[U-Boot] [PATCH V3 0/6] mxc_spi refactoring (for mx6q and mx6qsabrelite)
This patch set refactors mxc_spi as described in http://lists.denx.de/pipermail/u-boot/2010-March/068791.html and requested in http://lists.denx.de/pipermail/u-boot/2012-January/116023.html in order to add support for the MX6Q in general and the mx6qsabrelite specifically.
Patch 1 simply moves the conditional parts of mxc_spi.c into the respective CPU-specific imx-regs.h files.
Patch 2 adds general support for SPI to the i.MX6.
Patch 3 adds support to the mx6qsabrelite board
Patch 4 modifies the 'sf' command to allow a default chip-select to be specified by board headers as is done on efika et al. This allows a bare 'sf' probe command: U-Boot> sf probe instead of the more cumbersome usage when a GPIO is tacked onto the chip-select. Otherwise, this command-line would be needed to specify GP3:19 on SabreLite: U-Boot> sf probe 0x5300
Patch 5 adds default chip-select values for mx6qsabrelite platform.
Patch 6 adds reference macros for use in storing the environment in serial flash to match the use on Freescale's U-Boot release
This patch set has been compiled against the following configurations, but only tested on mx6qsabrelite: mx6qsabrelite mx51evk mx31pdk mx35pdk
Move (E)CSPI register declarations into the imx-regs.h files for each supported CPU
Introduce two new macros to control conditional setup MXC_CSPI - Used for processors with the Configurable Serial Peripheral Interface (MX3x) MXC_ECSPI - For processors with Enhanced Configurable... (MX5x, MX6x)
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com Acked-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx31/imx-regs.h | 27 ++++++++ arch/arm/include/asm/arch-mx35/imx-regs.h | 25 ++++++++ arch/arm/include/asm/arch-mx5/imx-regs.h | 30 +++++++++ drivers/spi/mxc_spi.c | 93 ++--------------------------- 4 files changed, 88 insertions(+), 87 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h index 6a517dd..70e3338 100644 --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -890,4 +890,31 @@ struct esdc_regs { #define MXC_EHCI_IPPUE_DOWN (1 << 8) #define MXC_EHCI_IPPUE_UP (1 << 9)
+/* + * CSPI register definitions + */ +#define MXC_CSPI +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_SMC (1 << 3) +#define MXC_CSPICTRL_POL (1 << 4) +#define MXC_CSPICTRL_PHA (1 << 5) +#define MXC_CSPICTRL_SSCTL (1 << 6) +#define MXC_CSPICTRL_SSPOL (1 << 7) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 24) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0x1f) << 8) +#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) +#define MXC_CSPICTRL_TC (1 << 8) +#define MXC_CSPICTRL_RXOVF (1 << 6) +#define MXC_CSPICTRL_MAXBITS 0x1f + +#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 4 + +#define MXC_SPI_BASE_ADDRESSES \ + 0x43fa4000, \ + 0x50010000, \ + 0x53f84000, + #endif /* __ASM_ARCH_MX31_IMX_REGS_H */ diff --git a/arch/arm/include/asm/arch-mx35/imx-regs.h b/arch/arm/include/asm/arch-mx35/imx-regs.h index df74508..e570ad1 100644 --- a/arch/arm/include/asm/arch-mx35/imx-regs.h +++ b/arch/arm/include/asm/arch-mx35/imx-regs.h @@ -179,6 +179,31 @@ #define IPU_CONF_IC_EN (1<<1) #define IPU_CONF_SCI_EN (1<<0)
+/* + * CSPI register definitions + */ +#define MXC_CSPI +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_SMC (1 << 3) +#define MXC_CSPICTRL_POL (1 << 4) +#define MXC_CSPICTRL_PHA (1 << 5) +#define MXC_CSPICTRL_SSCTL (1 << 6) +#define MXC_CSPICTRL_SSPOL (1 << 7) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) +#define MXC_CSPICTRL_TC (1 << 7) +#define MXC_CSPICTRL_RXOVF (1 << 6) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 4 + +#define MXC_SPI_BASE_ADDRESSES \ + 0x43fa4000, \ + 0x50010000, + #define GPIO_PORT_NUM 3 #define GPIO_NUM_PIN 32
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 0ee88d2..4fa6658 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -223,6 +223,36 @@ #define CS0_32M_CS1_32M_CS2_32M_CS3_32M 3
/* + * CSPI register definitions + */ +#define MXC_ECSPI +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) +#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) +#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPICTRL_TC (1 << 7) +#define MXC_CSPICTRL_RXOVF (1 << 6) +#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 32 + +/* Bit position inside CTRL register to be associated with SS */ +#define MXC_CSPICTRL_CHAN 18 + +/* Bit position inside CON register to be associated with SS */ +#define MXC_CSPICON_POL 4 +#define MXC_CSPICON_PHA 0 +#define MXC_CSPICON_SSPOL 12 +#define MXC_SPI_BASE_ADDRESSES \ + CSPI1_BASE_ADDR, \ + CSPI2_BASE_ADDR, \ + CSPI3_BASE_ADDR, + +/* * Number of GPIO pins per port */ #define GPIO_NUM_PIN 32 diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 2fa7486..2e15318 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -33,93 +33,12 @@
#error "i.MX27 CSPI not supported due to drastic differences in register definitions" \ "See linux mxc_spi driver from Freescale for details." - -#elif defined(CONFIG_MX31) - -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_SMC (1 << 3) -#define MXC_CSPICTRL_POL (1 << 4) -#define MXC_CSPICTRL_PHA (1 << 5) -#define MXC_CSPICTRL_SSCTL (1 << 6) -#define MXC_CSPICTRL_SSPOL (1 << 7) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 24) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0x1f) << 8) -#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) -#define MXC_CSPICTRL_TC (1 << 8) -#define MXC_CSPICTRL_RXOVF (1 << 6) -#define MXC_CSPICTRL_MAXBITS 0x1f - -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 4 - -static unsigned long spi_bases[] = { - 0x43fa4000, - 0x50010000, - 0x53f84000, -}; - -#elif defined(CONFIG_MX51) - -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) -#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) -#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) -#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) -#define MXC_CSPICTRL_MAXBITS 0xfff -#define MXC_CSPICTRL_TC (1 << 7) -#define MXC_CSPICTRL_RXOVF (1 << 6) - -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 32 - -/* Bit position inside CTRL register to be associated with SS */ -#define MXC_CSPICTRL_CHAN 18 - -/* Bit position inside CON register to be associated with SS */ -#define MXC_CSPICON_POL 4 -#define MXC_CSPICON_PHA 0 -#define MXC_CSPICON_SSPOL 12 - -static unsigned long spi_bases[] = { - CSPI1_BASE_ADDR, - CSPI2_BASE_ADDR, - CSPI3_BASE_ADDR, -}; - -#elif defined(CONFIG_MX35) - -#define MXC_CSPICTRL_EN (1 << 0) -#define MXC_CSPICTRL_MODE (1 << 1) -#define MXC_CSPICTRL_XCH (1 << 2) -#define MXC_CSPICTRL_SMC (1 << 3) -#define MXC_CSPICTRL_POL (1 << 4) -#define MXC_CSPICTRL_PHA (1 << 5) -#define MXC_CSPICTRL_SSCTL (1 << 6) -#define MXC_CSPICTRL_SSPOL (1 << 7) -#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) -#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) -#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) -#define MXC_CSPICTRL_TC (1 << 7) -#define MXC_CSPICTRL_RXOVF (1 << 6) -#define MXC_CSPICTRL_MAXBITS 0xfff - -#define MXC_CSPIPERIOD_32KHZ (1 << 15) -#define MAX_SPI_BYTES 4 +#endif
static unsigned long spi_bases[] = { - 0x43fa4000, - 0x50010000, + MXC_SPI_BASE_ADDRESSES };
-#else -#error "Unsupported architecture" -#endif - #define OUT MXC_GPIO_DIRECTION_OUT
#define reg_read readl @@ -129,7 +48,7 @@ struct mxc_spi_slave { struct spi_slave slave; unsigned long base; u32 ctrl_reg; -#if defined(CONFIG_MX51) +#if defined(MXC_ECSPI) u32 cfg_reg; #endif int gpio; @@ -167,7 +86,7 @@ u32 get_cspi_div(u32 div) return i; }
-#if defined(CONFIG_MX31) || defined(CONFIG_MX35) +#ifdef MXC_CSPI static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, unsigned int max_hz, unsigned int mode) { @@ -204,7 +123,7 @@ static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, } #endif
-#if defined(CONFIG_MX51) +#ifdef MXC_ECSPI static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, unsigned int max_hz, unsigned int mode) { @@ -316,7 +235,7 @@ int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, MXC_CSPICTRL_BITCOUNT(bitlen - 1);
reg_write(®s->ctrl, mxcs->ctrl_reg | MXC_CSPICTRL_EN); -#ifdef CONFIG_MX51 +#ifdef MXC_ECSPI reg_write(®s->cfg, mxcs->cfg_reg); #endif
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com Acked-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx6/imx-regs.h | 44 ++++++++++++++++++++++++++++++ 1 files changed, 44 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 7650cb9..00040c4 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -190,6 +190,50 @@ struct src { u32 gpr10; };
+/* ECSPI registers */ +struct cspi_regs { + u32 rxdata; + u32 txdata; + u32 ctrl; + u32 cfg; + u32 intr; + u32 dma; + u32 stat; + u32 period; +}; + +/* + * CSPI register definitions + */ +#define MXC_ECSPI +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) +#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) +#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPICTRL_TC (1 << 7) +#define MXC_CSPICTRL_RXOVF (1 << 6) +#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 32 + +/* Bit position inside CTRL register to be associated with SS */ +#define MXC_CSPICTRL_CHAN 18 + +/* Bit position inside CON register to be associated with SS */ +#define MXC_CSPICON_POL 4 +#define MXC_CSPICON_PHA 0 +#define MXC_CSPICON_SSPOL 12 +#define MXC_SPI_BASE_ADDRESSES \ + ECSPI1_BASE_ADDR, \ + ECSPI2_BASE_ADDR, \ + ECSPI3_BASE_ADDR, \ + ECSPI4_BASE_ADDR, \ + ECSPI5_BASE_ADDR + struct iim_regs { u32 ctrl; u32 ctrl_set;
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com Acked-by: Stefano Babic sbabic@denx.de --- board/freescale/mx6qsabrelite/imximage.cfg | 2 +- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 25 +++++++++++++++++++++++++ include/configs/mx6qsabrelite.h | 9 +++++++++ 3 files changed, 35 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mx6qsabrelite/imximage.cfg b/board/freescale/mx6qsabrelite/imximage.cfg index b4ff010..fa40bff 100644 --- a/board/freescale/mx6qsabrelite/imximage.cfg +++ b/board/freescale/mx6qsabrelite/imximage.cfg @@ -156,7 +156,7 @@ DATA 4 0x021b0404 0x00011006
# set the default clock gate to save power DATA 4 0x020c4068 0x00C03F3F -DATA 4 0x020c406c 0x0030FC00 +DATA 4 0x020c406c 0x0030FC03 DATA 4 0x020c4070 0x0FFFC000 DATA 4 0x020c4074 0x3FF00000 DATA 4 0x020c4078 0x00FFF300 diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index a0b648f..2ba6b0c 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -46,6 +46,10 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
+#define SPI_PAD_CTRL (PAD_CTL_HYS | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + int dram_init(void) { gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); @@ -193,6 +197,23 @@ int board_mmc_init(bd_t *bis) } #endif
+#ifdef CONFIG_MXC_SPI +iomux_v3_cfg_t ecspi1_pads[] = { + /* SS1 */ + MX6Q_PAD_EIM_D19__GPIO_3_19 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6Q_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6Q_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6Q_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), +}; + +void setup_spi(void) +{ + gpio_direction_output(IMX_GPIO_NR(3, 19), 1); + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, + ARRAY_SIZE(ecspi1_pads)); +} +#endif + #define MII_1000BASET_CTRL 0x9 #define MII_EXTENDED_CTRL 0xb #define MII_EXTENDED_DATAW 0xc @@ -250,6 +271,10 @@ int board_early_init_f(void) { setup_iomux_uart();
+#ifdef CONFIG_MXC_SPI + setup_spi(); +#endif + return 0; }
diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 034fc40..8dd6e39 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -44,6 +44,15 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE
+#define CONFIG_CMD_SF +#ifdef CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SST +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_SPEED 25000000 +#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) +#endif + /* MMC Configs */ #define CONFIG_FSL_ESDHC #define CONFIG_FSL_USDHC
This patch allows a board configuration file to provide a default chip-select for serial flash so that first argument to the 'sf' command is optional.
On boards that use the mxc_spi driver and a GPIO for chip select, this allows a much simpler command line: U-Boot> sf probe instead of U-Boot> sf probe 0x5300
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com Acked-by: Stefano Babic sbabic@denx.de --- common/cmd_sf.c | 34 +++++++++++++++++++++++----------- 1 files changed, 23 insertions(+), 11 deletions(-)
diff --git a/common/cmd_sf.c b/common/cmd_sf.c index 7225656..4b32171 100644 --- a/common/cmd_sf.c +++ b/common/cmd_sf.c @@ -70,20 +70,28 @@ static int do_spi_flash_probe(int argc, char * const argv[]) char *endp; struct spi_flash *new;
- if (argc < 2) - return -1; - - cs = simple_strtoul(argv[1], &endp, 0); - if (*argv[1] == 0 || (*endp != 0 && *endp != ':')) +#ifndef CONFIG_SPI_FLASH_CS + if (argc < 2) { + printf("%s: missing arguments\n", __func__); return -1; - if (*endp == ':') { - if (endp[1] == 0) - return -1; + } +#else + cs = CONFIG_SPI_FLASH_CS ; +#endif
- bus = cs; - cs = simple_strtoul(endp + 1, &endp, 0); - if (*endp != 0) + if (argc >= 2) { + cs = simple_strtoul(argv[1], &endp, 0); + if (*argv[1] == 0 || (*endp != 0 && *endp != ':')) return -1; + if (*endp == ':') { + if (endp[1] == 0) + return -1; + + bus = cs; + cs = simple_strtoul(endp + 1, &endp, 0); + if (*endp != 0) + return -1; + } }
if (argc >= 3) { @@ -299,7 +307,11 @@ usage: U_BOOT_CMD( sf, 5, 1, do_spi_flash, "SPI flash sub-system", +#ifndef CONFIG_SPI_FLASH_CS "probe [bus:]cs [hz] [mode] - init flash device on given SPI bus\n" +#else + "probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus\n" +#endif " and chip select\n" "sf read addr offset len - read `len' bytes starting at\n" " `offset' to memory at `addr'\n"
Acked-by: Fabio Estevam fabio.estevam@freescale.com
NAK (to this version of the patch): missing README update, and other issues below
- if (argc < 2) {
return -1;printf("%s: missing arguments\n", __func__);
return cmd_usage(cmdtp);
if (endp[1] == 0)
return -1;
+#else
- cs = CONFIG_SPI_FLASH_CS ;
you're setting the default CS, not locking it in. so a better config knob name would be something like: CONFIG_SF_DEFAULT_CS this matches the existing CONFIG_SF_XXX defines
also, you have a spurious space before the semicolon there
- "probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus\n"
this is ugly. i'd rather just omit it and not worry about the syntax being perfect. -mike
Which README? The only references I find to serial flash support are in board-specific README files.
~/u-boot$ find . -iname *readme* | xargs grep -w sf ./doc/README.p2041rdb: => sf erase 0 100000 ./doc/README.p2041rdb: => sf write 1000000 0 $filesize ./doc/README.p2041rdb: => sf erase 110000 10000 ./doc/README.p2041rdb: => sf write 1000000 110000 $filesize ./doc/README.sh7757lcr: => sf probe 0 ./doc/README.sh7757lcr: => sf erase 0 80000 ./doc/README.sh7757lcr: => sf write 0x89000000 0 80000
I can start one of those for the SabreLite board, but that's un-related to this patch.
- if (argc< 2) {
if (endp[1] == 0)
return -1;
+#else
Thanks Mike,
FWIW, I chose this name on purpose to make life easier on a couple of other boards immediately (efika and vision2):
~/u-boot$ grep CONFIG_SPI_FLASH_CS include/configs/* include/configs/efikamx.h:#define CONFIG_SPI_FLASH_CS (1 | 121 << 8) include/configs/m28evk.h:#define CONFIG_SPI_FLASH_CS 2 include/configs/mx6qsabrelite.h.rej: #define CONFIG_SPI_FLASH_CS 1 include/configs/vision2.h:#define CONFIG_SPI_FLASH_CS (1 | (121 << 8))
Works for me.
instead of
all new CONFIG_xxx defines should be documented in the top level README. granted, the existin SF ones have slipped in without being documented, but that's bad for them ;).
if (endp[1] == 0)
return -1;
+#else
Thanks Mike,
those boards are dumb -- that define isn't used anywhere, so that's just dead code. cmd_sf has a standard already, so new defines specific to cmd_sf should follow that. -mike
instead of
Ok. I'll re-send with README updates.
if (endp[1] == 0)
return -1;
+#else
Thanks Mike,
Ok. I'll let their maintainers update appropriately.
Hi Eric,
please see my comments below.
- if (argc < 2)
return -1;
- if (argc < 2) {
I think this format for the error message is a little bit untypical for u-boot. We do not show up the internal C function name. Better would be to show the command usage, right?
return -1;
if (endp[1] == 0)
return -1;
+#else
Other options for the spi flash subsystem are called CONFIG_SF_DEFAULT_MODE|SPEED. It think it make sense to call this CONFIG_SF_DEFAULT_CS and CONFIG_SF_DEFAULT_BUS (see below).
bus = cs;
if (*endp != 0)
if (argc >= 2) {
if (*endp == ':') {
if (endp[1] == 0)
return -1;
bus = cs;
if (*endp != 0)
return -1;
if (argc >= 3) {
Can you also add a config option for the SPI bus number? I think these two need to handled in the same patch.
So you could add this stuff:
diff --git a/common/cmd_sf.c b/common/cmd_sf.c index 9e97c8e..fa4312a 100644 --- a/common/cmd_sf.c +++ b/common/cmd_sf.c @@ -63,7 +63,11 @@ static int sf_parse_len_arg(char *arg, ulong *len)
static int do_spi_flash_probe(int argc, char * const argv[]) { +#ifdef CONFIG_SF_DEFAULT_BUS + unsigned int bus = CONFIG_SF_DEFAULT_BUS; +#else unsigned int bus = 0; +#endif unsigned int cs; unsigned int speed = CONFIG_SF_DEFAULT_SPEED; unsigned int mode = CONFIG_SF_DEFAULT_MODE;
Matthias
move the default logic to the top of the file like the existing CONFIG_SF_DEFAULT_SPEED, then the code later on only needs to do: unsigned int bus = CONFIG_SF_DEFAULT_BUS;
otherwise, this suggestion sounds good too -mike
On 01/25/2012 08:10 AM, Matthias Fuchs wrote:
Hi Eric,
Signed-off-by: Eric Nelsoneric.nelson@boundarydevices.com Acked-by: Dirk Behmedirk.behme@de.bosch.com Acked-by: Stefano Babicsbabic@denx.de
- if (argc< 2)
return -1;
- cs = simple_strtoul(argv[1],&endp, 0);
- if (*argv[1] == 0 || (*endp != 0&& *endp != ':'))
- if (argc< 2) {
Looking at this area of the code in more detail, there are quite a few cases where improper usage silently return -1.
I'm inclined to either follow that lead or toss them together with a "goto usage" as done in do_spi_flash().
Any preferences?
return -1;
if (endp[1] == 0)
return -1;
+#else
See include/configs/efikamx.h (reference to unused symbol CONFIG_SPI_FLASH_CS).
bus = cs;
cs = simple_strtoul(endp + 1,&endp, 0);
if (*endp != 0)
if (argc>= 2) {
if (*argv[1] == 0 || (*endp != 0&& *endp != ':')) return -1;
if (*endp == ':') {
if (endp[1] == 0)
return -1;
bus = cs;
if (*endp != 0)
return -1;
if (argc>= 3) {
Can do.
- if (argc< 2)
return -1;
- if (argc< 2) {
Any preferences?
invalid syntax should return cmd_usage(). errors should return non-zero, not usage information. -mike
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com Acked-by: Stefano Babic sbabic@denx.de --- include/configs/mx6qsabrelite.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 8dd6e39..e34f108 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -46,6 +46,7 @@
#define CONFIG_CMD_SF #ifdef CONFIG_CMD_SF +#define CONFIG_SPI_FLASH_CS 0x5300 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_SST #define CONFIG_MXC_SPI
The default settings store the persistent environment on SD card and not serial flash (SPI NOR).
To use SPI NOR to save the environment instead of SD card, edit include/configs/mx6qsabrelite.h and
- undefine CONFIG_ENV_IS_IN_MMC - define CONFIG_ENV_IS_IN_SPI_FLASH
The SPI driver can take as chip select the controller's chip selects as well as an external GPIO. The LSB byte has the value of the internal chip select, the highest (thought as 16-bit value) contains the GPIO number.
The GPIO used on Sabre Lite is GP3:19 == 83.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com --- include/configs/mx6qsabrelite.h | 12 +++++++++++- 1 files changed, 11 insertions(+), 1 deletions(-)
diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index e34f108..024a94c 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -174,10 +174,20 @@ /* FLASH and environment organization */ #define CONFIG_SYS_NO_FLASH
-#define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) + #define CONFIG_ENV_IS_IN_MMC +/* #define CONFIG_ENV_IS_IN_SPI_FLASH */ + +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#define CONFIG_ENV_OFFSET (768 * 1024) +#define CONFIG_ENV_SECT_SIZE (8 * 1024) +#define CONFIG_ENV_SPI_CS 0x5300 +#define CONFIG_ENV_SPI_MODE SPI_MODE_0 +#endif
#define CONFIG_OF_LIBFDT
Eric Nelson
Fabio Estevam
Matthias Fuchs
Mike Frysinger
