[U-Boot] [PATCH] configs: Remove empty #ifdef/#ifndef blocks from configs
Remove empty #ifdef/#ifndef..#endif blocks where the configuration they guarded has been completely removed.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
arch/powerpc/include/asm/config.h | 3 --- include/configs/MPC8610HPCD.h | 2 -- include/configs/P1022DS.h | 3 --- include/configs/T102xQDS.h | 2 -- include/configs/T208xQDS.h | 2 -- include/configs/UCP1020.h | 2 -- include/configs/advantech_dms-ba16.h | 3 --- include/configs/controlcenterd.h | 3 --- include/configs/cyrus.h | 3 --- include/configs/ea20.h | 7 ------- include/configs/ethernut5.h | 3 --- include/configs/ge_bx50v3.h | 3 --- include/configs/ipam390.h | 3 --- include/configs/lacie_kw.h | 6 ------ include/configs/mx6ul_14x14_evk.h | 3 --- include/configs/omapl138_lcdk.h | 3 --- include/configs/sunxi-common.h | 3 --- include/configs/tegra-common-post.h | 4 ---- include/configs/zynq-common.h | 4 ---- 19 files changed, 62 deletions(-)
diff --git a/arch/powerpc/include/asm/config.h b/arch/powerpc/include/asm/config.h index 284cfe21ab..bf11f40e23 100644 --- a/arch/powerpc/include/asm/config.h +++ b/arch/powerpc/include/asm/config.h @@ -14,9 +14,6 @@ #include <asm/config_mpc86xx.h> #endif
-#ifdef CONFIG_MPC83xx -#endif - #ifndef HWCONFIG_BUFFER_SIZE #define HWCONFIG_BUFFER_SIZE 256 #endif diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 24f9fca53c..ddfb241010 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -259,8 +259,6 @@ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */
#define CONFIG_ULI526X -#ifdef CONFIG_ULI526X -#endif
/************************************************************ * USB support diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 1b347541c0..63a4d12560 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -363,9 +363,6 @@ #undef CONFIG_SYS_FLASH_EMPTY_INFO #endif
-#ifndef CONFIG_FSL_DIU_FB -#endif - #ifdef CONFIG_ATI #define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT #define CONFIG_BIOSEMU diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index e457135e56..042cc360ad 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -515,8 +515,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#ifndef CONFIG_SPL_BUILD -#endif #define CONFIG_SPI_FLASH_BAR #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index f5d454b002..ba7980a22d 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -509,8 +509,6 @@ unsigned long get_board_ddr_clk(void); * eSPI - Enhanced SPI */ #ifdef CONFIG_SPI_FLASH -#ifndef CONFIG_SPL_BUILD -#endif
#define CONFIG_SPI_FLASH_BAR #define CONFIG_SF_DEFAULT_SPEED 10000000 diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 6231a1e4ae..fad1eabba3 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -38,8 +38,6 @@ #define CONFIG_NETMASK 255.255.252.0 #define CONFIG_ETHPRIME "eTSEC3"
-#ifndef CONFIG_SPI_FLASH -#endif #define CONFIG_SYS_REDUNDAND_ENVIRONMENT
#define CONFIG_SYS_L2_SIZE (256 << 10) diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 8e33d38f97..586e7a77ca 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -225,9 +225,6 @@ #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
-#ifndef CONFIG_SYS_DCACHE_OFF -#endif - #define CONFIG_SYS_FSL_USDHC_NUM 3
/* Framebuffer */ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 1fe6f2fa5e..e5bf048398 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -177,9 +177,6 @@ #define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F #define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100
-#ifndef CONFIG_TRAILBLAZER -#endif - #define CONFIG_PCA9698 /* NXP PCA9698 */
#define CONFIG_SYS_I2C_EEPROM_ADDR 0x52 diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 6ce2bc0042..0ce9a35f11 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -475,7 +475,4 @@
#include <asm/fsl_secure_boot.h>
-#ifdef CONFIG_SECURE_BOOT -#endif - #endif /* __CONFIG_H */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index c84cd962d7..ee122ad7a4 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -111,9 +111,6 @@ #define CONFIG_CLOCKS #endif
-#ifndef CONFIG_DRIVER_TI_EMAC -#endif - /* NAND Setup */ #ifdef CONFIG_SYS_USE_NAND #define CONFIG_MTD_DEVICE @@ -130,10 +127,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #endif
-/* SPI Flash */ -#ifdef CONFIG_USE_SPIFLASH -#endif - #if !defined(CONFIG_SYS_USE_NAND) && \ !defined(CONFIG_USE_NOR) && \ !defined(CONFIG_USE_SPIFLASH) diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index ca5c65fe5a..8913c1609c 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -58,9 +58,6 @@ #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE #define CONFIG_ENV_SPI_MAX_HZ 15000000
-#ifndef MINIMAL_LOADER -#endif - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 1b947db9d4..fef41a8a18 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -188,9 +188,6 @@ #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
/* Framebuffer */ diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index faf21ddb08..08978fa658 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -212,9 +212,6 @@ #define CONFIG_CLOCKS #endif
-#ifndef CONFIG_DRIVER_TI_EMAC -#endif - #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS
diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index ac9ac4aeaa..8af8fd5c63 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -39,12 +39,6 @@ #endif #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
-/* - * Commands configuration - */ -#ifndef CONFIG_NETSPACE_MINI_V2 /* No USB ports on Network Space v2 Mini */ -#endif - /* * Core clock definition */ diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 31305aab1b..da2a67fc21 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -166,9 +166,6 @@ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
-#ifndef CONFIG_SYS_DCACHE_OFF -#endif - #ifdef CONFIG_FSL_QSPI #define CONFIG_SF_DEFAULT_BUS 0 #define CONFIG_SF_DEFAULT_CS 0 diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 58624ec581..879c8a0cff 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -259,9 +259,6 @@ #define CONFIG_CLOCKS #endif
-#ifndef CONFIG_DRIVER_TI_EMAC -#endif - #ifdef CONFIG_USE_NAND #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b515e9bb1f..21371f4919 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -301,9 +301,6 @@ extern int soft_i2c_gpio_scl; #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 #endif
-#ifdef CONFIG_USB_FUNCTION_MASS_STORAGE -#endif - #ifdef CONFIG_USB_KEYBOARD #define CONFIG_PREBOOT #endif diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index 1c0046ac0d..e54428ba43 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -109,15 +109,11 @@ #ifdef CONFIG_SYS_I2C_TEGRA #undef CONFIG_SYS_I2C_TEGRA #endif -#ifdef CONFIG_CMD_I2C -#endif
/* remove USB */ #ifdef CONFIG_USB_EHCI_TEGRA #undef CONFIG_USB_EHCI_TEGRA #endif -#ifdef CONFIG_CMD_USB -#endif
#endif /* CONFIG_SPL_BUILD */
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 55b983fc16..a6f2aceea1 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -40,10 +40,6 @@ # define CONFIG_BOOTP_MAY_FAIL #endif
-/* SPI */ -#ifdef CONFIG_ZYNQ_SPI -#endif - /* QSPI */ #ifdef CONFIG_ZYNQ_QSPI # define CONFIG_SF_DEFAULT_SPEED 30000000
Just out of interest how did you perform these changes? I sent a similar patch for some kirkwood boards (manually generated) but I knew there was bound to be more. If we could automate the process it could be integrated with moveconfig.py.
Some horrid (and pretty dumb) sed & awk, something like:
for f in include/configs/*.h; do awk '/^\s*#\s*if/ {n=NR}; /^\s*#\s*endif/ && NR == n+1 {print n"d;"NR"d;"}' $f | sed -f - -i $f; done
It was seeing yours that reminded I'd tripped over a few of them when doing moveconfig.py manipulations and I should probably clean them up. I did wonder if unifdef could be persuaded to do it, but I couldn't immediately see a way of making it (without explicitly adding support for it).
Python has a multi-line regex support so I think I've figured out a way to automate it using that.
Alex Kiernan
Chris Packham
