[PATCH v1 00/16] arm: xea: Update i.MX28 XEA board to use DM_SERIAL
This patch series fixes i.MX28 based XEA board to utilize DM_SERIAL
Changes: - Patches 1-3 - fix DTS (after Linux update) to debrick XEA - Patches 4-8 - prepare XEA's DTS to support DM_SERIAL - Patches 9-11 - fixes serial_pl01x.c driver (as this driver is used by XEA, I would prefer to have this in a single patchset - otherwise board may be bricked - Patches 12-14 - XEA and imx28 generic code fixes to support DM_SERIAL with OF_PLATDATA - Patches 15-16 - config modification to support DM_SERIAL
CI: https://dev.azure.com/lukma633/U-Boot/_build/results?buildId=44&view=res...
Applied on top of u-boot/master branch SHA1: 6e1852ca2c418e2536ead4b51c4d84a59926b3f1
Lukasz Majewski (16): dts: xea: Delete not used in u-boot DTS nodes dts: xea: Provide missing FEC required properties (mac0 and reg_fec_3v3) defconfig: xea: Change default spi-nor memory bus to 2 spl: xea: Provide stub DM driver for imx28 clocks dts: xea: Enable debug UART support in XEA's SPL (DM_SERIAL) dts: xea: Add u-boot specific 'type' property to duart dts: xea: Remove clocks property from debug UART on XEA dts: xea: Disable 'clks' node for xea (imx287) serial: pl01x: Change OF_CONTROL to OF_REAL serial: pl01x: Prepare the driver to support SPL_OF_PLATDATA serial: pl01x: Modify pending callback to test if transmit FIFO is empty arm: mxs: Prevent serial console init when in very early SPL boot code arm: xea: Call spl_early_init() before DM serial console is enabled in SPL arm: Kconfig: Switch XEA (imx287 based) board to use CONFIG_PL01X_SERIAL config: xea: Enable DM_SERIAL for the XEA (imx287 based) board config: xea: Enable DM_SERIAL for the XEA - single binary (SB) u-boot
arch/arm/Kconfig | 2 +- arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 6 ++-- arch/arm/dts/imx28-xea-u-boot.dtsi | 45 +++++++++++++++++++++++++ arch/arm/mach-imx/mxs/Kconfig | 1 + board/liebherr/xea/xea.c | 20 ++++++++++- configs/imx28_xea_defconfig | 5 +-- configs/imx28_xea_sb_defconfig | 2 ++ drivers/serial/serial_pl01x.c | 16 +++++++-- include/dm/platform_data/serial_pl01x.h | 4 +++ 9 files changed, 93 insertions(+), 8 deletions(-)
After the re-sync with Linux Kernel's DTS (SHA1: 7d08ddd09b75e7a3c103cc0d0d3ed700287f268e), the XEA's descripion has nodes and properties, which are NOT utilized in the u-boot.
To avoid confusion - those are deleted.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
arch/arm/dts/imx28-xea-u-boot.dtsi | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi index f6488154d8..22dd7bc8a8 100644 --- a/arch/arm/dts/imx28-xea-u-boot.dtsi +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -12,6 +12,11 @@ */ #include "imx28-u-boot.dtsi" / { + aliases { + /delete-property/ spi1; + /delete-property/ usbphy0; + /delete-property/ usbphy1; + }; apb@80000000 { bootph-pre-ram;
@@ -34,6 +39,8 @@ };
&pinctrl { + /delete-property/ pinctrl-names; + /delete-property/ pinctrl-0; bootph-pre-ram; };
@@ -46,3 +53,12 @@ spi-max-frequency = <40000000>; bootph-pre-ram; }; + +/delete-node/ &ssp2; +/delete-node/ &usb0; +/delete-node/ &usbphy0; +/delete-node/ &usb1; +/delete-node/ &usbphy1; +/delete-node/ &hog_pins_a; +/delete-node/ &hog_pins_tiva; +/delete-node/ &hog_pins_coding;
After the re-sync with Linux Kernel's DTS (SHA1: 7d08ddd09b75e7a3c103cc0d0d3ed700287f268e), the XEA's descripion has nodes and properties, which are NOT utilized in the u-boot. To avoid confusion - those are deleted. Signed-off-by: Lukasz Majewski lukma@denx.de
Best regards, Stefano Babic
After the commit (SHA1: 7d08ddd09b75e7a3c103cc0d0d3ed700287f268e) some u-boot specific XEA FEC related properties have been replaced by ones from the Linux kernel.
To be more specific - XEA board (and imx287 in general) has built L2 switch connected to FEC, which needs some special treatment.
In u-boot it is handled with 'mac0' node, whereas Linux uses dedicated switch DTS node.
arch/arm/dts/imx28-xea-u-boot.dtsi | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi index 22dd7bc8a8..9f1e261b2f 100644 --- a/arch/arm/dts/imx28-xea-u-boot.dtsi +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -38,12 +38,34 @@ bootph-pre-ram; };
+&mac0 { + phy-mode = "rmii"; + pinctrl-names = "default"; + pinctrl-0 = <&mac0_pins_a>; + phy-supply = <®_fec_3v3>; + phy-reset-gpios = <&gpio2 13 GPIO_ACTIVE_LOW>; + phy-reset-duration = <1>; + phy-reset-post-delay = <1>; + status = "okay"; + + fixed-link { + speed = <100>; + full-duplex; + }; +}; + &pinctrl { /delete-property/ pinctrl-names; /delete-property/ pinctrl-0; bootph-pre-ram; };
+®_fec_3v3 { + gpio = <&gpio0 0 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-boot-on; +}; + &ssp0 { bootph-pre-ram; };
After the commit (SHA1: 7d08ddd09b75e7a3c103cc0d0d3ed700287f268e) some u-boot specific XEA FEC related properties have been replaced by ones from the Linux kernel. To be more specific - XEA board (and imx287 in general) has built L2 switch connected to FEC, which needs some special treatment. In u-boot it is handled with 'mac0' node, whereas Linux uses dedicated switch DTS node. Signed-off-by: Lukasz Majewski lukma@denx.de
After the re-sync with Linux kernel (v6.0) of the XEA DTS (SHA1: 7d08ddd09b75e7a3c103cc0d0d3ed700287f268e) the alias for SPI bus, to which SPI-NOR memory is connected, has changed from 'spi3' to 'spi2'.
To be in sync with current u-boot's xea dts, the default bus number (which allows running 'sf probe' without any extra parameters given) has been adjusted.
configs/imx28_xea_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index 06dd6b1f0e..4a217b1f91 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -95,7 +95,7 @@ CONFIG_MMC_MXS=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_DM_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=3 +CONFIG_SF_DEFAULT_BUS=2 CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_SPANSION=y
After the re-sync with Linux kernel (v6.0) of the XEA DTS (SHA1: 7d08ddd09b75e7a3c103cc0d0d3ed700287f268e) the alias for SPI bus, to which SPI-NOR memory is connected, has changed from 'spi3' to 'spi2'. To be in sync with current u-boot's xea dts, the default bus number (which allows running 'sf probe' without any extra parameters given) has been adjusted. Signed-off-by: Lukasz Majewski lukma@denx.de
This code fixes following WARNING: DTOC spl/dts/dt-plat.c fsl_imx28_clkctrl: WARNING: the driver fsl_imx28_clkctrl was not found in the driver list
As imx28 doesn't yet support common clock framework, this prevents from DTOC warnings during SPL build.
board/liebherr/xea/xea.c | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index 38e841c5f6..ed2b39f70e 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -203,5 +203,22 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; } #endif - +/* + * NOTE: + * + * IMX28 clock "stub" DM driver! + * + * Only used for SPL stage, which is NOT using DM; serial and + * eMMC configuration. + */ +static const struct udevice_id imx28_clk_ids[] = { + { .compatible = "fsl,imx28-clkctrl", }, + { } +}; + +U_BOOT_DRIVER(fsl_imx28_clkctrl) = { + .name = "fsl_imx28_clkctrl", + .id = UCLASS_CLK, + .of_match = imx28_clk_ids, +}; #endif /* CONFIG_SPL_BUILD */
This code fixes following WARNING: DTOC spl/dts/dt-plat.c fsl_imx28_clkctrl: WARNING: the driver fsl_imx28_clkctrl was not found in the driver list As imx28 doesn't yet support common clock framework, this prevents from DTOC warnings during SPL build. Signed-off-by: Lukasz Majewski lukma@denx.de
After enabling DM_SERIAL for XEA board, the same serial shall be used in the SPL (with SPL_OF_PLATDATA support).
arch/arm/dts/imx28-xea-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi index 9f1e261b2f..e40a6d240c 100644 --- a/arch/arm/dts/imx28-xea-u-boot.dtsi +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -34,6 +34,10 @@ bootph-pre-ram; };
+&duart { + bootph-pre-ram; +}; + &gpio0 { bootph-pre-ram; };
After enabling DM_SERIAL for XEA board, the same serial shall be used in the SPL (with SPL_OF_PLATDATA support). Signed-off-by: Lukasz Majewski lukma@denx.de
The DM_SERIAL implicitly requires CONFIG_PL01X_SERIAL, which allows support for both serial IP block versions (i.e. PL011 and PL010).
The decision about used IP block is based on the compatible string, when DM is used.
In the XEA, the OF_PLATDATA is used to allow usage of serial driver in the SPL (as the size of SPL is crucial). In this case one cannot extract the type of IP block from .data field (corresponding to compatible) and it must be explicitly read at probe from dtoc generated, u-boot specific property.
arch/arm/dts/imx28-xea-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi index e40a6d240c..50289cf6d7 100644 --- a/arch/arm/dts/imx28-xea-u-boot.dtsi +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -36,6 +36,7 @@
&duart { bootph-pre-ram; + type = <1>; /* TYPE_PL011 */ };
&gpio0 {
The DM_SERIAL implicitly requires CONFIG_PL01X_SERIAL, which allows support for both serial IP block versions (i.e. PL011 and PL010). The decision about used IP block is based on the compatible string, when DM is used. In the XEA, the OF_PLATDATA is used to allow usage of serial driver in the SPL (as the size of SPL is crucial). In this case one cannot extract the type of IP block from .data field (corresponding to compatible) and it must be explicitly read at probe from dtoc generated, u-boot specific property. Signed-off-by: Lukasz Majewski lukma@denx.de
The imx287 SoC doesn't support common clock framework (CCF), so the 'clocks' property is removed to avoid early (i.e. in SPL) errors when SPL_OF_PLATDATA is used.
diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi index 50289cf6d7..52fec31fbb 100644 --- a/arch/arm/dts/imx28-xea-u-boot.dtsi +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -35,6 +35,7 @@ };
&duart { + /delete-property/ clocks; bootph-pre-ram; type = <1>; /* TYPE_PL011 */ };
The imx287 SoC doesn't support common clock framework (CCF), so the 'clocks' property is removed to avoid early (i.e. in SPL) errors when SPL_OF_PLATDATA is used. Signed-off-by: Lukasz Majewski lukma@denx.de
As imx28 family of SoCs is NOT supporting the Common Clock Framework (CCF) the 'clks' property shall NOT be enabled by default.
Without this change u-boot proper before relocation tries to bind driver (which doesn't exists) for this device. As a result, pre-relocation DTB parsing is finished with error and the board hangs in a very early stage of u-boot proper boot process.
diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi index 52fec31fbb..bdbeca528c 100644 --- a/arch/arm/dts/imx28-xea-u-boot.dtsi +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -32,6 +32,7 @@
&clks { bootph-pre-ram; + status = "disable"; };
&duart {
As imx28 family of SoCs is NOT supporting the Common Clock Framework (CCF) the 'clks' property shall NOT be enabled by default. Without this change u-boot proper before relocation tries to bind driver (which doesn't exists) for this device. As a result, pre-relocation DTB parsing is finished with error and the board hangs in a very early stage of u-boot proper boot process. Signed-off-by: Lukasz Majewski lukma@denx.de
Before this change, building this driver for SPL with enabled SPL_DM_SERIAL was problematic, as '-Wunused-const-variable=' warning was visible.
Now, the code is only considered when u-boot proper is build.
drivers/serial/serial_pl01x.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index f5468353e1..18332c2192 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -331,7 +331,7 @@ static const struct dm_serial_ops pl01x_serial_ops = { .setbrg = pl01x_serial_setbrg, };
-#if CONFIG_IS_ENABLED(OF_CONTROL) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id pl01x_serial_id[] ={ {.compatible = "arm,pl011", .data = TYPE_PL011}, {.compatible = "arm,pl010", .data = TYPE_PL010},
Before this change, building this driver for SPL with enabled SPL_DM_SERIAL was problematic, as '-Wunused-const-variable=' warning was visible. Now, the code is only considered when u-boot proper is build. Signed-off-by: Lukasz Majewski lukma@denx.de
This commit prepares the pl01x serial driver to be used with SPL_OF_PLATDATA enabled.
drivers/serial/serial_pl01x.c | 12 ++++++++++++ include/dm/platform_data/serial_pl01x.h | 4 ++++ 2 files changed, 16 insertions(+)
diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index 18332c2192..dbf2b2df34 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -291,8 +291,16 @@ int pl01x_serial_probe(struct udevice *dev) struct pl01x_serial_plat *plat = dev_get_plat(dev); struct pl01x_priv *priv = dev_get_priv(dev);
+#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_serial_pl01x *dtplat = &plat->dtplat; + + priv->regs = (struct pl01x_regs *)dtplat->reg[0]; + plat->type = dtplat->type; +#else priv->regs = (struct pl01x_regs *)plat->base; +#endif priv->type = plat->type; + if (!plat->skip_init) return pl01x_generic_serial_init(priv->regs, priv->type); else @@ -380,8 +388,10 @@ int pl01x_serial_of_to_plat(struct udevice *dev) U_BOOT_DRIVER(serial_pl01x) = { .name = "serial_pl01x", .id = UCLASS_SERIAL, +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = of_match_ptr(pl01x_serial_id), .of_to_plat = of_match_ptr(pl01x_serial_of_to_plat), +#endif .plat_auto = sizeof(struct pl01x_serial_plat), .probe = pl01x_serial_probe, .ops = &pl01x_serial_ops, @@ -389,6 +399,8 @@ U_BOOT_DRIVER(serial_pl01x) = { .priv_auto = sizeof(struct pl01x_priv), };
+DM_DRIVER_ALIAS(serial_pl01x, arm_pl011) +DM_DRIVER_ALIAS(serial_pl01x, arm_pl010) #endif
#if defined(CONFIG_DEBUG_UART_PL010) || defined(CONFIG_DEBUG_UART_PL011) diff --git a/include/dm/platform_data/serial_pl01x.h b/include/dm/platform_data/serial_pl01x.h index e3d4e308a1..811697ce5c 100644 --- a/include/dm/platform_data/serial_pl01x.h +++ b/include/dm/platform_data/serial_pl01x.h @@ -20,7 +20,11 @@ enum pl01x_type { * @skip_init: Don't attempt to change port configuration (also means @clock * is ignored) */ +#include <dt-structs.h> struct pl01x_serial_plat { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_serial_pl01x dtplat; +#endif unsigned long base; enum pl01x_type type; unsigned int clock;
This commit prepares the pl01x serial driver to be used with SPL_OF_PLATDATA enabled. Signed-off-by: Lukasz Majewski lukma@denx.de
Before this change the FR_TXFF (Transmit FIFO full) bit (5 in HW_UARTDBG_FR) has been used to assess if there is still data pending to be sent via UART.
This approach is problematic, as it may happen that serial is in the middle of transmission (so the TX FIFO is NOT full anymore) and this test returns true infinitely. As a result, for example in _serial_flush() DM serial function we are locked in endless while().
The fix here is to test explicitly if the TX FIFO is empty.
diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index dbf2b2df34..428a4d210d 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -329,7 +329,7 @@ int pl01x_serial_pending(struct udevice *dev, bool input) if (input) return pl01x_tstc(priv->regs); else - return fr & UART_PL01x_FR_TXFF ? 0 : 1; + return fr & UART_PL01x_FR_TXFE ? 0 : 1; }
Before this change the FR_TXFF (Transmit FIFO full) bit (5 in HW_UARTDBG_FR) has been used to assess if there is still data pending to be sent via UART. This approach is problematic, as it may happen that serial is in the middle of transmission (so the TX FIFO is NOT full anymore) and this test returns true infinitely. As a result, for example in _serial_flush() DM serial function we are locked in endless while(). The fix here is to test explicitly if the TX FIFO is empty. Signed-off-by: Lukasz Majewski lukma@denx.de
When DM_SERIAL is enabled on mxs (i.e. imx28) platform, the console early initialization must be postponed until the driver model is correctly setup.
arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c index 763d79e803..5598c552ab 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c @@ -128,8 +128,10 @@ void mxs_common_spl_init(const uint32_t arg, const uint32_t *resptr,
mxs_iomux_setup_multiple_pads(iomux_setup, iomux_size);
- mxs_spl_console_init(); - debug("SPL: Serial Console Initialised\n"); + if (!CONFIG_IS_ENABLED(DM_SERIAL)) { + mxs_spl_console_init(); + debug("SPL: Serial Console Initialised\n"); + }
mxs_power_init();
When DM_SERIAL is enabled on mxs (i.e. imx28) platform, the console early initialization must be postponed until the driver model is correctly setup. Signed-off-by: Lukasz Majewski lukma@denx.de
The in-spl enabled DM serial console requires the board setup to be able to parse SPL_OF_PLATDATA based serial driver (pl01x) for the imx28 based XEA board.
board/liebherr/xea/xea.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index ed2b39f70e..e4d2eb65cc 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -62,6 +62,7 @@ static void init_clocks(void) void board_init_f(ulong arg) { init_clocks(); + spl_early_init(); preloader_console_init(); }
The in-spl enabled DM serial console requires the board setup to be able to parse SPL_OF_PLATDATA based serial driver (pl01x) for the imx28 based XEA board. Signed-off-by: Lukasz Majewski lukma@denx.de
The CONFIG_PL011 used by all other ARCH_MX28 based boards is not supporting DM_SERIAL. Instead, other define - namely CONFIG_PL01X_SERIAL shall be used by boards supporting DM_SERIAL.
arch/arm/Kconfig | 2 +- arch/arm/mach-imx/mxs/Kconfig | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 99264a6478..4604d41410 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -919,7 +919,7 @@ config ARCH_MX28 bool "NXP i.MX28 family" select CPU_ARM926EJS select GPIO_EXTRA_HEADER - select PL011_SERIAL + select PL011_SERIAL if !TARGET_XEA select MACH_IMX select SUPPORT_SPL
diff --git a/arch/arm/mach-imx/mxs/Kconfig b/arch/arm/mach-imx/mxs/Kconfig index b2026a3758..ded16aac46 100644 --- a/arch/arm/mach-imx/mxs/Kconfig +++ b/arch/arm/mach-imx/mxs/Kconfig @@ -45,6 +45,7 @@ config TARGET_MX28EVK
config TARGET_XEA bool "Support XEA" + select PL01X_SERIAL
endchoice
The CONFIG_PL011 used by all other ARCH_MX28 based boards is not supporting DM_SERIAL. Instead, other define - namely CONFIG_PL01X_SERIAL shall be used by boards supporting DM_SERIAL. Signed-off-by: Lukasz Majewski lukma@denx.de
The XEA board now supports the DM_SERIAL feature in u-boot.
The SPL is using the SPL_OF_PLATDATA - i.e. NOT SPL_DM_SERIAL to reduce the overall size of the SPL binary.
configs/imx28_xea_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index 4a217b1f91..b4a051a859 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -113,7 +113,8 @@ CONFIG_PINCTRL_MXS=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y -CONFIG_CONS_INDEX=0 +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXS_SPI=y
The XEA board now supports the DM_SERIAL feature in u-boot. The SPL is using the SPL_OF_PLATDATA - i.e. NOT SPL_DM_SERIAL to reduce the overall size of the SPL binary. Signed-off-by: Lukasz Majewski lukma@denx.de
The single binary version of u-boot for XEA board is used to debrick and factory programming.
The produced u-boot.sb is a single file, which allows having fully operational u-boot prompt loaded with imx287 ROM.
configs/imx28_xea_sb_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/imx28_xea_sb_defconfig b/configs/imx28_xea_sb_defconfig index bb7bf5d9da..a43183444d 100644 --- a/configs/imx28_xea_sb_defconfig +++ b/configs/imx28_xea_sb_defconfig @@ -94,7 +94,9 @@ CONFIG_PINCTRL_MXS=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_CONS_INDEX=0 +CONFIG_DM_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXS_SPI=y
The single binary version of u-boot for XEA board is used to debrick and factory programming. The produced u-boot.sb is a single file, which allows having fully operational u-boot prompt loaded with imx287 ROM. Signed-off-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
sbabic@denx.de
