[U-Boot-Users] How BRG output can be routed to a pin
Hi All, I am working on Motorola Power Quicc II 8266 based PMC card. Can any one please let me know how to route the BRG output to a pin.
Thanks and Regards, Apoorv ************************************************************************** This email (including any attachments) is intended for the sole use of the intended recipient/s and may contain material that is CONFIDENTIAL AND PRIVATE COMPANY INFORMATION. Any review or reliance by others or copying or distribution or forwarding of any or all of the contents in this message is STRICTLY PROHIBITED. If you are not the intended recipient, please contact the sender by email and delete all copies; your cooperation in this regard is appreciated. **************************************************************************
You need to initialize the proper port to do this. 1) Figure out which port pin the BRG comes out. Many functions are routable to two different pins, a "primary" (bolded in the User's Manual) and "secondary". Board schematics and/or hardware support is helpful here. For instance, BRG6:BRGO is PC21.
2) Look this up in Section 35 of your 8260 User's Manual (or other documentation).
3) In my random pick of BRG6, Table 35-7 (p. 35-15) shows that bit 21 of register PSORC needs to be 0 and bit 21 of PDIRC needs to be 1.
4) Find your board's port initialization and Do The Right Thing with it (alternately, you may need/want to put this in your support code for whatever is using the BRG).
gvb
In message 3D9FDCA910DD4445896A0BE5ECF009D40240EFC1@bla.satyam.com you wrote:
This is something you can find the processor's User's Manual. Please look it up there.
Apoorv_Sangal
Jerry Van Baren
