[U-Boot] [PATCH v5 00/26]MTD defconfigs/Kconfigs/Makefiles heavy cleanup
Hello,
A year ago, while working on SPI-NAND support in U-Boot, I discovered when modifying Makefiles a confusing organization where: * Sub-directories/files are compiled from the root Makefile * Commands are at the root of everything
First I sent a series to move Makefile entries in their respective directories. Then, I decided to continue working on the clarification of the Makefile hierarchy in MTD and I sent four iterations of this series which did not got merge at that time. Anyway, I revived this series by rebasing all my work and updating everything that needed an update.
Here are the main points of the re-organization: * Rename CONFIG_MTD into CONFIG_DM_MTD to reserve CONFIG_MTD to what is called today CONFIG_MTD_DEVICE. * Fix build dependencies in defconfigs, like: "UBI and NAND depend on MTD". * Fix the Kconfig files to reflect these dependencies (as defconfigs have been updated, nothing should break). * Simplify the Makefiles: compiling the drivers/mtd/nand/raw/ sub-directory should just depend on MTD being compiled and the NAND core as well, there is absolutely no logic to make it depend on CMD_NAND.
The New green Travis CI build for the fifth version of this series is there (yes, 53 iterations):
Please note that the only red test fails because of timeout, not an actual error (at least I could not spot it). It is possible that this series will produce noticeable changes for the users. The only reason for that is because their configuration file was wrong. I have done my best to fix them one by one, but I am not omniscient.
Thanks, Miquèl
Note: as the number of Cc:'ed people reached 184 with get_maintainers.pl I decided to trim the list to: * People interested by the MTD subsystem. * A few maintainers: I had to tweak some defconfigs after more digging than with other boards (k2g, bcm11130, M54418TWR, ls104/108/208). Maintainers of these platforms are Cc:'ed.
Changes since v4: ================= * Rebased on top of v2019.10-rc4. * Fixed tens of configurations that got broken since the last version of this series several months ago. * Added a specific commit for ls104/108/208 configurations.
Changes since v3: ================= * As suggested by Vignesh, SPI_FLASH_MTD depends on MTD. Enforce this in Kconfig with a new patch. There is no defconfig to fix, all defconfigs with SPI_FLASH_MTD already use MTD. * s/coherent Makefile/appropriate Makefile/ in commit title of patch 1. * s/Kconfig/Makefile in commit message of "mtd: nand: remove dependency on commands in Kconfig" and "mtd: ubi: remove dependency on command in Kconfig". * Add Boris R-b tags. * Correct typos pointed by Boris. * Remove the if/endif in cmd/Kconfig about mtdparts, let the "depends on" that was already present. * Use an if/endif block to compile legacy-mtd-utils.c (to avoid failures when both 'sf' and 'nand' commands are compiled-in). * Merge all Makefile changes in one consistent commit as suggested by Boris.
Changes since v2: ================= * Cleanup also applied to the SPL in an additional patch. * NOR dependency on MTD extracted from the patch adding MTD dependencies on commands only to do it in a separate change. * Typo s/copile/compile/ in "rename CONFIG_MTD_DEVICE..." commit log. * No more MTD depencency on SPI_FLASH, only kept on SPI_FLASH_MTD. * Same applies to the sf command. * Avoid compiling the NAND core while it is not needed (not speaking about the raw NAND core, really what is in drivers/mtd/nand:). * Last patch dropping CONFIG_MTD_PARTITIONS forgotten. We need them in order to reduce the final binary size. * Additional fixes in cmd/Kconfig.
Changes since v1: ================= * Squashed both patches from the first series and included them in "mtd: simplify Makefiles". * Added all other patches. * Renamed CONFIG_NAND into CONFIG_MTD_RAW_NAND as suggested.
Miquel Raynal (26): mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NAND mtd: rename CONFIG_MTD -> CONFIG_DM_MTD mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTD mtd: ensure MTD is compiled when there is a NOR flash mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flash mtd: ensure MTD is compiled when there is a SPI NOR flash using MTD mtd: ensure UBI is compiled when using fastmap mtd: ensure MTD is compiled when UBI is used mtd: ensure UBI is compiled when CMD_UBI is selected mtd: ensure UBI is compiled when ENV_IS_IN_UBI is selected mtd: ensure MTD_RAW_NAND is compiled when ENV_IS_IN_NAND is selected mtd: ensure CMD_NAND is compiled when its options are selected mtd: ensure MTD is compiled when CMD_MTDPARTS is selected configs: move CONFIG_MTD in defconfigs when set in arch includes configs: remove raw NAND core from k2g defconfigs configs: remove MTD support from bcm11130 and M54418TWR defconfigs configs: socfpga: mcvevk: Remove useless UBI infos configs: ls104x/ls108x/ls208x: Build the raw NAND core with TFABOOT mtd: nand: add includes in NAND core to avoid warnings dfu: add dependency on the raw NAND core mtd: nor: NOR flashes depend on MTD mtd: spi: SPI_FLASH_MTD depends on MTD cmd: mtdparts: Kconfig: join mtdparts command entry with its options cmd: nand/sf: isolate legacy code cmd: make MTD commands depend on MTD mtd: Makefile: deep cleanup
Makefile | 5 - arch/arm/mach-omap2/mem-common.c | 6 +- board/BuR/brppt1/board.c | 2 +- board/BuR/brppt1/mux.c | 6 +- board/birdland/bav335x/board.c | 2 +- board/bosch/shc/board.c | 2 +- board/freescale/ls2080aqds/ls2080aqds.c | 2 +- board/freescale/t102xrdb/t102xrdb.c | 2 +- board/phytec/pcm051/mux.c | 4 +- board/siemens/pxm2/mux.c | 4 +- board/sunxi/README.nand | 2 +- board/ti/am335x/board.c | 2 +- board/ti/am335x/mux.c | 8 +- board/ti/am43xx/mux.c | 8 +- board/ti/ti816x/evm.c | 2 +- board/vscom/baltos/board.c | 2 +- board/vscom/baltos/mux.c | 2 +- cmd/Kconfig | 34 ++++--- cmd/Makefile | 3 + cmd/legacy-mtd-utils.c | 99 +++++++++++++++++++ cmd/legacy-mtd-utils.h | 14 +++ cmd/nand.c | 2 + cmd/sf.c | 2 + configs/10m50_defconfig | 2 +- configs/3c120_defconfig | 1 + configs/B4420QDS_NAND_defconfig | 3 +- configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 3 +- configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 3 +- configs/BSC9131RDB_NAND_defconfig | 3 +- .../BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + ...BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 2 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 3 +- ...BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 2 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 3 +- .../BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + .../BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + ...C9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + ...C9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + ...132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + ...132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 3 +- configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/CHIP_pro_defconfig | 5 +- configs/M5208EVBE_defconfig | 1 + configs/M52277EVB_defconfig | 1 + configs/M52277EVB_stmicro_defconfig | 1 + configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5249EVB_defconfig | 1 + configs/M5253DEMO_defconfig | 1 + configs/M5272C3_defconfig | 1 + configs/M5275EVB_defconfig | 1 + configs/M5282EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M5329AFEE_defconfig | 1 + configs/M5329BFEE_defconfig | 1 + configs/M5373EVB_defconfig | 1 + configs/M54418TWR_nand_mii_defconfig | 1 + configs/M54418TWR_nand_rmii_defconfig | 1 + configs/M54418TWR_nand_rmii_lowfreq_defconfig | 1 + configs/M54451EVB_defconfig | 1 + configs/M54451EVB_stmicro_defconfig | 1 + configs/M54455EVB_a66_defconfig | 1 + configs/M54455EVB_defconfig | 1 + configs/M54455EVB_i66_defconfig | 1 + configs/M54455EVB_intel_defconfig | 1 + configs/M54455EVB_stm33_defconfig | 1 + configs/M5475AFE_defconfig | 1 + configs/M5475BFE_defconfig | 1 + configs/M5475CFE_defconfig | 1 + configs/M5475DFE_defconfig | 1 + configs/M5475EFE_defconfig | 1 + configs/M5475FFE_defconfig | 1 + configs/M5475GFE_defconfig | 1 + configs/M5485AFE_defconfig | 1 + configs/M5485BFE_defconfig | 1 + configs/M5485CFE_defconfig | 1 + configs/M5485DFE_defconfig | 1 + configs/M5485EFE_defconfig | 1 + configs/M5485FFE_defconfig | 1 + configs/M5485GFE_defconfig | 1 + configs/M5485HFE_defconfig | 1 + configs/MCR3000_defconfig | 1 + configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 3 +- configs/MPC8313ERDB_NAND_66_defconfig | 3 +- configs/MPC8315ERDB_defconfig | 1 + configs/MPC8323ERDB_defconfig | 1 + configs/MPC832XEMDS_ATM_defconfig | 1 + configs/MPC832XEMDS_HOST_33_defconfig | 1 + configs/MPC832XEMDS_HOST_66_defconfig | 1 + configs/MPC832XEMDS_SLAVE_defconfig | 1 + configs/MPC832XEMDS_defconfig | 1 + configs/MPC8349EMDS_PCI64_defconfig | 1 + configs/MPC8349EMDS_SDRAM_defconfig | 1 + configs/MPC8349EMDS_SLAVE_defconfig | 1 + configs/MPC8349EMDS_defconfig | 1 + configs/MPC8349ITXGP_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 1 + configs/MPC8349ITX_defconfig | 1 + configs/MPC837XEMDS_HOST_defconfig | 1 + configs/MPC837XEMDS_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/MigoR_defconfig | 1 + .../Nintendo_NES_Classic_Edition_defconfig | 3 +- .../P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 2 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 3 +- .../P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + ...010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 2 + configs/P1010RDB-PA_NAND_defconfig | 3 +- configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + .../P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + .../P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 2 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 3 +- .../P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + ...010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 2 + configs/P1010RDB-PB_NAND_defconfig | 3 +- configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + .../P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020MBG-PC_36BIT_defconfig | 1 + configs/P1020MBG-PC_SDCARD_defconfig | 1 + configs/P1020MBG-PC_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 3 +- configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 3 +- configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 3 +- configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020UTM-PC_36BIT_defconfig | 1 + configs/P1020UTM-PC_SDCARD_defconfig | 1 + configs/P1020UTM-PC_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 3 +- configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 3 +- configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 3 +- configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 3 +- configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1024RDB_36BIT_defconfig | 1 + configs/P1024RDB_NAND_defconfig | 3 +- configs/P1024RDB_SDCARD_defconfig | 1 + configs/P1024RDB_SPIFLASH_defconfig | 1 + configs/P1024RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 3 +- configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 3 +- configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 3 +- configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 3 +- configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SECURE_BOOT_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_SECURE_BOOT_defconfig | 3 +- configs/P3041DS_NAND_defconfig | 3 +- configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SECURE_BOOT_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SECURE_BOOT_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5020DS_NAND_SECURE_BOOT_defconfig | 3 +- configs/P5020DS_NAND_defconfig | 3 +- configs/P5020DS_SDCARD_defconfig | 1 + configs/P5020DS_SECURE_BOOT_defconfig | 1 + configs/P5020DS_SPIFLASH_defconfig | 1 + configs/P5020DS_defconfig | 1 + configs/P5040DS_NAND_SECURE_BOOT_defconfig | 3 +- configs/P5040DS_NAND_defconfig | 3 +- configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SECURE_BOOT_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 3 +- configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 3 +- configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 3 +- configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 3 +- configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 3 +- configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 3 +- configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + .../T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 3 +- configs/T1042RDB_PI_NAND_defconfig | 3 +- configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 3 +- configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 3 +- configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SECURE_BOOT_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2081QDS_NAND_defconfig | 3 +- configs/T2081QDS_SDCARD_defconfig | 1 + configs/T2081QDS_SPIFLASH_defconfig | 1 + configs/T2081QDS_defconfig | 1 + configs/T4160QDS_NAND_defconfig | 3 +- configs/T4160QDS_SDCARD_defconfig | 1 + configs/T4160QDS_SECURE_BOOT_defconfig | 1 + configs/T4160QDS_defconfig | 1 + configs/T4160RDB_defconfig | 1 + configs/T4240QDS_NAND_defconfig | 3 +- configs/T4240QDS_SDCARD_defconfig | 1 + configs/T4240QDS_SECURE_BOOT_defconfig | 1 + configs/T4240QDS_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/TQM834x_defconfig | 2 +- configs/TWR-P1025_defconfig | 2 +- configs/UCP1020_defconfig | 1 + configs/adp-ae3xx_defconfig | 3 +- configs/adp-ag101p_defconfig | 1 + configs/ae350_rv32_defconfig | 1 + configs/alt_defconfig | 2 +- configs/am335x_baltos_defconfig | 4 +- configs/am335x_evm_defconfig | 3 +- configs/am335x_guardian_defconfig | 3 +- configs/am335x_hs_evm_defconfig | 3 +- configs/am335x_hs_evm_uart_defconfig | 3 +- configs/am335x_igep003x_defconfig | 4 +- configs/am3517_crane_defconfig | 3 +- configs/am3517_evm_defconfig | 4 +- configs/am43xx_evm_defconfig | 3 +- configs/am43xx_evm_rtconly_defconfig | 3 +- configs/am43xx_evm_usbhost_boot_defconfig | 3 +- configs/am43xx_hs_evm_defconfig | 3 +- configs/amcore_defconfig | 1 + configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/apf27_defconfig | 5 +- configs/apx4devkit_defconfig | 4 +- configs/aristainetos2_defconfig | 5 +- configs/aristainetos2b_defconfig | 5 +- configs/aristainetos_defconfig | 5 +- configs/astro_mcf5373l_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/at91sam9260ek_dataflash_cs0_defconfig | 3 +- configs/at91sam9260ek_dataflash_cs1_defconfig | 3 +- configs/at91sam9260ek_nandflash_defconfig | 3 +- configs/at91sam9261ek_dataflash_cs0_defconfig | 3 +- configs/at91sam9261ek_dataflash_cs3_defconfig | 3 +- configs/at91sam9261ek_nandflash_defconfig | 3 +- configs/at91sam9263ek_dataflash_cs0_defconfig | 3 +- configs/at91sam9263ek_dataflash_defconfig | 3 +- configs/at91sam9263ek_nandflash_defconfig | 3 +- configs/at91sam9263ek_norflash_boot_defconfig | 3 +- configs/at91sam9263ek_norflash_defconfig | 3 +- configs/at91sam9g10ek_dataflash_cs0_defconfig | 3 +- configs/at91sam9g10ek_dataflash_cs3_defconfig | 3 +- configs/at91sam9g10ek_nandflash_defconfig | 3 +- configs/at91sam9g20ek_2mmc_defconfig | 3 +- .../at91sam9g20ek_2mmc_nandflash_defconfig | 3 +- configs/at91sam9g20ek_dataflash_cs0_defconfig | 3 +- configs/at91sam9g20ek_dataflash_cs1_defconfig | 3 +- configs/at91sam9g20ek_nandflash_defconfig | 3 +- configs/at91sam9m10g45ek_mmc_defconfig | 3 +- configs/at91sam9m10g45ek_nandflash_defconfig | 2 + configs/at91sam9n12ek_mmc_defconfig | 3 +- configs/at91sam9n12ek_nandflash_defconfig | 2 + configs/at91sam9n12ek_spiflash_defconfig | 3 +- configs/at91sam9rlek_dataflash_defconfig | 3 +- configs/at91sam9rlek_mmc_defconfig | 3 +- configs/at91sam9rlek_nandflash_defconfig | 3 +- configs/at91sam9x5ek_dataflash_defconfig | 4 +- configs/at91sam9x5ek_mmc_defconfig | 4 +- configs/at91sam9x5ek_nandflash_defconfig | 3 + configs/at91sam9x5ek_spiflash_defconfig | 4 +- configs/at91sam9xeek_dataflash_cs0_defconfig | 3 +- configs/at91sam9xeek_dataflash_cs1_defconfig | 3 +- configs/at91sam9xeek_nandflash_defconfig | 3 +- configs/axm_defconfig | 3 +- configs/bcm11130_nand_defconfig | 1 - configs/bcm963158_ram_defconfig | 3 +- configs/bcm968380gerg_ram_defconfig | 3 +- configs/bcm968580xref_ram_defconfig | 3 +- configs/bg0900_defconfig | 4 +- configs/bitmain_antminer_s9_defconfig | 7 +- configs/bk4r1_defconfig | 6 +- configs/blanche_defconfig | 1 + configs/boston32r2_defconfig | 1 + configs/boston32r2el_defconfig | 1 + configs/boston32r6_defconfig | 1 + configs/boston32r6el_defconfig | 1 + configs/boston64r2_defconfig | 1 + configs/boston64r2el_defconfig | 1 + configs/boston64r6_defconfig | 1 + configs/boston64r6el_defconfig | 1 + configs/brppt1_nand_defconfig | 3 +- configs/brppt1_spi_defconfig | 2 +- configs/caddy2_defconfig | 1 + configs/cairo_defconfig | 3 +- configs/chiliboard_defconfig | 3 +- configs/clearfog_defconfig | 1 + configs/cm_fx6_defconfig | 3 +- configs/cm_t335_defconfig | 3 +- configs/cm_t35_defconfig | 3 +- configs/cm_t43_defconfig | 3 +- configs/cobra5272_defconfig | 1 + configs/colibri-imx6ull_defconfig | 7 +- configs/colibri_imx7_defconfig | 5 +- configs/colibri_pxa270_defconfig | 1 + configs/colibri_t20_defconfig | 3 + configs/colibri_vf_defconfig | 5 +- configs/comtrend_ar5315u_ram_defconfig | 1 + configs/comtrend_ar5387un_ram_defconfig | 1 + configs/comtrend_ct5361_ram_defconfig | 1 + configs/comtrend_wap5813n_ram_defconfig | 1 + configs/corvus_defconfig | 3 +- configs/crs305-1g-4s_defconfig | 2 +- configs/da850evm_defconfig | 1 - configs/da850evm_nand_defconfig | 2 +- configs/db-88f6820-amc_defconfig | 3 +- configs/db-mv784mp-gp_defconfig | 3 +- configs/db-xc3-24g4xg_defconfig | 4 +- configs/devkit3250_defconfig | 3 +- configs/devkit8000_defconfig | 3 +- configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/dns325_defconfig | 3 + configs/dockstar_defconfig | 3 + configs/dra7xx_evm_defconfig | 3 +- configs/dra7xx_hs_evm_defconfig | 3 +- configs/draco_defconfig | 4 +- configs/ds414_defconfig | 3 +- configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/edb9315a_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/etamin_defconfig | 4 +- configs/ethernut5_defconfig | 4 +- configs/evb-rv1108_defconfig | 1 + configs/flea3_defconfig | 3 +- .../gardena-smart-gateway-at91sam_defconfig | 2 + ...gardena-smart-gateway-mt7688-ram_defconfig | 2 + .../gardena-smart-gateway-mt7688_defconfig | 2 + configs/gazerbeam_defconfig | 1 + configs/goflexhome_defconfig | 3 + configs/gose_defconfig | 2 +- configs/gurnard_defconfig | 3 +- configs/guruplug_defconfig | 3 + configs/gwventana_emmc_defconfig | 3 +- configs/gwventana_gw5904_defconfig | 3 +- configs/gwventana_nand_defconfig | 5 +- configs/harmony_defconfig | 3 + configs/helios4_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/huawei_hg556a_ram_defconfig | 1 + configs/ib62x0_defconfig | 3 + configs/iconnect_defconfig | 3 + configs/ids8313_defconfig | 3 + configs/igep00x0_defconfig | 4 +- configs/imx6dl_icore_nand_defconfig | 4 +- configs/imx6q_icore_nand_defconfig | 4 +- configs/imx6q_logic_defconfig | 5 +- configs/imx6qdl_icore_mmc_defconfig | 4 +- configs/imx6qdl_icore_nand_defconfig | 4 +- configs/imx6ul_geam_nand_defconfig | 4 +- configs/imx6ul_isiot_nand_defconfig | 4 +- configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 1 + configs/integratorcp_cm920t_defconfig | 1 + configs/integratorcp_cm926ejs_defconfig | 1 + configs/integratorcp_cm946es_defconfig | 1 + configs/k2e_evm_defconfig | 4 +- configs/k2e_hs_evm_defconfig | 4 +- configs/k2g_evm_defconfig | 5 +- configs/k2g_hs_evm_defconfig | 5 +- configs/k2hk_evm_defconfig | 4 +- configs/k2hk_hs_evm_defconfig | 4 +- configs/k2l_evm_defconfig | 4 +- configs/k2l_hs_evm_defconfig | 4 +- configs/khadas-vim2_defconfig | 2 +- configs/km_kirkwood_128m16_defconfig | 3 + configs/km_kirkwood_defconfig | 3 + configs/km_kirkwood_pci_defconfig | 3 + configs/kmcoge4_defconfig | 2 + configs/kmcoge5ne_defconfig | 2 + configs/kmcoge5un_defconfig | 3 + configs/kmeter1_defconfig | 3 +- configs/kmnusa_defconfig | 3 + configs/kmopti2_defconfig | 3 +- configs/kmsugp1_defconfig | 3 + configs/kmsupx5_defconfig | 3 +- configs/kmsuv31_defconfig | 3 + configs/kmtegr1_defconfig | 2 + configs/kmtepr2_defconfig | 3 +- configs/koelsch_defconfig | 2 +- configs/kzm9g_defconfig | 1 + configs/lager_defconfig | 2 +- configs/libretech-ac_defconfig | 2 +- configs/linkit-smart-7688-ram_defconfig | 1 + configs/linkit-smart-7688_defconfig | 1 + configs/lion-rk3368_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 2 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 2 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 2 + configs/ls1043aqds_tfa_defconfig | 2 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 + configs/ls1043ardb_nand_defconfig | 2 + .../ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 2 + configs/ls1043ardb_tfa_defconfig | 2 + configs/ls1046afrwy_tfa_defconfig | 2 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 2 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 2 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 2 + configs/ls1046aqds_tfa_defconfig | 2 + configs/ls1046ardb_emmc_defconfig | 2 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 2 + configs/ls1046ardb_qspi_defconfig | 2 + configs/ls1046ardb_qspi_spl_defconfig | 2 + .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 2 + configs/ls1046ardb_sdcard_defconfig | 2 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 2 + configs/ls1046ardb_tfa_defconfig | 2 + configs/ls1088aqds_defconfig | 2 + configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 2 + configs/ls1088aqds_qspi_defconfig | 2 + configs/ls1088aqds_sdcard_ifc_defconfig | 2 + configs/ls1088aqds_sdcard_qspi_defconfig | 2 + configs/ls1088aqds_tfa_defconfig | 2 + configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 2 + configs/ls1088ardb_qspi_defconfig | 2 + ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 2 + configs/ls1088ardb_sdcard_qspi_defconfig | 2 + configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 2 + configs/ls1088ardb_tfa_defconfig | 2 + configs/ls2080a_simu_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 2 + configs/ls2080aqds_qspi_defconfig | 2 + configs/ls2080aqds_sdcard_defconfig | 2 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 2 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/m53menlo_defconfig | 5 +- configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/mccmon6_nor_defconfig | 4 +- configs/mccmon6_sd_defconfig | 4 +- configs/medcom-wide_defconfig | 2 + configs/meesc_defconfig | 3 +- configs/mgcoge3un_defconfig | 3 + configs/microblaze-generic_defconfig | 2 +- configs/mpc8308_p1m_defconfig | 1 + configs/mscc_ocelot_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 5 +- configs/mx28evk_defconfig | 5 +- configs/mx28evk_nand_defconfig | 5 +- configs/mx28evk_spi_defconfig | 5 +- configs/mx31pdk_defconfig | 3 +- configs/mx35pdk_defconfig | 3 +- configs/mx53ard_defconfig | 3 +- configs/mx6sabreauto_defconfig | 4 +- configs/mx6sxsabreauto_defconfig | 4 +- configs/nas220_defconfig | 3 + configs/netgear_cg3100d_ram_defconfig | 1 + configs/nsa310s_defconfig | 3 + configs/omap35_logic_defconfig | 4 +- configs/omap35_logic_somlv_defconfig | 4 +- configs/omap3_beagle_defconfig | 4 +- configs/omap3_evm_defconfig | 4 +- configs/omap3_ha_defconfig | 4 +- configs/omap3_logic_defconfig | 4 +- configs/omap3_logic_somlv_defconfig | 4 +- configs/omap3_overo_defconfig | 4 +- configs/omap3_pandora_defconfig | 4 +- configs/omap3_zoom1_defconfig | 3 +- configs/omapl138_lcdk_defconfig | 3 +- configs/openrd_base_defconfig | 3 + configs/openrd_client_defconfig | 3 + configs/openrd_ultimate_defconfig | 3 + configs/pcm052_defconfig | 4 + configs/pcm058_defconfig | 5 +- configs/pengwyn_defconfig | 3 +- configs/pfla02_defconfig | 4 +- configs/phycore-am335x-r2-wega_defconfig | 2 +- configs/phycore_pcl063_defconfig | 3 +- configs/platinum_picon_defconfig | 5 +- configs/platinum_titanium_defconfig | 5 +- configs/plutux_defconfig | 2 + configs/pm9261_defconfig | 3 +- configs/pm9263_defconfig | 3 +- configs/pm9g45_defconfig | 2 + configs/pogo_e02_defconfig | 3 + configs/porter_defconfig | 2 +- configs/pxm2_defconfig | 4 +- configs/qemu_arm64_defconfig | 2 +- configs/qemu_arm_defconfig | 2 +- configs/qemu_mips64_defconfig | 1 + configs/qemu_mips64el_defconfig | 1 + configs/qemu_mips_defconfig | 1 + configs/qemu_mipsel_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r7780mp_defconfig | 1 + configs/r8a77995_draak_defconfig | 2 +- configs/rastaban_defconfig | 4 +- configs/rut_defconfig | 4 +- configs/s5pc210_universal_defconfig | 2 +- configs/sagem_f@st1704_ram_defconfig | 1 + configs/sama5d2_ptc_ek_mmc_defconfig | 3 +- configs/sama5d2_ptc_ek_nandflash_defconfig | 2 + configs/sama5d36ek_cmp_mmc_defconfig | 3 +- configs/sama5d36ek_cmp_nandflash_defconfig | 2 + configs/sama5d36ek_cmp_spiflash_defconfig | 3 +- configs/sama5d3_xplained_mmc_defconfig | 4 +- configs/sama5d3_xplained_nandflash_defconfig | 3 + configs/sama5d3xek_mmc_defconfig | 3 +- configs/sama5d3xek_nandflash_defconfig | 2 + configs/sama5d3xek_spiflash_defconfig | 3 +- configs/sama5d4_xplained_mmc_defconfig | 3 +- configs/sama5d4_xplained_nandflash_defconfig | 2 + configs/sama5d4_xplained_spiflash_defconfig | 3 +- configs/sama5d4ek_mmc_defconfig | 3 +- configs/sama5d4ek_nandflash_defconfig | 2 + configs/sama5d4ek_spiflash_defconfig | 3 +- configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sbc8349_PCI_33_defconfig | 1 + configs/sbc8349_PCI_66_defconfig | 1 + configs/sbc8349_defconfig | 1 + configs/sbc8548_PCI_33_PCIE_defconfig | 1 + configs/sbc8548_PCI_33_defconfig | 1 + configs/sbc8548_PCI_66_PCIE_defconfig | 1 + configs/sbc8548_PCI_66_defconfig | 1 + configs/sbc8548_defconfig | 1 + configs/sbc8641d_defconfig | 1 + configs/seaboard_defconfig | 2 + configs/sfr_nb4-ser_ram_defconfig | 1 + configs/sh7763rdp_defconfig | 1 + configs/sheevaplug_defconfig | 3 + configs/silk_defconfig | 2 +- configs/smartweb_defconfig | 3 +- configs/smdkc100_defconfig | 2 +- configs/snapper9260_defconfig | 3 +- configs/snapper9g20_defconfig | 3 +- configs/socfpga_arria10_defconfig | 2 +- configs/socfpga_arria5_defconfig | 3 +- configs/socfpga_cyclone5_defconfig | 3 +- configs/socfpga_dbm_soc1_defconfig | 2 +- configs/socfpga_de0_nano_soc_defconfig | 3 +- configs/socfpga_de10_nano_defconfig | 2 +- configs/socfpga_de1_soc_defconfig | 2 +- configs/socfpga_is1_defconfig | 3 +- configs/socfpga_mcvevk_defconfig | 3 - configs/socfpga_sockit_defconfig | 3 +- configs/socfpga_socrates_defconfig | 3 +- configs/socfpga_sr1500_defconfig | 3 +- configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 3 +- configs/socrates_defconfig | 1 + configs/spear300_defconfig | 2 +- configs/spear300_nand_defconfig | 4 +- configs/spear300_usbtty_defconfig | 2 +- configs/spear300_usbtty_nand_defconfig | 4 +- configs/spear310_defconfig | 2 +- configs/spear310_nand_defconfig | 4 +- configs/spear310_pnor_defconfig | 2 +- configs/spear310_usbtty_defconfig | 2 +- configs/spear310_usbtty_nand_defconfig | 4 +- configs/spear310_usbtty_pnor_defconfig | 2 +- configs/spear320_defconfig | 2 +- configs/spear320_nand_defconfig | 4 +- configs/spear320_pnor_defconfig | 2 +- configs/spear320_usbtty_defconfig | 2 +- configs/spear320_usbtty_nand_defconfig | 4 +- configs/spear320_usbtty_pnor_defconfig | 2 +- configs/spear600_defconfig | 2 +- configs/spear600_nand_defconfig | 4 +- configs/spear600_usbtty_defconfig | 2 +- configs/spear600_usbtty_nand_defconfig | 4 +- configs/stm32f429-discovery_defconfig | 1 + configs/stm32f429-evaluation_defconfig | 1 + configs/stm32f469-discovery_defconfig | 2 +- configs/stm32f746-disco_defconfig | 3 +- configs/stm32mp15_basic_defconfig | 3 +- configs/stm32mp15_trusted_defconfig | 3 +- configs/stmark2_defconfig | 2 +- configs/stout_defconfig | 2 +- configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/suvd3_defconfig | 3 +- configs/tao3530_defconfig | 4 +- configs/taurus_defconfig | 3 +- configs/tec_defconfig | 2 + configs/thuban_defconfig | 4 +- configs/ti816x_evm_defconfig | 3 +- configs/titanium_defconfig | 5 +- configs/tplink_wdr4300_defconfig | 1 + configs/tricorder_defconfig | 4 +- configs/tricorder_flash_defconfig | 4 +- configs/tuge1_defconfig | 3 +- configs/turris_mox_defconfig | 1 + configs/tuxx1_defconfig | 3 +- configs/uDPU_defconfig | 2 +- configs/uniphier_ld4_sld8_defconfig | 4 +- configs/uniphier_v7_defconfig | 4 +- configs/uniphier_v8_defconfig | 4 +- configs/usb_a9263_dataflash_defconfig | 3 +- configs/vct_platinum_defconfig | 1 + configs/vct_platinum_onenand_defconfig | 3 +- configs/vct_platinum_onenand_small_defconfig | 3 +- configs/vct_platinum_small_defconfig | 1 + configs/vct_platinumavc_defconfig | 1 + configs/vct_platinumavc_onenand_defconfig | 3 +- .../vct_platinumavc_onenand_small_defconfig | 3 +- configs/vct_platinumavc_small_defconfig | 1 + configs/vct_premium_defconfig | 1 + configs/vct_premium_onenand_defconfig | 3 +- configs/vct_premium_onenand_small_defconfig | 3 +- configs/vct_premium_small_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 2 +- configs/vexpress_aemv8a_semi_defconfig | 2 +- configs/vexpress_ca15_tc2_defconfig | 2 +- configs/vexpress_ca5x2_defconfig | 2 +- configs/vexpress_ca9x4_defconfig | 2 +- configs/vf610twr_defconfig | 4 + configs/vf610twr_nand_defconfig | 4 + configs/vme8349_defconfig | 1 + configs/wb45n_defconfig | 3 +- configs/wb50n_defconfig | 3 +- configs/woodburn_defconfig | 3 +- configs/woodburn_sd_defconfig | 4 +- configs/work_92105_defconfig | 2 + configs/x530_defconfig | 3 +- configs/x600_defconfig | 3 + configs/xilinx_zynqmp_mini_nand_defconfig | 3 +- .../xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 5 +- .../xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 4 +- configs/xpedite517x_defconfig | 1 + configs/xpedite520x_defconfig | 1 + configs/xpedite537x_defconfig | 1 + configs/xpedite550x_defconfig | 1 + configs/xtfpga_defconfig | 1 + configs/zmx25_defconfig | 1 + configs/zynq_cse_nand_defconfig | 4 +- configs/zynq_cse_nor_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 5 +- configs/zynq_zc770_xm011_x16_defconfig | 5 +- configs/zynq_zc770_xm012_defconfig | 1 + drivers/Makefile | 7 +- drivers/dfu/Kconfig | 1 + drivers/mtd/Kconfig | 13 +-- drivers/mtd/Makefile | 50 +++++++--- drivers/mtd/mtd_uboot.c | 96 +----------------- drivers/mtd/nand/Makefile | 5 + drivers/mtd/nand/bbt.c | 1 + drivers/mtd/nand/core.c | 1 + drivers/mtd/nand/raw/Kconfig | 4 +- drivers/mtd/nand/raw/nand.c | 2 +- drivers/mtd/onenand/onenand_uboot.c | 2 +- drivers/mtd/spi/Kconfig | 2 +- env/Kconfig | 2 + include/configs/B4860QDS.h | 10 +- include/configs/BSC9131RDB.h | 4 +- include/configs/BSC9132QDS.h | 8 +- include/configs/C29XPCIE.h | 8 +- include/configs/P1010RDB.h | 12 +-- include/configs/P1022DS.h | 10 +- include/configs/P2041RDB.h | 6 +- include/configs/T102xQDS.h | 8 +- include/configs/T102xRDB.h | 8 +- include/configs/T1040QDS.h | 6 +- include/configs/T104xRDB.h | 12 +-- include/configs/T208xQDS.h | 8 +- include/configs/T208xRDB.h | 8 +- include/configs/T4240QDS.h | 10 +- include/configs/T4240RDB.h | 6 +- include/configs/am335x_evm.h | 6 +- include/configs/am335x_guardian.h | 4 +- include/configs/am3517_evm.h | 6 +- include/configs/am43xx_evm.h | 6 +- include/configs/baltos.h | 6 +- include/configs/bav335x.h | 8 +- include/configs/broadcom_bcm963158.h | 4 +- include/configs/broadcom_bcm968380gerg.h | 4 +- include/configs/broadcom_bcm968580xref.h | 4 +- include/configs/brppt1.h | 16 +-- include/configs/corenet_ds.h | 8 +- include/configs/da850evm.h | 4 +- include/configs/dra7xx_evm.h | 4 +- include/configs/ls2080ardb.h | 2 +- include/configs/mvebu_armada-37xx.h | 1 - include/configs/omap3_beagle.h | 10 +- include/configs/omap3_evm.h | 10 +- include/configs/omap3_logic.h | 2 +- include/configs/omap3_overo.h | 6 +- include/configs/omap3_pandora.h | 2 +- include/configs/omapl138_lcdk.h | 2 +- include/configs/p1_p2_rdb_pc.h | 8 +- include/configs/phycore_am335x_r2.h | 6 +- include/configs/siemens-am33x-common.h | 2 +- include/configs/socfpga_stratix10_socdk.h | 1 - include/configs/ti_armv7_common.h | 2 +- include/configs/ti_armv7_omap.h | 2 +- include/configs/ti_omap3_common.h | 2 +- include/configs/x530.h | 1 - include/env_internal.h | 4 +- include/environment/ti/dfu.h | 2 +- include/environment/ti/nand.h | 2 +- include/flash.h | 2 +- include/linux/mtd/mtd.h | 6 -- 849 files changed, 1591 insertions(+), 640 deletions(-) create mode 100644 cmd/legacy-mtd-utils.c create mode 100644 cmd/legacy-mtd-utils.h
Add more clarity by changing the Kconfig entry name.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- arch/arm/mach-omap2/mem-common.c | 6 +++--- board/BuR/brppt1/board.c | 2 +- board/BuR/brppt1/mux.c | 6 +++--- board/birdland/bav335x/board.c | 2 +- board/bosch/shc/board.c | 2 +- board/freescale/ls2080aqds/ls2080aqds.c | 2 +- board/freescale/t102xrdb/t102xrdb.c | 2 +- board/phytec/pcm051/mux.c | 4 ++-- board/siemens/pxm2/mux.c | 4 ++-- board/sunxi/README.nand | 2 +- board/ti/am335x/board.c | 2 +- board/ti/am335x/mux.c | 8 ++++---- board/ti/am43xx/mux.c | 8 ++++---- board/ti/ti816x/evm.c | 2 +- board/vscom/baltos/board.c | 2 +- board/vscom/baltos/mux.c | 2 +- configs/B4420QDS_NAND_defconfig | 2 +- configs/B4860QDS_NAND_defconfig | 2 +- configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 2 +- configs/BSC9131RDB_NAND_defconfig | 2 +- configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 2 +- configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 2 +- configs/C29XPCIE_NAND_defconfig | 2 +- configs/CHIP_pro_defconfig | 2 +- configs/MPC8313ERDB_NAND_33_defconfig | 2 +- configs/MPC8313ERDB_NAND_66_defconfig | 2 +- configs/Nintendo_NES_Classic_Edition_defconfig | 2 +- configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 +- configs/P1010RDB-PA_NAND_defconfig | 2 +- configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 +- configs/P1010RDB-PB_NAND_defconfig | 2 +- configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P1020RDB-PC_NAND_defconfig | 2 +- configs/P1020RDB-PD_NAND_defconfig | 2 +- configs/P1021RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P1021RDB-PC_NAND_defconfig | 2 +- configs/P1022DS_36BIT_NAND_defconfig | 2 +- configs/P1022DS_NAND_defconfig | 2 +- configs/P1024RDB_NAND_defconfig | 2 +- configs/P1025RDB_NAND_defconfig | 2 +- configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P2020RDB-PC_NAND_defconfig | 2 +- configs/P2041RDB_NAND_defconfig | 2 +- configs/P3041DS_NAND_SECURE_BOOT_defconfig | 2 +- configs/P3041DS_NAND_defconfig | 2 +- configs/P5020DS_NAND_SECURE_BOOT_defconfig | 2 +- configs/P5020DS_NAND_defconfig | 2 +- configs/P5040DS_NAND_SECURE_BOOT_defconfig | 2 +- configs/P5040DS_NAND_defconfig | 2 +- configs/T1023RDB_NAND_defconfig | 2 +- configs/T1024QDS_NAND_defconfig | 2 +- configs/T1024RDB_NAND_defconfig | 2 +- configs/T1040D4RDB_NAND_defconfig | 2 +- configs/T1040RDB_NAND_defconfig | 2 +- configs/T1042D4RDB_NAND_defconfig | 2 +- configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 2 +- configs/T1042RDB_PI_NAND_defconfig | 2 +- configs/T2080QDS_NAND_defconfig | 2 +- configs/T2080RDB_NAND_defconfig | 2 +- configs/T2081QDS_NAND_defconfig | 2 +- configs/T4160QDS_NAND_defconfig | 2 +- configs/T4240QDS_NAND_defconfig | 2 +- configs/am335x_baltos_defconfig | 2 +- configs/am335x_evm_defconfig | 2 +- configs/am335x_guardian_defconfig | 2 +- configs/am335x_hs_evm_defconfig | 2 +- configs/am335x_hs_evm_uart_defconfig | 2 +- configs/am335x_igep003x_defconfig | 2 +- configs/am3517_crane_defconfig | 2 +- configs/am3517_evm_defconfig | 2 +- configs/am43xx_evm_defconfig | 2 +- configs/am43xx_evm_rtconly_defconfig | 2 +- configs/am43xx_evm_usbhost_boot_defconfig | 2 +- configs/am43xx_hs_evm_defconfig | 2 +- configs/apf27_defconfig | 2 +- configs/apx4devkit_defconfig | 2 +- configs/aristainetos2_defconfig | 2 +- configs/aristainetos2b_defconfig | 2 +- configs/aristainetos_defconfig | 2 +- configs/at91sam9260ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9260ek_dataflash_cs1_defconfig | 2 +- configs/at91sam9260ek_nandflash_defconfig | 2 +- configs/at91sam9261ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9261ek_dataflash_cs3_defconfig | 2 +- configs/at91sam9261ek_nandflash_defconfig | 2 +- configs/at91sam9263ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9263ek_dataflash_defconfig | 2 +- configs/at91sam9263ek_nandflash_defconfig | 2 +- configs/at91sam9263ek_norflash_boot_defconfig | 2 +- configs/at91sam9263ek_norflash_defconfig | 2 +- configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 +- configs/at91sam9g10ek_nandflash_defconfig | 2 +- configs/at91sam9g20ek_2mmc_defconfig | 2 +- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 2 +- configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 +- configs/at91sam9g20ek_nandflash_defconfig | 2 +- configs/at91sam9m10g45ek_mmc_defconfig | 2 +- configs/at91sam9n12ek_mmc_defconfig | 2 +- configs/at91sam9n12ek_spiflash_defconfig | 2 +- configs/at91sam9rlek_dataflash_defconfig | 2 +- configs/at91sam9rlek_mmc_defconfig | 2 +- configs/at91sam9rlek_nandflash_defconfig | 2 +- configs/at91sam9x5ek_dataflash_defconfig | 2 +- configs/at91sam9x5ek_mmc_defconfig | 2 +- configs/at91sam9x5ek_spiflash_defconfig | 2 +- configs/at91sam9xeek_dataflash_cs0_defconfig | 2 +- configs/at91sam9xeek_dataflash_cs1_defconfig | 2 +- configs/at91sam9xeek_nandflash_defconfig | 2 +- configs/axm_defconfig | 2 +- configs/bcm11130_nand_defconfig | 2 +- configs/bcm963158_ram_defconfig | 2 +- configs/bcm968380gerg_ram_defconfig | 2 +- configs/bcm968580xref_ram_defconfig | 2 +- configs/bg0900_defconfig | 2 +- configs/bitmain_antminer_s9_defconfig | 4 ++-- configs/brppt1_nand_defconfig | 2 +- configs/cairo_defconfig | 2 +- configs/chiliboard_defconfig | 2 +- configs/cm_fx6_defconfig | 2 +- configs/cm_t335_defconfig | 2 +- configs/cm_t35_defconfig | 2 +- configs/cm_t43_defconfig | 2 +- configs/colibri-imx6ull_defconfig | 4 ++-- configs/colibri_imx7_defconfig | 2 +- configs/corvus_defconfig | 2 +- configs/da850evm_nand_defconfig | 2 +- configs/db-88f6820-amc_defconfig | 2 +- configs/db-mv784mp-gp_defconfig | 2 +- configs/db-xc3-24g4xg_defconfig | 2 +- configs/devkit3250_defconfig | 2 +- configs/devkit8000_defconfig | 2 +- configs/dra7xx_evm_defconfig | 2 +- configs/dra7xx_hs_evm_defconfig | 2 +- configs/draco_defconfig | 2 +- configs/etamin_defconfig | 2 +- configs/ethernut5_defconfig | 2 +- configs/flea3_defconfig | 2 +- configs/gurnard_defconfig | 2 +- configs/gwventana_nand_defconfig | 2 +- configs/igep00x0_defconfig | 2 +- configs/imx6dl_icore_nand_defconfig | 2 +- configs/imx6q_icore_nand_defconfig | 2 +- configs/imx6q_logic_defconfig | 2 +- configs/imx6qdl_icore_mmc_defconfig | 2 +- configs/imx6qdl_icore_nand_defconfig | 2 +- configs/imx6ul_geam_nand_defconfig | 2 +- configs/imx6ul_isiot_nand_defconfig | 2 +- configs/k2e_evm_defconfig | 2 +- configs/k2e_hs_evm_defconfig | 2 +- configs/k2g_evm_defconfig | 2 +- configs/k2g_hs_evm_defconfig | 2 +- configs/k2hk_evm_defconfig | 2 +- configs/k2hk_hs_evm_defconfig | 2 +- configs/k2l_evm_defconfig | 2 +- configs/k2l_hs_evm_defconfig | 2 +- configs/m53menlo_defconfig | 2 +- configs/meesc_defconfig | 2 +- configs/mx28evk_auart_console_defconfig | 2 +- configs/mx28evk_defconfig | 2 +- configs/mx28evk_nand_defconfig | 2 +- configs/mx28evk_spi_defconfig | 2 +- configs/mx31pdk_defconfig | 2 +- configs/mx35pdk_defconfig | 2 +- configs/mx53ard_defconfig | 2 +- configs/mx6sabreauto_defconfig | 2 +- configs/mx6sxsabreauto_defconfig | 2 +- configs/omap35_logic_defconfig | 2 +- configs/omap35_logic_somlv_defconfig | 2 +- configs/omap3_beagle_defconfig | 2 +- configs/omap3_evm_defconfig | 2 +- configs/omap3_ha_defconfig | 2 +- configs/omap3_logic_defconfig | 2 +- configs/omap3_logic_somlv_defconfig | 2 +- configs/omap3_overo_defconfig | 2 +- configs/omap3_pandora_defconfig | 2 +- configs/omap3_zoom1_defconfig | 2 +- configs/omapl138_lcdk_defconfig | 2 +- configs/pcm058_defconfig | 2 +- configs/pengwyn_defconfig | 2 +- configs/pfla02_defconfig | 2 +- configs/phycore-am335x-r2-wega_defconfig | 2 +- configs/phycore_pcl063_defconfig | 2 +- configs/platinum_picon_defconfig | 2 +- configs/platinum_titanium_defconfig | 2 +- configs/pm9261_defconfig | 2 +- configs/pm9263_defconfig | 2 +- configs/pxm2_defconfig | 2 +- configs/rastaban_defconfig | 2 +- configs/rut_defconfig | 2 +- configs/sama5d2_ptc_ek_mmc_defconfig | 2 +- configs/sama5d36ek_cmp_mmc_defconfig | 2 +- configs/sama5d36ek_cmp_spiflash_defconfig | 2 +- configs/sama5d3_xplained_mmc_defconfig | 2 +- configs/sama5d3xek_mmc_defconfig | 2 +- configs/sama5d3xek_spiflash_defconfig | 2 +- configs/sama5d4_xplained_mmc_defconfig | 2 +- configs/sama5d4_xplained_spiflash_defconfig | 2 +- configs/sama5d4ek_mmc_defconfig | 2 +- configs/sama5d4ek_spiflash_defconfig | 2 +- configs/smartweb_defconfig | 2 +- configs/snapper9260_defconfig | 2 +- configs/snapper9g20_defconfig | 2 +- configs/spear300_nand_defconfig | 2 +- configs/spear300_usbtty_nand_defconfig | 2 +- configs/spear310_nand_defconfig | 2 +- configs/spear310_usbtty_nand_defconfig | 2 +- configs/spear320_nand_defconfig | 2 +- configs/spear320_usbtty_nand_defconfig | 2 +- configs/spear600_nand_defconfig | 2 +- configs/spear600_usbtty_nand_defconfig | 2 +- configs/stm32mp15_basic_defconfig | 2 +- configs/stm32mp15_trusted_defconfig | 2 +- configs/tao3530_defconfig | 2 +- configs/taurus_defconfig | 2 +- configs/thuban_defconfig | 2 +- configs/ti816x_evm_defconfig | 2 +- configs/titanium_defconfig | 2 +- configs/tricorder_defconfig | 2 +- configs/tricorder_flash_defconfig | 2 +- configs/uniphier_ld4_sld8_defconfig | 2 +- configs/uniphier_v7_defconfig | 2 +- configs/uniphier_v8_defconfig | 2 +- configs/usb_a9263_dataflash_defconfig | 2 +- configs/wb45n_defconfig | 2 +- configs/wb50n_defconfig | 2 +- configs/woodburn_defconfig | 2 +- configs/woodburn_sd_defconfig | 2 +- configs/x530_defconfig | 2 +- configs/xilinx_zynqmp_mini_nand_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 2 +- configs/zynq_cse_nand_defconfig | 2 +- configs/zynq_zc770_xm011_defconfig | 2 +- configs/zynq_zc770_xm011_x16_defconfig | 2 +- drivers/mtd/nand/raw/Kconfig | 4 ++-- include/configs/B4860QDS.h | 10 +++++----- include/configs/BSC9131RDB.h | 4 ++-- include/configs/BSC9132QDS.h | 8 ++++---- include/configs/C29XPCIE.h | 8 ++++---- include/configs/P1010RDB.h | 12 ++++++------ include/configs/P1022DS.h | 10 +++++----- include/configs/P2041RDB.h | 6 +++--- include/configs/T102xQDS.h | 8 ++++---- include/configs/T102xRDB.h | 8 ++++---- include/configs/T1040QDS.h | 6 +++--- include/configs/T104xRDB.h | 12 ++++++------ include/configs/T208xQDS.h | 8 ++++---- include/configs/T208xRDB.h | 8 ++++---- include/configs/T4240QDS.h | 10 +++++----- include/configs/T4240RDB.h | 6 +++--- include/configs/am335x_evm.h | 6 +++--- include/configs/am335x_guardian.h | 4 ++-- include/configs/am3517_evm.h | 6 +++--- include/configs/am43xx_evm.h | 6 +++--- include/configs/baltos.h | 6 +++--- include/configs/bav335x.h | 8 ++++---- include/configs/broadcom_bcm963158.h | 4 ++-- include/configs/broadcom_bcm968380gerg.h | 4 ++-- include/configs/broadcom_bcm968580xref.h | 4 ++-- include/configs/brppt1.h | 16 ++++++++-------- include/configs/corenet_ds.h | 8 ++++---- include/configs/da850evm.h | 4 ++-- include/configs/dra7xx_evm.h | 4 ++-- include/configs/ls2080ardb.h | 2 +- include/configs/omap3_beagle.h | 10 +++++----- include/configs/omap3_evm.h | 10 +++++----- include/configs/omap3_logic.h | 2 +- include/configs/omap3_overo.h | 6 +++--- include/configs/omap3_pandora.h | 2 +- include/configs/omapl138_lcdk.h | 2 +- include/configs/p1_p2_rdb_pc.h | 8 ++++---- include/configs/phycore_am335x_r2.h | 6 +++--- include/configs/siemens-am33x-common.h | 2 +- include/configs/ti_armv7_common.h | 2 +- include/configs/ti_armv7_omap.h | 2 +- include/configs/ti_omap3_common.h | 2 +- include/environment/ti/dfu.h | 2 +- include/environment/ti/nand.h | 2 +- 280 files changed, 384 insertions(+), 384 deletions(-)
diff --git a/arch/arm/mach-omap2/mem-common.c b/arch/arm/mach-omap2/mem-common.c index ff1e3125a0..50d5f3e9eb 100644 --- a/arch/arm/mach-omap2/mem-common.c +++ b/arch/arm/mach-omap2/mem-common.c @@ -25,7 +25,7 @@ const struct gpmc *gpmc_cfg = (struct gpmc *)GPMC_BASE;
#if defined(CONFIG_NOR) char gpmc_cs0_flash = MTD_DEV_TYPE_NOR; -#elif defined(CONFIG_NAND) || defined(CONFIG_CMD_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) || defined(CONFIG_CMD_NAND) char gpmc_cs0_flash = MTD_DEV_TYPE_NAND; #elif defined(CONFIG_CMD_ONENAND) char gpmc_cs0_flash = MTD_DEV_TYPE_ONENAND; @@ -93,7 +93,7 @@ void set_gpmc_cs0(int flash_type) STNOR_GPMC_CONFIG7 }; #endif -#if defined(CONFIG_NAND) || defined(CONFIG_CMD_NAND) +#if defined(CONFIG_MTD_RAW_NAND) || defined(CONFIG_CMD_NAND) const u32 gpmc_regs_nand[GPMC_MAX_REG] = { M_NAND_GPMC_CONFIG1, M_NAND_GPMC_CONFIG2, @@ -128,7 +128,7 @@ void set_gpmc_cs0(int flash_type) GPMC_SIZE_16M))); break; #endif -#if defined(CONFIG_NAND) || defined(CONFIG_CMD_NAND) +#if defined(CONFIG_MTD_RAW_NAND) || defined(CONFIG_CMD_NAND) case MTD_DEV_TYPE_NAND: gpmc_regs = gpmc_regs_nand; base = CONFIG_SYS_NAND_BASE; diff --git a/board/BuR/brppt1/board.c b/board/BuR/brppt1/board.c index ef4f5c9501..fb825b49dc 100644 --- a/board/BuR/brppt1/board.c +++ b/board/BuR/brppt1/board.c @@ -148,7 +148,7 @@ int board_init(void) hw_watchdog_init(); #endif gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND gpmc_init(); #endif return 0; diff --git a/board/BuR/brppt1/mux.c b/board/BuR/brppt1/mux.c index 87eee709fd..b863d37335 100644 --- a/board/BuR/brppt1/mux.c +++ b/board/BuR/brppt1/mux.c @@ -118,7 +118,7 @@ static struct module_pin_mux mii2_pin_mux[] = { {OFFSET(gpmc_be1n), (MODE(1) | RXACTIVE)},/* MII1_COL */ {-1}, }; -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND static struct module_pin_mux nand_pin_mux[] = { {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */ {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */ @@ -180,7 +180,7 @@ static struct module_pin_mux gpIOs[] = { {OFFSET(mcasp0_axr0), (MODE(7) | PULLUDDIS) }, /* GPIO3_17 (MCASP0_AHCLKR) - ETH2_LEDY */ {OFFSET(mcasp0_ahclkr), (MODE(7) | PULLUDDIS) }, -#ifndef CONFIG_NAND +#ifndef CONFIG_MTD_RAW_NAND /* GPIO2_3 - NAND_OE */ {OFFSET(gpmc_oen_ren), (MODE(7) | PULLDOWN_EN | RXACTIVE)}, /* GPIO2_4 - NAND_WEN */ @@ -241,7 +241,7 @@ void enable_board_pin_mux(void) configure_module_pin_mux(i2c0_pin_mux); configure_module_pin_mux(mii1_pin_mux); configure_module_pin_mux(mii2_pin_mux); -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND configure_module_pin_mux(nand_pin_mux); #elif defined(CONFIG_MMC) configure_module_pin_mux(mmc1_pin_mux); diff --git a/board/birdland/bav335x/board.c b/board/birdland/bav335x/board.c index 8811583ac6..04bf12edd1 100644 --- a/board/birdland/bav335x/board.c +++ b/board/birdland/bav335x/board.c @@ -290,7 +290,7 @@ int board_init(void) #endif
gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; -#if defined(CONFIG_NOR) || defined(CONFIG_NAND) +#if defined(CONFIG_NOR) || defined(CONFIG_MTD_RAW_NAND) gpmc_init(); #endif return 0; diff --git a/board/bosch/shc/board.c b/board/bosch/shc/board.c index a96fdef992..b72d54d6ab 100644 --- a/board/bosch/shc/board.c +++ b/board/bosch/shc/board.c @@ -442,7 +442,7 @@ int board_init(void) puts("EEPROM Content Invalid.\n");
gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; -#if defined(CONFIG_NOR) || defined(CONFIG_NAND) +#if defined(CONFIG_NOR) || defined(CONFIG_MTD_RAW_NAND) gpmc_init(); #endif shc_request_gpio(); diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 91c80353ed..4ba909fa1b 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -220,7 +220,7 @@ int board_init(void) else config_board_mux(MUX_TYPE_SDHC);
-#if defined(CONFIG_NAND) && defined(CONFIG_FSL_QSPI) +#if defined(CONFIG_MTD_RAW_NAND) && defined(CONFIG_FSL_QSPI) val = in_le32(dcfg_ccsr + DCFG_RCWSR15 / 4);
if (DCFG_RCWSR15_IFCGRPABASE_QSPI == (val & (u32)0x3)) diff --git a/board/freescale/t102xrdb/t102xrdb.c b/board/freescale/t102xrdb/t102xrdb.c index 793f54d69e..6e4819a223 100644 --- a/board/freescale/t102xrdb/t102xrdb.c +++ b/board/freescale/t102xrdb/t102xrdb.c @@ -75,7 +75,7 @@ int checkboard(void) printf("NOR vBank%d\n", reg); } #elif defined(CONFIG_TARGET_T1023RDB) -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND puts("NAND\n"); #else printf("NOR vBank%d\n", t1023rdb_ctrl(I2C_GET_BANK)); diff --git a/board/phytec/pcm051/mux.c b/board/phytec/pcm051/mux.c index 6e9c3d257c..9bca8eae9f 100644 --- a/board/phytec/pcm051/mux.c +++ b/board/phytec/pcm051/mux.c @@ -82,7 +82,7 @@ static struct module_pin_mux cbmux_pin_mux[] = { {-1}, };
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND static struct module_pin_mux nand_pin_mux[] = { {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */ {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */ @@ -118,7 +118,7 @@ void enable_board_pin_mux() configure_module_pin_mux(rmii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux); configure_module_pin_mux(cbmux_pin_mux); -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND configure_module_pin_mux(nand_pin_mux); #endif #ifdef CONFIG_SPI diff --git a/board/siemens/pxm2/mux.c b/board/siemens/pxm2/mux.c index 9b69b6f5c4..2f35bb4a73 100644 --- a/board/siemens/pxm2/mux.c +++ b/board/siemens/pxm2/mux.c @@ -26,7 +26,7 @@ static struct module_pin_mux uart0_pin_mux[] = { {-1}, };
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND static struct module_pin_mux nand_pin_mux[] = { {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */ {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */ @@ -169,7 +169,7 @@ void enable_board_pin_mux(void) { configure_module_pin_mux(uart0_pin_mux); configure_module_pin_mux(i2c1_pin_mux); -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND configure_module_pin_mux(nand_pin_mux); #endif #ifndef CONFIG_NO_ETH diff --git a/board/sunxi/README.nand b/board/sunxi/README.nand index 98ebe5fb7f..0e97316aeb 100644 --- a/board/sunxi/README.nand +++ b/board/sunxi/README.nand @@ -21,7 +21,7 @@ In order to accomodate that, we create a tool that will generate an SPL image that is ready to be programmed directly embedding the ECCs, randomized, and with the necessary bits needed to reduce the number of bitflips. The U-Boot build system, when configured for the NAND (with -CONFIG_NAND=y) will also generate the image sunxi-spl-with-ecc.bin +CONFIG_MTD_RAW_NAND=y) will also generate the image sunxi-spl-with-ecc.bin that will have been generated by that tool.
In order to flash your U-Boot image onto a board, assuming that the diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 7eaa6cd96d..d9554baf19 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -709,7 +709,7 @@ int board_init(void) #endif
diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 6e1ede3933..6fb2c009ba 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -195,7 +195,7 @@ static struct module_pin_mux rmii1_pin_mux[] = { {-1}, };
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND static struct module_pin_mux nand_pin_mux[] = { {OFFSET(gpmc_ad0), (MODE(0) | PULLUDDIS | RXACTIVE)}, /* AD0 */ {OFFSET(gpmc_ad1), (MODE(0) | PULLUDDIS | RXACTIVE)}, /* AD1 */ @@ -360,7 +360,7 @@ void enable_board_pin_mux(void) /* Beaglebone pinmux */ configure_module_pin_mux(mii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux); -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) configure_module_pin_mux(nand_pin_mux); #elif defined(CONFIG_NOR) configure_module_pin_mux(bone_norcape_pin_mux); @@ -376,7 +376,7 @@ void enable_board_pin_mux(void) if (profile & ~PROFILE_2) configure_module_pin_mux(i2c1_pin_mux); /* Profiles 2 & 3 don't have NAND */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND if (profile & ~(PROFILE_2 | PROFILE_3)) configure_module_pin_mux(nand_pin_mux); #endif @@ -404,7 +404,7 @@ void enable_board_pin_mux(void) } /* Beaglebone LT pinmux */ configure_module_pin_mux(mmc0_pin_mux); -#if defined(CONFIG_NAND) && defined(CONFIG_EMMC_BOOT) +#if defined(CONFIG_MTD_RAW_NAND) && defined(CONFIG_EMMC_BOOT) configure_module_pin_mux(nand_pin_mux); #elif defined(CONFIG_NOR) && defined(CONFIG_EMMC_BOOT) configure_module_pin_mux(bone_norcape_pin_mux); diff --git a/board/ti/am43xx/mux.c b/board/ti/am43xx/mux.c index a61987e4c6..f59e93a0eb 100644 --- a/board/ti/am43xx/mux.c +++ b/board/ti/am43xx/mux.c @@ -73,7 +73,7 @@ static struct module_pin_mux gpio5_7_pin_mux[] = { {-1}, };
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND static struct module_pin_mux nand_pin_mux[] = { {OFFSET(gpmc_ad0), (MODE(0) | PULLUDDIS | RXACTIVE)}, /* AD0 */ {OFFSET(gpmc_ad1), (MODE(0) | PULLUDDIS | RXACTIVE)}, /* AD1 */ @@ -128,18 +128,18 @@ void enable_board_pin_mux(void) if (board_is_evm()) { configure_module_pin_mux(gpio5_7_pin_mux); configure_module_pin_mux(rgmii1_pin_mux); -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) configure_module_pin_mux(nand_pin_mux); #endif } else if (board_is_sk() || board_is_idk()) { configure_module_pin_mux(rgmii1_pin_mux); -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) printf("Error: NAND flash not present on this board\n"); #endif configure_module_pin_mux(qspi_pin_mux); } else if (board_is_eposevm()) { configure_module_pin_mux(rmii1_pin_mux); -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) configure_module_pin_mux(nand_pin_mux); #else configure_module_pin_mux(qspi_pin_mux); diff --git a/board/ti/ti816x/evm.c b/board/ti/ti816x/evm.c index 8f7b591b5c..3896ebbfda 100644 --- a/board/ti/ti816x/evm.c +++ b/board/ti/ti816x/evm.c @@ -25,7 +25,7 @@ DECLARE_GLOBAL_DATA_PTR; int board_init(void) { gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) gpmc_init(); #endif return 0; diff --git a/board/vscom/baltos/board.c b/board/vscom/baltos/board.c index 1ba58d0f11..106e02b9c2 100644 --- a/board/vscom/baltos/board.c +++ b/board/vscom/baltos/board.c @@ -263,7 +263,7 @@ int board_init(void) #endif
gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; -#if defined(CONFIG_NOR) || defined(CONFIG_NAND) +#if defined(CONFIG_NOR) || defined(CONFIG_MTD_RAW_NAND) gpmc_init(); #endif return 0; diff --git a/board/vscom/baltos/mux.c b/board/vscom/baltos/mux.c index 9c5542ea02..e01899c83a 100644 --- a/board/vscom/baltos/mux.c +++ b/board/vscom/baltos/mux.c @@ -112,7 +112,7 @@ void enable_board_pin_mux() configure_module_pin_mux(rmii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux);
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) configure_module_pin_mux(nand_pin_mux); #endif } diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index 863389e884..1a1acc0a6f 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -44,7 +44,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index b1922c1d32..f9299b2b00 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -44,7 +44,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index e2c7cf373e..b6e5a74ce7 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -34,7 +34,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:1m(uboot),8m(kernel),512k(dtb), CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index cf715e5e58..bc4c9d55b6 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -33,7 +33,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:1m(uboot),8m(kernel),512k(dtb), CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index f0c9288d05..b4fa77c81f 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -41,7 +41,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 3f29e824dc..f58285b12c 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -41,7 +41,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index 2a01b52b8e..a3ff33ba15 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -41,7 +41,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 82994212a2..91d032633e 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -16,7 +16,7 @@ CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot-env" # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0x100 diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index 4c30f7546f..f1d6efde83 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -156,7 +156,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_MARVELL=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index 1c7c72d74a..3889b0783a 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -155,7 +155,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_MARVELL=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index 2a75804105..26b0da8ded 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -16,7 +16,7 @@ CONFIG_CMD_MTDPARTS=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-nintendo-nes-classic-edition" # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 99c7288ca5..da9c6313e8 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -49,7 +49,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index c2b9af5e1a..2390fdc33c 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -48,7 +48,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index b2ffe4a5ef..67295ec2e3 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -49,7 +49,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index b35bf6db1a..b53d5ecbb9 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -48,7 +48,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index ba4229e3e0..d45a986b20 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -51,7 +51,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 705bc717ec..aceb7aad81 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -50,7 +50,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 835cbd8407..8c8108cbd8 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -54,7 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index b52ae950b5..7cbdaed04d 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -53,7 +53,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index ee88894db3..18a5018782 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -52,7 +52,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index d69e527e0c..7c1db02a49 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -50,7 +50,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index 92b95c03a5..a4218a85af 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -49,7 +49,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index f1c9d3d39e..35dcc44d89 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -47,7 +47,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index af5012bf65..fc7cfdf239 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -49,7 +49,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index aa47e89e96..abdeffa487 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -56,7 +56,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index ee13ac2fec..f1f4ea2dd0 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -55,7 +55,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 7ed8abf2c7..7ce51fa1fb 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -34,7 +34,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index d83206342e..d715a2ce46 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -31,7 +31,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 0bdd2aba57..0dd7d336c0 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -34,7 +34,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index 85f04ac323..11ea810912 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -32,7 +32,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index 0c9328bfee..f9960e06dc 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -31,7 +31,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index c085e68efb..5ace78159b 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -32,7 +32,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 47a230c002..9567a6011d 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -35,7 +35,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 1902197f5b..89f1d16dd2 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -52,7 +52,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index cf010f1c99..ba0f62c97f 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -54,7 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index af65615f7d..294d87a23c 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -57,7 +57,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index ab5a9b73c0..db4469a7ea 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -51,7 +51,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index c00c850384..2e1cc50edc 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -52,7 +52,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 2fcd9e1940..8ad75d0606 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -55,7 +55,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 721641270b..c4c50d085e 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -57,7 +57,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index a32fa4c646..cc70ffa247 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -54,7 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 4d80baead6..06cb9ad080 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -54,7 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 692d01cbbd..8c40a58c4b 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -53,7 +53,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index f793e2a72a..1f874041af 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -48,7 +48,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index 1a47bbc5db..edea4fa972 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -44,7 +44,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index 031cdc205e..f0e414e671 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -44,7 +44,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index d6db96c379..5776483f25 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -47,7 +47,7 @@ CONFIG_SYS_OMAP24_I2C_SPEED=1000 CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP_HS_ADMA=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x00080000 CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 2aa9b65caf..5917619fb3 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -46,7 +46,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 3cada51d35..bd6c8c86c2 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -67,7 +67,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x100000 CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND=0x200000 diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index f5da7f674f..155534b672 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -42,7 +42,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 3708a6f623..4d9760e2a5 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -44,7 +44,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 8ed52a5ffb..f1058073d0 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -62,7 +62,7 @@ CONFIG_ENV_UBI_VOLUME_REDUND="config_r" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 921b9ba564..2a98b43ae0 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 9612bbae24..44bc4d6aab 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -49,7 +49,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_PCA953X=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 7c74047f3a..961535deb6 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -45,7 +45,7 @@ CONFIG_DM_GPIO=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 3064f3198d..7d106edff5 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -36,7 +36,7 @@ CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index f1a1a48248..de576a842e 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -49,7 +49,7 @@ CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 0b32568316..e5e4161d38 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -46,7 +46,7 @@ CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 2b82f05dc6..cbd5eb0eda 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -43,7 +43,7 @@ CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y CONFIG_MXC_GPIO=y CONFIG_MMC_MXC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_MII=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 89f58e5c34..26562b9621 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 18ef5d2dce..22dec52167 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -36,7 +36,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=3 diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 1054c05d8c..72c91288a4 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -36,7 +36,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 4080a7b310..3e4d76446c 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -36,7 +36,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=3 diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index ef1b3b46be..cbf5498ad5 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 89129ce2f9..5489546946 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 79ef08c8ce..9be766a03e 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -36,7 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 410f71142d..ca3a7b3980 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 83437583b6..401fbf2b68 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 471715ab86..59d6c5f4f8 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -36,7 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index ce30dbb370..7877484480 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -46,7 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index ce30dbb370..7877484480 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -46,7 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 5149b34760..1c57e7b199 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -41,7 +41,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 6e7ab93062..e9ad03c64b 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -45,7 +45,7 @@ CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 03c55622e0..8b3a754363 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -45,7 +45,7 @@ CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 8a3cf115dc..e0d40f01eb 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 89466b0014..af0f59aa63 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 029cc9bbcf..77c0c7dedb 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -36,7 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 1c9cc0cdc9..ef00828b09 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -40,7 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index a0a149904d..51928a2c82 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -38,7 +38,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 86c7116b83..854dc34390 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index c1c7b21cd8..b2ff294024 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index d8535b60d9..b98d05a744 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -36,7 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index a5b6f45a8e..948c10e03c 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -40,7 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_ETH=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index aad6ee43f3..b9ed419cfc 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -40,7 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index e49a90d21f..0365bbced4 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -42,7 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 85130d7a49..3be0e8547f 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -44,7 +44,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 38357632e7..26cff3526d 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -40,7 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 41a59891af..2890f4781c 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -39,7 +39,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 10df6441a4..892772a262 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -44,7 +44,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 158c1ec3cb..57b10d83fc 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -42,7 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 1fe37f96d1..39020cb667 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -44,7 +44,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index c713735306..ce56029131 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 1862fc4b5a..67d33bc647 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -41,7 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 110b1799f2..09589e19d4 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -36,7 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index a1d374aeb5..d3b30b7ec6 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -57,7 +57,7 @@ CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_CLK=y CONFIG_CLK_AT91=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index aa4105db39..5dc6fa036a 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -25,7 +25,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index 1d8a81e5e2..3b4c86ce59 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -35,7 +35,7 @@ CONFIG_LED_BCM6858=y CONFIG_LED_BLINK=y # CONFIG_MMC is not set CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_63158=y CONFIG_SPECIFY_CONSOLE_INDEX=y diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 368f67463d..0d04863721 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -38,7 +38,7 @@ CONFIG_LED=y CONFIG_LED_BCM6328=y CONFIG_LED_BLINK=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6838=y CONFIG_PHY=y diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index 62f9077a5c..f3a87edebb 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -30,7 +30,7 @@ CONFIG_LED_BCM6858=y CONFIG_LED_BLINK=y # CONFIG_MMC is not set CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6858=y CONFIG_SPECIFY_CONSOLE_INDEX=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 32dcb25fea..cdfcc5c636 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -29,7 +29,7 @@ CONFIG_CMD_CACHE=y CONFIG_DOS_PARTITION=y CONFIG_MXS_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index 14f8d769bb..966fc9134e 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -58,9 +58,9 @@ CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y -CONFIG_NAND_ZYNQ_USE_BOOTLOADER1_TIMINGS=y +CONFIG_MTD_RAW_NAND_ZYNQ_USE_BOOTLOADER1_TIMINGS=y CONFIG_MII=y CONFIG_ZYNQ_GEM=y CONFIG_DEBUG_UART_ZYNQ=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index ff227de4b7..1de0f0585b 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -79,7 +79,7 @@ CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_MISC=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_PHY_NATSEMI=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 21f4aae42a..a5a2eb90b0 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -30,7 +30,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=2 CONFIG_SPI=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index f275d21d16..bb1d796f9b 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -40,7 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index eed0558e24..cc0ce67a49 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -59,7 +59,7 @@ CONFIG_DWC_AHSATA=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index ab9f1fde44..53475e6b36 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -47,7 +47,7 @@ CONFIG_LED_STATUS_BIT=64 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y CONFIG_FAT_WRITE=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 918a84872e..83ab05e845 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -43,7 +43,7 @@ CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x2C000000 diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 933c1c5bb7..c2835358e8 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -56,7 +56,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 8c21ff4d6e..4980f91d37 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -54,10 +54,10 @@ CONFIG_SYS_I2C_MXC=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y -CONFIG_NAND_MXS_DT=y +CONFIG_MTD_RAW_NAND_MXS_DT=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index c1bee450f6..8e2657dcf0 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -54,7 +54,7 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS_DT=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 56c6123958..ef5ca7d26a 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -46,7 +46,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_PHYLIB=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 063b5b8924..a7367f20e2 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -52,7 +52,7 @@ CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 3d23c12aec..1bfd949f59 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -56,7 +56,7 @@ CONFIG_BLK=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 265f254582..3aef717b8f 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -52,7 +52,7 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y CONFIG_BLK=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig index de34d1fd6f..5850536ce6 100644 --- a/configs/db-xc3-24g4xg_defconfig +++ b/configs/db-xc3-24g4xg_defconfig @@ -37,7 +37,7 @@ CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index bc07eab10c..fc453c6282 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -37,7 +37,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_LPC32XX_SLC=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 962cdee012..10f9f91e3f 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -28,7 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 868030d34c..1b4f8d6229 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -72,7 +72,7 @@ CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 7a5c3e72d4..5d25e4f4fa 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -75,7 +75,7 @@ CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 4ba3bde2e6..59e79a2556 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -64,7 +64,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 31e711d32f..d8002f6d05 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -65,7 +65,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 45a9175dac..8c3abd0cd7 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -57,7 +57,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_MTD_NOR_FLASH=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index a13f609da4..023170db5a 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -30,7 +30,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index f461d92980..01ff5dda70 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -27,7 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-gurnard" CONFIG_ENV_IS_IN_NAND=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HWECC=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index a485fc9b5e..7552d9868b 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -67,7 +67,7 @@ CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_E1000=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 04e9c95b51..4a8ea8693f 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -49,7 +49,7 @@ CONFIG_ENV_UBI_VOLUME_REDUND="config_r" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index 36c52b0ff4..800e580018 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -41,7 +41,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index eb19ae2336..2f4e74066b 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -42,7 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index ec14b8eaf6..c1e3971432 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -68,7 +68,7 @@ CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_FSL_USDHC=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 6f4f712c8a..252484de0a 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -56,7 +56,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index eb19ae2336..2f4e74066b 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -42,7 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 77cd1f20b5..b146f2494e 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -42,7 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 60327d3f54..35d63d3322 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -42,7 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-nand" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 260605533e..08d19b55e8 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -44,7 +44,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 98e3cdeb90..e3af08d09e 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -36,7 +36,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 27804517fe..8b56002db1 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -44,7 +44,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index f5f3678bbe..48c0ecc11b 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -37,7 +37,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 2d5f1934d0..a8b1806dae 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -44,7 +44,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 8d679208b0..82e4b5cb2f 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -36,7 +36,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index b0898b0000..e426a86980 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -44,7 +44,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 8b7089bbc7..ccca8b910e 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -35,7 +35,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 50047952a7..ca5744d29e 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -63,7 +63,7 @@ CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC_IMX=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 5312974c3b..bf989535b8 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -30,7 +30,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index ce3e77a90e..d92755ba7e 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -40,7 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 361375ce24..32ba6c4881 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -40,7 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index d34d50a94d..8d0f1b9d70 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -39,7 +39,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 6e06571db7..a34688219c 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -38,7 +38,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),5 CONFIG_CMD_UBI=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index bdeb6b2590..349b21131d 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -24,7 +24,7 @@ CONFIG_CMD_DATE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MXC_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0xB6000000 diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 3d36045ab5..2f01d2f840 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -33,7 +33,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_MII=y CONFIG_SMC911X=y diff --git a/configs/mx53ard_defconfig b/configs/mx53ard_defconfig index 429a78ffa5..da9d6f5527 100644 --- a/configs/mx53ard_defconfig +++ b/configs/mx53ard_defconfig @@ -16,7 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC_IMX=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXC=y CONFIG_MII=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index c2c4ca276f..c2e230c3fd 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -64,7 +64,7 @@ CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index fa9853def6..4ab43b6c1a 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -35,7 +35,7 @@ CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 78fcbaaca2..a5e6151f44 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -47,7 +47,7 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 9eaccfb434..08520f403c 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -52,7 +52,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index bf49de4704..ee3462efb1 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -67,7 +67,7 @@ CONFIG_LED_STATUS_CMD=y CONFIG_TWL4030_LED=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index b00552293c..e7cd58a132 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -54,7 +54,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_DM_MMC=y # CONFIG_SPL_DM_MMC is not set CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index c2d2a31842..bb36740dd4 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -28,7 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 81b57a8f7a..8f1f232387 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -46,7 +46,7 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP36XX_PINS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 656a2d5cb1..7d1bb72190 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -53,7 +53,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index be604fd7f2..ef33ef09b9 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -36,7 +36,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SMC911X=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index df9256688f..5ee0dace26 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -30,7 +30,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SERIAL=y CONFIG_SPI=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index d9ac7a8364..516c0e6ea1 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -24,7 +24,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x08000000 diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 9821df9884..ba42133e94 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -47,7 +47,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DAVINCI=y CONFIG_DM_MMC=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 879f9932be..9fd33da324 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -46,7 +46,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index bd7d0a6d8b..215e0d14d2 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -49,7 +49,7 @@ CONFIG_CMD_DIAG=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y CONFIG_SPI=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index 7bd146d1ba..e6a679554e 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -45,7 +45,7 @@ CONFIG_CMD_UBI=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 43acb55c41..ab343ce33d 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -59,7 +59,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND=0x100000 diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index be16f484d5..27e3a7c88e 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -37,7 +37,7 @@ CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y CONFIG_PHYLIB=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index fc0768a304..5033e7c2c0 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -49,7 +49,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(e CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 8ab916ec9d..78abe3d0dd 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -49,7 +49,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(e CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index d087699f13..ec71ef5346 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -43,7 +43,7 @@ CONFIG_AT91_GPIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 76476e38da..768917bbdc 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -43,7 +43,7 @@ CONFIG_AT91_GPIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 201b9c9357..1b75972229 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -66,7 +66,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 452e761412..6166c025f4 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -64,7 +64,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index ec31d52377..af53e75e89 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -67,7 +67,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index e1ff84f3b4..9ccf98bba5 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -49,7 +49,7 @@ CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index 2f0415d97f..c97db770f8 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -43,7 +43,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 3fbdd54c04..61ebabe4ee 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -45,7 +45,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 0270472f8f..74a1f34cb9 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -62,7 +62,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_ETH=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 934d020471..26ce4867a3 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -68,7 +68,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index ed9d806445..16f228dceb 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -66,7 +66,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 58b4bd1fbf..04e2e24871 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -59,7 +59,7 @@ CONFIG_SYS_I2C_AT91=y CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 82458be7b9..560221e4c0 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -62,7 +62,7 @@ CONFIG_SYS_I2C_AT91=y CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 48f9db44ea..a3aab63c33 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -59,7 +59,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index e23d6cbd8e..f5cbbb5129 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -59,7 +59,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 9e73051def..1daea16a57 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -47,7 +47,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_PHYLIB=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index d3d51c52e0..eaf52f9f01 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -31,7 +31,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_USB=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 6466ee80f2..dedaa93fd5 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -30,7 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_USB=y diff --git a/configs/spear300_nand_defconfig b/configs/spear300_nand_defconfig index 154a5cac03..0fc1198d4a 100644 --- a/configs/spear300_nand_defconfig +++ b/configs/spear300_nand_defconfig @@ -24,7 +24,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear300_usbtty_nand_defconfig b/configs/spear300_usbtty_nand_defconfig index 77926c1bb7..93979928e0 100644 --- a/configs/spear300_usbtty_nand_defconfig +++ b/configs/spear300_usbtty_nand_defconfig @@ -24,7 +24,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear310_nand_defconfig b/configs/spear310_nand_defconfig index 29cf8f889f..bd2bb5abcd 100644 --- a/configs/spear310_nand_defconfig +++ b/configs/spear310_nand_defconfig @@ -24,7 +24,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear310_usbtty_nand_defconfig b/configs/spear310_usbtty_nand_defconfig index 87baf30559..9802082f11 100644 --- a/configs/spear310_usbtty_nand_defconfig +++ b/configs/spear310_usbtty_nand_defconfig @@ -24,7 +24,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear320_nand_defconfig b/configs/spear320_nand_defconfig index 86addccd37..cb8feb655c 100644 --- a/configs/spear320_nand_defconfig +++ b/configs/spear320_nand_defconfig @@ -24,7 +24,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear320_usbtty_nand_defconfig b/configs/spear320_usbtty_nand_defconfig index 694c51bcab..9b3ad1b354 100644 --- a/configs/spear320_usbtty_nand_defconfig +++ b/configs/spear320_usbtty_nand_defconfig @@ -24,7 +24,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear600_nand_defconfig b/configs/spear600_nand_defconfig index 978204ecfa..b37b19d87e 100644 --- a/configs/spear600_nand_defconfig +++ b/configs/spear600_nand_defconfig @@ -24,7 +24,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear600_usbtty_nand_defconfig b/configs/spear600_usbtty_nand_defconfig index cc490f0e3d..1d57def8a9 100644 --- a/configs/spear600_usbtty_nand_defconfig +++ b/configs/spear600_usbtty_nand_defconfig @@ -24,7 +24,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index f6c68feb6f..daa126ec2d 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -80,7 +80,7 @@ CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_STM32_SDMMC2=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 71ad1157ec..88d342ae7c 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -66,7 +66,7 @@ CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_STM32_SDMMC2=y CONFIG_MTD=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index ab3590cc7b..9fad4de201 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -28,7 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 3676ecd419..dac3a1437c 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -65,7 +65,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index ade82c86e3..ef3f5c2f56 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -64,7 +64,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 2a817ed3ba..dd764a6f30 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -45,7 +45,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_ETH=y CONFIG_MII=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 86d1da3324..e79b9c3ba4 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -35,7 +35,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:16M(uboot),512k(env1),512k(env2),-(u CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 730fd7fc10..09a5553347 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -40,7 +40,7 @@ CONFIG_LED_STATUS_STATE2=2 CONFIG_LED_STATUS_CMD=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 3a7061eb9c..85ff46c83c 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -38,7 +38,7 @@ CONFIG_LED_STATUS_STATE2=2 CONFIG_LED_STATUS_CMD=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 7a1010d54b..9e091a10ed 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -44,7 +44,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_UNIPHIER=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index 922420102b..88d7b061e9 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -43,7 +43,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_UNIPHIER=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 3908ff80d6..3da0f36a18 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -44,7 +44,7 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_CADENCE=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_DM_ETH=y diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 5779aeb053..23aa277c08 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -37,7 +37,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index 0f22a1ee42..1a66acbba0 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -28,7 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index 3e7f03a867..7bc852b770 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -28,7 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index 73b76aa65b..5e7a226411 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -35,7 +35,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index b26b084d22..b1250e001f 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -47,7 +47,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 6d272add23..852039d32d 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -53,7 +53,7 @@ CONFIG_SYS_I2C_MVTWSI=y CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 4be624813c..cd0d30e49c 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -47,6 +47,6 @@ CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set # CONFIG_MMC is not set -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y # CONFIG_EFI_LOADER is not set diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 02f6d4a9bc..9db0e21f56 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -56,7 +56,7 @@ CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_DM_MMC=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y CONFIG_SYS_NAND_MAX_CHIPS=2 CONFIG_SPI_FLASH=y diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index c243064112..826a48702f 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -54,7 +54,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y CONFIG_PHY_MARVELL=y CONFIG_PHY_NATSEMI=y diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 0910d3bf9d..a07799fbcb 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -54,6 +54,6 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nand" CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_MMC is not set CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y # CONFIG_EFI_LOADER is not set diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index feedb327bd..911148cc8f 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -40,7 +40,7 @@ CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_ANNOUNCE=y diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig index 28d63c9ec5..a2cf0786fa 100644 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ b/configs/zynq_zc770_xm011_x16_defconfig @@ -40,7 +40,7 @@ CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_DEVICE=y -CONFIG_NAND=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_ANNOUNCE=y diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index a129f44869..645ab0bbc6 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -1,7 +1,7 @@
-menuconfig NAND +menuconfig MTD_RAW_NAND bool "Raw NAND Device Support" -if NAND +if MTD_RAW_NAND
config SYS_NAND_SELF_INIT bool diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 3ccd0925e2..0bf8aca37e 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -12,7 +12,7 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/b4860qds/b4_pbi.cfg #define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/b4860qds/b4_rcw.cfg -#ifndef CONFIG_NAND +#ifndef CONFIG_MTD_RAW_NAND #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #else @@ -103,7 +103,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 1097) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) @@ -154,7 +154,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE 256 << 10 #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #endif #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) @@ -328,7 +328,7 @@ unsigned long get_board_ddr_clk(void);
#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024)
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -586,7 +586,7 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 1130) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (13 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index b5d759ce02..fe5df95ce5 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -18,7 +18,7 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0x110bfffc #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SPL_INIT_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" @@ -253,7 +253,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 1c615acb3b..5776df7ccd 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -20,13 +20,13 @@ #define CONFIG_SYS_RAMBOOT #define CONFIG_RESET_VECTOR_ADDRESS 0x110bfffc #endif -#ifdef CONFIG_NAND_SECBOOT +#ifdef CONFIG_MTD_RAW_NAND_SECBOOT #define CONFIG_RAMBOOT_NAND #define CONFIG_SYS_RAMBOOT #define CONFIG_RESET_VECTOR_ADDRESS 0x110bfffc #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SPL_INIT_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" @@ -307,7 +307,7 @@ combinations. this should be removed later #endif
/* Set up IFC registers for boot location NOR/NAND */ -#if defined(CONFIG_NAND) || defined(CONFIG_NAND_SECBOOT) +#if defined(CONFIG_MTD_RAW_NAND) || defined(CONFIG_MTD_RAW_NAND_SECBOOT) #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK #define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR @@ -453,7 +453,7 @@ combinations. this should be removed later #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_NAND) || defined(CONFIG_NAND_SECBOOT) +#elif defined(CONFIG_MTD_RAW_NAND) || defined(CONFIG_MTD_RAW_NAND_SECBOOT) #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 5a1a29bd9e..4b0ba7eb35 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -15,7 +15,7 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0x110bfffc #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #ifdef CONFIG_TPL_BUILD #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_NAND_INIT @@ -215,7 +215,7 @@ #define CONFIG_SYS_NAND_DDR_LAW 11
/* Set up IFC registers for boot location NOR/NAND */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK #define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR @@ -300,7 +300,7 @@ #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 160 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (96 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 112 * 1024) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 #define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR @@ -380,7 +380,7 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 #endif -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 1152bca03b..a1ec2897b0 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -49,7 +49,7 @@ #endif #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #ifdef CONFIG_SECURE_BOOT #define CONFIG_SPL_INIT_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE @@ -90,7 +90,7 @@ #endif #endif
-#ifdef CONFIG_NAND_SECBOOT /* NAND Boot */ +#ifdef CONFIG_MTD_RAW_NAND_SECBOOT /* NAND Boot */ #define CONFIG_RAMBOOT_NAND #define CONFIG_RESET_VECTOR_ADDRESS 0x110bfffc #endif @@ -388,7 +388,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_NAND_DDR_LAW 11
/* Set up IFC registers for boot location NOR/NAND */ -#if defined(CONFIG_NAND) || defined(CONFIG_NAND_SECBOOT) +#if defined(CONFIG_MTD_RAW_NAND) || defined(CONFIG_MTD_RAW_NAND_SECBOOT) #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK #define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR @@ -484,7 +484,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 128 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (128 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 96 * 1024) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_SYS_INIT_L2_ADDR 0xD0000000 #define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR @@ -558,7 +558,7 @@ extern unsigned long get_sdram_size(void); * SPI interface will not be available in case of NAND boot SPI CS0 will be * used for SLIC */ -#if !defined(CONFIG_NAND) || !defined(CONFIG_NAND_SECBOOT) +#if !defined(CONFIG_MTD_RAW_NAND) || !defined(CONFIG_MTD_RAW_NAND_SECBOOT) /* eSPI - Enhanced SPI */ #endif
@@ -634,7 +634,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 4b2eb6525b..6bb44dffab 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -45,7 +45,7 @@ #define CONFIG_SYS_NAND_MAX_ECCPOS 56 #define CONFIG_SYS_NAND_MAX_OOBFREE 5
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #ifdef CONFIG_TPL_BUILD #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_NAND_INIT @@ -187,7 +187,7 @@ (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | BR_PS_16 | BR_V) #define CONFIG_FLASH_OR_PRELIM (OR_AM_128MB | 0xff7)
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_BR1_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ #define CONFIG_SYS_OR1_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ #else @@ -242,7 +242,7 @@ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ | OR_FCM_EHTR) -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Address */ #define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ #else @@ -298,7 +298,7 @@ #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 148 * 1024) #define CONFIG_SPL_RELOC_MALLOC_SIZE (108 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 112 * 1024) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 #define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR @@ -500,7 +500,7 @@ #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index f8cfef7b2d..5fec58f2f4 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -56,7 +56,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 1658) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) @@ -221,7 +221,7 @@ unsigned long get_board_sys_clk(unsigned long dummy); | OR_FCM_TRLX \ | OR_FCM_EHTR)
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Address */ #define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ #define CONFIG_SYS_BR1_PRELIM CONFIG_SYS_FLASH_BR_PRELIM /* NOR Base Address */ @@ -419,7 +419,7 @@ unsigned long get_board_sys_clk(unsigned long dummy); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index fe9a9097ce..00cfd85e5d 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -39,7 +39,7 @@ #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x00200000 #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 @@ -129,7 +129,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) @@ -336,7 +336,7 @@ unsigned long get_board_ddr_clk(void);
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -651,7 +651,7 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) #define CONFIG_SYS_QE_FW_ADDR (512 * 0x920) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_SYS_QE_FW_ADDR (12 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 8c1434fb10..2f56f4af25 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -42,7 +42,7 @@ #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x30000000 #define CONFIG_SYS_NAND_U_BOOT_START 0x30000000 @@ -148,7 +148,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE 0x2000 #if defined(CONFIG_TARGET_T1024RDB) #define CONFIG_ENV_OFFSET (2 * CONFIG_SYS_NAND_BLOCK_SIZE) @@ -360,7 +360,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -611,7 +611,7 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) #define CONFIG_SYS_QE_FW_ADDR (512 * 0x920) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #if defined(CONFIG_TARGET_T1024RDB) #define CONFIG_SYS_FMAN_FW_ADDR (3 * CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_SYS_QE_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index d8b65e699c..c4b767707b 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -66,7 +66,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 1658) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #else @@ -264,7 +264,7 @@ unsigned long get_board_ddr_clk(void);
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -545,7 +545,7 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 53ee1484d0..226cba75f7 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -31,7 +31,7 @@ #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #ifdef CONFIG_SECURE_BOOT #define CONFIG_U_BOOT_HDR_SIZE (16 << 10) /* @@ -162,7 +162,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_SECURE_BOOT #define CONFIG_RAMBOOT_NAND #define CONFIG_BOOTSCRIPT_COPY_RAM @@ -370,7 +370,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024)
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -417,7 +417,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #endif
#ifdef CONFIG_SYS_FSL_ERRATUM_A008044 -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_A008044_WORKAROUND #endif #endif @@ -647,7 +647,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (5 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 @@ -657,7 +657,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_SYS_QE_FW_ADDR 0x130000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_QE_FW_ADDR (512 * 0x920) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_QE_FW_ADDR (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FW_ADDR 0xEFF10000 diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 54ec1abd66..b4803a439b 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -46,7 +46,7 @@ #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x00200000 #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 @@ -125,7 +125,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) @@ -307,7 +307,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024)
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -587,7 +587,7 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 3d95c4afa2..059fb29921 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -40,7 +40,7 @@ #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x00200000 #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 @@ -110,7 +110,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (2 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) @@ -271,7 +271,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024)
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -535,7 +535,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) #define CONFIG_CORTINA_FW_ADDR (512 * 0x8a0)
-#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CORTINA_FW_IN_NAND #define CONFIG_SYS_FMAN_FW_ADDR (3 * CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_CORTINA_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index f17625365e..260a67ee71 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -16,7 +16,7 @@
#ifdef CONFIG_RAMBOOT_PBL #define CONFIG_SYS_FSL_PBL_PBI board/freescale/t4qds/t4_pbi.cfg -#if !defined(CONFIG_NAND) && !defined(CONFIG_SDCARD) +#if !defined(CONFIG_MTD_RAW_NAND) && !defined(CONFIG_SDCARD) #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #else @@ -26,7 +26,7 @@ #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x00200000 #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 @@ -76,7 +76,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) @@ -240,7 +240,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NAND_MAX_OOBFREE 2 #define CONFIG_SYS_NAND_MAX_ECCPOS 256
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -402,7 +402,7 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 57d8d171a7..b674152e18 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -287,7 +287,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_ENV_IS_NOWHERE) @@ -402,7 +402,7 @@ unsigned long get_board_ddr_clk(void);
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -552,7 +552,7 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index be571066f2..ae1e465ef6 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -31,7 +31,7 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define NANDARGS \ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ @@ -193,7 +193,7 @@ /* USB gadget RNDIS */ #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ @@ -220,7 +220,7 @@ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ #endif -#endif /* !CONFIG_NAND */ +#endif /* !CONFIG_MTD_RAW_NAND */
/* * For NOR boot, we must set this to the start of where NOR is mapped diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index 8bde198313..ebd78c8acd 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -64,7 +64,7 @@ /* Bootcount using the RTC block */ #define CONFIG_SYS_BOOTCOUNT_LE
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_ENV_OFFSET_REDUND 0x340000 #define CONFIG_ENV_SIZE 0x040000 @@ -106,6 +106,6 @@
#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS
-#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
#endif /* ! __CONFIG_AM335X_GUARDIAN_H */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 3e5f0b1992..5e430c87b6 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -42,7 +42,7 @@ #define CONFIG_NET_RETRY_COUNT 10
/* Board NAND Info. */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 @@ -73,7 +73,7 @@ * DTB 4 * NAND_BLOCK_SIZE = 512 KiB @ 0xAA0000 * RootFS Remaining Flash Space @ 0xB20000 */ -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
/* Environment information */
@@ -168,7 +168,7 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
-#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE #endif
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index d355b80c2f..01482e8fea 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -208,7 +208,7 @@ #define CONFIG_SYS_RX_ETH_BUFFER 64
/* NAND support */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ #define CONFIG_SYS_NAND_PAGE_SIZE 4096 #define CONFIG_SYS_NAND_OOBSIZE 224 @@ -265,10 +265,10 @@ "nand read ${loadaddr} NAND.kernel; " \ "bootz ${loadaddr} - ${fdtaddr}\0" #define NANDBOOT "run nandboot; " -#else /* !CONFIG_NAND */ +#else /* !CONFIG_MTD_RAW_NAND */ #define NANDARGS #define NANDBOOT -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
#if defined(CONFIG_TI_SECURE_DEVICE) /* Avoid relocating onto firewalled area at end of DRAM */ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index a9b14c5b03..42a5abd1b4 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -28,7 +28,7 @@ /* FIT support */ #define CONFIG_SYS_BOOTM_LEN SZ_64M
#define NANDARGS \ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ @@ -214,7 +214,7 @@ /* SPL */ #ifndef CONFIG_NOR_BOOT
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) @@ -251,7 +251,7 @@ #define CONFIG_AM335X_USB1_MODE MUSB_OTG
/* NAND support */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define GPMC_NAND_ECC_LP_x8_LAYOUT 1 #endif
diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index db21a473f1..9137883353 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -31,7 +31,7 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define NANDARGS \ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ @@ -336,7 +336,7 @@ DEFAULT_LINUX_BOOT_ENV \ /* USB gadget RNDIS */ #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ @@ -367,7 +367,7 @@ DEFAULT_LINUX_BOOT_ENV \ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ #endif -#endif /* !CONFIG_NAND */ +#endif /* !CONFIG_MTD_RAW_NAND */
/* * For NOR boot, we must set this to the start of where NOR is mapped @@ -406,7 +406,7 @@ DEFAULT_LINUX_BOOT_ENV \ "spl-os-image fat 0 1;" \ "u-boot.img fat 0 1;" \ "uEnv.txt fat 0 1\0" -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define DFU_ALT_INFO_NAND \ "dfu_alt_info_nand=" \ "SPL part 0 1;" \ diff --git a/include/configs/broadcom_bcm963158.h b/include/configs/broadcom_bcm963158.h index a0f7ead4c7..e474f9d071 100644 --- a/include/configs/broadcom_bcm963158.h +++ b/include/configs/broadcom_bcm963158.h @@ -30,11 +30,11 @@
#define CONFIG_SKIP_LOWLEVEL_INIT
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT #define CONFIG_SYS_NAND_ONFI_DETECTION -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
/* * bcm963158 diff --git a/include/configs/broadcom_bcm968380gerg.h b/include/configs/broadcom_bcm968380gerg.h index aa6ce67d53..2f109fc59c 100644 --- a/include/configs/broadcom_bcm968380gerg.h +++ b/include/configs/broadcom_bcm968380gerg.h @@ -8,8 +8,8 @@
#define CONFIG_ENV_SIZE (8 * 1024)
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT #define CONFIG_SYS_NAND_ONFI_DETECTION -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */ diff --git a/include/configs/broadcom_bcm968580xref.h b/include/configs/broadcom_bcm968580xref.h index fdb620341d..fbe3bd4981 100644 --- a/include/configs/broadcom_bcm968580xref.h +++ b/include/configs/broadcom_bcm968580xref.h @@ -29,11 +29,11 @@
/* * 968580xref diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index bc0dabb51b..7b5cdb0b66 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -46,20 +46,20 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */
/* NAND */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x140000 -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */ #endif /* CONFIG_SPL_OS_BOOT */
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define NANDTGTS \ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ @@ -74,7 +74,7 @@ "b_tgts_pme=usb0 nand net\0" #else #define NANDTGTS "" -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
#define MMCSPI_TGTS \ "t30args#0=setenv bootargs ${optargs_rot} ${optargs} console=${console} " \ @@ -147,7 +147,7 @@ NANDTGTS \ " if test ${b_break} = 1; then; exit; fi; done\0" #endif /* !CONFIG_SPL_BUILD*/
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND /* * GPMC block. We support 1 device and the physical address to * access CS0 at is 0x8000000. @@ -177,7 +177,7 @@ NANDTGTS \ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE
#define CONFIG_NAND_OMAP_GPMC_WSCFG 1 -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
#if defined(CONFIG_SPI) /* SPI Flash */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 60e09c1939..e87a7a7695 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -15,7 +15,7 @@ #ifdef CONFIG_SECURE_BOOT #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_RAMBOOT_NAND #endif #define CONFIG_BOOTSCRIPT_COPY_RAM @@ -67,7 +67,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 1658) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) @@ -230,7 +230,7 @@ | OR_FCM_TRLX \ | OR_FCM_EHTR)
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Address */ #define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ #define CONFIG_SYS_BR2_PRELIM CONFIG_SYS_FLASH_BR_PRELIM /* NOR Base Address */ @@ -431,7 +431,7 @@ * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 41f0813a01..11e818348a 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -123,7 +123,7 @@ /* * Flash & Environment */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #ifdef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 10) @@ -245,7 +245,7 @@ #define CONFIG_CLOCKS #endif
-#if !defined(CONFIG_NAND) && \ +#if !defined(CONFIG_MTD_RAW_NAND) && \ !defined(CONFIG_USE_NOR) && \ !defined(CONFIG_USE_SPIFLASH) #define CONFIG_ENV_SIZE (16 << 10) diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 3487b8ac1b..e2194e5fd0 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -102,7 +102,7 @@ #define CONFIG_SCSI_AHCI_PLAT
/* NAND support */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 @@ -129,7 +129,7 @@ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ #endif -#endif /* !CONFIG_NAND */ +#endif /* !CONFIG_MTD_RAW_NAND */
/* Parallel NOR Support */ #if defined(CONFIG_NOR) diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 2bf8217685..7c2ff4bb03 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -202,7 +202,7 @@ unsigned long get_board_sys_clk(void); FTIM2_GPCM_TWP(0x3E)) #define CONFIG_SYS_CS3_FTIM3 0x0
-#if defined(CONFIG_SPL) && defined(CONFIG_NAND) +#if defined(CONFIG_SPL) && defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR_EARLY #define CONFIG_SYS_CSPR2_FINAL CONFIG_SYS_NOR0_CSPR diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index e8c60838b7..fa54ecc453 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -24,7 +24,7 @@ #define CONFIG_REVISION_TAG
/* NAND */ -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_5_ADDR_CYCLE @@ -46,7 +46,7 @@ #if defined(CONFIG_SPL_OS_BOOT) #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 #endif /* CONFIG_SPL_OS_BOOT */ -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
/* USB EHCI */ #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 147 @@ -68,7 +68,7 @@ #define BOOTENV_DEV_NAME_LEGACY_MMC(devtypeu, devtypel, instance) \ #devtypel #instance " "
#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ "bootcmd_" #devtypel #instance "=" \ @@ -86,13 +86,13 @@ func(UBIFS, ubifs, 0) \ func(NAND, nand, 0)
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(LEGACY_MMC, legacy_mmc, 0)
#include <config_distro_bootcmd.h>
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 8e98977de8..1ce9470d4a 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -29,7 +29,7 @@ #define CONFIG_REVISION_TAG
/* NAND */ -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_5_ADDR_CYCLE @@ -50,7 +50,7 @@ #if defined(CONFIG_SPL_OS_BOOT) #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 #endif /* CONFIG_SPL_OS_BOOT */ -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
#define MEM_LAYOUT_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV @@ -62,7 +62,7 @@ #define BOOTENV_DEV_NAME_LEGACY_MMC(devtypeu, devtypel, instance) \ #devtypel #instance " "
#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ "bootcmd_" #devtypel #instance "=" \ @@ -80,13 +80,13 @@ func(UBIFS, ubifs, 0) \ func(NAND, nand, 0)
diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 90292ae312..ca06f59bab 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -38,7 +38,7 @@ #endif
/* Board NAND Info. */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 38a10e23d9..7fd52a429d 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -32,7 +32,7 @@
/* commands to include */
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND /* NAND block size is 128 KiB. Synchronize these values with * overo_nand_partitions in mach-omap2/board-overo.c in Linux: * xloader 4 * NAND_BLOCK_SIZE = 512 KiB @@ -41,7 +41,7 @@ * linux 64 * NAND_BLOCK_SIZE = 8 MiB * rootfs remainder */ -#endif /* CONFIG_NAND */ +#endif /* CONFIG_MTD_RAW_NAND */
/* Board NAND Info. */ /* Environment information */ @@ -145,7 +145,7 @@ 0x01F00000) /* 31MB */
/* FLASH and environment organization */ -#if defined(CONFIG_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE #endif
diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 98f243f4dd..94e80896ca 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -52,7 +52,7 @@ #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ 0x01F00000) /* 31MB */
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 1c41e7e97a..de010bcad7 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -116,7 +116,7 @@ /* * Flash & Environment */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 9) #define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 1481d683e5..1a37e2692c 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -163,7 +163,7 @@ #endif #endif
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #ifdef CONFIG_TPL_BUILD #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_NAND_INIT @@ -442,7 +442,7 @@ OR_GPCM_SCY | OR_GPCM_TRLX | OR_GPCM_EHTR | \ OR_GPCM_EAD)
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Addr */ #define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ #define CONFIG_SYS_BR1_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ @@ -498,7 +498,7 @@ #else #define CONFIG_SPL_RELOC_MALLOC_SIZE (108 << 10) #endif -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 #define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR @@ -704,7 +704,7 @@ #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 -#elif defined(CONFIG_NAND) +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h index ca28b6ff1b..58fa2162a8 100644 --- a/include/configs/phycore_am335x_r2.h +++ b/include/configs/phycore_am335x_r2.h @@ -18,7 +18,7 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define NANDARGS \ "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ @@ -87,7 +87,7 @@
#define CONFIG_POWER_TPS65910
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ @@ -114,7 +114,7 @@ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ #endif -#endif /* !CONFIG_NAND */ +#endif /* !CONFIG_MTD_RAW_NAND */
/* CPU */
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index ea6cc38fc1..4ab030cadd 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -183,7 +183,7 @@ #define CONFIG_NET_RETRY_COUNT 10
/* NAND support */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND /* UBI Support */
/* Commen environment */ diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 2de6bc2390..b498681615 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -174,7 +174,7 @@
/* General parts of the framework, required. */
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC diff --git a/include/configs/ti_armv7_omap.h b/include/configs/ti_armv7_omap.h index 98b5839154..727c648319 100644 --- a/include/configs/ti_armv7_omap.h +++ b/include/configs/ti_armv7_omap.h @@ -15,7 +15,7 @@ * GPMC NAND block. We support 1 device and the physical address to * access CS0 at is 0x8000000. */ -#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #ifndef CONFIG_SYS_NAND_BASE #define CONFIG_SYS_NAND_BASE 0x8000000 #endif diff --git a/include/configs/ti_omap3_common.h b/include/configs/ti_omap3_common.h index 5d9c8efe58..3d7cb175fa 100644 --- a/include/configs/ti_omap3_common.h +++ b/include/configs/ti_omap3_common.h @@ -58,7 +58,7 @@ #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (64 << 20))
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_BASE 0x30000000 #endif
diff --git a/include/environment/ti/dfu.h b/include/environment/ti/dfu.h index 9f7ea03226..720c3453af 100644 --- a/include/environment/ti/dfu.h +++ b/include/environment/ti/dfu.h @@ -39,7 +39,7 @@ "u-boot.img fat 1 1;" \ "uEnv.txt fat 1 1\0"
-#ifdef CONFIG_NAND +#ifdef CONFIG_MTD_RAW_NAND #define DFU_ALT_INFO_NAND \ "dfu_alt_info_nand=" \ "SPL part 0 1;" \ diff --git a/include/environment/ti/nand.h b/include/environment/ti/nand.h index f838cb3ed1..f2482e8c35 100644 --- a/include/environment/ti/nand.h +++ b/include/environment/ti/nand.h @@ -5,7 +5,7 @@ * Environment variable definitions for NAND on TI boards. */
On Thu, Oct 03, 2019 at 07:50:03PM +0200, Miquel Raynal wrote:
Add more clarity by changing the Kconfig entry name.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com
After re-running the migration: Applied to u-boot/master, thanks!
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/10m50_defconfig | 2 +- configs/3c120_defconfig | 2 +- configs/adp-ae3xx_defconfig | 2 +- configs/alt_defconfig | 2 +- configs/am335x_guardian_defconfig | 2 +- configs/bcm963158_ram_defconfig | 2 +- configs/bcm968380gerg_ram_defconfig | 2 +- configs/bcm968580xref_ram_defconfig | 2 +- configs/bk4r1_defconfig | 2 +- configs/boston32r2_defconfig | 2 +- configs/boston32r2el_defconfig | 2 +- configs/boston32r6_defconfig | 2 +- configs/boston32r6el_defconfig | 2 +- configs/boston64r2_defconfig | 2 +- configs/boston64r2el_defconfig | 2 +- configs/boston64r6_defconfig | 2 +- configs/boston64r6el_defconfig | 2 +- configs/colibri-imx6ull_defconfig | 2 +- configs/colibri_imx7_defconfig | 2 +- configs/colibri_t20_defconfig | 2 +- configs/colibri_vf_defconfig | 2 +- configs/comtrend_ct5361_ram_defconfig | 2 +- configs/comtrend_wap5813n_ram_defconfig | 2 +- configs/crs305-1g-4s_defconfig | 2 +- configs/db-xc3-24g4xg_defconfig | 2 +- configs/gardena-smart-gateway-mt7688-ram_defconfig | 2 +- configs/gardena-smart-gateway-mt7688_defconfig | 2 +- configs/gazerbeam_defconfig | 2 +- configs/gose_defconfig | 2 +- configs/harmony_defconfig | 2 +- configs/huawei_hg556a_ram_defconfig | 2 +- configs/imx6q_logic_defconfig | 2 +- configs/khadas-vim2_defconfig | 2 +- configs/koelsch_defconfig | 2 +- configs/lager_defconfig | 2 +- configs/libretech-ac_defconfig | 2 +- configs/mccmon6_nor_defconfig | 2 +- configs/mccmon6_sd_defconfig | 2 +- configs/mscc_ocelot_defconfig | 2 +- configs/pcm052_defconfig | 2 +- configs/pcm058_defconfig | 2 +- configs/pfla02_defconfig | 2 +- configs/phycore_pcl063_defconfig | 2 +- configs/porter_defconfig | 2 +- configs/qemu_arm64_defconfig | 2 +- configs/qemu_arm_defconfig | 2 +- configs/r8a77995_draak_defconfig | 2 +- configs/sfr_nb4-ser_ram_defconfig | 2 +- configs/silk_defconfig | 2 +- configs/stm32f469-discovery_defconfig | 2 +- configs/stm32f746-disco_defconfig | 2 +- configs/stm32mp15_basic_defconfig | 2 +- configs/stm32mp15_trusted_defconfig | 2 +- configs/stout_defconfig | 2 +- configs/uDPU_defconfig | 2 +- drivers/mtd/Kconfig | 2 +- drivers/mtd/Makefile | 2 +- drivers/mtd/mtd_uboot.c | 2 +- include/flash.h | 2 +- 59 files changed, 59 insertions(+), 59 deletions(-)
diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index 119cbcd354..8df747904b 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -23,7 +23,7 @@ CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y CONFIG_MISC=y CONFIG_ALTERA_SYSID=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y CONFIG_ALTERA_QSPI=y diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index 42a032f1e7..a6f369603a 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -23,7 +23,7 @@ CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y CONFIG_MISC=y CONFIG_ALTERA_SYSID=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index a591681819..322fc8da84 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -27,7 +27,7 @@ CONFIG_MMC=y CONFIG_DM_MMC=y CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 0284d80b93..44a1698d45 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -65,7 +65,7 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index bd6c8c86c2..ed288136c3 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -66,7 +66,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x100000 diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index 3b4c86ce59..a08ece81ad 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -34,7 +34,7 @@ CONFIG_LED=y CONFIG_LED_BCM6858=y CONFIG_LED_BLINK=y # CONFIG_MMC is not set -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_63158=y diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 0d04863721..4f963ee38e 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -37,7 +37,7 @@ CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_BCM6328=y CONFIG_LED_BLINK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6838=y diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index f3a87edebb..0812a81c72 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -29,7 +29,7 @@ CONFIG_LED=y CONFIG_LED_BCM6858=y CONFIG_LED_BLINK=y # CONFIG_MMC is not set -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6858=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 20d3e33e96..9b965c5b7a 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -54,7 +54,7 @@ CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_DM_MMC=y CONFIG_FSL_ESDHC_IMX=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 3d8d97252c..7023dbe5c9 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -27,7 +27,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 6650211b48..44b4f9be78 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -28,7 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/boston32r6_defconfig b/configs/boston32r6_defconfig index b916460f05..6a48a8b7dc 100644 --- a/configs/boston32r6_defconfig +++ b/configs/boston32r6_defconfig @@ -28,7 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/boston32r6el_defconfig b/configs/boston32r6el_defconfig index 6bf0027e69..f6cc9f2551 100644 --- a/configs/boston32r6el_defconfig +++ b/configs/boston32r6el_defconfig @@ -29,7 +29,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 250a70da90..bcea44b03e 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -28,7 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index 84c4e5372b..0383c0932b 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -29,7 +29,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/boston64r6_defconfig b/configs/boston64r6_defconfig index 133a0a9115..55bf9906d9 100644 --- a/configs/boston64r6_defconfig +++ b/configs/boston64r6_defconfig @@ -28,7 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/boston64r6el_defconfig b/configs/boston64r6el_defconfig index 8c97dca774..8ebc293acc 100644 --- a/configs/boston64r6el_defconfig +++ b/configs/boston64r6el_defconfig @@ -29,7 +29,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 4980f91d37..71f64bae6a 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -53,7 +53,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 8e2657dcf0..973b681bdd 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -53,7 +53,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS_DT=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 262ff9e5fc..49ed114522 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -39,7 +39,7 @@ CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=1536 CONFIG_SPL_DM=y CONFIG_SYS_I2C_TEGRA=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index c21efa2cf1..593ff34117 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -59,7 +59,7 @@ CONFIG_VYBRID_GPIO=y CONFIG_DM_MMC=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_FSL_ESDHC_IMX=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index 41ce399194..f95ea35880 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -36,7 +36,7 @@ CONFIG_DM_GPIO=y CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index f466cabc61..8b2107bec5 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -36,7 +36,7 @@ CONFIG_DM_GPIO=y CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/crs305-1g-4s_defconfig b/configs/crs305-1g-4s_defconfig index c396a7c5ba..6146556968 100644 --- a/configs/crs305-1g-4s_defconfig +++ b/configs/crs305-1g-4s_defconfig @@ -32,7 +32,7 @@ CONFIG_BLK=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig index 5850536ce6..20c7f8931b 100644 --- a/configs/db-xc3-24g4xg_defconfig +++ b/configs/db-xc3-24g4xg_defconfig @@ -35,7 +35,7 @@ CONFIG_BLK=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index 03f9d99760..281ad308e6 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -49,7 +49,7 @@ CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_SPI_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 6cb8fc0631..d5792b63d8 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -52,7 +52,7 @@ CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_SPI_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index 3a29bb1277..a176bcd431 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -164,7 +164,7 @@ CONFIG_GDSYS_SOC=y CONFIG_IHS_FPGA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 15a9c5c8f1..d5649aff79 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -63,7 +63,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 519da65c19..c7c8bc249c 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -29,7 +29,7 @@ CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-harmony" CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PCI=y CONFIG_DM_PCI=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index 8c4f87ad57..3401e18c2b 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -36,7 +36,7 @@ CONFIG_DM_GPIO=y CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index c1e3971432..110f91c4b2 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -67,7 +67,7 @@ CONFIG_PCF8575_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y diff --git a/configs/khadas-vim2_defconfig b/configs/khadas-vim2_defconfig index a9f6a0e281..be49256320 100644 --- a/configs/khadas-vim2_defconfig +++ b/configs/khadas-vim2_defconfig @@ -27,7 +27,7 @@ CONFIG_SARADC_MESON=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_PHY_REALTEK=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 393a1c680a..1118e7b69c 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -63,7 +63,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index c3a96471f4..c6f5b71a31 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -65,7 +65,7 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/libretech-ac_defconfig b/configs/libretech-ac_defconfig index f4f7b068a1..20a153770a 100644 --- a/configs/libretech-ac_defconfig +++ b/configs/libretech-ac_defconfig @@ -34,7 +34,7 @@ CONFIG_SARADC_MESON=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index a738ddba7c..f0aac83850 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -29,7 +29,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 377c52a41a..f8acb5e81b 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -30,7 +30,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index edc476d143..18dd956b98 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -49,7 +49,7 @@ CONFIG_DM_GPIO=y CONFIG_MSCC_SGPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_SPI_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index b7e3d04641..cce7cf435a 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -40,7 +40,7 @@ CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_DM_MMC=y CONFIG_FSL_ESDHC_IMX=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 9fd33da324..86999429ef 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -45,7 +45,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index e6a679554e..bfbc30f680 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -44,7 +44,7 @@ CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DM=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index 27e3a7c88e..6b11bfe2f3 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -36,7 +36,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-phycore-segin" CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index f3f5105aa6..8bfa845439 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -63,7 +63,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index 7237819909..5cde505e78 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -17,7 +17,7 @@ CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y CONFIG_BLK=y # CONFIG_MMC is not set -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 7c95892d98..e8604d8e2a 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -18,7 +18,7 @@ CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y CONFIG_BLK=y # CONFIG_MMC is not set -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 1f6add93e4..f5a8428f21 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -44,7 +44,7 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index db12ce85d5..d2ba552777 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -38,7 +38,7 @@ CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_BCM6358=y CONFIG_LED_GPIO=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index db63b14f19..60ca53baa9 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -65,7 +65,7 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/stm32f469-discovery_defconfig b/configs/stm32f469-discovery_defconfig index dcd0697677..6de461555c 100644 --- a/configs/stm32f469-discovery_defconfig +++ b/configs/stm32f469-discovery_defconfig @@ -26,7 +26,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="stm32f469-disco" CONFIG_DM_MMC=y CONFIG_ARM_PL180_MMCI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 3c43d2a591..8543f9d002 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -39,7 +39,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM_MMC=y # CONFIG_SPL_DM_MMC is not set CONFIG_ARM_PL180_MMCI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index daa126ec2d..a9c3ad5dec 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -79,7 +79,7 @@ CONFIG_STM32_IPCC=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_STM32_SDMMC2=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 88d342ae7c..f7f9f4d0a0 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -65,7 +65,7 @@ CONFIG_STM32_IPCC=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_STM32_SDMMC2=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index f32c005e8c..c38d0c339f 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -63,7 +63,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/uDPU_defconfig b/configs/uDPU_defconfig index ec0b731a3f..672a1b857b 100644 --- a/configs/uDPU_defconfig +++ b/configs/uDPU_defconfig @@ -56,7 +56,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_XENON=y -CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_BAR=y diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 0050fb2b9b..ecd62642eb 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -3,7 +3,7 @@ menu "MTD Support" config MTD_PARTITIONS bool
-config MTD +config DM_MTD bool "Enable Driver Model for MTD drivers" depends on DM help diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 22ceda93c0..eac6930de6 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -6,7 +6,7 @@ ifneq (,$(findstring y,$(CONFIG_MTD_DEVICE)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND)$(CONFIG_CMD_SF)$(CONFIG_CMD_MTD))) obj-y += mtdcore.o mtd_uboot.o endif -obj-$(CONFIG_MTD) += mtd-uclass.o +obj-$(CONFIG_DM_MTD) += mtd-uclass.o obj-$(CONFIG_MTD_PARTITIONS) += mtdpart.o obj-$(CONFIG_MTD_CONCAT) += mtdconcat.o obj-$(CONFIG_ALTERA_QSPI) += altera_qspi.o diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 5574227598..7c6c9ac0bc 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -99,7 +99,7 @@ int mtd_search_alternate_name(const char *mtdname, char *altname, return -EINVAL; }
-#if IS_ENABLED(CONFIG_MTD) +#if IS_ENABLED(CONFIG_DM_MTD) static void mtd_probe_uclass_mtd_devs(void) { struct udevice *dev; diff --git a/include/flash.h b/include/flash.h index 70ab435199..807800b524 100644 --- a/include/flash.h +++ b/include/flash.h @@ -44,7 +44,7 @@ typedef struct { uchar sr_supported; /* status register supported */ const char *name; /* human-readable name */ #endif -#ifdef CONFIG_MTD +#ifdef CONFIG_DM_MTD struct mtd_info *mtd; #endif #ifdef CONFIG_CFI_FLASH /* DM-specific parts */
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- cmd/Kconfig | 2 +- configs/10m50_defconfig | 2 +- configs/TQM834x_defconfig | 2 +- configs/TWR-P1025_defconfig | 2 +- configs/alt_defconfig | 2 +- configs/bitmain_antminer_s9_defconfig | 2 +- configs/brppt1_spi_defconfig | 2 +- configs/crs305-1g-4s_defconfig | 2 +- configs/da850evm_defconfig | 1 - configs/db-xc3-24g4xg_defconfig | 2 +- configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/ds414_defconfig | 2 +- configs/gose_defconfig | 2 +- configs/gwventana_emmc_defconfig | 2 +- configs/gwventana_gw5904_defconfig | 2 +- configs/kmeter1_defconfig | 2 +- configs/kmopti2_defconfig | 2 +- configs/kmsupx5_defconfig | 2 +- configs/kmtepr2_defconfig | 2 +- configs/koelsch_defconfig | 2 +- configs/lager_defconfig | 2 +- configs/mccmon6_nor_defconfig | 1 - configs/mccmon6_sd_defconfig | 1 - configs/microblaze-generic_defconfig | 2 +- configs/porter_defconfig | 2 +- configs/r8a77995_draak_defconfig | 1 - configs/s5pc210_universal_defconfig | 2 +- configs/silk_defconfig | 2 +- configs/smdkc100_defconfig | 2 +- configs/socfpga_arria10_defconfig | 2 +- configs/socfpga_arria5_defconfig | 2 +- configs/socfpga_cyclone5_defconfig | 2 +- configs/socfpga_dbm_soc1_defconfig | 2 +- configs/socfpga_de0_nano_soc_defconfig | 2 +- configs/socfpga_de10_nano_defconfig | 2 +- configs/socfpga_de1_soc_defconfig | 2 +- configs/socfpga_is1_defconfig | 2 +- configs/socfpga_sockit_defconfig | 2 +- configs/socfpga_socrates_defconfig | 2 +- configs/socfpga_sr1500_defconfig | 2 +- configs/socfpga_vining_fpga_defconfig | 2 +- configs/spear300_defconfig | 2 +- configs/spear300_nand_defconfig | 2 +- configs/spear300_usbtty_defconfig | 2 +- configs/spear300_usbtty_nand_defconfig | 2 +- configs/spear310_defconfig | 2 +- configs/spear310_nand_defconfig | 2 +- configs/spear310_pnor_defconfig | 2 +- configs/spear310_usbtty_defconfig | 2 +- configs/spear310_usbtty_nand_defconfig | 2 +- configs/spear310_usbtty_pnor_defconfig | 2 +- configs/spear320_defconfig | 2 +- configs/spear320_nand_defconfig | 2 +- configs/spear320_pnor_defconfig | 2 +- configs/spear320_usbtty_defconfig | 2 +- configs/spear320_usbtty_nand_defconfig | 2 +- configs/spear320_usbtty_pnor_defconfig | 2 +- configs/spear600_defconfig | 2 +- configs/spear600_nand_defconfig | 2 +- configs/spear600_usbtty_defconfig | 2 +- configs/spear600_usbtty_nand_defconfig | 2 +- configs/stmark2_defconfig | 2 +- configs/stout_defconfig | 2 +- configs/suvd3_defconfig | 2 +- configs/tuge1_defconfig | 2 +- configs/tuxx1_defconfig | 2 +- configs/vct_platinum_onenand_defconfig | 2 +- configs/vct_platinum_onenand_small_defconfig | 2 +- configs/vct_platinumavc_onenand_defconfig | 2 +- configs/vct_platinumavc_onenand_small_defconfig | 2 +- configs/vct_premium_onenand_defconfig | 2 +- configs/vct_premium_onenand_small_defconfig | 2 +- configs/vexpress_aemv8a_juno_defconfig | 2 +- configs/vexpress_aemv8a_semi_defconfig | 2 +- configs/vexpress_ca15_tc2_defconfig | 2 +- configs/vexpress_ca5x2_defconfig | 2 +- configs/vexpress_ca9x4_defconfig | 2 +- configs/x530_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 2 +- configs/zynq_cse_nand_defconfig | 2 +- configs/zynq_zc770_xm011_defconfig | 2 +- configs/zynq_zc770_xm011_x16_defconfig | 2 +- drivers/mtd/Kconfig | 12 ++++++------ drivers/mtd/Makefile | 2 +- drivers/mtd/nand/raw/nand.c | 2 +- drivers/mtd/onenand/onenand_uboot.c | 2 +- include/configs/mvebu_armada-37xx.h | 2 +- include/configs/socfpga_stratix10_socdk.h | 2 +- include/configs/x530.h | 1 - 91 files changed, 91 insertions(+), 95 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 98647f58b7..bcfbbb4fc6 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1895,7 +1895,7 @@ config CMD_JFFS2
config CMD_MTDPARTS bool "MTD partition support" - select MTD_DEVICE if (CMD_NAND || NAND) + select MTD if (CMD_NAND || NAND) help MTD partitioning tool support. It is strongly encouraged to avoid using this command diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index 8df747904b..d283a17105 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -23,9 +23,9 @@ CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y CONFIG_MISC=y CONFIG_ALTERA_SYSID=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y CONFIG_ALTERA_QSPI=y CONFIG_PHY_MARVELL=y CONFIG_DM_ETH=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index d2e85c9408..effd305a3c 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -140,7 +140,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=TQM834x-0" CONFIG_MTDPARTS_DEFAULT="mtdparts=TQM834x-0:256k(u-boot),256k(env),1m(kernel),2m(initrd),-(user);" # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index 53f66c714d..d997666b4b 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -33,7 +33,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SATA_SIL3114=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 44a1698d45..e9280d587a 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -65,8 +65,8 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index 966fc9134e..21cd33a2ec 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -57,7 +57,7 @@ CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y CONFIG_MTD_RAW_NAND_ZYNQ_USE_BOOTLOADER1_TIMINGS=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index a29dc0385e..4d7bab6d10 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -85,7 +85,7 @@ CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 diff --git a/configs/crs305-1g-4s_defconfig b/configs/crs305-1g-4s_defconfig index 6146556968..8049747f0a 100644 --- a/configs/crs305-1g-4s_defconfig +++ b/configs/crs305-1g-4s_defconfig @@ -33,7 +33,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 5eb015022f..e352c75f6f 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -57,7 +57,6 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DAVINCI=y CONFIG_DM_MMC=y CONFIG_MTD=y -CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig index 20c7f8931b..58b2843c47 100644 --- a/configs/db-xc3-24g4xg_defconfig +++ b/configs/db-xc3-24g4xg_defconfig @@ -36,7 +36,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index e48b6467e6..33b6dda17a 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -68,7 +68,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 5b79057074..955c6f3d5d 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -67,7 +67,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index 408904df22..9720ff8e91 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -50,7 +50,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_BLK=y # CONFIG_MMC is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index d5649aff79..0109bf7552 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -63,8 +63,8 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 8c79cbad40..6b343bf7b3 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -64,7 +64,7 @@ CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 6b2e0c7fc4..48ce0112ae 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -64,7 +64,7 @@ CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHYLIB=y CONFIG_MV88E61XX_SWITCH=y CONFIG_MV88E61XX_CPU_PORT=5 diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 518e9f4229..369ba6a9d4 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -144,7 +144,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index 8231ce4d7c..a72dc7f808 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -164,7 +164,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 72931a716f..8ce90cd23f 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -144,7 +144,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index 42fbbbbac3..c131d7f2ef 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -164,7 +164,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 1118e7b69c..232714e578 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -63,8 +63,8 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index c6f5b71a31..cde19d1b83 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -65,8 +65,8 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index f0aac83850..586ea618a7 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -31,7 +31,6 @@ CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index f8acb5e81b..cfc911d13f 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -32,7 +32,6 @@ CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 94b9c78a6c..dbf5cecaeb 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -47,7 +47,7 @@ CONFIG_XILINX_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 8bfa845439..2d2ba05170 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -63,8 +63,8 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index f5a8428f21..4acdd21662 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -46,7 +46,6 @@ CONFIG_MMC_HS200_SUPPORT=y CONFIG_RENESAS_SDHI=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index ad52e3a2cb..de4a094b79 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -34,7 +34,7 @@ CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_S5P=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_MAX8998=y CONFIG_USB=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 60ca53baa9..07da617814 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -65,8 +65,8 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index 88b56cbb81..8ecae59679 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -22,6 +22,6 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=s3c-onenand:256k(bootloader),128k@0x40000(para CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-smdkc100" CONFIG_ENV_IS_IN_ONENAND=y # CONFIG_MMC is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x98800300 diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index a2d555b9b4..f2f3acfd6f 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -36,7 +36,7 @@ CONFIG_DWAPB_GPIO=y CONFIG_FS_LOADER=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index d591c7e4d7..7517df6e1e 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -42,7 +42,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 3f9766d0fb..1c576cedfe 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -42,7 +42,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index c6c8f073ea..7a2532cd5f 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -45,7 +45,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index bbd9d7f4b4..f677149bec 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -42,7 +42,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index a2f58766cc..0fdaf402f2 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -38,7 +38,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index fa2bace56f..2882b54779 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -36,7 +36,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 9e58fd1158..274e2aa382 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -40,7 +40,7 @@ CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MICREL=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index a3c6af7810..8e804a425f 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -42,7 +42,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 1143cd3f37..7c78fa3224 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -43,7 +43,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 89349ceb4e..e4286e5415 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -44,7 +44,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=100000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 6b2266fdfd..627009d632 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -67,7 +67,7 @@ CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=3 CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=70 CONFIG_DM_MMC=y CONFIG_MMC_DW=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/spear300_defconfig b/configs/spear300_defconfig index 8e22c1e9d1..c44167bedf 100644 --- a/configs/spear300_defconfig +++ b/configs/spear300_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear300_nand_defconfig b/configs/spear300_nand_defconfig index 0fc1198d4a..85976ee03a 100644 --- a/configs/spear300_nand_defconfig +++ b/configs/spear300_nand_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_usbtty_defconfig b/configs/spear300_usbtty_defconfig index fbdd4a31af..6ebab8be1f 100644 --- a/configs/spear300_usbtty_defconfig +++ b/configs/spear300_usbtty_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear300_usbtty_nand_defconfig b/configs/spear300_usbtty_nand_defconfig index 93979928e0..31292e27bb 100644 --- a/configs/spear300_usbtty_nand_defconfig +++ b/configs/spear300_usbtty_nand_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_defconfig b/configs/spear310_defconfig index 423e1ff009..7b8bd93e9c 100644 --- a/configs/spear310_defconfig +++ b/configs/spear310_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear310_nand_defconfig b/configs/spear310_nand_defconfig index bd2bb5abcd..22dc7a10fb 100644 --- a/configs/spear310_nand_defconfig +++ b/configs/spear310_nand_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_pnor_defconfig b/configs/spear310_pnor_defconfig index dea51b9efe..7d61243bf6 100644 --- a/configs/spear310_pnor_defconfig +++ b/configs/spear310_pnor_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/spear310_usbtty_defconfig b/configs/spear310_usbtty_defconfig index 722c84804d..71713f242c 100644 --- a/configs/spear310_usbtty_defconfig +++ b/configs/spear310_usbtty_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear310_usbtty_nand_defconfig b/configs/spear310_usbtty_nand_defconfig index 9802082f11..877c09f39a 100644 --- a/configs/spear310_usbtty_nand_defconfig +++ b/configs/spear310_usbtty_nand_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_pnor_defconfig b/configs/spear310_usbtty_pnor_defconfig index 7fd7dda431..3b4af6bc41 100644 --- a/configs/spear310_usbtty_pnor_defconfig +++ b/configs/spear310_usbtty_pnor_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/spear320_defconfig b/configs/spear320_defconfig index 979bf04121..319ae23147 100644 --- a/configs/spear320_defconfig +++ b/configs/spear320_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear320_nand_defconfig b/configs/spear320_nand_defconfig index cb8feb655c..e1f2b19cc2 100644 --- a/configs/spear320_nand_defconfig +++ b/configs/spear320_nand_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_pnor_defconfig b/configs/spear320_pnor_defconfig index f7dd487115..311d69e085 100644 --- a/configs/spear320_pnor_defconfig +++ b/configs/spear320_pnor_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/spear320_usbtty_defconfig b/configs/spear320_usbtty_defconfig index 9fab406f13..f7f933093d 100644 --- a/configs/spear320_usbtty_defconfig +++ b/configs/spear320_usbtty_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear320_usbtty_nand_defconfig b/configs/spear320_usbtty_nand_defconfig index 9b3ad1b354..36e7d2afcd 100644 --- a/configs/spear320_usbtty_nand_defconfig +++ b/configs/spear320_usbtty_nand_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_pnor_defconfig b/configs/spear320_usbtty_pnor_defconfig index 1dfac113d3..6908fb7435 100644 --- a/configs/spear320_usbtty_pnor_defconfig +++ b/configs/spear320_usbtty_pnor_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/spear600_defconfig b/configs/spear600_defconfig index eeb2746a9e..7120cd6c1e 100644 --- a/configs/spear600_defconfig +++ b/configs/spear600_defconfig @@ -26,7 +26,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear600_nand_defconfig b/configs/spear600_nand_defconfig index b37b19d87e..9c7c604e12 100644 --- a/configs/spear600_nand_defconfig +++ b/configs/spear600_nand_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_usbtty_defconfig b/configs/spear600_usbtty_defconfig index 2e6f3f159c..1d001ca057 100644 --- a/configs/spear600_usbtty_defconfig +++ b/configs/spear600_usbtty_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/spear600_usbtty_nand_defconfig b/configs/spear600_usbtty_nand_defconfig index 1d57def8a9..dd98ff137d 100644 --- a/configs/spear600_usbtty_nand_defconfig +++ b/configs/spear600_usbtty_nand_defconfig @@ -23,7 +23,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/stmark2_defconfig b/configs/stmark2_defconfig index b039ebb9ea..796a69ed55 100644 --- a/configs/stmark2_defconfig +++ b/configs/stmark2_defconfig @@ -24,7 +24,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_CS=y CONFIG_ENV_SPI_CS=1 # CONFIG_NET is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/stout_defconfig b/configs/stout_defconfig index c38d0c339f..63623a020b 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -64,7 +64,7 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_RENESAS_SDHI=y CONFIG_DM_MTD=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index bb21bde3ee..9c45501038 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -165,7 +165,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 22ba1929c7..3ddcad39d4 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -144,7 +144,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 94214a2356..621e4ece7e 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -166,7 +166,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index ded3de0499..1d3d405d8e 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -23,7 +23,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(r CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_ENV_IS_IN_ONENAND=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x00000000 CONFIG_SMC911X_32_BIT=y diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig index 4afb03ee9e..50adb73129 100644 --- a/configs/vct_platinum_onenand_small_defconfig +++ b/configs/vct_platinum_onenand_small_defconfig @@ -29,5 +29,5 @@ CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y # CONFIG_NET is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index e7e9c6cde1..692fae7036 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -20,6 +20,6 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SYS_NS16550=y # CONFIG_REGEX is not set diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig index 776472666c..bcf39bc1ed 100644 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ b/configs/vct_platinumavc_onenand_small_defconfig @@ -29,5 +29,5 @@ CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y # CONFIG_NET is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index f1d01d9c90..2e87bdf358 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -23,7 +23,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(r CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_ENV_IS_IN_ONENAND=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x00000000 CONFIG_SMC911X_32_BIT=y diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig index 751f881942..93fd4299d2 100644 --- a/configs/vct_premium_onenand_small_defconfig +++ b/configs/vct_premium_onenand_small_defconfig @@ -29,5 +29,5 @@ CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y # CONFIG_NET is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_SYS_NS16550=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 0823d17c11..6891e79469 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -30,7 +30,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index db5ad3dfa5..ea96403e8e 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -30,7 +30,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 904c75614f..db242a7828 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -21,7 +21,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index ca847a2f9a..18cdb8f734 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -20,7 +20,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 06fcfee1d3..771d5c9bbb 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -20,7 +20,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 852039d32d..0b19a1af90 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_I2C_MVTWSI=y CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 9db0e21f56..9faebdcf46 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -55,7 +55,7 @@ CONFIG_SYS_I2C_CADENCE=y CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_DM_MMC=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y CONFIG_SYS_NAND_MAX_CHIPS=2 diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index 826a48702f..2a0f97f456 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -53,7 +53,7 @@ CONFIG_MISC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y CONFIG_PHY_MARVELL=y diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index a07799fbcb..ae0e6d3690 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -53,7 +53,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nand" # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_MMC is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y # CONFIG_EFI_LOADER is not set diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index 911148cc8f..029093396e 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -39,7 +39,7 @@ CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y CONFIG_DEBUG_UART_ZYNQ=y diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig index a2cf0786fa..b24764e42d 100644 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ b/configs/zynq_zc770_xm011_x16_defconfig @@ -39,7 +39,7 @@ CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set -CONFIG_MTD_DEVICE=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y CONFIG_DEBUG_UART_ZYNQ=y diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index ecd62642eb..345046c2a6 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -3,6 +3,12 @@ menu "MTD Support" config MTD_PARTITIONS bool
+config MTD + bool "Enable MTD layer" + help + Enable the MTD stack, necessary to interract with NAND, NOR, + SPI-NOR, SPI-NAND, onenand, etc. + config DM_MTD bool "Enable Driver Model for MTD drivers" depends on DM @@ -16,12 +22,6 @@ config MTD_NOR_FLASH help Enable support for parallel NOR flash.
-config MTD_DEVICE - bool "Enable MTD Device for NAND and ONENAND devices" - help - Adds the MTD device infrastructure from the Linux kernel. - Needed for mtdparts command support. - config FLASH_CFI_DRIVER bool "Enable CFI Flash driver" help diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index eac6930de6..3542042245 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifneq (,$(findstring y,$(CONFIG_MTD_DEVICE)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND)$(CONFIG_CMD_SF)$(CONFIG_CMD_MTD))) +ifneq (,$(findstring y,$(CONFIG_MTD)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND)$(CONFIG_CMD_SF)$(CONFIG_CMD_MTD))) obj-y += mtdcore.o mtd_uboot.o endif obj-$(CONFIG_DM_MTD) += mtd-uclass.o diff --git a/drivers/mtd/nand/raw/nand.c b/drivers/mtd/nand/raw/nand.c index bca51ffbf2..026419e4e6 100644 --- a/drivers/mtd/nand/raw/nand.c +++ b/drivers/mtd/nand/raw/nand.c @@ -59,7 +59,7 @@ int nand_register(int devnum, struct mtd_info *mtd) sprintf(dev_name[devnum], "nand%d", devnum); mtd->name = dev_name[devnum];
-#ifdef CONFIG_MTD_DEVICE +#ifdef CONFIG_MTD /* * Add MTD device so that we can reference it later * via the mtdcore infrastructure (e.g. ubi). diff --git a/drivers/mtd/onenand/onenand_uboot.c b/drivers/mtd/onenand/onenand_uboot.c index c15ec9df07..6893394e08 100644 --- a/drivers/mtd/onenand/onenand_uboot.c +++ b/drivers/mtd/onenand/onenand_uboot.c @@ -43,7 +43,7 @@ void onenand_init(void) puts("Flex-"); puts("OneNAND: ");
-#ifdef CONFIG_MTD_DEVICE +#ifdef CONFIG_MTD /* * Add MTD device so that we can reference it later * via the mtdcore infrastructure (e.g. ubi). diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index bc249039c8..3a890ab843 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -56,7 +56,7 @@ * SPI Flash configuration */
-#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */
/* Environment in SPI NOR flash */ diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index 7b55dd14da..a1920caa9d 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -71,7 +71,7 @@ #endif /* CONFIG_ENV_IS_IN_SPI_FLASH */
#ifndef CONFIG_SPL_BUILD -#define CONFIG_MTD_DEVICE +#define CONFIG_MTD #define CONFIG_MTD_PARTITIONS #define MTDIDS_DEFAULT "nor0=ff705000.spi.0" #endif /* CONFIG_SPL_BUILD */ diff --git a/include/configs/x530.h b/include/configs/x530.h index 2269d1ed8c..c7d2aa91ae 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -77,7 +77,6 @@ #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS #define CONFIG_LZO -#define CONFIG_MTD_DEVICE #define CONFIG_CMD_MTDPARTS
#define CONFIG_SYS_MALLOC_LEN (4 << 20)
After re-running the migration: Applied to u-boot/master, thanks!
CONFIG_MTD must be enabled when there is a NOR flash selected.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/3c120_defconfig | 1 + configs/B4420QDS_NAND_defconfig | 1 + configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 2 ++ configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 2 ++ configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/CHIP_pro_defconfig | 1 + configs/M5208EVBE_defconfig | 1 + configs/M52277EVB_defconfig | 1 + configs/M52277EVB_stmicro_defconfig | 1 + configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5249EVB_defconfig | 1 + configs/M5253DEMO_defconfig | 1 + configs/M5272C3_defconfig | 1 + configs/M5275EVB_defconfig | 1 + configs/M5282EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M5329AFEE_defconfig | 1 + configs/M5329BFEE_defconfig | 1 + configs/M5373EVB_defconfig | 1 + configs/M54451EVB_defconfig | 1 + configs/M54451EVB_stmicro_defconfig | 1 + configs/M54455EVB_a66_defconfig | 1 + configs/M54455EVB_defconfig | 1 + configs/M54455EVB_i66_defconfig | 1 + configs/M54455EVB_intel_defconfig | 1 + configs/M54455EVB_stm33_defconfig | 1 + configs/M5475AFE_defconfig | 1 + configs/M5475BFE_defconfig | 1 + configs/M5475CFE_defconfig | 1 + configs/M5475DFE_defconfig | 1 + configs/M5475EFE_defconfig | 1 + configs/M5475FFE_defconfig | 1 + configs/M5475GFE_defconfig | 1 + configs/M5485AFE_defconfig | 1 + configs/M5485BFE_defconfig | 1 + configs/M5485CFE_defconfig | 1 + configs/M5485DFE_defconfig | 1 + configs/M5485EFE_defconfig | 1 + configs/M5485FFE_defconfig | 1 + configs/M5485GFE_defconfig | 1 + configs/M5485HFE_defconfig | 1 + configs/MCR3000_defconfig | 1 + configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8315ERDB_defconfig | 1 + configs/MPC8323ERDB_defconfig | 1 + configs/MPC832XEMDS_ATM_defconfig | 1 + configs/MPC832XEMDS_HOST_33_defconfig | 1 + configs/MPC832XEMDS_HOST_66_defconfig | 1 + configs/MPC832XEMDS_SLAVE_defconfig | 1 + configs/MPC832XEMDS_defconfig | 1 + configs/MPC8349EMDS_PCI64_defconfig | 1 + configs/MPC8349EMDS_SDRAM_defconfig | 1 + configs/MPC8349EMDS_SLAVE_defconfig | 1 + configs/MPC8349EMDS_defconfig | 1 + configs/MPC8349ITXGP_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 1 + configs/MPC8349ITX_defconfig | 1 + configs/MPC837XEMDS_HOST_defconfig | 1 + configs/MPC837XEMDS_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/MigoR_defconfig | 1 + configs/Nintendo_NES_Classic_Edition_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020MBG-PC_36BIT_defconfig | 1 + configs/P1020MBG-PC_SDCARD_defconfig | 1 + configs/P1020MBG-PC_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020UTM-PC_36BIT_defconfig | 1 + configs/P1020UTM-PC_SDCARD_defconfig | 1 + configs/P1020UTM-PC_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1024RDB_36BIT_defconfig | 1 + configs/P1024RDB_NAND_defconfig | 1 + configs/P1024RDB_SDCARD_defconfig | 1 + configs/P1024RDB_SPIFLASH_defconfig | 1 + configs/P1024RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SECURE_BOOT_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SECURE_BOOT_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SECURE_BOOT_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5020DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5020DS_NAND_defconfig | 1 + configs/P5020DS_SDCARD_defconfig | 1 + configs/P5020DS_SECURE_BOOT_defconfig | 1 + configs/P5020DS_SPIFLASH_defconfig | 1 + configs/P5020DS_defconfig | 1 + configs/P5040DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SECURE_BOOT_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SECURE_BOOT_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2081QDS_NAND_defconfig | 1 + configs/T2081QDS_SDCARD_defconfig | 1 + configs/T2081QDS_SPIFLASH_defconfig | 1 + configs/T2081QDS_defconfig | 1 + configs/T4160QDS_NAND_defconfig | 1 + configs/T4160QDS_SDCARD_defconfig | 1 + configs/T4160QDS_SECURE_BOOT_defconfig | 1 + configs/T4160QDS_defconfig | 1 + configs/T4160RDB_defconfig | 1 + configs/T4240QDS_NAND_defconfig | 1 + configs/T4240QDS_SDCARD_defconfig | 1 + configs/T4240QDS_SECURE_BOOT_defconfig | 1 + configs/T4240QDS_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/adp-ae3xx_defconfig | 1 + configs/adp-ag101p_defconfig | 1 + configs/ae350_rv32_defconfig | 1 + configs/am335x_baltos_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am335x_hs_evm_uart_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/amcore_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/astro_mcf5373l_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 1 + configs/at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axm_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/blanche_defconfig | 1 + configs/boston32r2_defconfig | 1 + configs/boston32r2el_defconfig | 1 + configs/boston32r6_defconfig | 1 + configs/boston32r6el_defconfig | 1 + configs/boston64r2_defconfig | 1 + configs/boston64r2el_defconfig | 1 + configs/boston64r6_defconfig | 1 + configs/boston64r6el_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/caddy2_defconfig | 1 + configs/cairo_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/cobra5272_defconfig | 1 + configs/colibri_pxa270_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/comtrend_ct5361_ram_defconfig | 1 + configs/comtrend_wap5813n_ram_defconfig | 1 + configs/corvus_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/draco_defconfig | 1 + configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/edb9315a_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/etamin_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/flea3_defconfig | 1 + configs/gazerbeam_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/huawei_hg556a_ram_defconfig | 1 + configs/ids8313_defconfig | 3 +++ configs/igep00x0_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 1 + configs/integratorcp_cm920t_defconfig | 1 + configs/integratorcp_cm926ejs_defconfig | 1 + configs/integratorcp_cm946es_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + configs/kmcoge5ne_defconfig | 1 + configs/kmtegr1_defconfig | 1 + configs/kzm9g_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 2 ++ configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 2 ++ configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 ++ configs/ls1043ardb_nand_defconfig | 2 ++ configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 2 ++ configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls2080a_simu_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 2 ++ configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/meesc_defconfig | 1 + configs/mpc8308_p1m_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx31pdk_defconfig | 1 + configs/mx35pdk_defconfig | 1 + configs/mx53ard_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sxsabreauto_defconfig | 1 + configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/qemu_mips64_defconfig | 1 + configs/qemu_mips64el_defconfig | 1 + configs/qemu_mips_defconfig | 1 + configs/qemu_mipsel_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r7780mp_defconfig | 1 + configs/r8a77995_draak_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/sama5d2_ptc_ek_mmc_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sbc8349_PCI_33_defconfig | 1 + configs/sbc8349_PCI_66_defconfig | 1 + configs/sbc8349_defconfig | 1 + configs/sbc8548_PCI_33_PCIE_defconfig | 1 + configs/sbc8548_PCI_33_defconfig | 1 + configs/sbc8548_PCI_66_PCIE_defconfig | 1 + configs/sbc8548_PCI_66_defconfig | 1 + configs/sbc8548_defconfig | 1 + configs/sbc8641d_defconfig | 1 + configs/sfr_nb4-ser_ram_defconfig | 1 + configs/sh7763rdp_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/socrates_defconfig | 1 + configs/stm32f429-discovery_defconfig | 1 + configs/stm32f429-evaluation_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/taurus_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/titanium_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 1 + configs/vct_platinum_defconfig | 1 + configs/vct_platinum_small_defconfig | 1 + configs/vct_platinumavc_defconfig | 1 + configs/vct_platinumavc_small_defconfig | 1 + configs/vct_premium_defconfig | 1 + configs/vct_premium_small_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/vme8349_defconfig | 1 + configs/wb45n_defconfig | 1 + configs/wb50n_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/woodburn_sd_defconfig | 2 +- configs/x600_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + configs/xpedite517x_defconfig | 1 + configs/xpedite520x_defconfig | 1 + configs/xpedite537x_defconfig | 1 + configs/xpedite550x_defconfig | 1 + configs/xtfpga_defconfig | 1 + configs/zmx25_defconfig | 1 + configs/zynq_cse_nor_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + 571 files changed, 585 insertions(+), 1 deletion(-)
diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index a6f369603a..369f6f041b 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -23,6 +23,7 @@ CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y CONFIG_MISC=y CONFIG_ALTERA_SYSID=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index 1a1acc0a6f..2827a81842 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 8959910e11..2de06f49f1 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index c94444f42c..401345fc11 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index f9299b2b00..5a04ae45e6 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index 3eb310716c..8f980e16ac 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -25,6 +25,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_DM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index b11b071e35..482390a492 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index 2df7196ef3..8e5c0b6264 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index b6e5a74ce7..54659bd46b 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -34,6 +34,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:1m(uboot),8m(kernel),512k(dtb), CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index bc4c9d55b6..0e4b5da3ca 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -33,6 +33,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:1m(uboot),8m(kernel),512k(dtb), CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index af1bc88b3a..a31823c447 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -29,6 +29,8 @@ CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index b4fa77c81f..ac16113e08 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -36,6 +36,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(u CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index abc0886de3..6c2b4078ce 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -29,6 +29,8 @@ CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index f58285b12c..e6cf0726c0 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -36,6 +36,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(u CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index 81c3b3b73e..2602f590ac 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index a16838c49a..0e339f144d 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(u CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index dca12608aa..553d0050ce 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index e56be3fda0..5112fd9ac2 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(u CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index 1e5c7627dc..d28362f285 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index f55cb6127c..faac56925d 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(u CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index 1203bdb46d..59e0b92b2f 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index 407c2e6d43..3ad98b1082 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(u CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index a0e9cd8d1f..4896f5b08e 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index 309159e180..ea893898b2 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(u CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index f086438cd2..b32a57fdee 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index 1af0223d67..7c250fb18c 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(u CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index a3ff33ba15..4549fce2cb 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -37,6 +37,7 @@ CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index a256315c68..0fa7abfc7a 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y CONFIG_DM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index 8629f8aa42..ee9a5a66a9 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y CONFIG_DM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index 031ab2c6b9..ca889b7668 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -22,6 +22,7 @@ CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index ac525e8e92..5091dbf3e7 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -21,6 +21,7 @@ CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 91d032633e..524c56ed4b 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -16,6 +16,7 @@ CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot-env" # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 9b5d35cd55..6952772cc5 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5208EVBE" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M52277EVB_defconfig b/configs/M52277EVB_defconfig index 55f6fb9c90..5f9793c4af 100644 --- a/configs/M52277EVB_defconfig +++ b/configs/M52277EVB_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_JFFS2=y CONFIG_DEFAULT_DEVICE_TREE="M52277EVB" CONFIG_ENV_IS_IN_FLASH=y # CONFIG_NET is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M52277EVB_stmicro_defconfig b/configs/M52277EVB_stmicro_defconfig index ee0dced2fd..cacf029bab 100644 --- a/configs/M52277EVB_stmicro_defconfig +++ b/configs/M52277EVB_stmicro_defconfig @@ -19,6 +19,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_CS=y CONFIG_ENV_SPI_CS=2 # CONFIG_NET is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index 2e40b21d76..5b7b295223 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5235EVB_Flash32" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index fd5dd984be..a2a53927e0 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5235EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index b93f1271d4..fbc5efbb7d 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -12,6 +12,7 @@ CONFIG_MX_CYCLIC=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5249EVB" # CONFIG_NET is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index 0775ad5a82..567d4873de 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -14,4 +14,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_MAC_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M5253DEMO" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index c39876d89c..aabfa20478 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5272C3" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M5275EVB_defconfig b/configs/M5275EVB_defconfig index ecb3e32070..ec6739bf33 100644 --- a/configs/M5275EVB_defconfig +++ b/configs/M5275EVB_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5275EVB" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index 731fb1ec68..8df7ab453e 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5282EVB" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index 92dfd0256d..df7ac2e0e4 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M53017EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index 20acb64b1a..b3a77536f5 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M5329AFEE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index 96c57ec9db..be4ea4a9ed 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M5329BFEE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index ef66d7ca00..7c2b2a92fe 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M5373EVB" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/M54451EVB_defconfig b/configs/M54451EVB_defconfig index f0bd93f2d9..16f56cf85b 100644 --- a/configs/M54451EVB_defconfig +++ b/configs/M54451EVB_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_DEFAULT_DEVICE_TREE="M54451EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54451EVB_stmicro_defconfig b/configs/M54451EVB_stmicro_defconfig index 144d29b902..5780f6c96d 100644 --- a/configs/M54451EVB_stmicro_defconfig +++ b/configs/M54451EVB_stmicro_defconfig @@ -23,6 +23,7 @@ CONFIG_DEFAULT_DEVICE_TREE="M54451EVB_stmicro" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_CS=y CONFIG_ENV_SPI_CS=1 +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_a66_defconfig b/configs/M54455EVB_a66_defconfig index ca403083f7..544eb18062 100644 --- a/configs/M54455EVB_a66_defconfig +++ b/configs/M54455EVB_a66_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M54455EVB_a66" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_defconfig b/configs/M54455EVB_defconfig index 3ca2d73797..4878607e6c 100644 --- a/configs/M54455EVB_defconfig +++ b/configs/M54455EVB_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M54455EVB" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_i66_defconfig b/configs/M54455EVB_i66_defconfig index 20abcd80ab..6a0f11db4e 100644 --- a/configs/M54455EVB_i66_defconfig +++ b/configs/M54455EVB_i66_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M54455EVB_i66" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_intel_defconfig b/configs/M54455EVB_intel_defconfig index a17e4fab25..201efad5ed 100644 --- a/configs/M54455EVB_intel_defconfig +++ b/configs/M54455EVB_intel_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="M54455EVB_intel" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_stm33_defconfig b/configs/M54455EVB_stm33_defconfig index c3f04645bf..9723e104ff 100644 --- a/configs/M54455EVB_stm33_defconfig +++ b/configs/M54455EVB_stm33_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="M54455EVB_stm33" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_CS=y CONFIG_ENV_SPI_CS=1 +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475AFE_defconfig b/configs/M5475AFE_defconfig index 368f73e9dd..adaf1ac888 100644 --- a/configs/M5475AFE_defconfig +++ b/configs/M5475AFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475AFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475BFE_defconfig b/configs/M5475BFE_defconfig index d44b0b267f..bbfa2307d5 100644 --- a/configs/M5475BFE_defconfig +++ b/configs/M5475BFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475BFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475CFE_defconfig b/configs/M5475CFE_defconfig index 108ef978a6..3857ede5ec 100644 --- a/configs/M5475CFE_defconfig +++ b/configs/M5475CFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475CFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475DFE_defconfig b/configs/M5475DFE_defconfig index 9325db5ba6..64a2948033 100644 --- a/configs/M5475DFE_defconfig +++ b/configs/M5475DFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475DFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475EFE_defconfig b/configs/M5475EFE_defconfig index 6873f1500c..43b993c8cd 100644 --- a/configs/M5475EFE_defconfig +++ b/configs/M5475EFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475EFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475FFE_defconfig b/configs/M5475FFE_defconfig index a98e804c41..7dc50089e1 100644 --- a/configs/M5475FFE_defconfig +++ b/configs/M5475FFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475FFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5475GFE_defconfig b/configs/M5475GFE_defconfig index ed75743801..541a938c4a 100644 --- a/configs/M5475GFE_defconfig +++ b/configs/M5475GFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5475GFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485AFE_defconfig b/configs/M5485AFE_defconfig index 8f94ac99a1..2b6a6a14ca 100644 --- a/configs/M5485AFE_defconfig +++ b/configs/M5485AFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485AFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485BFE_defconfig b/configs/M5485BFE_defconfig index 96bd5200da..7474df4880 100644 --- a/configs/M5485BFE_defconfig +++ b/configs/M5485BFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485BFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485CFE_defconfig b/configs/M5485CFE_defconfig index 148be33d5a..bf4d9f48e5 100644 --- a/configs/M5485CFE_defconfig +++ b/configs/M5485CFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485CFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485DFE_defconfig b/configs/M5485DFE_defconfig index 5facb0733d..fc2d46e891 100644 --- a/configs/M5485DFE_defconfig +++ b/configs/M5485DFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485DFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485EFE_defconfig b/configs/M5485EFE_defconfig index ece3e115ea..a1bd43388d 100644 --- a/configs/M5485EFE_defconfig +++ b/configs/M5485EFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485EFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485FFE_defconfig b/configs/M5485FFE_defconfig index c2a2d926d6..08ad781ffc 100644 --- a/configs/M5485FFE_defconfig +++ b/configs/M5485FFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485FFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485GFE_defconfig b/configs/M5485GFE_defconfig index 9cf620242a..8ea15cd23e 100644 --- a/configs/M5485GFE_defconfig +++ b/configs/M5485GFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485GFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M5485HFE_defconfig b/configs/M5485HFE_defconfig index e6c9225ea9..01b6871ba4 100644 --- a/configs/M5485HFE_defconfig +++ b/configs/M5485HFE_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M5485HFE" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MCR3000_defconfig b/configs/MCR3000_defconfig index 8678616f10..bfe364ea57 100644 --- a/configs/MCR3000_defconfig +++ b/configs/MCR3000_defconfig @@ -69,6 +69,7 @@ CONFIG_DEFAULT_DEVICE_TREE="mcr3000" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8308RDB_defconfig b/configs/MPC8308RDB_defconfig index 5faf20f163..e313370992 100644 --- a/configs/MPC8308RDB_defconfig +++ b/configs/MPC8308RDB_defconfig @@ -127,6 +127,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC8313ERDB_33_defconfig b/configs/MPC8313ERDB_33_defconfig index 9b58860e08..01de720b46 100644 --- a/configs/MPC8313ERDB_33_defconfig +++ b/configs/MPC8313ERDB_33_defconfig @@ -144,6 +144,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=e2800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC8313ERDB_66_defconfig b/configs/MPC8313ERDB_66_defconfig index 98fcda1de2..d4ed63424a 100644 --- a/configs/MPC8313ERDB_66_defconfig +++ b/configs/MPC8313ERDB_66_defconfig @@ -143,6 +143,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=e2800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index f1d6efde83..8c5bf552f1 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -151,6 +151,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(ker # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index 3889b0783a..9a01d42fa8 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -150,6 +150,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(ker # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC8315ERDB_defconfig b/configs/MPC8315ERDB_defconfig index 2a550bc98b..1b1619be84 100644 --- a/configs/MPC8315ERDB_defconfig +++ b/configs/MPC8315ERDB_defconfig @@ -129,6 +129,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=e0600000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e0600000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" CONFIG_FSL_SATA=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC8323ERDB_defconfig b/configs/MPC8323ERDB_defconfig index 349d611086..df8ad0f1e4 100644 --- a/configs/MPC8323ERDB_defconfig +++ b/configs/MPC8323ERDB_defconfig @@ -102,6 +102,7 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC832XEMDS_ATM_defconfig b/configs/MPC832XEMDS_ATM_defconfig index 3eda9a4deb..0b28b5f50d 100644 --- a/configs/MPC832XEMDS_ATM_defconfig +++ b/configs/MPC832XEMDS_ATM_defconfig @@ -127,6 +127,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC832XEMDS_HOST_33_defconfig b/configs/MPC832XEMDS_HOST_33_defconfig index ede3b8a0e4..7dc6114ab8 100644 --- a/configs/MPC832XEMDS_HOST_33_defconfig +++ b/configs/MPC832XEMDS_HOST_33_defconfig @@ -148,6 +148,7 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC832XEMDS_HOST_66_defconfig b/configs/MPC832XEMDS_HOST_66_defconfig index 370a9141c9..45f069c529 100644 --- a/configs/MPC832XEMDS_HOST_66_defconfig +++ b/configs/MPC832XEMDS_HOST_66_defconfig @@ -148,6 +148,7 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC832XEMDS_SLAVE_defconfig b/configs/MPC832XEMDS_SLAVE_defconfig index 5b1c8f89b6..251554ad9e 100644 --- a/configs/MPC832XEMDS_SLAVE_defconfig +++ b/configs/MPC832XEMDS_SLAVE_defconfig @@ -145,6 +145,7 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC832XEMDS_defconfig b/configs/MPC832XEMDS_defconfig index 34fbe53f72..a9b196def0 100644 --- a/configs/MPC832XEMDS_defconfig +++ b/configs/MPC832XEMDS_defconfig @@ -126,6 +126,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC8349EMDS_PCI64_defconfig b/configs/MPC8349EMDS_PCI64_defconfig index 00dc72d81c..398bab9221 100644 --- a/configs/MPC8349EMDS_PCI64_defconfig +++ b/configs/MPC8349EMDS_PCI64_defconfig @@ -94,6 +94,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC8349EMDS_SDRAM_defconfig b/configs/MPC8349EMDS_SDRAM_defconfig index ee2de0ad68..51d6367711 100644 --- a/configs/MPC8349EMDS_SDRAM_defconfig +++ b/configs/MPC8349EMDS_SDRAM_defconfig @@ -103,6 +103,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC8349EMDS_SLAVE_defconfig b/configs/MPC8349EMDS_SLAVE_defconfig index 7550aa30c7..f382db479a 100644 --- a/configs/MPC8349EMDS_SLAVE_defconfig +++ b/configs/MPC8349EMDS_SLAVE_defconfig @@ -94,6 +94,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index ba00a275cd..579b6abc95 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -95,6 +95,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index b4cf8c33d0..824b579443 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -165,6 +165,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index fbfeda57cf..06f0e45647 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -170,6 +170,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_SATA_SIL3114=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index e9a8bb1836..6f7d950c21 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -169,6 +169,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_SATA_SIL3114=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC837XEMDS_HOST_defconfig b/configs/MPC837XEMDS_HOST_defconfig index 7b69f5b44f..0afc35ea84 100644 --- a/configs/MPC837XEMDS_HOST_defconfig +++ b/configs/MPC837XEMDS_HOST_defconfig @@ -162,6 +162,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC837XEMDS_defconfig b/configs/MPC837XEMDS_defconfig index 47125e27bc..0c908e3328 100644 --- a/configs/MPC837XEMDS_defconfig +++ b/configs/MPC837XEMDS_defconfig @@ -140,6 +140,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index 738e75ac36..a1a9c8e709 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -160,6 +160,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_FSL_SATA=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index 428586a486..72bd9075bb 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_FSL_DDR2=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index 1a02f26ff6..7c32f5d155 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_FSL_DDR2=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index 155f227efc..ddea575560 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_FSL_DDR2=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 01863a443c..4815517824 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_FSL_DDR2=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index 3307dbbb48..b08253b0fe 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index bef89171ea..ad46749e5c 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index a77f8f14cd..3bebf8ff81 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SCSI_AHCI=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 1c37624978..a6c93f59a5 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -21,6 +21,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="mpc8548cds_36b" CONFIG_DM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index ef82aa8c2b..00f6a9c5ee 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -20,6 +20,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="mpc8548cds" CONFIG_DM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index e36fcf8435..3e20a227bf 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -20,6 +20,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="mpc8548cds" CONFIG_DM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index f5fcd81f11..83a4a6453f 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index 7887bccb64..39748dfe6a 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index 190b0b89df..00d0d1ec10 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8569MDS_ATM_defconfig b/configs/MPC8569MDS_ATM_defconfig index 08e17bf5f2..45b18a6896 100644 --- a/configs/MPC8569MDS_ATM_defconfig +++ b/configs/MPC8569MDS_ATM_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8569MDS_defconfig b/configs/MPC8569MDS_defconfig index f1b4a7befd..1d17ad3641 100644 --- a/configs/MPC8569MDS_defconfig +++ b/configs/MPC8569MDS_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index 3f02171737..359d649865 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_SCSI_AHCI=y CONFIG_SYS_FSL_DDR2=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index acb4af4b3d..fc9096f633 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT2=y CONFIG_SCSI_AHCI=y CONFIG_SYS_FSL_DDR2=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 80ea441aa3..4aa2a3cd4f 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SCSI_AHCI=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 81901f7a28..ce20dd2559 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SCSI_AHCI=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index 497d398c83..0046d41c42 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_SCSI_AHCI=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/MigoR_defconfig b/configs/MigoR_defconfig index b261a92e03..754fc55513 100644 --- a/configs/MigoR_defconfig +++ b/configs/MigoR_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_SDRAM=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index 26b0da8ded..5a663e2689 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_MTDPARTS=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-nintendo-nes-classic-edition" # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index 51b648806d..d5fbb1d82b 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -29,6 +29,8 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index da9c6313e8..0f78251ea9 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -45,6 +45,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index b14e7deaf6..c7f697f9d5 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 10a2eff357..b255399d7a 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -27,6 +27,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 73c22efef5..7902648dd3 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index b24f704aad..c223b2786d 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index d5a2ffac3b..23593fc2bc 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -41,6 +41,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index 036f8e8a44..e4f9b88ed4 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -28,6 +28,8 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 2390fdc33c..88a574ea2d 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -44,6 +44,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index 349fc95ee1..9fa82d4d3d 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -27,6 +27,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 47c5cca91c..8f92d38b4a 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -26,6 +26,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index 628f9008bd..58d92174e6 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -39,6 +39,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index 0fa105ce70..1a4f48980d 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index f14051b748..7581f71cd2 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index dcc7d11d51..23dd730d35 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -29,6 +29,8 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 67295ec2e3..bc3f0f5fb6 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -45,6 +45,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index 6ed4467323..016ee97fc5 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 9ea5d83e92..60baa3fd03 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -27,6 +27,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index e73cc4c9d7..17bca5b946 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index 6f43d694ea..41b55af660 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 754355b43f..71503de0f2 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -41,6 +41,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index 8e76629ad5..7a3f5d45c7 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -28,6 +28,8 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index b53d5ecbb9..cbb849f83d 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -44,6 +44,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index cc2a04f710..f0f24767ac 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -27,6 +27,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 4178800a3a..d1c0b47301 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -26,6 +26,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index afdb173a0e..8e21c3607b 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -39,6 +39,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index 78aef8395a..c82f9ae1fe 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 1e0a28b731..3924e77b70 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index 9ddcb432d4..2b91d2e004 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020MBG-PC_36BIT_defconfig b/configs/P1020MBG-PC_36BIT_defconfig index 63cc1b6b77..490b9ec39c 100644 --- a/configs/P1020MBG-PC_36BIT_defconfig +++ b/configs/P1020MBG-PC_36BIT_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index df5fa9916a..841e14c538 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020MBG-PC_defconfig b/configs/P1020MBG-PC_defconfig index f0a479aca8..436aa33d7a 100644 --- a/configs/P1020MBG-PC_defconfig +++ b/configs/P1020MBG-PC_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index d45a986b20..0ed849855b 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -47,6 +47,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc_36b" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 883c4d97f0..8c183dedd4 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -43,6 +43,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc_36b" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 4ec953a5b5..6c75e7b160 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -44,6 +44,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc_36b" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 9ce12c5647..03d2422968 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -32,6 +32,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc_36b" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index aceb7aad81..6d72b6deb4 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -46,6 +46,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index e7407aa3ea..ba87fb89fb 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -42,6 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 99457cbcd5..dccfc53f32 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -43,6 +43,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 9158fefdfd..9b8fe30a12 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -31,6 +31,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 8c8108cbd8..eb1b87b06d 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -49,6 +49,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pd" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index a07c46d7f0..7c5fc7184d 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pd" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 591c4ebf18..7ed5340fa1 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -46,6 +46,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pd" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index a29f811450..b65d6740fd 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -34,6 +34,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pd" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index c0ce9ed9c0..5d9c16679f 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020UTM-PC_36BIT_defconfig b/configs/P1020UTM-PC_36BIT_defconfig index 4fe2a9228a..a807dc03ca 100644 --- a/configs/P1020UTM-PC_36BIT_defconfig +++ b/configs/P1020UTM-PC_36BIT_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index 537e7b60ff..baddb99b23 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1020UTM-PC_defconfig b/configs/P1020UTM-PC_defconfig index dbe1879d88..844f5b5055 100644 --- a/configs/P1020UTM-PC_defconfig +++ b/configs/P1020UTM-PC_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index 7cbdaed04d..f694c48cf8 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -48,6 +48,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index 18f326cadd..6162e0aada 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -44,6 +44,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index 6f5ff78ee7..03a1485b7e 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -45,6 +45,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index 273435a6b4..391db52f35 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -32,6 +32,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index 18a5018782..333366e802 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -47,6 +47,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=ef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index c7f4306a37..d4aa9d5e89 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -43,6 +43,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=ef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 28326388ec..f8f1448834 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -44,6 +44,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=ef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index 9671af1d86..628ceebb62 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=ef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index 7c1db02a49..2bfb96db7b 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -46,6 +46,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 9d45489fe0..e3bf3728d4 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -42,6 +42,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index 2eea528ec5..c4ce1041a8 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -43,6 +43,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index 44c950ed13..f85c58d752 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -30,6 +30,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index a4218a85af..3393b212c5 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -45,6 +45,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=e8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=e8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index daee4dda1f..5b6a979385 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -41,6 +41,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=e8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=e8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index ce522f5cf8..5f63aeab59 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -42,6 +42,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=e8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=e8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index 42c47f732a..fde6232662 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -29,6 +29,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=e8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=e8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index ee2aee4a32..ff9bdbca70 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/P1024RDB_36BIT_defconfig b/configs/P1024RDB_36BIT_defconfig index 577d9e863a..5d32c19c50 100644 --- a/configs/P1024RDB_36BIT_defconfig +++ b/configs/P1024RDB_36BIT_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index 35dcc44d89..641ca6d269 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index 5f0c4b2763..dde51f0a3b 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index fe052b2d06..4b086e1d4f 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1024RDB_defconfig b/configs/P1024RDB_defconfig index 694a2e9eac..e7537f02e0 100644 --- a/configs/P1024RDB_defconfig +++ b/configs/P1024RDB_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index e2407e3ae8..324ea7d5cb 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index fc7cfdf239..4b96ed19a6 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 35fc471500..0de815eede 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index f05d73e90c..c51860ccc9 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index a22f1a10da..f4e8a7c8ba 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index abdeffa487..a47cf0fe21 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -51,6 +51,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc_36b" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 96ea15fbed..a34fa0b51f 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -47,6 +47,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc_36b" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index d0103b25ef..f7f1d845c8 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -48,6 +48,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc_36b" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index c99c25f835..068c4d9428 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -36,6 +36,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc_36b" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index f1f4ea2dd0..f7edc70334 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -50,6 +50,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 7c43b95535..95ac8ce83f 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -46,6 +46,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index cddef3e991..90e934ad67 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -47,6 +47,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index a0a69ca22f..2ea5aca9c1 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -35,6 +35,7 @@ CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 7ce51fa1fb..0ba5ce4447 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 4d64d089ca..9838ba4f77 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2041RDB_SECURE_BOOT_defconfig b/configs/P2041RDB_SECURE_BOOT_defconfig index 91514e1641..3b49730166 100644 --- a/configs/P2041RDB_SECURE_BOOT_defconfig +++ b/configs/P2041RDB_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index ec22c95925..2d5be8e04b 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index e757330510..458287bfde 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index d715a2ce46..d3f11ff23a 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 0dd7d336c0..7834f20175 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 4d76efd5d7..6cc703b2f7 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P3041DS_SECURE_BOOT_defconfig b/configs/P3041DS_SECURE_BOOT_defconfig index 483e393246..069a9ba67b 100644 --- a/configs/P3041DS_SECURE_BOOT_defconfig +++ b/configs/P3041DS_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 8b5e13d67e..59fe000e0a 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 96297df0df..a5626c3bae 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index b412e4f3da..a2a200a0b4 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P4080DS_SECURE_BOOT_defconfig b/configs/P4080DS_SECURE_BOOT_defconfig index e6b1207d0e..6e202bf699 100644 --- a/configs/P4080DS_SECURE_BOOT_defconfig +++ b/configs/P4080DS_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index e5e0eb255a..a53abb041c 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index a9a90e4998..0fa7f450f4 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index 11ea810912..b18421e78b 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index f9960e06dc..93f163196a 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5020DS_SDCARD_defconfig b/configs/P5020DS_SDCARD_defconfig index c319a84af6..3d6615c87c 100644 --- a/configs/P5020DS_SDCARD_defconfig +++ b/configs/P5020DS_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5020DS_SECURE_BOOT_defconfig b/configs/P5020DS_SECURE_BOOT_defconfig index 85fa7bdfbf..5af500a722 100644 --- a/configs/P5020DS_SECURE_BOOT_defconfig +++ b/configs/P5020DS_SECURE_BOOT_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5020DS_SPIFLASH_defconfig b/configs/P5020DS_SPIFLASH_defconfig index 5ae3097307..9523c1bc06 100644 --- a/configs/P5020DS_SPIFLASH_defconfig +++ b/configs/P5020DS_SPIFLASH_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5020DS_defconfig b/configs/P5020DS_defconfig index df43d13f7c..6344100e84 100644 --- a/configs/P5020DS_defconfig +++ b/configs/P5020DS_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index 5ace78159b..0bf2096b1b 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 9567a6011d..27b81b624a 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index 719c8b4859..307731d1f6 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -31,6 +31,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5040DS_SECURE_BOOT_defconfig b/configs/P5040DS_SECURE_BOOT_defconfig index 22b4d4ebda..f91c147d66 100644 --- a/configs/P5040DS_SECURE_BOOT_defconfig +++ b/configs/P5040DS_SECURE_BOOT_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 3912dc93ab..d8f4d6f946 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -31,6 +31,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index f922521e7f..0eb9beb3d8 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 89f1d16dd2..c02a04d671 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -47,6 +47,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index 8f1caae066..a0b4dc7aac 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -45,6 +45,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index 886aba79df..8a193f8fc2 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -32,6 +32,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000 CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:1m(uboot),5m(kernel),128k(dtb),-(user)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index 49df3528b9..2e1643dfce 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -46,6 +46,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index cadc16a2b0..a9b1e5ba90 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 423d64265c..4e59695f35 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000 CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index 6a61ddff88..a703f292cc 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -32,6 +32,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index ba0f62c97f..135e85daed 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -49,6 +49,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index df896b3b56..3addc04de2 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -47,6 +47,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index 9d6bc98611..64c8fd7665 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -34,6 +34,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 1a0915b90d..c5d74fdd74 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index af0eb46f84..474726bdfb 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -33,6 +33,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 294d87a23c..18f54bf57a 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -52,6 +52,7 @@ CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 43817bedf2..dd09bfcf10 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -50,6 +50,7 @@ CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index cb751dfc71..a24e77e9e9 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -34,6 +34,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 9ffd5d6230..dda01ece17 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -51,6 +51,7 @@ CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 08a6225444..049e5b9a55 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -37,6 +37,7 @@ CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index db4469a7ea..454bc8665c 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -46,6 +46,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index edbedf841b..e8af5021a7 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -44,6 +44,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index 7391eff2a3..f6cfdb3e3b 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000 CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 1f08ee8e80..e542d43bc1 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -45,6 +45,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index 8d7427d310..3fa8a13d7c 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -30,6 +30,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 9aa552379f..b7ba880b69 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -33,6 +33,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index 9cd30e5704..f888681106 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -35,6 +35,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 5901ca51f1..706dd92fce 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -34,6 +34,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 2e1cc50edc..cf5c9d7beb 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -47,6 +47,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index 369b08d4ef..10d324d8c7 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -45,6 +45,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index 5f482c3f60..0b2efaa007 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -32,6 +32,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index a19d506c60..8b49c7df66 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -46,6 +46,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 9ef146bed0..b3b934472c 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -31,6 +31,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 8ad75d0606..1b3e76625a 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -50,6 +50,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 04372fd26a..79607f2b6f 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index d52521c96c..5db55bada8 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -32,6 +32,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000 CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:2m(uboot),9m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:2m(uboot),9m(kernel),128k(dtb),-(user)" CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 2c869cdbd0..b1992bf262 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -49,6 +49,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 5d8a25f2b5..e7eec2b89c 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -35,6 +35,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index c4c50d085e..1457aefaa3 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -52,6 +52,7 @@ CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index cc70ffa247..9e0228dad5 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -49,6 +49,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index ad145b65d4..3105f5fdad 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -47,6 +47,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 120fc14d1f..6ee035222c 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 7aeac60203..319dd840b3 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -33,6 +33,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index a255e085b9..af5d310022 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index 6378c95efc..36eaca6510 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 06cb9ad080..7acadad716 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -49,6 +49,7 @@ CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 786f154e71..ee07c063d1 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -47,6 +47,7 @@ CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index dea8479253..414b1b6b39 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -34,6 +34,7 @@ CONFIG_DM=y CONFIG_FSL_AHCI=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 066a83b727..e9ae51741b 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -48,6 +48,7 @@ CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index e22542fd8c..760fe7c8f6 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -34,6 +34,7 @@ CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 8c40a58c4b..e2b99049c3 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 247cc314b0..a2c5cdace1 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -46,6 +46,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080RDB_SECURE_BOOT_defconfig b/configs/T2080RDB_SECURE_BOOT_defconfig index 120bfccade..edebecc822 100644 --- a/configs/T2080RDB_SECURE_BOOT_defconfig +++ b/configs/T2080RDB_SECURE_BOOT_defconfig @@ -30,6 +30,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 # CONFIG_CMD_IRQ is not set CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 1370e16d68..89daaee090 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -47,6 +47,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index bc4a02663f..c905c83c40 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -33,6 +33,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index 1f874041af..40f6021acc 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -43,6 +43,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index 7d4c147b95..c80c018775 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -41,6 +41,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index eb752cd99c..504c032760 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -42,6 +42,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T2081QDS_defconfig b/configs/T2081QDS_defconfig index 306d8b79d8..b6912c3034 100644 --- a/configs/T2081QDS_defconfig +++ b/configs/T2081QDS_defconfig @@ -27,6 +27,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index edea4fa972..e5a5c71ef5 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index f04c34dc5e..c22d3ab1a0 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4160QDS_SECURE_BOOT_defconfig b/configs/T4160QDS_SECURE_BOOT_defconfig index fafcdd52cc..0ce1a247a7 100644 --- a/configs/T4160QDS_SECURE_BOOT_defconfig +++ b/configs/T4160QDS_SECURE_BOOT_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4160QDS_defconfig b/configs/T4160QDS_defconfig index 50970fc795..0ca31bfd7c 100644 --- a/configs/T4160QDS_defconfig +++ b/configs/T4160QDS_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index 077961de62..6ca719863c 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index f0e414e671..951eccd5e2 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index 579d4f42b6..85e86f1145 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4240QDS_SECURE_BOOT_defconfig b/configs/T4240QDS_SECURE_BOOT_defconfig index 55a7f19dd5..368d6eabbc 100644 --- a/configs/T4240QDS_SECURE_BOOT_defconfig +++ b/configs/T4240QDS_SECURE_BOOT_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4240QDS_defconfig b/configs/T4240QDS_defconfig index c9f541c0ef..d028101040 100644 --- a/configs/T4240QDS_defconfig +++ b/configs/T4240QDS_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index df308d4fbc..9e25ce2c6e 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -41,6 +41,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 9cf2c6afa6..95f6051079 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 128f10fa5d..674888fc25 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y # CONFIG_SATA_SIL is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index 322fc8da84..66885fe80f 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ae3xx" +CONFIG_MTD=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index c91f13d0ee..13d67569c0 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -24,6 +24,7 @@ CONFIG_MMC=y CONFIG_DM_MMC=y CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index a31027016b..f3fd8363d9 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -21,6 +21,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 5776483f25..c9524cab73 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_OMAP24_I2C_SPEED=1000 CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP_HS_ADMA=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x00080000 diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 5917619fb3..f3b1e9693e 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -46,6 +46,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 155534b672..89625cda54 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -42,6 +42,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 4d9760e2a5..26dcf3b149 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -44,6 +44,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index f1058073d0..f8d8eb640c 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -62,6 +62,7 @@ CONFIG_ENV_UBI_VOLUME_REDUND="config_r" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MII=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 2a98b43ae0..702bee2a29 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 44bc4d6aab..6dd04a4c17 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -49,6 +49,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_PCA953X=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 961535deb6..57712379c8 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_DM_GPIO=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 7d106edff5..1721b1a27e 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -36,6 +36,7 @@ CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index de576a842e..a08ed37d1d 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -49,6 +49,7 @@ CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index e5e4161d38..52ce3a50bd 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -46,6 +46,7 @@ CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/amcore_defconfig b/configs/amcore_defconfig index d68d5223c1..2dc17db4f8 100644 --- a/configs/amcore_defconfig +++ b/configs/amcore_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DIAG=y CONFIG_DEFAULT_DEVICE_TREE="amcore" CONFIG_ENV_IS_IN_FLASH=y # CONFIG_NET is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index cbd5eb0eda..be8ef7d2dd 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -43,6 +43,7 @@ CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y CONFIG_MXC_GPIO=y CONFIG_MMC_MXC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 26562b9621..28b507e23f 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 22dec52167..9213915390 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 72c91288a4..eda3baea0e 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 3e4d76446c..39b0c38412 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index 126b50c9b6..da7d42fa60 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -22,6 +22,7 @@ CONFIG_FPGA_ALTERA=y CONFIG_FPGA_CYCLON2=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 834457cb99..4999fcedb2 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 93171912bc..d8ca94f870 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index cbf5498ad5..a3a7943582 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 5489546946..0ccf829c63 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 9be766a03e..b19e055712 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -36,6 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index ca3a7b3980..2b6ddd2d59 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 401fbf2b68..10dcc30de0 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 59d6c5f4f8..984ab6dfd1 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -36,6 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 7877484480..80292facf9 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 7877484480..80292facf9 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 1c57e7b199..518d95a7f3 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -41,6 +41,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index e9ad03c64b..a1b2d28657 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 8b3a754363..201b9fc49b 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index e0d40f01eb..9d835ecf68 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index af0f59aa63..dd64ab6502 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 77c0c7dedb..8e1ef861b7 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -36,6 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index ef00828b09..b9ecae2a05 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 51928a2c82..bdb1a4223a 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -38,6 +38,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 854dc34390..4e8d1f61fc 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index b2ff294024..b585896eb3 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index b98d05a744..0e6fb94dc1 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -36,6 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 948c10e03c..06c7650ce7 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index b9ed419cfc..6dd27a9f97 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 0365bbced4..98c3ac8b3a 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 3be0e8547f..813c759a88 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 26cff3526d..ee79ba0007 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 2890f4781c..bd0806bbd3 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -39,6 +39,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 892772a262..ebb3885e91 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 57b10d83fc..a225cf291a 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 39020cb667..8f53244e6f 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index ce56029131..7f54271ef0 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 67d33bc647..9825ffc072 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -41,6 +41,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 09589e19d4..4a694d6431 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -36,6 +36,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index d3b30b7ec6..bc7ec37361 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -57,6 +57,7 @@ CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_CLK=y CONFIG_CLK_AT91=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 5dc6fa036a..9d98402992 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -25,6 +25,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index cdfcc5c636..fae085e14d 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_CACHE=y CONFIG_DOS_PARTITION=y CONFIG_MXS_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index 58ee355db4..efb700dda5 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -45,6 +45,7 @@ CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_SH_MMCIF=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 7023dbe5c9..dd0a306795 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -27,6 +27,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 44b4f9be78..ac9e47d254 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/boston32r6_defconfig b/configs/boston32r6_defconfig index 6a48a8b7dc..3ddd4b46b0 100644 --- a/configs/boston32r6_defconfig +++ b/configs/boston32r6_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/boston32r6el_defconfig b/configs/boston32r6el_defconfig index f6cc9f2551..454f1f3d60 100644 --- a/configs/boston32r6el_defconfig +++ b/configs/boston32r6el_defconfig @@ -29,6 +29,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index bcea44b03e..bc59130784 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index 0383c0932b..8f3d398c8a 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -29,6 +29,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/boston64r6_defconfig b/configs/boston64r6_defconfig index 55bf9906d9..8bde71ddbc 100644 --- a/configs/boston64r6_defconfig +++ b/configs/boston64r6_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/boston64r6el_defconfig b/configs/boston64r6el_defconfig index 8ebc293acc..c9d8c46ccd 100644 --- a/configs/boston64r6el_defconfig +++ b/configs/boston64r6el_defconfig @@ -29,6 +29,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 1de0f0585b..5a8456c7a6 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -79,6 +79,7 @@ CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_MISC=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index 51c37e2e1a..8d590ad7ea 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -107,6 +107,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index a5a2eb90b0..b5387f5b9e 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=2 diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index bb1d796f9b..c6f58293f4 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_DM_ETH=y CONFIG_MII=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index cc0ce67a49..f727a2fe87 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -59,6 +59,7 @@ CONFIG_DWC_AHSATA=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 53475e6b36..7e81dec8aa 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -47,6 +47,7 @@ CONFIG_LED_STATUS_BIT=64 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 83ab05e845..416f811eed 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -43,6 +43,7 @@ CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SMC911X=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index c2835358e8..5c975deacc 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -56,6 +56,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/cobra5272_defconfig b/configs/cobra5272_defconfig index 8865618999..df239a5393 100644 --- a/configs/cobra5272_defconfig +++ b/configs/cobra5272_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_IMLS=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_DEFAULT_DEVICE_TREE="cobra5272" +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MII=y CONFIG_BAUDRATE=19200 diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig index ab2d1851c6..0578531a30 100644 --- a/configs/colibri_pxa270_defconfig +++ b/configs/colibri_pxa270_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 593ff34117..c359d86bd9 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -63,6 +63,7 @@ CONFIG_DM_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y +CONFIG_MTD=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index f95ea35880..efebf2d07e 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -36,6 +36,7 @@ CONFIG_DM_GPIO=y CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index 8b2107bec5..180bfa9df6 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -36,6 +36,7 @@ CONFIG_DM_GPIO=y CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index ef5ca7d26a..663b9e8062 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -46,6 +46,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 1bfd949f59..8738555b65 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -56,6 +56,7 @@ CONFIG_BLK=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 3aef717b8f..ae504c16ef 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -52,6 +52,7 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y CONFIG_BLK=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index fc453c6282..20cea4021c 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 10f9f91e3f..9b925f4714 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 59e79a2556..4e075776a4 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -64,6 +64,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index daaf83a94e..1c0bb72686 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -22,6 +22,7 @@ CONFIG_LED_STATUS_BIT=8 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_LED_STATUS_CMD=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 7bd0d30fb6..8048f70ab2 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -21,6 +21,7 @@ CONFIG_LED_STATUS_BIT=8 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_LED_STATUS_CMD=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index f8f2e16f85..a63528e5b2 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -37,6 +37,7 @@ CONFIG_LED_STATUS_RED=1 CONFIG_LED_STATUS_GREEN_ENABLE=y CONFIG_LED_STATUS_GREEN=0 # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 9630d15cb4..158e479441 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -28,6 +28,7 @@ CONFIG_ISO_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index d8002f6d05..479a1fbcc3 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -65,6 +65,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 8c3abd0cd7..6058272b24 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -56,6 +56,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 023170db5a..6cc3825801 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -24,6 +24,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:50m(root1),32m(rootfb),64m(pcache),64 CONFIG_ENV_IS_IN_FLASH=y CONFIG_MXC_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index a176bcd431..e28c447b1a 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -165,6 +165,7 @@ CONFIG_IHS_FPGA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 01ff5dda70..52c3a95d02 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-gurnard" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 7552d9868b..d53210e204 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -67,6 +67,7 @@ CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index 6afd64733d..6fddc4c0ba 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -120,6 +120,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index 544a98c504..0d1059c8b3 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -118,6 +118,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index 3401e18c2b..6a9fb95e88 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -36,6 +36,7 @@ CONFIG_DM_GPIO=y CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 418a4b3706..117c0efe18 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -150,6 +150,9 @@ CONFIG_CMD_UBI=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_I2C=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_MTD_UBI=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 4a8ea8693f..e1b7f673ca 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -49,6 +49,7 @@ CONFIG_ENV_UBI_VOLUME_REDUND="config_r" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index 800e580018..e0fac8e60a 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -41,6 +41,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 2f4e74066b..9b01bc3555 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -42,6 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 252484de0a..2e8721e559 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -56,6 +56,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 2f4e74066b..9b01bc3555 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -42,6 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index b146f2494e..86fdc61690 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -42,6 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 35d63d3322..95beb0a143 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -42,6 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-nand" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index eb3aebf3f3..f9030bf37f 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_ARMFLASH=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index 6af27016c3..8faf25731b 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_ARMFLASH=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 177709e852..f72278bdde 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_ARMFLASH=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index 0620e3760f..592c557fde 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_ARMFLASH=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 1b3d067ce6..f14ff95632 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_IMLS=y CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index 847196e1cf..c185457a40 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_IMLS=y CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index b3a1bcba3c..8cfbc97751 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_IMLS=y CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index cadf5e8915..369d859900 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_IMLS=y CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 08d19b55e8..a74b6e565b 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index e3af08d09e..15982f7c6d 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 8b56002db1..bfcd616824 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 48c0ecc11b..7cc7f77e28 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -37,6 +37,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index a8b1806dae..7d33520de4 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 82e4b5cb2f..8b3b70d2b8 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index e426a86980..b781cccb40 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index ccca8b910e..916de8f56e 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -35,6 +35,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index faeb0c7175..b66665416d 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -180,6 +180,7 @@ CONFIG_CMD_UBI=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index 14f7c2f8ce..e13bd84a45 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -144,6 +144,7 @@ CONFIG_CMD_UBI=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index 94f77cf733..f48a3197ff 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 61855e9b7c..57601fc92c 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -38,6 +38,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 213f2dfb5b..b6fee84bec 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -39,6 +39,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index f2aafa9283..f06c34a444 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -55,6 +55,8 @@ CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 43b3f6d255..686006aec4 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -39,6 +39,7 @@ CONFIG_SATA_CEVA=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 7f42e51263..3c6febfbce 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -39,6 +39,7 @@ CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index b67c24cf64..c3d9c497c2 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -40,6 +40,7 @@ CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 445eb04508..6c6dea0966 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -53,6 +53,7 @@ CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 8871c61b87..03cbc1c061 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index a5aaa9a350..d8639cd5f0 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -33,6 +33,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index fe0f6c4052..a0a3a83a45 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -35,6 +35,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 8277d6a114..b0d6eb169d 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -46,6 +46,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index f07820a705..e7d4bcc0b6 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -47,6 +47,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 65b2dd18f9..982eb0bd94 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -34,6 +34,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 51fc761f45..d6fff2271e 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -35,6 +35,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 551176f58b..c32cc3f15a 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -50,6 +50,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 65734f5cda..01d295aef0 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -35,6 +35,7 @@ CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 3506b31867..ca00909de8 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -50,6 +50,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 472786ab26..3edc466e41 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -35,6 +35,7 @@ CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index b49ac2cb5d..1a51ba3826 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -41,6 +41,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 57791a748e..6831ead857 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_DM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 49d498ae80..c8056eb4e9 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -27,6 +27,7 @@ CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 7aa8c54a12..7bf9134913 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -45,6 +45,8 @@ CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 22ccf526f6..8e49c4bbd9 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -45,6 +45,8 @@ CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 486a2e089b..77bade9381 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -43,6 +43,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index b3c2970207..9d51749d08 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -43,6 +43,7 @@ CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index 5c8257de4e..bdf2dc7d93 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_DM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 75bb52ad4a..27b068c330 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -31,6 +31,7 @@ CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index e863c97307..02fd2c5ff4 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -34,6 +34,7 @@ CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 30f9d82291..ebbb3e3184 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -35,6 +35,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index a2381b7952..dae9ab018d 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -36,6 +36,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 75f9ebffef..ee29f80948 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -43,6 +43,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 3e537ec2de..4f31b67b4d 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -52,6 +52,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 2b4f72f54c..7863c1ed0e 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -36,6 +36,7 @@ CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 6449d3a771..17d67c544a 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -42,6 +42,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 56af5261e3..1ba0c81bdd 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -32,6 +32,7 @@ CONFIG_SCSI_AHCI=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 229308160f..2a81d2615a 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -43,6 +43,7 @@ CONFIG_SCSI_AHCI=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 145beea761..27f55a1025 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -44,6 +44,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index 12f5b2eb74..1f8de1b72d 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -32,6 +32,7 @@ CONFIG_MP=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index c0fde247fc..6c89feffa8 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -35,6 +35,7 @@ CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index e265ac177b..5c6d780d2b 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -36,6 +36,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 5f307f6caf..bf4543f348 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -35,6 +35,7 @@ CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index c92121e6d3..3c39fc22c5 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -36,6 +36,7 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 9201ccbc9d..0967cd5747 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -45,6 +45,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index f0ebe7bc35..379e05ccb8 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -45,6 +45,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 0f84055993..3c2990c980 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -43,6 +43,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 014acc5e91..b3c9d595b1 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -46,6 +46,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index ca5744d29e..2b16c1d403 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -63,6 +63,7 @@ CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC_IMX=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXC=y diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index 10d2e55f5a..82d2bc661e 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index 6759d18176..c9de055e43 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 6b6869dce6..160715f40c 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 8dca7ff32f..bc0cc49611 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 586ea618a7..e3874d4827 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index cfc911d13f..c4a8f4916c 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -37,6 +37,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index bf989535b8..c5c8fc6ad5 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -30,6 +30,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index cb0da4701f..7d0dbe2f01 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -108,6 +108,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index d92755ba7e..f434ee0c34 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 32ba6c4881..3f96f07586 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 8d0f1b9d70..81856e2286 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index a34688219c..6867c17209 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -38,6 +38,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),5 CONFIG_CMD_UBI=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index 349b21131d..4cd567f056 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_DATE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MXC_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_SMC911X=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 2f01d2f840..cf7d700dcf 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -27,6 +27,7 @@ CONFIG_EFI_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/mx53ard_defconfig b/configs/mx53ard_defconfig index da9d6f5527..4226402929 100644 --- a/configs/mx53ard_defconfig +++ b/configs/mx53ard_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC_IMX=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXC=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index c2e230c3fd..be34d25bd3 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -64,6 +64,7 @@ CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 4ab43b6c1a..377a4dbbb0 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -35,6 +35,7 @@ CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index a5e6151f44..a1fd2c1fb0 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 08520f403c..9773464d04 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -46,6 +46,7 @@ CONFIG_SPL_DM=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index ee3462efb1..ed7cb8f2ff 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -67,6 +67,7 @@ CONFIG_LED_STATUS_CMD=y CONFIG_TWL4030_LED=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index e7cd58a132..2670dfb1e6 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -54,6 +54,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_DM_MMC=y # CONFIG_SPL_DM_MMC is not set CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index bb36740dd4..12ce30659f 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 8f1f232387..bc7334cef5 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP36XX_PINS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 7d1bb72190..c2fac5b7c5 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -47,6 +47,7 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP36XX_PINS=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index ef33ef09b9..a5069fd964 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index 5ee0dace26..d8ee7995de 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SERIAL=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index 516c0e6ea1..17b36350e6 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -24,6 +24,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SMC911X=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 215e0d14d2..088f7966ab 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -49,6 +49,7 @@ CONFIG_CMD_DIAG=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 5033e7c2c0..b850e2cbc9 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -49,6 +49,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(e CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 78abe3d0dd..88d6d5302d 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -49,6 +49,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(e CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index ec71ef5346..46dd55dac0 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -40,6 +40,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 768917bbdc..f210b99e91 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -40,6 +40,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 1b75972229..b170b5a355 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -66,6 +66,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/qemu_mips64_defconfig b/configs/qemu_mips64_defconfig index aff109512e..9bf4c64b34 100644 --- a/configs/qemu_mips64_defconfig +++ b/configs/qemu_mips64_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/qemu_mips64el_defconfig b/configs/qemu_mips64el_defconfig index 63cbd44c0d..370ee47b5b 100644 --- a/configs/qemu_mips64el_defconfig +++ b/configs/qemu_mips64el_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/qemu_mips_defconfig b/configs/qemu_mips_defconfig index 37bf69f9e8..5e302ba825 100644 --- a/configs/qemu_mips_defconfig +++ b/configs/qemu_mips_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/qemu_mipsel_defconfig b/configs/qemu_mipsel_defconfig index 82091b97df..c729ac1f5c 100644 --- a/configs/qemu_mipsel_defconfig +++ b/configs/qemu_mipsel_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index e10ac939c5..b4679ffbb9 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -21,6 +21,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="sh7751-r2dplus" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 7862312d23..fbb4cb238b 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 4acdd21662..f37b887001 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -44,6 +44,7 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 6166c025f4..bf2fd33bf8 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -64,6 +64,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index af53e75e89..735d856a65 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -67,6 +67,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 9ccf98bba5..3313cc2e69 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -49,6 +49,7 @@ CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index c97db770f8..6b4e49d7ed 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -43,6 +43,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 61ebabe4ee..cfaf3a1b17 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -45,6 +45,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 74a1f34cb9..ab3d1d0d32 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -62,6 +62,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 26ce4867a3..2d4eca3da2 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -64,6 +64,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 3cf365bde5..dafb8efd1d 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -58,6 +58,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 16f228dceb..974c28192d 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -62,6 +62,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 04e2e24871..ee57eb8747 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -59,6 +59,7 @@ CONFIG_SYS_I2C_AT91=y CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 560221e4c0..038d52a6b9 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_I2C_AT91=y CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index a3aab63c33..382261618f 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -59,6 +59,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index f5cbbb5129..2f0f5cac7e 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -59,6 +59,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sbc8349_PCI_33_defconfig b/configs/sbc8349_PCI_33_defconfig index 915ba3664b..38d0a78847 100644 --- a/configs/sbc8349_PCI_33_defconfig +++ b/configs/sbc8349_PCI_33_defconfig @@ -100,6 +100,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sbc8349_PCI_66_defconfig b/configs/sbc8349_PCI_66_defconfig index c224fea1c9..9e96fc7e31 100644 --- a/configs/sbc8349_PCI_66_defconfig +++ b/configs/sbc8349_PCI_66_defconfig @@ -100,6 +100,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sbc8349_defconfig b/configs/sbc8349_defconfig index 6231057d6b..a035cc5152 100644 --- a/configs/sbc8349_defconfig +++ b/configs/sbc8349_defconfig @@ -77,6 +77,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sbc8548_PCI_33_PCIE_defconfig b/configs/sbc8548_PCI_33_PCIE_defconfig index 5a04646a7e..bafc1aab24 100644 --- a/configs/sbc8548_PCI_33_PCIE_defconfig +++ b/configs/sbc8548_PCI_33_PCIE_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sbc8548_PCI_33_defconfig b/configs/sbc8548_PCI_33_defconfig index 36291e0e7a..93cc1d7029 100644 --- a/configs/sbc8548_PCI_33_defconfig +++ b/configs/sbc8548_PCI_33_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sbc8548_PCI_66_PCIE_defconfig b/configs/sbc8548_PCI_66_PCIE_defconfig index cfe0f3a340..3a725900e5 100644 --- a/configs/sbc8548_PCI_66_PCIE_defconfig +++ b/configs/sbc8548_PCI_66_PCIE_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sbc8548_PCI_66_defconfig b/configs/sbc8548_PCI_66_defconfig index e4b3c63def..d2cb72c1d1 100644 --- a/configs/sbc8548_PCI_66_defconfig +++ b/configs/sbc8548_PCI_66_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sbc8548_defconfig b/configs/sbc8548_defconfig index 33be2b90df..f6d22e50a7 100644 --- a/configs/sbc8548_defconfig +++ b/configs/sbc8548_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set # CONFIG_CMD_IRQ is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sbc8641d_defconfig b/configs/sbc8641d_defconfig index 47cec18a95..d36b1083ec 100644 --- a/configs/sbc8641d_defconfig +++ b/configs/sbc8641d_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_PING=y CONFIG_MP=y CONFIG_DOS_PARTITION=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index d2ba552777..43e69d6103 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -38,6 +38,7 @@ CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_BCM6358=y CONFIG_LED_GPIO=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index 89fdc98ee6..8bc809ae80 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 1daea16a57..3a229ae0f6 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -47,6 +47,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index eaf52f9f01..12401839c7 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index dedaa93fd5..b6e02e8b99 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 58d135b907..d0e9768148 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT2=y # CONFIG_CMD_IRQ is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index 3c3501566c..9a40e80d4d 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -22,4 +22,5 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="stm32f429-disco" CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/stm32f429-evaluation_defconfig b/configs/stm32f429-evaluation_defconfig index 51f587f629..45931a4607 100644 --- a/configs/stm32f429-evaluation_defconfig +++ b/configs/stm32f429-evaluation_defconfig @@ -25,4 +25,5 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="stm32429i-eval" CONFIG_DM_MMC=y CONFIG_ARM_PL180_MMCI=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 8543f9d002..b774364dfe 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -41,6 +41,7 @@ CONFIG_DM_MMC=y CONFIG_ARM_PL180_MMCI=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 6a561d0cd1..9dee0c96f7 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -117,6 +117,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/strider_con_dp_defconfig b/configs/strider_con_dp_defconfig index eb4ad77456..1bbe6b769e 100644 --- a/configs/strider_con_dp_defconfig +++ b/configs/strider_con_dp_defconfig @@ -117,6 +117,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index 8a48df25f6..999f51d3b7 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -117,6 +117,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/strider_cpu_dp_defconfig b/configs/strider_cpu_dp_defconfig index 26793dbdd6..d4cb73fcb0 100644 --- a/configs/strider_cpu_dp_defconfig +++ b/configs/strider_cpu_dp_defconfig @@ -117,6 +117,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index 9fad4de201..1fa5f010b1 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -28,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index dac3a1437c..6d04eec08c 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -65,6 +65,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index ef3f5c2f56..94b010ca89 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -64,6 +64,7 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index dd764a6f30..bb0a2e217e 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_ETH=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index e79b9c3ba4..3bd9262a4f 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -35,6 +35,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:16M(uboot),512k(env1),512k(env2),-(u CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 09a5553347..5c1404f4f0 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -40,6 +40,7 @@ CONFIG_LED_STATUS_STATE2=2 CONFIG_LED_STATUS_CMD=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 85ff46c83c..fbcce5f6bc 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -38,6 +38,7 @@ CONFIG_LED_STATUS_STATE2=2 CONFIG_LED_STATUS_CMD=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 9e091a10ed..4f22f3eefa 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -44,6 +44,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_UNIPHIER=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index 88d7b061e9..f41c61f7bd 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -43,6 +43,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_UNIPHIER=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 3da0f36a18..78a872e157 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -44,6 +44,7 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_CADENCE=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 23aa277c08..bede11665d 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -37,6 +37,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig index 2a35ace0e0..c0e405e23c 100644 --- a/configs/vct_platinum_defconfig +++ b/configs/vct_platinum_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_platinum_small_defconfig b/configs/vct_platinum_small_defconfig index 8a3f94aadf..e65b9f3d81 100644 --- a/configs/vct_platinum_small_defconfig +++ b/configs/vct_platinum_small_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_IMLS=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_NET is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig index 3783becc8a..af3f21cb17 100644 --- a/configs/vct_platinumavc_defconfig +++ b/configs/vct_platinumavc_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_NET is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_platinumavc_small_defconfig b/configs/vct_platinumavc_small_defconfig index 0d8cd07f9f..32f25743fc 100644 --- a/configs/vct_platinumavc_small_defconfig +++ b/configs/vct_platinumavc_small_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_IMLS=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_NET is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig index 2396b24d55..fb8af2914d 100644 --- a/configs/vct_premium_defconfig +++ b/configs/vct_premium_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_premium_small_defconfig b/configs/vct_premium_small_defconfig index a8eba61827..8d93c5e355 100644 --- a/configs/vct_premium_small_defconfig +++ b/configs/vct_premium_small_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_IMLS=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y # CONFIG_NET is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 53777093a0..59e7b31699 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -135,6 +135,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index f6b9eb6c2c..0aae86738f 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -109,6 +109,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index 1a66acbba0..8cff8512ef 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index 7bc852b770..437b776196 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index 5e7a226411..1fef4b95f9 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -29,6 +29,7 @@ CONFIG_EFI_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index b1250e001f..f064490d0a 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -40,7 +40,7 @@ CONFIG_EFI_PARTITION=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_MXC_GPIO=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 62ca1d64ac..406f60c0ba 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -49,6 +49,7 @@ CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_MICREL=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index cd0d30e49c..91581e0ba9 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -47,6 +47,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y # CONFIG_EFI_LOADER is not set diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index 86819427fa..776f8580e2 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_IRQ=y CONFIG_CMD_PCA953X=y CONFIG_DS4510=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index 81689a44d5..49ca7d41a3 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index 72a2a424e2..d013cd2051 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -32,6 +32,7 @@ CONFIG_SYS_FSL_DDR2=y CONFIG_CMD_PCA953X=y CONFIG_DS4510=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index f86d1bdc2d..dad493d02f 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/xtfpga_defconfig b/configs/xtfpga_defconfig index 051bba0ceb..5fdad549bc 100644 --- a/configs/xtfpga_defconfig +++ b/configs/xtfpga_defconfig @@ -24,6 +24,7 @@ CONFIG_DM=y # CONFIG_DM_DEVICE_REMOVE is not set # CONFIG_DM_STDIO is not set # CONFIG_DM_SEQ_ALIAS is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index 3bba1ec74a..baaaffc577 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 0a6b172b7e..1dbf9e41be 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -52,6 +52,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nor" # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 01e3d5fb84..e2d53d5156 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -37,6 +37,7 @@ CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y
On Thu, Oct 03, 2019 at 07:50:06PM +0200, Miquel Raynal wrote:
CONFIG_MTD must be enabled when there is a NOR flash selected.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com
This is not applied. On deeper inspection of the overall changes, there are a number of cases and parts of NOR access that do not require the MTD subsystem. At the end of the series CONFIG_MTD is not entirely and wholly only a gating symbol but also grabs mtdcore.o / mtd_uboot.o and so causes size growth without functional change in some boards. Thanks!
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/M54418TWR_nand_mii_defconfig | 2 ++ configs/M54418TWR_nand_rmii_defconfig | 2 ++ configs/M54418TWR_nand_rmii_lowfreq_defconfig | 2 ++ configs/am335x_guardian_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 2 ++ configs/at91sam9n12ek_nandflash_defconfig | 2 ++ configs/at91sam9x5ek_nandflash_defconfig | 2 ++ configs/bcm963158_ram_defconfig | 1 + configs/bcm968380gerg_ram_defconfig | 1 + configs/bcm968580xref_ram_defconfig | 1 + configs/colibri-imx6ull_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_t20_defconfig | 2 ++ configs/dns325_defconfig | 2 ++ configs/dockstar_defconfig | 2 ++ configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/gardena-smart-gateway-at91sam_defconfig | 2 ++ configs/goflexhome_defconfig | 2 ++ configs/guruplug_defconfig | 2 ++ configs/ib62x0_defconfig | 2 ++ configs/iconnect_defconfig | 2 ++ configs/km_kirkwood_128m16_defconfig | 2 ++ configs/km_kirkwood_defconfig | 2 ++ configs/km_kirkwood_pci_defconfig | 2 ++ configs/kmcoge5un_defconfig | 2 ++ configs/kmnusa_defconfig | 2 ++ configs/kmsugp1_defconfig | 2 ++ configs/kmsuv31_defconfig | 2 ++ configs/ls1046ardb_emmc_defconfig | 2 ++ configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1046ardb_qspi_defconfig | 2 ++ configs/ls1046ardb_qspi_spl_defconfig | 2 ++ configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 2 ++ configs/ls1046ardb_sdcard_defconfig | 2 ++ configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1088aqds_qspi_defconfig | 2 ++ configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 2 ++ configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1088ardb_qspi_defconfig | 2 ++ configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1088ardb_sdcard_qspi_defconfig | 2 ++ configs/ls2080aqds_nand_defconfig | 2 ++ configs/ls2080aqds_qspi_defconfig | 2 ++ configs/ls2080aqds_sdcard_defconfig | 2 ++ configs/medcom-wide_defconfig | 2 ++ configs/mgcoge3un_defconfig | 2 ++ configs/nas220_defconfig | 2 ++ configs/nsa310s_defconfig | 2 ++ configs/openrd_base_defconfig | 2 ++ configs/openrd_client_defconfig | 2 ++ configs/openrd_ultimate_defconfig | 2 ++ configs/pcm052_defconfig | 2 ++ configs/pcm058_defconfig | 1 + configs/pfla02_defconfig | 1 + configs/phycore_pcl063_defconfig | 1 + configs/plutux_defconfig | 2 ++ configs/pm9g45_defconfig | 2 ++ configs/pogo_e02_defconfig | 2 ++ configs/sama5d2_ptc_ek_nandflash_defconfig | 2 ++ configs/sama5d36ek_cmp_nandflash_defconfig | 2 ++ configs/sama5d3_xplained_nandflash_defconfig | 2 ++ configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 2 ++ configs/sama5d4ek_nandflash_defconfig | 2 ++ configs/seaboard_defconfig | 2 ++ configs/sheevaplug_defconfig | 2 ++ configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + configs/tec_defconfig | 2 ++ configs/vf610twr_defconfig | 2 ++ configs/vf610twr_nand_defconfig | 2 ++ configs/work_92105_defconfig | 2 ++ configs/x600_defconfig | 1 + 76 files changed, 135 insertions(+)
diff --git a/configs/M54418TWR_nand_mii_defconfig b/configs/M54418TWR_nand_mii_defconfig index 6fa822d790..1b04860b5c 100644 --- a/configs/M54418TWR_nand_mii_defconfig +++ b/configs/M54418TWR_nand_mii_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M54418TWR_nand_mii" +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/M54418TWR_nand_rmii_defconfig b/configs/M54418TWR_nand_rmii_defconfig index 1fa7b38828..b28c8067ce 100644 --- a/configs/M54418TWR_nand_rmii_defconfig +++ b/configs/M54418TWR_nand_rmii_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M54418TWR_nand_rmii" +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/M54418TWR_nand_rmii_lowfreq_defconfig b/configs/M54418TWR_nand_rmii_lowfreq_defconfig index 5208e598f4..b0af1dbf17 100644 --- a/configs/M54418TWR_nand_rmii_lowfreq_defconfig +++ b/configs/M54418TWR_nand_rmii_lowfreq_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M54418TWR_nand_rmii_lowfreq" +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index ed288136c3..06abc888be 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -67,6 +67,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x100000 diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 44c50739a0..f35ace1b42 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9m10g45ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index a2cb37e1ae..0120b20199 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -32,6 +32,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9n12ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index b5c282dc25..1509dd7cff 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -42,6 +42,8 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index a08ece81ad..2b00d997d3 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -35,6 +35,7 @@ CONFIG_LED_BCM6858=y CONFIG_LED_BLINK=y # CONFIG_MMC is not set CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_63158=y diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 4f963ee38e..a5290b3c12 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -38,6 +38,7 @@ CONFIG_LED=y CONFIG_LED_BCM6328=y CONFIG_LED_BLINK=y CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6838=y diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index 0812a81c72..4389e2e4f2 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -30,6 +30,7 @@ CONFIG_LED_BCM6858=y CONFIG_LED_BLINK=y # CONFIG_MMC is not set CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6858=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 71f64bae6a..55db6c7ea5 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -53,6 +53,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 973b681bdd..9a47eafddd 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -54,6 +54,7 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS_DT=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 49ed114522..ea51675003 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -39,6 +39,8 @@ CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=1536 CONFIG_SPL_DM=y CONFIG_SYS_I2C_TEGRA=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM_MTD=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_DM_PMIC=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 6e95fb265e..5fa13df1c6 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -31,6 +31,8 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dns325" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 18df663b7b..2d501ef5cb 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -28,6 +28,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dockstar" CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 1b4f8d6229..e40f1cd32d 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -72,6 +72,7 @@ CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 5d25e4f4fa..d4a2714673 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -75,6 +75,7 @@ CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 65dd083854..9f83000445 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -67,6 +67,8 @@ CONFIG_LED=y CONFIG_LED_GPIO=y # CONFIG_MMC is not set # CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_ETH=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 5fa8b4d1f5..3d51c0de82 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -36,6 +36,8 @@ CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_DM_RTC=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 12ca8b35a8..18346e59af 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -36,6 +36,8 @@ CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_DM_RTC=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 13a2e83a0b..89eb677664 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -32,6 +32,8 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ib62x0" CONFIG_ENV_IS_IN_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index aa67a6cef0..47ddd62ea0 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -27,6 +27,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-iconnect" CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 1ba69fc614..10b33ab7ad 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -36,6 +36,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index df0c9d322c..199bb3c2fe 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -36,6 +36,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index c5020caab0..7ff7ccf00d 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -37,6 +37,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index c3510c473b..3ab3671faa 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -39,6 +39,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index bcdf97ce1a..9ce041e1bd 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -39,6 +39,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index 2f123bd3f2..d67b4bc4b6 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -39,6 +39,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 2c9c9bb3fa..141f5e7e01 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -38,6 +38,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 4467239d27..7a3fb9965a 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -47,6 +47,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index dd784459b3..398a055e57 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -30,6 +30,8 @@ CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index ef5e73dd28..325b2dd10f 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -31,6 +31,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 41c998816a..563e536431 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -50,6 +50,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index fcc3632d9a..c9f06cee6c 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -44,6 +44,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index f3b2f61119..6ce0ee1ab7 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -46,6 +46,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 1ba0c81bdd..a42bd24735 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -33,6 +33,7 @@ CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index bb90ed7549..9e23d69821 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 8aeca657e8..20b4d21723 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -34,6 +34,8 @@ CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 2a81d2615a..f429b4ad0b 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -44,6 +44,7 @@ CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 5fd9b940d4..d2cb3ca7bb 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -45,6 +45,8 @@ CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index 265303c356..924cc24ab2 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -35,6 +35,8 @@ CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 6dd9df2dc1..c469a6e980 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -35,6 +35,8 @@ CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index 079ef9d8bc..cb29808e31 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -46,6 +46,8 @@ CONFIG_SPL_DM=y CONFIG_SCSI_AHCI=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 9dbaae6c56..4b23bc81dc 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -46,6 +46,8 @@ CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 33a75ac83a..2ff04b01e3 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -41,6 +41,8 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 53abf71bbd..e04aa574cf 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -37,6 +37,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 4e392a8bef..0cf147bae7 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -58,6 +58,8 @@ CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index c927418c06..1a7b8c1bbf 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-medcom-wide" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 15a6dd5b08..51b5358e69 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -38,6 +38,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 9b5d594c81..27dd7752db 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -32,6 +32,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-blackarmor-nas220" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 064ea0523d..df49fd8498 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -29,6 +29,8 @@ CONFIG_ISO_PARTITION=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 43dc6c5c1a..b7e05a8039 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -34,6 +34,8 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-base" CONFIG_ENV_IS_IN_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 71c4475466..731e5cb1df 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -32,6 +32,8 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-client" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MVGBE=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index bdfa4ac862..fd6fe37ae9 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -32,6 +32,8 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-ultimate" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MVGBE=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index cce7cf435a..ad744c86e8 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -41,6 +41,8 @@ CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_DM_MMC=y CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_MTD=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 86999429ef..f617d130d6 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index bfbc30f680..f80240b25a 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -44,6 +44,7 @@ CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DM=y CONFIG_FSL_USDHC=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index 6b11bfe2f3..42f05d1ec0 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -37,6 +37,7 @@ CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 56489535a6..939b681e12 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -23,6 +23,8 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-plutux" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPL_DM=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index b5304b963c..9f3420d64c 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -41,6 +41,8 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 08c52ffdf1..a1998f62ce 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -27,6 +27,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogo_e02" CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index 4210a52a13..13e1bd0675 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -49,6 +49,8 @@ CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 3bcfbf071e..345bba447e 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -43,6 +43,8 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 8a2b01f386..5f12455d47 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -58,6 +58,8 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index dafb8efd1d..4ecd8e9b8a 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -59,6 +59,7 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index efdf0a4da1..3d2a0041a4 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -56,6 +56,8 @@ CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index a5a151c6b2..c3d8ab4600 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -56,6 +56,8 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 0dd0a3831f..f0fed97f89 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -46,3 +46,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_AES=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 734e894c98..75682298ec 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -34,6 +34,8 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-sheevaplug" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_MVGBE=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index a9c3ad5dec..bcd0c593b2 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -80,6 +80,7 @@ CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_STM32_SDMMC2=y CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index f7f9f4d0a0..6b13791b35 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -66,6 +66,7 @@ CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_STM32_SDMMC2=y CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 45902ff8c4..4608cdf8d9 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-tec" CONFIG_ENV_IS_IN_NAND=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index f3e55b87bd..92c3299b4f 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -32,6 +32,8 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y CONFIG_FSL_ESDHC_IMX=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 64b108d41d..b9a046ef8e 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -32,6 +32,8 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y CONFIG_FSL_ESDHC_IMX=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index a5d76e8194..9bcde21438 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -37,6 +37,8 @@ CONFIG_CMD_DATE=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_SYS_NS16550=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 406f60c0ba..33f67c8a0f 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -50,6 +50,7 @@ CONFIG_FPGA_SPARTAN3=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_MICREL=y
After re-running the migration but also adjusting many of the migrations based on deeper inspection of the changes visible in u-boot.cfg before and after the entire series: Applied to u-boot/master, thanks!
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/comtrend_ar5315u_ram_defconfig | 1 + configs/comtrend_ar5387un_ram_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/helios4_defconfig | 1 + configs/linkit-smart-7688-ram_defconfig | 1 + configs/linkit-smart-7688_defconfig | 1 + configs/netgear_cg3100d_ram_defconfig | 1 + configs/sagem_f@st1704_ram_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + 13 files changed, 13 insertions(+)
diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig index eca24e9d25..706091899b 100644 --- a/configs/ap121_defconfig +++ b/configs/ap121_defconfig @@ -36,6 +36,7 @@ CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=25000000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/ap143_defconfig b/configs/ap143_defconfig index 9a5a9f89c6..3a54789e7d 100644 --- a/configs/ap143_defconfig +++ b/configs/ap143_defconfig @@ -35,6 +35,7 @@ CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=25000000 # CONFIG_NET is not set CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 9b965c5b7a..173e56813e 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -59,6 +59,7 @@ CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index ebfe3cf158..b1e6c2798a 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -53,6 +53,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_MV=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/comtrend_ar5315u_ram_defconfig b/configs/comtrend_ar5315u_ram_defconfig index 0f26c89899..998b1d7e32 100644 --- a/configs/comtrend_ar5315u_ram_defconfig +++ b/configs/comtrend_ar5315u_ram_defconfig @@ -40,6 +40,7 @@ CONFIG_LED=y CONFIG_LED_BCM6328=y CONFIG_LED_BLINK=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/comtrend_ar5387un_ram_defconfig b/configs/comtrend_ar5387un_ram_defconfig index 3bd6ea74bf..879f55ef94 100644 --- a/configs/comtrend_ar5387un_ram_defconfig +++ b/configs/comtrend_ar5387un_ram_defconfig @@ -40,6 +40,7 @@ CONFIG_LED=y CONFIG_LED_BCM6328=y CONFIG_LED_BLINK=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index 2e28871f37..c310959805 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -27,6 +27,7 @@ CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index ed488cb8ad..5e359897af 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -50,6 +50,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_MV=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_SPEED=104000000 diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index 8402147593..6ab38b0eaf 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -39,6 +39,7 @@ CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 5d800512a5..1c34621921 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -43,6 +43,7 @@ CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/netgear_cg3100d_ram_defconfig b/configs/netgear_cg3100d_ram_defconfig index 754a03ecb0..babe8bdd33 100644 --- a/configs/netgear_cg3100d_ram_defconfig +++ b/configs/netgear_cg3100d_ram_defconfig @@ -37,6 +37,7 @@ CONFIG_LED_BCM6328=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/sagem_f@st1704_ram_defconfig b/configs/sagem_f@st1704_ram_defconfig index b146330687..a062469324 100644 --- a/configs/sagem_f@st1704_ram_defconfig +++ b/configs/sagem_f@st1704_ram_defconfig @@ -39,6 +39,7 @@ CONFIG_BCM6345_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index 12ebd989a2..bca3ae8385 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -24,6 +24,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tplink_wdr4300" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_SPI_FLASH=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y
UBI must be enabled when using fastmap, reflect this is defconfigs.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/am335x_igep003x_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/colibri-imx6ull_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/draco_defconfig | 1 + configs/etamin_defconfig | 1 + configs/harmony_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/thuban_defconfig | 1 + 17 files changed, 17 insertions(+)
diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index f8d8eb640c..959e7dc5aa 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -64,6 +64,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 9213915390..17ce35341f 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -45,6 +45,7 @@ CONFIG_SF_DEFAULT_CS=1 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_PHYLIB=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index eda3baea0e..6143eb2264 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -43,6 +43,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_PHYLIB=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 39b0c38412..895a014069 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -44,6 +44,7 @@ CONFIG_SF_DEFAULT_BUS=3 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_PHYLIB=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 55db6c7ea5..2f7003cca0 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -59,6 +59,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y CONFIG_MTD_RAW_NAND_MXS_DT=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 9a47eafddd..e873099b63 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -57,6 +57,7 @@ CONFIG_DM_MTD=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS_DT=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index ea51675003..aeb824b003 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -42,6 +42,7 @@ CONFIG_SYS_I2C_TEGRA=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_DM_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index c359d86bd9..f657ccf659 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -64,6 +64,7 @@ CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 4e075776a4..ea317d043c 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 479a1fbcc3..f9d888bae2 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -69,6 +69,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index c7c8bc249c..70779b89cf 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -30,6 +30,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-harmony" CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_DM_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PCI=y CONFIG_DM_PCI=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index e1b7f673ca..8660b339a5 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -53,6 +53,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x2C000000 diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index b170b5a355..d1cda87d71 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -70,6 +70,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_MII=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index bf2fd33bf8..98b77cd93f 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 735d856a65..c728318f18 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -71,6 +71,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_MII=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 627009d632..0c2c2a53b1 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -72,6 +72,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 94b010ca89..1ebab8c87c 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_DRIVER_TI_CPSW=y
MTD must be enabled when UBI is used, this is mandatory and will later be reflected thanks to a "depends on" in Kconfig. But first, defconfigs need to be fixed.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/gardena-smart-gateway-mt7688-ram_defconfig | 1 + configs/gardena-smart-gateway-mt7688_defconfig | 1 + configs/harmony_defconfig | 1 + configs/mscc_ocelot_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index 281ad308e6..c362b407ea 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -49,6 +49,7 @@ CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_SPI_NAND=y CONFIG_SPI_FLASH=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index d5792b63d8..5d3d7c9f04 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -52,6 +52,7 @@ CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_SPI_NAND=y CONFIG_SPI_FLASH=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 70779b89cf..441cbf9774 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -29,6 +29,7 @@ CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-harmony" CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y +CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index 18dd956b98..109d947934 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -50,6 +50,7 @@ CONFIG_MSCC_SGPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_DM_MTD=y +CONFIG_MTD=y CONFIG_MTD_SPI_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y
This is not applied. Upon full migration in the initial part of this series this patch is no longer required, so is dropped. Thanks!
UBI must be enabled when CMD_UBI is used, this is mandatory and will later be reflected thanks to a "depends on" in Kconfig. But first, defconfigs needs to be fixed.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/am335x_baltos_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/ds414_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/gardena-smart-gateway-mt7688-ram_defconfig | 1 + configs/gardena-smart-gateway-mt7688_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 2 ++ configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge4_defconfig | 2 ++ configs/kmcoge5ne_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmeter1_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmopti2_defconfig | 1 + configs/kmsugp1_defconfig | 1 + configs/kmsupx5_defconfig | 1 + configs/kmsuv31_defconfig | 1 + configs/kmtegr1_defconfig | 1 + configs/kmtepr2_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/mgcoge3un_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/nas220_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/pfla02_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sheevaplug_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/suvd3_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/titanium_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/tuge1_defconfig | 1 + configs/tuxx1_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + configs/vct_platinum_onenand_defconfig | 1 + configs/vct_platinum_onenand_small_defconfig | 1 + configs/vct_platinumavc_onenand_defconfig | 1 + configs/vct_platinumavc_onenand_small_defconfig | 1 + configs/vct_premium_onenand_defconfig | 1 + configs/vct_premium_onenand_small_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/x600_defconfig | 1 + include/env_internal.h | 4 ++-- 108 files changed, 111 insertions(+), 2 deletions(-)
diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index c9524cab73..635c9beac7 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -48,6 +48,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP_HS_ADMA=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x00080000 diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 6dd04a4c17..02d5ed3aa0 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -50,6 +50,7 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_PCA953X=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index be8ef7d2dd..41f4b2cf15 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -44,6 +44,7 @@ CONFIG_FPGA_SPARTAN3=y CONFIG_MXC_GPIO=y CONFIG_MMC_MXC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 28b507e23f..e46a9f1a2c 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -34,6 +34,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index ebb3885e91..c791a062f0 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -45,6 +45,7 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index a225cf291a..0a575b411f 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -43,6 +43,7 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 1509dd7cff..fe2353178a 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -43,6 +43,7 @@ CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 8f53244e6f..a2e4a01f8e 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -45,6 +45,7 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 173e56813e..686f1ca482 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -60,6 +60,7 @@ CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_MTD=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 5fa13df1c6..a7193875d5 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dns325" CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_DM=y CONFIG_MVSATA_IDE=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 2d501ef5cb..3cb368293d 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -29,6 +29,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dockstar" CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index 9720ff8e91..110f7f96cf 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -51,6 +51,7 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 6058272b24..c09888b4ed 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -57,6 +57,7 @@ CONFIG_CLK_AT91=y CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index c362b407ea..0e43576c1c 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -50,6 +50,7 @@ CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_DM_MTD=y CONFIG_MTD_SPI_NAND=y CONFIG_SPI_FLASH=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 5d3d7c9f04..b4ed551b43 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -53,6 +53,7 @@ CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_DM_MTD=y CONFIG_MTD_SPI_NAND=y CONFIG_SPI_FLASH=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 3d51c0de82..33de608b6f 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -37,6 +37,7 @@ CONFIG_MVSATA_IDE=y CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 18346e59af..23e550ae07 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -37,6 +37,7 @@ CONFIG_MVSATA_IDE=y CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 6b343bf7b3..d8462001ea 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -65,6 +65,7 @@ CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 48ce0112ae..bb87d7728e 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -65,6 +65,7 @@ CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_PHYLIB=y CONFIG_MV88E61XX_SWITCH=y CONFIG_MV88E61XX_CPU_PORT=5 diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index d53210e204..21ffa20bff 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -68,6 +68,7 @@ CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 89eb677664..df79f314d2 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -33,6 +33,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index 47ddd62ea0..c93a3d6992 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-iconnect" CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index e0fac8e60a..a93194bf3b 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -42,6 +42,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 9b01bc3555..0dc81f026c 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -43,6 +43,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 110f91c4b2..ae3395a5bc 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -68,6 +68,8 @@ CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_FSL_USDHC=y CONFIG_DM_MTD=y +CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 2e8721e559..c497aee973 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -57,6 +57,7 @@ CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 9b01bc3555..0dc81f026c 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -43,6 +43,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 86fdc61690..77fa6da182 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -43,6 +43,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 95beb0a143..fe9e5c1dcc 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -43,6 +43,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index a74b6e565b..3ffba36dff 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 15982f7c6d..8d494e6804 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -37,6 +37,7 @@ CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index bfcd616824..0346558c69 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 7cc7f77e28..b28f4a7da9 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -38,6 +38,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 7d33520de4..01c8be6201 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 8b3b70d2b8..d9ed31f5fc 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -37,6 +37,7 @@ CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index b781cccb40..00cc1a563f 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 916de8f56e..79cca378b4 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -36,6 +36,7 @@ CONFIG_TI_AEMIF=y CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 10b33ab7ad..2f7a9e328c 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -37,6 +37,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index 199bb3c2fe..db60a113bf 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -37,6 +37,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 7ff7ccf00d..5ff8c2842c 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -38,6 +38,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 7ee4ce44aa..653ab00f4a 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -39,6 +39,8 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index b66665416d..0a5b798d96 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -181,6 +181,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 3ab3671faa..45c528a64f 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -40,6 +40,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 369ba6a9d4..4da683c3a2 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -145,6 +145,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 9ce041e1bd..aae2106187 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -40,6 +40,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index a72dc7f808..5abb694e18 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -165,6 +165,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index d67b4bc4b6..0bd6d9fa33 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -40,6 +40,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 8ce90cd23f..1004cedccc 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -145,6 +145,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 141f5e7e01..f813a76430 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -39,6 +39,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index e13bd84a45..276dbeacdf 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -145,6 +145,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index c131d7f2ef..7dc5bef99e 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -165,6 +165,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 2b16c1d403..9c8cbf9378 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -64,6 +64,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXC=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 51b5358e69..6844600c57 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -39,6 +39,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=8100000 diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index f434ee0c34..cdbfffca87 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -41,6 +41,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 3f96f07586..207ebd4be1 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -41,6 +41,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 81856e2286..cc536aa297 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 6867c17209..7fcd068356 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_UBI=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_MII=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 27dd7752db..9d194a2f6a 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-blackarmor-nas220" CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_DM=y CONFIG_MVSATA_IDE=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index df49fd8498..e950f6aabf 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index a1fd2c1fb0..5decb71008 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -48,6 +48,7 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 9773464d04..fe97a2f1a8 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -47,6 +47,7 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index ed7cb8f2ff..a4fd5cd494 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -68,6 +68,7 @@ CONFIG_TWL4030_LED=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 2670dfb1e6..0aa6ed3f10 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -55,6 +55,7 @@ CONFIG_DM_MMC=y # CONFIG_SPL_DM_MMC is not set CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index 12ce30659f..a78fc386bb 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index bc7334cef5..50172b2c10 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -47,6 +47,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP36XX_PINS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index c2fac5b7c5..c6ac4e5682 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -48,6 +48,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP36XX_PINS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index a5069fd964..e8b18bdddd 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -37,6 +37,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index d8ee7995de..1e33be3c39 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -31,6 +31,7 @@ CONFIG_DM=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SERIAL=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index ba42133e94..fee278907b 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -47,6 +47,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DAVINCI=y CONFIG_DM_MMC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index b7e05a8039..ea0c6f719d 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -35,6 +35,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 731e5cb1df..150de1f7c8 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-client" CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index fd6fe37ae9..b6f8f078d9 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-ultimate" CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index ad744c86e8..0525a97830 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_MTD=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index f617d130d6..6ca24c0007 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -46,6 +46,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index f80240b25a..970670d0ab 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_UBI=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index b850e2cbc9..86763c85fd 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -50,6 +50,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 88d6d5302d..f5e8b7038e 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -50,6 +50,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index a1998f62ce..5aace219a4 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogo_e02" CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index ab3d1d0d32..94c32be666 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -63,6 +63,7 @@ CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 5f12455d47..9b30ee8efc 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -59,6 +59,7 @@ CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 75682298ec..54bb1f5a5e 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -35,6 +35,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-sheevaplug" CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_DM=y CONFIG_MVSATA_IDE=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 7517df6e1e..983e04dddb 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 1c576cedfe..559d820ea3 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index f677149bec..273803d7e9 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 274e2aa382..aff5e5b05a 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -41,6 +41,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MICREL=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 8e804a425f..dce6ef56e1 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 7c78fa3224..7455ffcabd 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index e4286e5415..214edf46c3 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -45,6 +45,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=100000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index 9c45501038..41de60b39a 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -166,6 +166,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index 1fa5f010b1..72b1fb5c98 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 3bd9262a4f..13675885c3 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_USDHC=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 5c1404f4f0..4d22c63454 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -41,6 +41,7 @@ CONFIG_LED_STATUS_CMD=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index fbcce5f6bc..c957bd4ea2 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -39,6 +39,7 @@ CONFIG_LED_STATUS_CMD=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 3ddcad39d4..d5ef094716 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -145,6 +145,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 621e4ece7e..d3d4230626 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -167,6 +167,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 4f22f3eefa..0602bf89ce 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -45,6 +45,7 @@ CONFIG_MMC_UNIPHIER=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index f41c61f7bd..9315ffa5f7 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -44,6 +44,7 @@ CONFIG_MMC_UNIPHIER=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 78a872e157..7a4f78b0b8 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -45,6 +45,7 @@ CONFIG_MMC_SDHCI_CADENCE=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index 1d3d405d8e..5cb798859c 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_ENV_IS_IN_ONENAND=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x00000000 CONFIG_SMC911X_32_BIT=y diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig index 50adb73129..00fc222710 100644 --- a/configs/vct_platinum_onenand_small_defconfig +++ b/configs/vct_platinum_onenand_small_defconfig @@ -30,4 +30,5 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_ONENAND=y # CONFIG_NET is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index 692fae7036..f9f598b3cb 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -21,5 +21,6 @@ CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_ONENAND=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SYS_NS16550=y # CONFIG_REGEX is not set diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig index bcf39bc1ed..be06cf5aac 100644 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ b/configs/vct_platinumavc_onenand_small_defconfig @@ -30,4 +30,5 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_ONENAND=y # CONFIG_NET is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index 2e87bdf358..fea07c1916 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_ENV_IS_IN_ONENAND=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x00000000 CONFIG_SMC911X_32_BIT=y diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig index 93fd4299d2..998c5d3ef5 100644 --- a/configs/vct_premium_onenand_small_defconfig +++ b/configs/vct_premium_onenand_small_defconfig @@ -30,4 +30,5 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_ONENAND=y # CONFIG_NET is not set CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_SYS_NS16550=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 92c3299b4f..46e2ee9321 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -33,6 +33,7 @@ CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index b9a046ef8e..e8113f6684 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -33,6 +33,7 @@ CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y +CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 33f67c8a0f..7267955fa3 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -51,6 +51,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_MTD_UBI=y CONFIG_MTD_NOR_FLASH=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_MICREL=y diff --git a/include/env_internal.h b/include/env_internal.h index b1ddcb5adf..801edfa23a 100644 --- a/include/env_internal.h +++ b/include/env_internal.h @@ -107,8 +107,8 @@ extern unsigned long nand_env_oob_offset; # ifndef CONFIG_ENV_SIZE # error "Need to define CONFIG_ENV_SIZE when using CONFIG_ENV_IS_IN_UBI" # endif -# ifndef CONFIG_CMD_UBI -# error "Need to define CONFIG_CMD_UBI when using CONFIG_ENV_IS_IN_UBI" +# ifndef CONFIG_MTD_UBI +# error "Need to define CONFIG_MTD_UBI when using CONFIG_ENV_IS_IN_UBI" # endif #endif /* CONFIG_ENV_IS_IN_UBI */
UBI must be enabled when the environment is in UBI.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/CHIP_pro_defconfig | 2 ++ env/Kconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 524c56ed4b..f2aeedf5af 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -9,6 +9,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_UBI=y CONFIG_MTDIDS_DEFAULT="nand0=sunxi-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=sunxi-nand.0:256k(spl),256k(spl-backup),2m(uboot),2m(uboot-backup),-(UBI)" CONFIG_DEFAULT_DEVICE_TREE="sun5i-gr8-chip-pro" @@ -18,6 +19,7 @@ CONFIG_ENV_UBI_VOLUME="uboot-env" # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_MTD_UBI=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0x100 diff --git a/env/Kconfig b/env/Kconfig index 74db2f38cc..87614430f8 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -373,6 +373,8 @@ config ENV_SPI_MODE config ENV_IS_IN_UBI bool "Environment in a UBI volume" depends on !CHAIN_OF_TRUST + depends on MTD_UBI + depends on CMD_UBI help Define this if you have an UBI volume that you want to use for the environment. This has the benefit of wear-leveling the environment
Raw NAND support must be enabled when the environment is in NAND.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/bk4r1_defconfig | 1 + configs/harmony_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 686f1ca482..12bdf22876 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -60,6 +60,7 @@ CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_UBI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 441cbf9774..330802d28e 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -31,6 +31,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_MTD=y CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PCI=y
In some files, options of CMD_NAND are selected but not the command itself. Fix this inconsistency.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/apf27_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/bitmain_antminer_s9_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/colibri-imx6ull_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sxsabreauto_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/titanium_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 1 + configs/zynq_zc770_xm011_x16_defconfig | 1 + 28 files changed, 28 insertions(+)
diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 41f4b2cf15..edc9c8dfca 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_NAND_LOCK_UNLOCK=y CONFIG_CMD_DHCP=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 17ce35341f..275a8d4f16 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 6143eb2264..550058bc24 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 895a014069..31a699bdf5 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index fae085e14d..53237e110b 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -21,6 +21,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index 21cd33a2ec..a06f222a8f 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FPGA_LOADMK=y CONFIG_CMD_FPGA_LOADP=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_LOCK_UNLOCK=y CONFIG_CMD_PART=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 12bdf22876..5e1e3b4745 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_DHCP=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 2f7003cca0..b265b315d2 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_NAND_TORTURE=y CONFIG_CMD_USB=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index e873099b63..14502b9ca3 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_NAND_TORTURE=y CONFIG_CMD_USB=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 21ffa20bff..3122971c99 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index ae3395a5bc..99561be4a6 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 9c8cbf9378..e8b2c12e29 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_USB=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index cdbfffca87..e8c36ee0cf 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 207ebd4be1..28305e5431 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index cc536aa297..f24bd7a995 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 7fcd068356..305213d9c5 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index be34d25bd3..b8bf2e164d 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_PART=y CONFIG_CMD_SF=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 377a4dbbb0..5eec92098e 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 0525a97830..ffbd1c26bb 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 6ca24c0007..6430238f20 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_CACHE=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 86763c85fd..5b5986f6ce 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index f5e8b7038e..0bacbc7e40 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 13675885c3..4c556043da 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 46e2ee9321..7fd071e88a 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index e8113f6684..df9761a0c4 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 9faebdcf46..ed7b33c337 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FPGA_LOAD_SECURE=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_LOCK_UNLOCK=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index 029093396e..3cafcd7711 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FPGA_LOADFS=y CONFIG_CMD_FPGA_LOADMK=y CONFIG_CMD_FPGA_LOADP=y CONFIG_CMD_GPIO=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_LOCK_UNLOCK=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig index b24764e42d..904ff56ed1 100644 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ b/configs/zynq_zc770_xm011_x16_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FPGA_LOADFS=y CONFIG_CMD_FPGA_LOADMK=y CONFIG_CMD_FPGA_LOADP=y CONFIG_CMD_GPIO=y +CONFIG_CMD_NAND=y CONFIG_CMD_NAND_LOCK_UNLOCK=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set
MTD support must be enabled when using mtdparts. Indeed, functions like get_mtd_info(), get_mtd_device() and put_mtd_device() are in drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + configs/lion-rk3368_defconfig | 1 + configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + 5 files changed, 5 insertions(+)
diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 2324158349..8ca800c830 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -26,6 +26,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:1m(uboot),8m(kernel),512k(dtb), CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index 0e5a2dacf5..b2b5d1f8a1 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -26,6 +26,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:1m(uboot),8m(kernel),512k(dtb), CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index 1c87416980..cbabba80a6 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -64,6 +64,7 @@ CONFIG_TPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 7aa2d38b7b..a99cee3889 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -113,6 +113,7 @@ CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y CONFIG_I2C_EEPROM=y CONFIG_MMC_SANDBOX=y +CONFIG_MTD=y CONFIG_SPI_FLASH_SANDBOX=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index f77b9e8a7d..770fa7b186 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -133,6 +133,7 @@ CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y CONFIG_I2C_EEPROM=y CONFIG_MMC_SANDBOX=y +CONFIG_MTD=y CONFIG_SPI_FLASH_SANDBOX=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y
Let's be consistent and always declare CONFIG_MTD from the defconfig file when needed.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/socfpga_stratix10_defconfig | 1 + configs/turris_mox_defconfig | 1 + include/configs/mvebu_armada-37xx.h | 1 - include/configs/socfpga_stratix10_socdk.h | 1 - 4 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 5ae53a4db9..9d6108e386 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -39,6 +39,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0x2003 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/turris_mox_defconfig b/configs/turris_mox_defconfig index 25c4fc14b5..3669cae385 100644 --- a/configs/turris_mox_defconfig +++ b/configs/turris_mox_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 3a890ab843..b7a8fae723 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -56,7 +56,6 @@ * SPI Flash configuration */
-#define CONFIG_MTD /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */
/* Environment in SPI NOR flash */ diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index a1920caa9d..7b6ac6eda2 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -71,7 +71,6 @@ #endif /* CONFIG_ENV_IS_IN_SPI_FLASH */
#ifndef CONFIG_SPL_BUILD -#define CONFIG_MTD #define CONFIG_MTD_PARTITIONS #define MTDIDS_DEFAULT "nor0=ff705000.spi.0" #endif /* CONFIG_SPL_BUILD */
Due to previous Makefile organization, the raw NAND subdirectory was not compiled in if CMD_NAND was not enabled. Because the Denali driver does not compile with these boards (undefined environment offset), remove the dependency within the defconfig over the controller driver (was ignored anyway in the past).
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- configs/k2g_evm_defconfig | 1 - configs/k2g_hs_evm_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 0346558c69..a7230e66ff 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -48,7 +48,6 @@ CONFIG_MTD=y CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y -CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index b28f4a7da9..3a0d9a2d52 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -41,7 +41,6 @@ CONFIG_MTD=y CONFIG_MTD_UBI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y -CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1
While the right Kconfig entries were selected, because of the missing CMD_NAND symbol the raw NAND core was never compiled. Remove it from the defconfigs otherwise the build will fail.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- configs/M54418TWR_nand_mii_defconfig | 1 - configs/M54418TWR_nand_rmii_defconfig | 1 - configs/M54418TWR_nand_rmii_lowfreq_defconfig | 1 - configs/bcm11130_nand_defconfig | 2 -- 4 files changed, 5 deletions(-)
diff --git a/configs/M54418TWR_nand_mii_defconfig b/configs/M54418TWR_nand_mii_defconfig index 1b04860b5c..5eaece8dee 100644 --- a/configs/M54418TWR_nand_mii_defconfig +++ b/configs/M54418TWR_nand_mii_defconfig @@ -21,7 +21,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M54418TWR_nand_mii" CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/M54418TWR_nand_rmii_defconfig b/configs/M54418TWR_nand_rmii_defconfig index b28c8067ce..b0a76e0558 100644 --- a/configs/M54418TWR_nand_rmii_defconfig +++ b/configs/M54418TWR_nand_rmii_defconfig @@ -21,7 +21,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M54418TWR_nand_rmii" CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/M54418TWR_nand_rmii_lowfreq_defconfig b/configs/M54418TWR_nand_rmii_lowfreq_defconfig index b0af1dbf17..737c1be40b 100644 --- a/configs/M54418TWR_nand_rmii_lowfreq_defconfig +++ b/configs/M54418TWR_nand_rmii_lowfreq_defconfig @@ -21,7 +21,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="M54418TWR_nand_rmii_lowfreq" CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 9d98402992..0c9d27166b 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -25,8 +25,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y
There is no flash on this board, there is no reason to define MTD environment variables nor UBI. Drop them from the configuration file.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- configs/socfpga_mcvevk_defconfig | 3 --- 1 file changed, 3 deletions(-)
diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 39cc753888..15c9f7fdb0 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -28,9 +28,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_MTDIDS_DEFAULT="nor0=ff705000.spi.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=ff705000.spi.0:1m(u-boot),256k(env1),256k(env2),14848k(boot),16m(rootfs),-@1536k(UBI)0" -CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk"
This board has SPI flash and so the MTDIDS/PARTS make sense there. I'm adding in the board maintainer for further comment about how UBI might be used, thanks!
Hello,
Am 24.11.19 um 16:13 schrieb Tom Rini:
There is *no* SPI-FLash connected to the HPS on that module/board. Therefore these options can safely be removed. (There is a SPI-NOR connected to the FPGA for configuration purposes).
Miquel, feel free to add my:
Reviewed-by: Wolfgang Grandegger wg@aries-embedded.de
Thanks,
Wolfgang
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Wolfgang Grandegger wg@aries-embedded.de
Enabling TFABOOT configuration will compile-in a call to nand_read in the boot sequence. Handle the situation by also selecting officially the raw NAND core in this case.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046afrwy_tfa_defconfig | 2 ++ configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 2 ++ configs/ls1046ardb_tfa_defconfig | 2 ++ configs/ls1088aqds_tfa_defconfig | 1 + configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 2 ++ configs/ls1088ardb_tfa_defconfig | 2 ++ 13 files changed, 18 insertions(+)
diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 3edc466e41..80d14be7eb 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -37,6 +37,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_MTD_RAW_NAND=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index 1a51ba3826..58369dae4b 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -43,6 +43,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_MTD_RAW_NAND=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index bdf2dc7d93..6a81c87299 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -30,6 +30,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_MTD_RAW_NAND=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 27b068c330..10294d47e5 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -33,6 +33,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_MTD_RAW_NAND=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 1d27408762..5f72370571 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -33,6 +33,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index ebbb3e3184..82ce0a6119 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -37,6 +37,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_MTD_RAW_NAND=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 7863c1ed0e..51bec73a17 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -38,6 +38,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_MTD_RAW_NAND=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 17d67c544a..625397c63d 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -43,6 +43,7 @@ CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index 9423d7db22..0d317ab149 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -31,6 +31,8 @@ CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index 1aca8ef13e..104bc45e9b 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -33,6 +33,8 @@ CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 27f55a1025..49a8af5f08 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_MTD_RAW_NAND=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index 45df1347fa..27640ead0a 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -61,6 +61,8 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index b7c40a4d6c..823ab7a6e9 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -48,6 +48,8 @@ CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y
Because of the include's game, when some files are compiled for a SPI NAND device, no warning appears. But when it is for a raw NAND device, GCC complains. Fix these warning by including <common.h>.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- drivers/mtd/nand/bbt.c | 1 + drivers/mtd/nand/core.c | 1 + 2 files changed, 2 insertions(+)
diff --git a/drivers/mtd/nand/bbt.c b/drivers/mtd/nand/bbt.c index 7e0ad3190c..f3d05e6757 100644 --- a/drivers/mtd/nand/bbt.c +++ b/drivers/mtd/nand/bbt.c @@ -9,6 +9,7 @@
#define pr_fmt(fmt) "nand-bbt: " fmt
+#include <common.h> #include <linux/mtd/nand.h> #ifndef __UBOOT__ #include <linux/slab.h> diff --git a/drivers/mtd/nand/core.c b/drivers/mtd/nand/core.c index 0b793695cc..3abaef23c5 100644 --- a/drivers/mtd/nand/core.c +++ b/drivers/mtd/nand/core.c @@ -9,6 +9,7 @@
#define pr_fmt(fmt) "nand: " fmt
+#include <common.h> #ifndef __UBOOT__ #include <linux/module.h> #endif
CONFIG_DFU_NAND needs the raw NAND core being compiled.
Also fix the colibri_vf defconfig to reflect this dependency.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com --- configs/colibri_vf_defconfig | 1 + drivers/dfu/Kconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index f657ccf659..63494b7509 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -64,6 +64,7 @@ CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y CONFIG_MTD_UBI=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y diff --git a/drivers/dfu/Kconfig b/drivers/dfu/Kconfig index 4692736c9d..5ee260913c 100644 --- a/drivers/dfu/Kconfig +++ b/drivers/dfu/Kconfig @@ -31,6 +31,7 @@ config DFU_MMC config DFU_NAND bool "NAND back end for DFU" depends on CMD_MTDPARTS + depends on MTD_RAW_NAND help This option enables using DFU to read and write to NAND based storage.
A NOR flash needs the MTD core, ensure this dependency is met by adding a "depends on" in Kconfig. This is fine since defconfigs have been fixed.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- drivers/mtd/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 345046c2a6..0832f5b411 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -19,6 +19,7 @@ config DM_MTD
config MTD_NOR_FLASH bool "Enable parallel NOR flash support" + depends on MTD help Enable support for parallel NOR flash.
This is not correct and has been dropped (same comment as before about mtdcore.o / mtd_uboot.o inclusion).
It is already the case that all defconfigs with SPI_FLASH_MTD also declare using MTD, but let's make this consistent and enforce it in Kconfig. Most of the time SPI_FLASH_MTD is used in conjunction with UBI, which already depends on MTD.
Suggested-by: Vignesh R vigneshr@ti.com Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- drivers/mtd/spi/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index d3b007a731..c0f383ab4a 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -186,7 +186,7 @@ config SPI_FLASH_DATAFLASH
config SPI_FLASH_MTD bool "SPI Flash MTD support" - depends on SPI_FLASH + depends on SPI_FLASH && MTD help Enable the MTD support for spi flash layer, this adapter is for translating mtd_read/mtd_write commands into spi_flash_read/write
Move the Kconfig entry of the option right after the entry of the mtdparts command.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- cmd/Kconfig | 28 ++++++++++++++-------------- 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index bcfbbb4fc6..33adf29a96 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1903,20 +1903,6 @@ config CMD_MTDPARTS declare the partitions in the mtdparts environment variable but better use the MTD stack and the 'mtd' command instead.
-config MTDIDS_DEFAULT - string "Default MTD IDs" - depends on MTD_PARTITIONS || CMD_MTDPARTS || CMD_NAND || CMD_FLASH - help - Defines a default MTD IDs list for use with MTD partitions in the - Linux MTD command line partitions format. - -config MTDPARTS_DEFAULT - string "Default MTD partition scheme" - depends on MTD_PARTITIONS || CMD_MTDPARTS || CMD_NAND || CMD_FLASH - help - Defines a default MTD partitioning scheme in the Linux MTD command - line partitions format - config CMD_MTDPARTS_SPREAD bool "Padd partition size to take account of bad blocks" depends on CMD_MTDPARTS @@ -1927,6 +1913,20 @@ config CMD_MTDPARTS_SPREAD at least as large as the size specified in the mtdparts variable and 2) each partition starts on a good block.
+config MTDIDS_DEFAULT + string "Default MTD IDs" + depends on MTD_PARTITIONS || CMD_MTDPARTS || CMD_NAND || CMD_FLASH + help + Defines a default MTD IDs list for use with MTD partitions in the + Linux MTD command line partitions format. + +config MTDPARTS_DEFAULT + string "Default MTD partition scheme" + depends on MTD_PARTITIONS || CMD_MTDPARTS || CMD_NAND || CMD_FLASH + help + Defines a default MTD partitioning scheme in the Linux MTD command + line partitions format + config CMD_REISER bool "reiser - Access to reiserfs filesystems" help
The 'sf' command is not supposed to rely on the MTD stack, but both 'sf' and 'nand' commands use helpers located in mtd_uboot.c. Despite their location, these functions do not depend at all on the MTD stack.
This file (drivers/mtd/mtd_uboot.c) is only compiled if CONFIG_MTD is selected, which is inconsistent with the current situation. Solve this by moving these three functions (which are only used by the above two commands) out of mtd_uboot.c and put them in a C file only compiled with cmd/sf.c and cmd/nand.c.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- cmd/Makefile | 3 ++ cmd/legacy-mtd-utils.c | 99 +++++++++++++++++++++++++++++++++++++++++ cmd/legacy-mtd-utils.h | 14 ++++++ cmd/nand.c | 2 + cmd/sf.c | 2 + drivers/mtd/mtd_uboot.c | 94 -------------------------------------- include/linux/mtd/mtd.h | 6 --- 7 files changed, 120 insertions(+), 100 deletions(-) create mode 100644 cmd/legacy-mtd-utils.c create mode 100644 cmd/legacy-mtd-utils.h
diff --git a/cmd/Makefile b/cmd/Makefile index ac843b4b16..88b77c9f78 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -97,6 +97,9 @@ obj-$(CONFIG_CMD_MMC) += mmc.o obj-$(CONFIG_MP) += mp.o obj-$(CONFIG_CMD_MTD) += mtd.o obj-$(CONFIG_CMD_MTDPARTS) += mtdparts.o +ifneq ($(CONFIG_CMD_NAND)$(CONFIG_CMD_SF),) +obj-y += legacy-mtd-utils.o +endif obj-$(CONFIG_CMD_NAND) += nand.o obj-$(CONFIG_CMD_NET) += net.o obj-$(CONFIG_CMD_NVEDIT_EFI) += nvedit_efi.o diff --git a/cmd/legacy-mtd-utils.c b/cmd/legacy-mtd-utils.c new file mode 100644 index 0000000000..1aa3bfc8ec --- /dev/null +++ b/cmd/legacy-mtd-utils.c @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <jffs2/jffs2.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/partitions.h> +#include <linux/string.h> +#include <mtd.h> + +int get_part(const char *partname, int *idx, loff_t *off, loff_t *size, + loff_t *maxsize, int devtype) +{ +#ifdef CONFIG_CMD_MTDPARTS + struct mtd_device *dev; + struct part_info *part; + u8 pnum; + int ret; + + ret = mtdparts_init(); + if (ret) + return ret; + + ret = find_dev_and_part(partname, &dev, &pnum, &part); + if (ret) + return ret; + + if (dev->id->type != devtype) { + printf("not same typ %d != %d\n", dev->id->type, devtype); + return -1; + } + + *off = part->offset; + *size = part->size; + *maxsize = part->size; + *idx = dev->id->num; + + return 0; +#else + puts("mtdparts support missing.\n"); + return -1; +#endif +} + +int mtd_arg_off(const char *arg, int *idx, loff_t *off, loff_t *size, + loff_t *maxsize, int devtype, uint64_t chipsize) +{ + if (!str2off(arg, off)) + return get_part(arg, idx, off, size, maxsize, devtype); + + if (*off >= chipsize) { + puts("Offset exceeds device limit\n"); + return -1; + } + + *maxsize = chipsize - *off; + *size = *maxsize; + return 0; +} + +int mtd_arg_off_size(int argc, char *const argv[], int *idx, loff_t *off, + loff_t *size, loff_t *maxsize, int devtype, + uint64_t chipsize) +{ + int ret; + + if (argc == 0) { + *off = 0; + *size = chipsize; + *maxsize = *size; + goto print; + } + + ret = mtd_arg_off(argv[0], idx, off, size, maxsize, devtype, + chipsize); + if (ret) + return ret; + + if (argc == 1) + goto print; + + if (!str2off(argv[1], size)) { + printf("'%s' is not a number\n", argv[1]); + return -1; + } + + if (*size > *maxsize) { + puts("Size exceeds partition or device limit\n"); + return -1; + } + +print: + printf("device %d ", *idx); + if (*size == chipsize) + puts("whole chip\n"); + else + printf("offset 0x%llx, size 0x%llx\n", + (unsigned long long)*off, (unsigned long long)*size); + return 0; +} diff --git a/cmd/legacy-mtd-utils.h b/cmd/legacy-mtd-utils.h new file mode 100644 index 0000000000..b31342bcb7 --- /dev/null +++ b/cmd/legacy-mtd-utils.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __LEGACY_MTD_UTILS_H +#define __LEGACY_MTD_UTILS_H + +int get_part(const char *partname, int *idx, loff_t *off, loff_t *size, + loff_t *maxsize, int devtype); +int mtd_arg_off(const char *arg, int *idx, loff_t *off, loff_t *size, + loff_t *maxsize, int devtype, uint64_t chipsize); +int mtd_arg_off_size(int argc, char *const argv[], int *idx, loff_t *off, + loff_t *size, loff_t *maxsize, int devtype, + uint64_t chipsize); + +#endif /* LEGACY_MTD_UTILS_H */ diff --git a/cmd/nand.c b/cmd/nand.c index 27efef20bc..f40936cf68 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -30,6 +30,8 @@ #include <jffs2/jffs2.h> #include <nand.h>
+#include "legacy-mtd-utils.h" + #if defined(CONFIG_CMD_MTDPARTS)
/* partition handling routines */ diff --git a/cmd/sf.c b/cmd/sf.c index 6ccf98ae51..e993b3e5ad 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -18,6 +18,8 @@ #include <asm/io.h> #include <dm/device-internal.h>
+#include "legacy-mtd-utils.h" + static struct spi_flash *flash;
/* diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 7c6c9ac0bc..8aeccb016d 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -7,7 +7,6 @@ #include <env.h> #include <dm/device.h> #include <dm/uclass-internal.h> -#include <jffs2/jffs2.h> /* LEGACY */ #include <linux/mtd/mtd.h> #include <linux/mtd/partitions.h> #include <mtd.h> @@ -356,96 +355,3 @@ int mtd_probe_devices(void) return 0; } #endif /* defined(CONFIG_MTD_PARTITIONS) */ - -/* Legacy */ - -static int get_part(const char *partname, int *idx, loff_t *off, loff_t *size, - loff_t *maxsize, int devtype) -{ -#ifdef CONFIG_CMD_MTDPARTS - struct mtd_device *dev; - struct part_info *part; - u8 pnum; - int ret; - - ret = mtdparts_init(); - if (ret) - return ret; - - ret = find_dev_and_part(partname, &dev, &pnum, &part); - if (ret) - return ret; - - if (dev->id->type != devtype) { - printf("not same typ %d != %d\n", dev->id->type, devtype); - return -1; - } - - *off = part->offset; - *size = part->size; - *maxsize = part->size; - *idx = dev->id->num; - - return 0; -#else - puts("mtdparts support missing.\n"); - return -1; -#endif -} - -int mtd_arg_off(const char *arg, int *idx, loff_t *off, loff_t *size, - loff_t *maxsize, int devtype, uint64_t chipsize) -{ - if (!str2off(arg, off)) - return get_part(arg, idx, off, size, maxsize, devtype); - - if (*off >= chipsize) { - puts("Offset exceeds device limit\n"); - return -1; - } - - *maxsize = chipsize - *off; - *size = *maxsize; - return 0; -} - -int mtd_arg_off_size(int argc, char *const argv[], int *idx, loff_t *off, - loff_t *size, loff_t *maxsize, int devtype, - uint64_t chipsize) -{ - int ret; - - if (argc == 0) { - *off = 0; - *size = chipsize; - *maxsize = *size; - goto print; - } - - ret = mtd_arg_off(argv[0], idx, off, size, maxsize, devtype, - chipsize); - if (ret) - return ret; - - if (argc == 1) - goto print; - - if (!str2off(argv[1], size)) { - printf("'%s' is not a number\n", argv[1]); - return -1; - } - - if (*size > *maxsize) { - puts("Size exceeds partition or device limit\n"); - return -1; - } - -print: - printf("device %d ", *idx); - if (*size == chipsize) - puts("whole chip\n"); - else - printf("offset 0x%llx, size 0x%llx\n", - (unsigned long long)*off, (unsigned long long)*size); - return 0; -} diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index e3549f0a46..ceffd994de 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -588,12 +588,6 @@ struct mtd_info *__mtd_next_device(int i); (mtd) != NULL; \ (mtd) = __mtd_next_device(mtd->index + 1))
-int mtd_arg_off(const char *arg, int *idx, loff_t *off, loff_t *size, - loff_t *maxsize, int devtype, uint64_t chipsize); -int mtd_arg_off_size(int argc, char *const argv[], int *idx, loff_t *off, - loff_t *size, loff_t *maxsize, int devtype, - uint64_t chipsize); - /* drivers/mtd/mtdcore.c */ void mtd_get_len_incl_bad(struct mtd_info *mtd, uint64_t offset, const uint64_t length, uint64_t *len_incl_bad,
On Thu, Oct 3, 2019 at 11:21 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Better to drop CMD_SF, CMD_NAND in makefile so-that it can't build this file in this patch.
Hi Jagan,
Jagan Teki jagan@amarulasolutions.com wrote on Fri, 25 Oct 2019 14:44:38 +0530:
I don't understand what you mean. Can you please detail what you have in mind for this patch?
Is it something blocking for you? Or is it something that should be taken care of after?
Thanks, Miquèl
Hi Miquel,
On Fri, Oct 25, 2019 at 2:55 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Jagan,
I think it is simple rebase, this patch is moving code from mtd_uboot.c to legacy-mtd-utils.c but mtd_uboot still building. I'm saying to make change on drivers/mtd/Makefile to drop SF, NAND dependency.
Jagan.
Hi Jagan,
Jagan Teki jagan@amarulasolutions.com wrote on Fri, 25 Oct 2019 14:57:36 +0530:
Hi Miquel,
Hi Jagan,
What do you mean by "mtd_uboot still building"? Do you mean it is a problem? Or did I forgot something?
I don't see what CMD_SF/CMD_NAND dependency you are referring to. Can you please share a snippet of code?
Thanks, Miquèl
On Fri, Oct 25, 2019 at 3:06 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Jagan,
Hi Miquel,
Hi Jagan,
-ifneq (,$(findstring y,$(CONFIG_MTD_DEVICE)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND)$(CONFIG_CMD_SF)$(CONFIG_CMD_MTD))) +ifneq (,$(findstring y,$(CONFIG_MTD_DEVICE)$(CONFIG_CMD_ONENAND)$(CONFIG_CMD_MTD))) obj-y += mtdcore.o mtd_uboot.o endif obj-$(CONFIG_MTD) += mtd-uclass.o
Hi Jagan,
Jagan Teki jagan@amarulasolutions.com wrote on Fri, 25 Oct 2019 15:16:38 +0530:
Hi Jagan,
Hi Miquel,
Hi Jagan,
Indeed! Thanks for the clarification. Please apply patches 1 to 23 of this series, I am resending 24-26 corrected.
Thanks, Miquèl
Defconfigs have been fixed, now we can add proper dependencies in Kconfig. SPI FLASH is still not dependent on MTD (deeper rework needed).
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- cmd/Kconfig | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 33adf29a96..01d4330e04 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -799,6 +799,7 @@ config CMD_FDC config CMD_FLASH bool "flinfo, erase, protect" default y + depends on MTD help NOR flash support. flinfo - print FLASH memory information @@ -988,6 +989,7 @@ config CMD_MMC_SWRITE
config CMD_MTD bool "mtd" + depends on MTD select MTD_PARTITIONS help MTD commands support. @@ -995,6 +997,7 @@ config CMD_MTD config CMD_NAND bool "nand" default y if NAND_SUNXI + depends on MTD_RAW_NAND help NAND support.
@@ -1026,6 +1029,7 @@ config CMD_NVME
config CMD_ONENAND bool "onenand - access to onenand device" + depends on MTD help OneNAND is a brand of NAND ('Not AND' gate) flash which provides various useful features. This command allows reading, writing, @@ -1895,7 +1899,7 @@ config CMD_JFFS2
config CMD_MTDPARTS bool "MTD partition support" - select MTD if (CMD_NAND || NAND) + depends on MTD help MTD partitioning tool support. It is strongly encouraged to avoid using this command @@ -1915,14 +1919,14 @@ config CMD_MTDPARTS_SPREAD
config MTDIDS_DEFAULT string "Default MTD IDs" - depends on MTD_PARTITIONS || CMD_MTDPARTS || CMD_NAND || CMD_FLASH + depends on MTD || SPI_FLASH help Defines a default MTD IDs list for use with MTD partitions in the Linux MTD command line partitions format.
config MTDPARTS_DEFAULT string "Default MTD partition scheme" - depends on MTD_PARTITIONS || CMD_MTDPARTS || CMD_NAND || CMD_FLASH + depends on MTD || SPI_FLASH help Defines a default MTD partitioning scheme in the Linux MTD command line partitions format
Move MTD-related lines out of the root Makefile. Put them in their respective directories. Enclose some of these new lines to skip them when building the SPL. MTD core files and some MTD device drivers are compiled in a mtd.o object and included in the final object only if MTD support is required (there are two different symbols for that, one for U-Boot and one for the SPL).
Now that all defconfigs have been fixed, we can stop the logic where enabling a command selects the core files to compile. This logic is broken since selecting a symbol with a 'depends on' will not enforce this secondary dependency.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- Makefile | 5 ---- drivers/Makefile | 7 ++---- drivers/mtd/Makefile | 50 +++++++++++++++++++++++++++------------ drivers/mtd/nand/Makefile | 5 ++++ 4 files changed, 42 insertions(+), 25 deletions(-)
diff --git a/Makefile b/Makefile index 1d9ade948b..e55c0b236e 100644 --- a/Makefile +++ b/Makefile @@ -708,11 +708,6 @@ libs-y += drivers/ libs-y += drivers/dma/ libs-y += drivers/gpio/ libs-y += drivers/i2c/ -libs-y += drivers/mtd/ -libs-$(CONFIG_CMD_NAND) += drivers/mtd/nand/raw/ -libs-y += drivers/mtd/onenand/ -libs-$(CONFIG_CMD_UBI) += drivers/mtd/ubi/ -libs-y += drivers/mtd/spi/ libs-y += drivers/net/ libs-y += drivers/net/phy/ libs-y += drivers/power/ \ diff --git a/drivers/Makefile b/drivers/Makefile index a4bb5e4975..708aa2a1a7 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -11,7 +11,7 @@ obj-$(CONFIG_$(SPL_TPL_)I2C_SUPPORT) += i2c/ obj-$(CONFIG_$(SPL_TPL_)INPUT) += input/ obj-$(CONFIG_$(SPL_TPL_)LED) += led/ obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += mmc/ -obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += mtd/nand/raw/ +obj-y += mtd/ obj-$(CONFIG_$(SPL_TPL_)PCH_SUPPORT) += pch/ obj-$(CONFIG_$(SPL_TPL_)PCI) += pci/ obj-$(CONFIG_$(SPL_TPL_)PHY) += phy/ @@ -19,7 +19,6 @@ obj-$(CONFIG_$(SPL_TPL_)PINCTRL) += pinctrl/ obj-$(CONFIG_$(SPL_TPL_)RAM) += ram/ obj-$(CONFIG_$(SPL_TPL_)RTC_SUPPORT) += rtc/ obj-$(CONFIG_$(SPL_TPL_)SERIAL_SUPPORT) += serial/ -obj-$(CONFIG_$(SPL_TPL_)SPI_FLASH_SUPPORT) += mtd/spi/ obj-$(CONFIG_$(SPL_TPL_)SPI_SUPPORT) += spi/ obj-$(CONFIG_$(SPL_TPL_)TIMER) += timer/ obj-$(CONFIG_$(SPL_TPL_)VIRTIO) += virtio/ @@ -42,9 +41,6 @@ obj-$(CONFIG_SPL_POWER_SUPPORT) += power/ power/pmic/ obj-$(CONFIG_SPL_POWER_SUPPORT) += power/regulator/ obj-$(CONFIG_SPL_POWER_DOMAIN) += power/domain/ obj-$(CONFIG_SPL_DM_RESET) += reset/ -obj-$(CONFIG_SPL_MTD_SUPPORT) += mtd/ -obj-$(CONFIG_SPL_ONENAND_SUPPORT) += mtd/onenand/ -obj-$(CONFIG_SPL_UBI) += mtd/ubispl/ obj-$(CONFIG_SPL_DMA_SUPPORT) += dma/ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/phy/ @@ -102,6 +98,7 @@ obj-$(CONFIG_QE) += qe/ obj-$(CONFIG_U_QE) += qe/ obj-y += mailbox/ obj-y += memory/ +obj-y += mtd/ obj-y += pwm/ obj-y += reset/ obj-y += input/ diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 3542042245..fd4c6687cb 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -3,20 +3,40 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifneq (,$(findstring y,$(CONFIG_MTD)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND)$(CONFIG_CMD_SF)$(CONFIG_CMD_MTD))) -obj-y += mtdcore.o mtd_uboot.o +mtd-$(CONFIG_MTD) += mtdcore.o mtd_uboot.o +mtd-$(CONFIG_DM_MTD) += mtd-uclass.o +mtd-$(CONFIG_MTD_PARTITIONS) += mtdpart.o +mtd-$(CONFIG_MTD_CONCAT) += mtdconcat.o +mtd-$(CONFIG_ALTERA_QSPI) += altera_qspi.o +mtd-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o +mtd-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o +mtd-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o +mtd-$(CONFIG_MW_EEPROM) += mw_eeprom.o +mtd-$(CONFIG_FLASH_PIC32) += pic32_flash.o +mtd-$(CONFIG_ST_SMI) += st_smi.o +mtd-$(CONFIG_STM32_FLASH) += stm32_flash.o +mtd-$(CONFIG_RENESAS_RPC_HF) += renesas_rpc_hf.o + +# U-Boot build +ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) + +ifneq ($(mtd-y),) +obj-y += mtd.o endif -obj-$(CONFIG_DM_MTD) += mtd-uclass.o -obj-$(CONFIG_MTD_PARTITIONS) += mtdpart.o -obj-$(CONFIG_MTD_CONCAT) += mtdconcat.o -obj-$(CONFIG_ALTERA_QSPI) += altera_qspi.o -obj-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o -obj-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o -obj-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o -obj-$(CONFIG_MW_EEPROM) += mw_eeprom.o -obj-$(CONFIG_FLASH_PIC32) += pic32_flash.o -obj-$(CONFIG_ST_SMI) += st_smi.o -obj-$(CONFIG_STM32_FLASH) += stm32_flash.o -obj-$(CONFIG_RENESAS_RPC_HF) += renesas_rpc_hf.o - obj-y += nand/ +obj-y += onenand/ +obj-y += spi/ +obj-$(CONFIG_MTD_UBI) += ubi/ + +#SPL/TPL build +else + +ifneq ($(mtd-y),) +obj-$(CONFIG_SPL_MTD_SUPPORT) += mtd.o +endif +obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += nand/ +obj-$(CONFIG_SPL_ONENAND_SUPPORT) += onenand/ +obj-$(CONFIG_$(SPL_TPL_)SPI_FLASH_SUPPORT) += spi/ +obj-$(CONFIG_SPL_UBI) += ubispl/ + +endif diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index a358bc680e..96e186600a 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -1,5 +1,10 @@ # SPDX-License-Identifier: GPL-2.0+
+ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) nandcore-objs := core.o bbt.o obj-$(CONFIG_MTD_NAND_CORE) += nandcore.o +obj-$(CONFIG_MTD_RAW_NAND) += raw/ obj-$(CONFIG_MTD_SPI_NAND) += spi/ +else +obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += raw/ +endif
Hi Miquel,
Miquel Raynal miquel.raynal@bootlin.com wrote on Thu, 3 Oct 2019 19:50:02 +0200:
Hello,
A year ago, while working on SPI-NAND support in U-Boot, I discovered when modifying Makefiles a confusing organization where:
- Sub-directories/files are compiled from the root Makefile
- Commands are at the root of everything
First I sent a series to move Makefile entries in their respective directories. Then, I decided to continue working on the clarification of the Makefile hierarchy in MTD and I sent four iterations of this series which did not got merge at that time. Anyway, I revived this series by rebasing all my work and updating everything that needed an update.
Here are the main points of the re-organization:
- Rename CONFIG_MTD into CONFIG_DM_MTD to reserve CONFIG_MTD to what is called today CONFIG_MTD_DEVICE.
- Fix build dependencies in defconfigs, like: "UBI and NAND depend on MTD".
- Fix the Kconfig files to reflect these dependencies (as defconfigs have been updated, nothing should break).
- Simplify the Makefiles: compiling the drivers/mtd/nand/raw/ sub-directory should just depend on MTD being compiled and the NAND core as well, there is absolutely no logic to make it depend on CMD_NAND.
The New green Travis CI build for the fifth version of this series is there (yes, 53 iterations):
And here is the missing link:
https://travis-ci.org/miquelraynal/u-boot/builds/592943849
Cheers, Miquèl
Hi Jagan,
Gentle ping.
As discussed half a year ago, please do not trash this series :)
Miquel Raynal miquel.raynal@bootlin.com wrote on Thu, 3 Oct 2019 19:55:15 +0200:
Hi Miquel,
Hello,
Thanks, Miquèl
Hi Miquel,
On Mon, Oct 21, 2019 at 1:38 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Jagan,
Gentle ping.
Please give us sometime, will update accordingly.
On Mon, Oct 21, 2019 at 01:42:08PM +0530, Jagan Teki wrote:
Hi Miquel,
Hi Jagan,
Gentle ping.
Would you object to me taking this and doing the size-check build and pushing if it's no-change? Thanks!
Hi Miquel,
Hi Jagan,
Gentle ping.
Please wait till end of this weekend.
On Thu, Oct 3, 2019 at 11:20 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Hello,
Please note that the only red test fails because of timeout, not an actual error (at least I could not spot it). It is possible that this series will produce noticeable changes for the users. The only reason for that is because their configuration file was wrong. I have done my best to fix them one by one, but I am not omniscient.
Thanks, Miquèl
Note: as the number of Cc:'ed people reached 184 with get_maintainers.pl I decided to trim the list to:
- People interested by the MTD subsystem.
- A few maintainers: I had to tweak some defconfigs after more digging than with other boards (k2g, bcm11130, M54418TWR, ls104/108/208). Maintainers of these platforms are Cc:'ed.
Changes since v4:
- Rebased on top of v2019.10-rc4.
- Fixed tens of configurations that got broken since the last version of this series several months ago.
- Added a specific commit for ls104/108/208 configurations.
Changes since v3:
- As suggested by Vignesh, SPI_FLASH_MTD depends on MTD. Enforce this in Kconfig with a new patch. There is no defconfig to fix, all defconfigs with SPI_FLASH_MTD already use MTD.
- s/coherent Makefile/appropriate Makefile/ in commit title of patch 1.
- s/Kconfig/Makefile in commit message of "mtd: nand: remove dependency on commands in Kconfig" and "mtd: ubi: remove dependency on command in Kconfig".
- Add Boris R-b tags.
- Correct typos pointed by Boris.
- Remove the if/endif in cmd/Kconfig about mtdparts, let the "depends on" that was already present.
- Use an if/endif block to compile legacy-mtd-utils.c (to avoid failures when both 'sf' and 'nand' commands are compiled-in).
- Merge all Makefile changes in one consistent commit as suggested by Boris.
Changes since v2:
- Cleanup also applied to the SPL in an additional patch.
- NOR dependency on MTD extracted from the patch adding MTD dependencies on commands only to do it in a separate change.
- Typo s/copile/compile/ in "rename CONFIG_MTD_DEVICE..." commit log.
- No more MTD depencency on SPI_FLASH, only kept on SPI_FLASH_MTD.
- Same applies to the sf command.
- Avoid compiling the NAND core while it is not needed (not speaking about the raw NAND core, really what is in drivers/mtd/nand:).
- Last patch dropping CONFIG_MTD_PARTITIONS forgotten. We need them in order to reduce the final binary size.
- Additional fixes in cmd/Kconfig.
Changes since v1:
- Squashed both patches from the first series and included them in "mtd: simplify Makefiles".
- Added all other patches.
- Renamed CONFIG_NAND into CONFIG_MTD_RAW_NAND as suggested.
Miquel Raynal (26): mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NAND mtd: rename CONFIG_MTD -> CONFIG_DM_MTD mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTD mtd: ensure MTD is compiled when there is a NOR flash mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flash mtd: ensure MTD is compiled when there is a SPI NOR flash using MTD mtd: ensure UBI is compiled when using fastmap mtd: ensure MTD is compiled when UBI is used mtd: ensure UBI is compiled when CMD_UBI is selected mtd: ensure UBI is compiled when ENV_IS_IN_UBI is selected mtd: ensure MTD_RAW_NAND is compiled when ENV_IS_IN_NAND is selected mtd: ensure CMD_NAND is compiled when its options are selected mtd: ensure MTD is compiled when CMD_MTDPARTS is selected configs: move CONFIG_MTD in defconfigs when set in arch includes configs: remove raw NAND core from k2g defconfigs configs: remove MTD support from bcm11130 and M54418TWR defconfigs configs: socfpga: mcvevk: Remove useless UBI infos configs: ls104x/ls108x/ls208x: Build the raw NAND core with TFABOOT mtd: nand: add includes in NAND core to avoid warnings dfu: add dependency on the raw NAND core mtd: nor: NOR flashes depend on MTD mtd: spi: SPI_FLASH_MTD depends on MTD cmd: mtdparts: Kconfig: join mtdparts command entry with its options cmd: nand/sf: isolate legacy code cmd: make MTD commands depend on MTD mtd: Makefile: deep cleanup
Except 24/26 comments. all look fine to me.
Acked-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com # SoPine, SiFive FU540
On Thu, Oct 03, 2019 at 07:50:02PM +0200, Miquel Raynal wrote:
Hello,
OK, so I want to grab this series, and I intend to do my best to do so. But the problem this exposes is just how complex the uses of CONFIG_NAND got and in turn symbol re-use, on PowerPC. This (+ v6) showed a few minor migration problems when I size compared, and those are easily fixed. What isn't so easily fixed is that it was also changing how/where the environment is found on some PowerPC boards. Fixing that in turn requires finally finishing off the migration of the main CONFIG_ENV_xxx symbols to Kconfig. I have this done outside of about 20 boards. I'm going to get that finished up as soon as I can and posted, then make this series depend on that. Thanks again for doing the hard work here, we really need this particular migration and clean up!
Hi Tom,
Tom Rini trini@konsulko.com wrote on Wed, 30 Oct 2019 09:57:13 -0400:
Hello,
I see the problem, well, thanks for grabbing it, please keep us updated and do not hesitate if you need help.
Thanks, Miquèl
Hello,
Thanks, Miquèl
Changes since v4:
Changes since v3:
Changes since v2:
Changes since v1:
So, a feature of this series is that it exposes a problem of the following PowerPC configurations: P1022DS P1022DS_SDCARD P1022DS_SPIFLASH P1022DS_36BIT_SPIFLASH P1022DS_36BIT P1022DS_36BIT_SDCARD T4240QDS_SRIO_PCIE_BOOT T4240QDS_SDCARD T4160QDS_SECURE_BOOT T4160QDS T4240QDS T4160QDS_SDCARD T4240QDS_SECURE_BOOT B4860QDS_SECURE_BOOT T4160RDB B4420QDS B4860QDS B4860QDS_SRIO_PCIE_BOOT B4860QDS_SPIFLASH B4420QDS_SPIFLASH T4240RDB_SDCARD T4240RDB P1025RDB_SPIFLASH P1025RDB_SDCARD P1024RDB_SPIFLASH P1025RDB P1024RDB_SDCARD P1024RDB P1024RDB_36BIT P1025RDB_36BIT P5020DS_SECURE_BOOT P3041DS_SRIO_PCIE_BOOT P3041DS_SECURE_BOOT P5020DS_SDCARD P5020DS P5020DS_SRIO_PCIE_BOOT P5020DS_SPIFLASH P5040DS_SECURE_BOOT P2041RDB_SECURE_BOOT P2041RDB_SRIO_PCIE_BOOT P1021RDB-PC_SPIFLASH P1021RDB-PC P1021RDB-PC_SDCARD P1021RDB-PC_36BIT_SPIFLASH P1021RDB-PC_36BIT_SDCARD P1021RDB-PC_36BIT P1020RDB-PC_SDCARD P1020RDB-PC_SPIFLASH P1020RDB-PC P1020RDB-PC_36BIT_SPIFLASH P1020RDB-PC_36BIT_SDCARD P1020RDB-PC_36BIT P5040DS_SDCARD P3041DS_SPIFLASH P3041DS_SDCARD P5040DS P5040DS_SPIFLASH P2041RDB P2041RDB_SDCARD P2041RDB_SPIFLASH P3041DS P1020RDB-PD_SDCARD P2020RDB-PC_SPIFLASH P1020RDB-PD P2020RDB-PC P2020RDB-PC_SDCARD P1020RDB-PD_SPIFLASH P2020RDB-PC_36BIT P2020RDB-PC_36BIT_SPIFLASH P2020RDB-PC_36BIT_SDCARD C29XPCIE_NOR_SECBOOT C29XPCIE_SPIFLASH C29XPCIE_SPIFLASH_SECBOOT C29XPCIE BSC9132QDS_SDCARD_DDRCLK133_SECURE BSC9132QDS_NOR_DDRCLK133_SECURE BSC9132QDS_SDCARD_DDRCLK100_SECURE BSC9132QDS_NOR_DDRCLK100_SECURE BSC9132QDS_SPIFLASH_DDRCLK133_SECURE BSC9132QDS_SPIFLASH_DDRCLK100_SECURE BSC9132QDS_NOR_DDRCLK100 BSC9132QDS_SPIFLASH_DDRCLK133 BSC9132QDS_NAND_DDRCLK133_SECURE BSC9132QDS_NOR_DDRCLK133 BSC9132QDS_SDCARD_DDRCLK100 BSC9132QDS_SPIFLASH_DDRCLK100 BSC9132QDS_NAND_DDRCLK100_SECURE BSC9132QDS_SDCARD_DDRCLK133 P1010RDB-PA_SPIFLASH_SECBOOT P1010RDB-PA_NAND_SECBOOT P1010RDB-PA_SPIFLASH P1010RDB-PA_NOR P1010RDB-PA_SDCARD BSC9131RDB_SPIFLASH_SYSCLK100 BSC9131RDB_SPIFLASH P1010RDB-PA_36BIT_SPIFLASH P1010RDB-PA_36BIT_NOR_SECBOOT P1010RDB-PA_36BIT_NOR_SECBOOT P1010RDB-PA_36BIT_SPIFLASH_SECBOOT P1010RDB-PA_36BIT_SDCARD P1010RDB-PA_36BIT_NAND_SECBOOT T2081QDS_SRIO_PCIE_BOOT T2080RDB_SRIO_PCIE_BOOT T1024QDS_DDR4 T2081QDS T1042RDB T1040RDB_SDCARD T1040RDB T2081QDS_SPIFLASH T1042RDB_PI_SDCARD T1042D4RDB_SECURE_BOOT T1023RDB_SECURE_BOOT T1023RDB T1040RDB_SPIFLASH T1040D4RDB_SDCARD T1023RDB_SDCARD T1042RDB_PI T1040D4RDB T2081QDS_SDCARD T2080RDB_SECURE_BOOT T1042RDB_PI_SPIFLASH T1023RDB_SPIFLASH T1040D4RDB_SPIFLASH T1040QDS_SECURE_BOOT T1040QDS T1024QDS_DDR4_SECURE_BOOT T1040QDS_DDR4 T1024QDS_SDCARD T1024QDS T1024QDS_SECURE_BOOT T1024RDB_SECURE_BOOT T1040D4RDB_SECURE_BOOT T1040RDB_SECURE_BOOT T1042RDB_SECURE_BOOT T1024QDS_SPIFLASH T2080QDS_SRIO_PCIE_BOOT P1010RDB-PB_SPIFLASH_SECBOOT P1010RDB-PB_NOR_SECBOOT P1010RDB-PB_SDCARD P1010RDB-PB_NAND_SECBOOT P1010RDB-PB_SPIFLASH P1010RDB-PB_NOR P1010RDB-PB_36BIT_NOR P1010RDB-PB_36BIT_NAND_SECBOOT P1010RDB-PB_36BIT_SPIFLASH_SECBOOT P1010RDB-PB_36BIT_SDCARD P1010RDB-PB_36BIT_NOR_SECBOOT P1010RDB-PB_36BIT_SPIFLASH T2080QDS_SECURE_BOOT T1042D4RDB T1042D4RDB_SDCARD T2080RDB_SDCARD T2080RDB T1042D4RDB_SPIFLASH T2080RDB_SPIFLASH T1024RDB_SDCARD T1024RDB T1024RDB_SPIFLASH T2080QDS_SDCARD T2080QDS_SPIFLASH T2080QDS P1010RDB-PA_NOR_SECBOOT
And that is that before this series they do not fully enable NAND support normally but do enable it partially and do enable CMD_NAND. After this series they do not enable CMD_NAND. This is because if I do enable CMD_NAND instead we see a large number of other changes wrt things such as CONFIG_SYS_AMASK0/CONFIG_SYS_AMASK1 and change those configs from pointing at NOR to pointing at NAND and that seems the larger functional regression over removing the nand command. If the NAND command really should be on in these boards then we do need to figure out or otherwise rework the config files such that the rest of the board functions the intended way still.
Also note that while there are a few *_NAND_* configs in that list, investigation of the u-boot.cfg files shows that enabling CONFIG_MTD_RAW_NAND (formerly CONFIG_NAND) leads to the other functional changes noted above. My assumption currently is that those *_NAND_* boards above have a latent bug that is now exposed.
Jagan Teki
Miquel Raynal
Wolfgang Grandegger
