +++ b/drivers/mtd/nand/raw/denali_dt.c @@ -62,7 +62,6 @@ static int denali_dt_probe(struct udevice *dev) { struct denali_nand_info *denali = dev_get_priv(dev); const struct denali_dt_data *data; - struct clk clk, clk_x, clk_ecc; struct resource res; int ret;
@@ -87,11 +86,14 @@ static int denali_dt_probe(struct udevice *dev)
denali->host = devm_ioremap(dev, res.start, resource_size(&res));
+#if CONFIG_IS_ENABLED(CLK) + struct clk clk, clk_x, clk_ecc; + ret = clk_get_by_name(dev, "nand", &clk); if (ret) ret = clk_get_by_index(dev, 0, &clk); if (ret) - return ret; + clk.dev = NULL;
ret = clk_get_by_name(dev, "nand_x", &clk_x); if (ret) @@ -117,10 +119,12 @@ static int denali_dt_probe(struct udevice *dev) return ret; }
- if (clk_x.dev) { + if (clk.dev && clk_x.dev) { denali->clk_rate = clk_get_rate(&clk); denali->clk_x_rate = clk_get_rate(&clk_x); - } else { + } else +#endif + { /* * Hardcode the clock rates for the backward compatibility. * This works for both SOCFPGA and UniPhier.
return ret;
clk.dev = NULL;
This line changes the 'clk' optional. Do you need additional #if CONFIG_IS_ENABLED(CLK) ?
BTW, in Linux, clk_get() and clk_enable() are no-op when CONFIG_HAVE_CLK is unset.
The U-Boot's clk_get() returns -ENOSYS, hence drivers tend to be ugly. I already stopped caring the U-Boot code, though.
if (clk_x.dev) {
} else {
} else
-- 2.24.0.432.g9d3f5f5b63
-- Best Regards
Masahiro Yamada
return ret;
clk.dev = NULL;
This whole block is in such ifdef.
Because of the DM ?
Legacy kernel versions for SoCFPGA may not implement proper reset handling. Apply the same approach as SoCFPGA reset driver, check environment variable "socfpga_legacy_reset_compat", and if it is set, do not reset the IP before booting Linux. This way, even the older kernel versions can be booted by up to date U-Boot.
Signed-off-by: Marek Vasut marex@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mtd/nand/raw/denali_dt.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/mtd/nand/raw/denali_dt.c b/drivers/mtd/nand/raw/denali_dt.c index 2c9e249ab6..d35f2a3543 100644 --- a/drivers/mtd/nand/raw/denali_dt.c +++ b/drivers/mtd/nand/raw/denali_dt.c @@ -148,6 +148,18 @@ static int denali_dt_remove(struct udevice *dev) { struct denali_nand_info *denali = dev_get_priv(dev);
+#if CONFIG_IS_ENABLED(ARCH_SOCFPGA) + /* + * Legacy kernel versions do not implement proper reset handling on + * SoCFPGA. To let those older kernel versions work, reuse the same + * approach as the SoCFPGA reset driver does -- check environment + * variable socfpga_legacy_reset_compat and avoid resetting the IP + * before booting the kernel if it is set to 1. + */ + if (env_get_ulong("socfpga_legacy_reset_compat", 10, 0)) + return 0; +#endif + return reset_release_bulk(&denali->resets); }
What is "legacy kernel versions" ?
How about removing denali_dt_remove() entirely ?
Not only SOCFPGA, but also my boards are broken.
I am really annoyed since the following commit:
commit ed784ac3822b7d7019679a41a17907296e2dadbe Author: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com AuthorDate: Fri Mar 1 20:12:34 2019 +0100 Commit: Marek Vasut marex@denx.de CommitDate: Wed Apr 17 22:20:16 2019 +0200
mtd: rawnand: denali: add reset handling
This adds reset handling to the devicetree-enabled Denali NAND driver.
For backwards compatibility, only a warning is printed when failing to get reset handles.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Anything older than 5.x , which got proper reset handling, finally.
Fine by me.
How come ?
mtd: rawnand: denali: add reset handling This adds reset handling to the devicetree-enabled Denali NAND driver. For backwards compatibility, only a warning is printed when failing to get reset handles. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
CCing Simon.
Really? Could you tell the commit ID?
Fine by me.
How come ?
Because the Linux kernel version I am using does not have the reset handling for the Denali driver.
CCing Simon. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
commit 37f7453a4b7aa3e1d1608edeb500b105257ee945 ARM: dts: socfpga: update missing reset property peripherals
commit 1c909b2dfe6a21de2c24dc1c1405593e40e3a88c ARM: dts: socfpga: update more missing reset properties
These are just DT updates.
I do not see any proper reset handling in drivers/mtd/nand/raw/denali*.c
I am curious how the NAND reset is working in your kernel.
-- Best Regards Masahiro Yamada
Yes, DT updates which actually wire the reset to the IP so it can be toggled.
It was not working at all until those patches were in.
On Thu, Nov 21, 2019 at 6:38 AM Marek Vasut wrote: > > Legacy kernel versions for SoCFPGA may not implement proper reset > handling.
I am asking where the reset _consumer_ code is.
I'd like to find where reset_control_get* reset_control_deassert() are called for the NAND reset.
It was not working at all until those patches were in. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
On 11/26/19 3:47 AM, Masahiro Yamada wrote: > On Thu, Nov 21, 2019 at 6:38 AM Marek Vasut wrote: >> >> Legacy kernel versions for SoCFPGA may not implement proper reset >> handling. > > What is "legacy kernel versions" ?
Clearly nowhere if the old kernels do not implement the reset properly.
Fine by me.
How come ?
Sorry to break anything there. I fail to see what's wrong with that commit, could you tell me more details so we can fix this?
CCing Simon.
I'd like to know this in more detailed.
I assume these registers are set up by the BootROM, and SPL is supposed to read data in the same manner as the Boot ROM.
In which situation does the data get corrupted?
I guess you tested this for SOCFPGA.
Please tell me the value of CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES.
When I boot the board, these registers are not set up correctly. The bootrom reads the SPL fine, but the SPL cannot read U-Boot anymore, probably because the bootrom does something funny to the controller settings.
2
Interesting. The boot ROM can load SPL from a NAND device, but SPL cannot load U-Boot from it in the same manner.
How did you burn SPL, U-Boot proper, respectively? Were they written in different ways?
2
U-Boot proper, all of it.
2
CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=2 is the only value that works with the Boot ROM, right?
How did you find the correct value is 2 ?
Is it documented in the SOCFPGA datasheet or somewhere? Or, did you repeat try-and-error?
2
I took it from the old vendoruboot port.
Masahiro Yamada
Simon Goldschmidt
