[U-Boot] [PATCH] imx: iomux-v3: fix UART input selects
Several UART input selects are missing. The fourth input select for UART2_TX_DATA_ALT0 is actually also missing in the documentation. (at least in Rev. B of the i.MX 7Dual Reference Manual). However, when looking at the tables of other input selects, it is very natural that there must be an input select for the UART2_TX_DATA_ALT0 pad. The Colibri iMX7 also uses that pad for UART2 RX (in DTE mode), and it was required to set that particular input select register to get a working UART2. --- arch/arm/include/asm/arch-mx7/mx7d_pins.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx7/mx7d_pins.h b/arch/arm/include/asm/arch-mx7/mx7d_pins.h index d8b4097..0ab1246 100644 --- a/arch/arm/include/asm/arch-mx7/mx7d_pins.h +++ b/arch/arm/include/asm/arch-mx7/mx7d_pins.h @@ -635,7 +635,7 @@ enum { MX7D_PAD_LCD_DATA23__GPIO3_IO28 = IOMUX_PAD(0x0394, 0x0124, 5, 0x0000, 0, 0), MX7D_PAD_LCD_DATA23__I2C4_SDA = IOMUX_PAD(0x0394, 0x0124, IOMUX_CONFIG_SION | 6, 0x05F0, 1, 0),
- MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX = IOMUX_PAD(0x0398, 0x0128, 0, 0x0000, 0, 0), + MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX = IOMUX_PAD(0x0398, 0x0128, 0, 0x06F4, 0, 0),
MX7D_PAD_UART1_RX_DATA__UART1_DTE_TX = IOMUX_PAD(0x0398, 0x0128, 0, 0x0000, 0, 0), MX7D_PAD_UART1_RX_DATA__I2C1_SCL = IOMUX_PAD(0x0398, 0x0128, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0), @@ -655,7 +655,7 @@ enum { MX7D_PAD_UART1_TX_DATA__GPIO4_IO1 = IOMUX_PAD(0x039C, 0x012C, 5, 0x0000, 0, 0), MX7D_PAD_UART1_TX_DATA__ENET1_MDC = IOMUX_PAD(0x039C, 0x012C, 6, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__UART2_DCE_RX = IOMUX_PAD(0x03A0, 0x0130, 0, 0x0000, 0, 0), + MX7D_PAD_UART2_RX_DATA__UART2_DCE_RX = IOMUX_PAD(0x03A0, 0x0130, 0, 0x06FC, 2, 0),
MX7D_PAD_UART2_RX_DATA__UART2_DTE_TX = IOMUX_PAD(0x03A0, 0x0130, 0, 0x0000, 0, 0), MX7D_PAD_UART2_RX_DATA__I2C2_SCL = IOMUX_PAD(0x03A0, 0x0130, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0), @@ -667,7 +667,7 @@ enum {
MX7D_PAD_UART2_TX_DATA__UART2_DCE_TX = IOMUX_PAD(0x03A4, 0x0134, 0, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX = IOMUX_PAD(0x03A4, 0x0134, 0, 0x0000, 0, 0), + MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX = IOMUX_PAD(0x03A4, 0x0134, 0, 0x06FC, 3, 0), MX7D_PAD_UART2_TX_DATA__I2C2_SDA = IOMUX_PAD(0x03A4, 0x0134, IOMUX_CONFIG_SION | 1, 0x05E0, 0, 0), MX7D_PAD_UART2_TX_DATA__SAI3_RX_DATA0 = IOMUX_PAD(0x03A4, 0x0134, 2, 0x06C8, 0, 0), MX7D_PAD_UART2_TX_DATA__ECSPI1_RDY = IOMUX_PAD(0x03A4, 0x0134, 3, 0x0000, 0, 0), @@ -695,7 +695,7 @@ enum { MX7D_PAD_UART3_TX_DATA__GPIO4_IO5 = IOMUX_PAD(0x03AC, 0x013C, 5, 0x0000, 0, 0), MX7D_PAD_UART3_TX_DATA__SD2_LCTL = IOMUX_PAD(0x03AC, 0x013C, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__UART3_DCE_RTS = IOMUX_PAD(0x03B0, 0x0140, 0, 0x0000, 0, 0), + MX7D_PAD_UART3_RTS_B__UART3_DCE_RTS = IOMUX_PAD(0x03B0, 0x0140, 0, 0x0700, 2, 0),
MX7D_PAD_UART3_RTS_B__UART3_DTE_CTS = IOMUX_PAD(0x03B0, 0x0140, 0, 0x0000, 0, 0), MX7D_PAD_UART3_RTS_B__USB_OTG2_OC = IOMUX_PAD(0x03B0, 0x0140, 1, 0x0000, 0, 0),
Hi Stefan,
- MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX = IOMUX_PAD(0x03A4, 0x0134, 0, 0x06FC, 3, 0), MX7D_PAD_UART2_TX_DATA__I2C2_SDA = IOMUX_PAD(0x03A4, 0x0134, IOMUX_CONFIG_SION | 1, 0x05E0, 0, 0), MX7D_PAD_UART2_TX_DATA__SAI3_RX_DATA0 = IOMUX_PAD(0x03A4, 0x0134, 2, 0x06C8, 0, 0), MX7D_PAD_UART2_TX_DATA__ECSPI1_RDY = IOMUX_PAD(0x03A4, 0x0134, 3, 0x0000, 0, 0),
Applied to -next, thanks !
Best regards, Stefano Babic
Stefan Agner
Stefano Babic
