[U-Boot] VEXPRESS64 ARMv8 U-Boot maintenance
Hi folks (David & Steve listed as AArch64/v8 maintainers),
are you actively maintaining and reviewing ARM64 board patches?
I am working on support for the ARM Juno Development Platform real hardware, which is now up and running on my desk. I will add this board with myself as maintainer.
But who takes care of the code in arch/arm/cpu/armv8?
I have some questions about the rendez-vous code in the armv8 start.S file, as if two CPUs (master & slave) would come running into U-Boot, which is not what ARM Trusted Firmware does, it arrives only on the master CPU. Can any of you explain why that code is there?
Else I will start looking at it and add myself as maintainer for this.
Please also have a look at my patches to the Semihosting code: http://patchwork.ozlabs.org/patch/412628/ http://patchwork.ozlabs.org/patch/412629/ http://patchwork.ozlabs.org/patch/412630/
Yours, Linus Walleij
Oh good. I was hoping someone would get a chance to do this. I had a few more ideas about what might have been needed but haven't been able to cycle back around to hooking mine up and playing again.
Currently it falls under Albert's care as the overall core ARM maintainer.
I think the overall answer here is that as the code base and implementation evolves everywhere, we'll need some adjustments to match up. Please make sure to keep York Sun in the loop too as Freescale is active in this area as well (and the other Freescale folks too as they transition from multi-core PowerPC to multi-core ARMv8 :)). Thanks!
Sadly, no. If you would take over being maintainer for the "vexpress_aemv8a_semi" board, that would be appreciated. Thanks, Steve
I will look at these -- Thanks, Steve
Linus Walleij
Steve Rae
