[U-Boot] [PATCH] ppc4xx: Cleanup of "ppc4xx: Optimize PLB4 Arbiter..." patch
This patch fixes some minor issues introduced with the patch: ppc4xx: Optimize PLB4 Arbiter... from Prodyut Hazarika:
- Rework memory-queue and PLB arbiter optimization code, that the local variable is not needed anymore. This removes one #ifdef. - Use consistant spacing in ppc4xx.h header (XXX + 0x01 instead of XXX+ 0x01). This was not introduced by Prodyut, just a copy-paste problem.
Signed-off-by: Stefan Roese sr@denx.de --- cpu/ppc4xx/44x_spd_ddr2.c | 20 +++++--------------- cpu/ppc4xx/cpu_init.c | 17 ++++++++--------- include/ppc4xx.h | 24 ++++++++++++------------ 3 files changed, 25 insertions(+), 36 deletions(-)
diff --git a/cpu/ppc4xx/44x_spd_ddr2.c b/cpu/ppc4xx/44x_spd_ddr2.c index c7ed161..001f2c1 100644 --- a/cpu/ppc4xx/44x_spd_ddr2.c +++ b/cpu/ppc4xx/44x_spd_ddr2.c @@ -2172,11 +2172,6 @@ static void program_memory_queue(unsigned long *dimm_populated, unsigned long i; unsigned long bank_0_populated = 0; phys_size_t total_size = 0; -#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ - defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) - unsigned long val; -#endif
/*------------------------------------------------------------------ * Reset the rank_base_address. @@ -2257,7 +2252,6 @@ static void program_memory_queue(unsigned long *dimm_populated, #if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_460SX) - /* * Enable high bandwidth access * This is currently not used, but with this setup @@ -2270,15 +2264,11 @@ static void program_memory_queue(unsigned long *dimm_populated, /* * Set optimal value for Memory Queue HB/LL Configuration registers */ - - val = (mfdcr(SDRAM_CONF1HB) | SDRAM_CONF1HB_AAFR | SDRAM_CONF1HB_RPEN | SDRAM_CONF1HB_RFTE); - mtdcr(SDRAM_CONF1HB, val); - - val = (mfdcr(SDRAM_CONF1LL) | SDRAM_CONF1LL_AAFR | SDRAM_CONF1LL_RPEN | SDRAM_CONF1LL_RFTE); - mtdcr(SDRAM_CONF1LL, val); - - val = (mfdcr(SDRAM_CONFPATHB) | SDRAM_CONFPATHB_TPEN); - mtdcr(SDRAM_CONFPATHB, val); + mtdcr(SDRAM_CONF1HB, mfdcr(SDRAM_CONF1HB) | SDRAM_CONF1HB_AAFR | + SDRAM_CONF1HB_RPEN | SDRAM_CONF1HB_RFTE); + mtdcr(SDRAM_CONF1LL, mfdcr(SDRAM_CONF1LL) | SDRAM_CONF1LL_AAFR | + SDRAM_CONF1LL_RPEN | SDRAM_CONF1LL_RFTE); + mtdcr(SDRAM_CONFPATHB, mfdcr(SDRAM_CONFPATHB) | SDRAM_CONFPATHB_TPEN); #endif }
diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index 281819a..dee9807 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -138,9 +138,7 @@ void reconfigure_pll(u32 new_cpu_freq) void cpu_init_f (void) { -#if defined(CONFIG_WATCHDOG) || defined(CONFIG_440GX) || defined(CONFIG_460EX) || \ - defined(CONFIG_440SP) || defined(CONFIG_440SPE) || defined(CONFIG_405EX) || \ - defined(CONFIG_460GT) || defined(CONFIG_460SX) +#if defined(CONFIG_WATCHDOG) || defined(CONFIG_440GX) || defined(CONFIG_460EX) u32 val; #endif
@@ -304,16 +302,17 @@ cpu_init_f (void) mtsdr(SDR0_USB2HOST_CFG, val); #endif /* CONFIG_460EX */
-#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ +#if defined(CONFIG_405EX) || \ + defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_405EX) || defined(CONFIG_460SX) + defined(CONFIG_460SX) /* * Set PLB4 arbiter (Segment 0 and 1) to 4 deep pipeline read */ - val = (mfdcr(plb0_acr) & ~plb0_acr_rdp_mask) | plb0_acr_rdp_4deep; - mtdcr(plb0_acr, val); - val = (mfdcr(plb1_acr) & ~plb1_acr_rdp_mask) | plb1_acr_rdp_4deep; - mtdcr(plb1_acr, val); + mtdcr(plb0_acr, (mfdcr(plb0_acr) & ~plb0_acr_rdp_mask) | + plb0_acr_rdp_4deep); + mtdcr(plb1_acr, (mfdcr(plb1_acr) & ~plb1_acr_rdp_mask) | + plb1_acr_rdp_4deep); #endif /* CONFIG_440SP/SPE || CONFIG_460EX/GT || CONFIG_405EX */ }
diff --git a/include/ppc4xx.h b/include/ppc4xx.h index e1613dd..59a3b06 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -56,8 +56,8 @@
#define PLB_ARBITER_BASE 0x80
-#define plb0_revid (PLB_ARBITER_BASE+ 0x00) -#define plb0_acr (PLB_ARBITER_BASE+ 0x01) +#define plb0_revid (PLB_ARBITER_BASE + 0x00) +#define plb0_acr (PLB_ARBITER_BASE + 0x01) #define plb0_acr_ppm_mask 0xF0000000 #define plb0_acr_ppm_fixed 0x00000000 #define plb0_acr_ppm_fair 0xD0000000 @@ -73,13 +73,13 @@ #define plb0_acr_wrp_disabled 0x00000000 #define plb0_acr_wrp_2deep 0x01000000
-#define plb0_besrl (PLB_ARBITER_BASE+ 0x02) -#define plb0_besrh (PLB_ARBITER_BASE+ 0x03) -#define plb0_bearl (PLB_ARBITER_BASE+ 0x04) -#define plb0_bearh (PLB_ARBITER_BASE+ 0x05) -#define plb0_ccr (PLB_ARBITER_BASE+ 0x08) +#define plb0_besrl (PLB_ARBITER_BASE + 0x02) +#define plb0_besrh (PLB_ARBITER_BASE + 0x03) +#define plb0_bearl (PLB_ARBITER_BASE + 0x04) +#define plb0_bearh (PLB_ARBITER_BASE + 0x05) +#define plb0_ccr (PLB_ARBITER_BASE + 0x08)
-#define plb1_acr (PLB_ARBITER_BASE+ 0x09) +#define plb1_acr (PLB_ARBITER_BASE + 0x09) #define plb1_acr_ppm_mask 0xF0000000 #define plb1_acr_ppm_fixed 0x00000000 #define plb1_acr_ppm_fair 0xD0000000 @@ -95,10 +95,10 @@ #define plb1_acr_wrp_disabled 0x00000000 #define plb1_acr_wrp_2deep 0x01000000
-#define plb1_besrl (PLB_ARBITER_BASE+ 0x0A) -#define plb1_besrh (PLB_ARBITER_BASE+ 0x0B) -#define plb1_bearl (PLB_ARBITER_BASE+ 0x0C) -#define plb1_bearh (PLB_ARBITER_BASE+ 0x0D) +#define plb1_besrl (PLB_ARBITER_BASE + 0x0A) +#define plb1_besrh (PLB_ARBITER_BASE + 0x0B) +#define plb1_bearl (PLB_ARBITER_BASE + 0x0C) +#define plb1_bearh (PLB_ARBITER_BASE + 0x0D)
#endif /* 440EP/EPX 440GR/GRX 440SP/SPE 460EX/GT/SX 405EX*/
Stefan Roese
