[U-Boot] [RFC] efi_loader: Handle 32-bit memory overflows
jetson-tk1 has 2 GB of RAM at 0x80000000, causing gd->ram_top to be zero. Handle this by replacing it with 0x100000000 in that case.
Cc: Alexander Graf agraf@suse.de Signed-off-by: Andreas Färber afaerber@suse.de --- lib/efi_loader/efi_memory.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 138736f..7b87108 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -225,7 +225,7 @@ efi_status_t efi_allocate_pages(int type, int memory_type, switch (type) { case 0: /* Any page */ - addr = efi_find_free_memory(len, gd->ram_top); + addr = efi_find_free_memory(len, gd->ram_top == 0 ? 0x100000000ull : gd->ram_top); if (!addr) { r = EFI_NOT_FOUND; break; @@ -343,7 +343,7 @@ int efi_memory_init(void)
/* Add U-Boot */ uboot_start = (gd->start_addr_sp - uboot_stack_size) & ~EFI_PAGE_MASK; - uboot_pages = (gd->ram_top - uboot_start) >> EFI_PAGE_SHIFT; + uboot_pages = ((gd->ram_top == 0 ? 0x100000000ull : gd->ram_top) - uboot_start) >> EFI_PAGE_SHIFT; efi_add_memory_map(uboot_start, uboot_pages, EFI_LOADER_DATA, false);
/* Add Runtime Services */
Am 13.04.2016 um 05:24 schrieb Andreas Färber afaerber@suse.de:
Nice catch!
Couldn't we just use gd->ram_top - 1? Then we underflow to 0xffffffff and everything should just work.
- uboot_pages = ((gd->ram_top == 0 ? 0x100000000ull : gd->ram_top) - uboot_start) >> EFI_PAGE_SHIFT;
Are you sure this hunk is necessary? We should already underflow to the correct value here.
Alex
2.6.6
Am 13.04.2016 um 07:50 schrieb Alexander Graf:
Nice catch!
If we do use a constant, we should probably be using UINT64_C(0x100000000) rather than ull for compatibility.
Hm, that does work in my testing. Is it guaranteed it will handle that as unsigned long rather than uint64_t? And did you mean to always use it that way or just in the zero case? I.e., might we be wasting one byte in the non-zero case or is it guaranteed that the top of RAM is always reserved?
I was wondering whether we might run into the same overflow problem on aarch64, in which case my hunk would be wrong, but your -1 should work.
Positive that _something_ here is necessary for sanity, it was using a huge number of pages (uboot_start is uint64_t).
If we use an odd number like -1, then we probably should add EFI_PAGE_MASK as done for the RAM for the non-zero case, shouldn't we? That might overflow on aarch64 though...
2.6.6
Thanks, Andreas
Nice catch!
Top of RAM is where U-Boot lives, so it's always reserved anyways :).
I'm not aware of an aarch64 implementation (or even spec) that would allow for 64bit physical address space, so we're safe on aarch64. But I like the -1 better, since it just completely negates any overflow.
Ok, so the fix would be to change uboot_start to unsigned long to have the same type as gd->ram_top.
Since we shift afterwards we don't need to mask anything. Bits that we would mask away are already gone after the shift ;).
Does the patch below work?
Alex
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index df99585..71a3d19 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -220,7 +220,7 @@ efi_status_t efi_allocate_pages(int type, int memory_type, switch (type) { case 0: /* Any page */ - addr = efi_find_free_memory(len, gd->ram_top); + addr = efi_find_free_memory(len, gd->start_addr_sp); if (!addr) { r = EFI_NOT_FOUND; break; @@ -320,9 +320,9 @@ efi_status_t efi_get_memory_map(unsigned long *memory_map_size,
int efi_memory_init(void) { - uint64_t runtime_start, runtime_end, runtime_pages; - uint64_t uboot_start, uboot_pages; - uint64_t uboot_stack_size = 16 * 1024 * 1024; + unsigned long runtime_start, runtime_end, runtime_pages; + unsigned long uboot_start, uboot_pages; + unsigned long uboot_stack_size = 16 * 1024 * 1024; int i;
/* Add RAM */
Alexander Graf
Andreas Färber
