[U-Boot] crashed u-boot with MV88F6560
hello. I deleted the u-boot witch MV88F6560. The board is ZTE-88F6560-FXXX this is modem of epon (ftth). I have the copy of the rom with mtdblock0 (~10MB). If I look with hex editor when I see information witch first 512KB is u-boot room.
If I connect with rs232 (added max232) and checked bootrom dipswitch for ths board I have information: BootROM 1.34
If I send the backup rom with mtdblock0 (xmodem with hyperterminal) then hyperterminal send me information checksum error.
I find with internet u-boot.bin then I send with hyperterminal then hyperterminal send witch board first 1024block (uboot have 1670block :( ). This not work.
Log with good board connected with hyperterminal:
BootROM 1.34 Booting from NAND flash BootROM: Image checksum verification PASSED
U-Boot 2009.08 (Sep 20 2011 - 17:28:41)
CPU: Feroceon (Rev 1) @ 1200Mhz - LE, L2 @ 400Mhz DDR3 @ 400Mhz, TClock @ 200Mhz, P/V ID=7/15 DRAM: 128 MB CS 0: base 0x00000000 size 128 MB Addresses 26M - 0M are saved for the U-Boot usage. NAND: 1bit HM ECC, Size: 32 MiB Modules Detected: GPON module detected. TDM module. Ethernet Switch on MAC0. 3xFE PHY Module. GE-PHY on Switch port #0. Net: egiga0 [PRIME], egiga1 Hit 1 to upgrade softwate version Hit enter to stop autoboot: 0 select=0x0
NAND read: device 0 offset 0x1980000, size 0x100 256 bytes read: OK select=0x0 search=0x2
NAND read: device 0 offset 0x80000, size 0x937110 9662736 bytes read: OK
NAND read: device 0 offset 0x30000, size 0x30000 196608 bytes read: OK ## Booting kernel from Legacy Image at 02000100 ... Image Name: Linux Kernel Image Image Type: ARM Linux Kernel Image (lzma compressed) Data Size: 9662403 Bytes = 9.2 MB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK Uncompressing (lzma) Kernel Image ... OK ---------------------- |-->setup start tag... ---------------------- |-->setup memory tag... ---------------------- |-->setup cmdline tag... ---------------------- |-->setup marvell tag... ---------------------- |-->setup versioninfo tag... ---------------------- |-->setup end tag... ----------------------
Starting kernel ...
Linux version 2.6.21.5 (wangkai@localhost.localdomain) (gcc version 4.3.4 (Build root 2010.05) ) #44 Tue Sep 20 17:53:59 CST 2011 CPU: ARM926EJ-S [56251311] revision 1 (ARMv5TE), cr=00053977 Machine: Feroceon-KW2 Using UBoot passing parameters structure Memory policy: ECC disabled, Data cache writeback <7>On node 0 totalpages: 32512 <7> Normal zone: 0 pages used for memmap CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets Built 1 zonelists. Total pages: 32258 Kernel command line: console=ttyS0,115200 root=/dev/ram0 rw load_ramdisk=1 rdini t=/sbin/init mv_net_config=0 mem=127M PID hash table entries: 512 (order: 9, 2048 bytes) Console: colour dummy device 80x30 Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 127MB = 127MB total Memory: 116352KB available (3536K code, 714K data, 8168K init) Mount-cache hash table entries: 512 <6>CPU: Testing write buffer coherency: ok pdt_cspkernel_init NET: Registered protocol family 16
CPU Interface ------------- SDRAM_CS0 ....base 00000000, size 128MB SDRAM_CS1 ....no such SDRAM_CS2 ....no such SDRAM_CS3 ....no such DEVICE_CS0 ....no such DEVICE_CS1 ....no such DEVICE_CS2 ....no such DEVICE_CS3 ....no such PEX0_MEM ....base f3000000, size 16MB PEX0_IO ....base f2000000, size 1MB PEX1_MEM ....base f4000000, size 16MB PEX1_IO ....base f2100000, size 1MB INTER_REGS ....base f1000000, size 1MB NAND_NOR_CS ....base f8000000, size 2MB SPI_CS0 ....base f0000000, size 16MB SPI_CS1 ....no such SPI_CS2 ....no such SPI_CS3 ....no such <4>SPI_CS4 ....no such SPI_CS5 ....no such SPI_CS6 ....no such SPI_CS7 ....no such SPI_B_CS0 ....no such BOOT_ROM_CS ....no such <4>DEV_BOOTCS ....no such CRYPT1_ENG ....no such CRYPT2_ENG ....no such PNC_BM ....base f5000000, size 1MB ETH_CTRL ....base f5100000, size 1MB PON_CTRL ....base f5200000, size 1MB NFC_CTRL ....no such
Marvell Development Board (LSP Version KW2_LSP_1.0.4_p26_KERNEL_2.6.21.5_NQ)-- ZTE-88F6560-FXXX Soc: MV88F6560 Rev 2 LE
Detected Tclk 200000000 and SysClk 400000000 g_pdwWdRsvMemBase is c8000000 g_dwWdRsvMemLen is 40052 magic has been changed! g_pdwWdRegTableBase = c800000c : success register character device for /dev/watchdog Marvell USB EHCI Host controller #0: c0d75600 <4>PEX0 interface detected no Link. PEX1 interface detected Link X4 PCI: bus0: Fast back to back transfers enabled PCI: bus1: Fast back to back transfers disabled SCSI subsystem initialized Time: kw_clocksource clocksource has been installed. NET: Registered protocol family 2 ip_rt_init() start call CSP_alloc_large_system_hash IP route cache hash table entries: 1024 (order: 0, 4096 bytes) ip_rt_init() call CSP_alloc_large_system_hash end TCP established hash table entries: 4096 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 4096 bind 2048) TCP reno registered RTC has been updated!!! RTC registered cpufreq: Init kirkwood cpufreq driver NTFS driver 2.1.28 [Flags: R/W]. JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc. <4>fuse init (API version 7.8) <6>io scheduler noop registered <6>io scheduler anticipatory registered (default) Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A serial8250.1: ttyS1 at MMIO 0xf1012100 (irq = 34) is a 16550A RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize 0 - Base 0x00000000 , Size = 0x08000000. 8 - Base 0xf3000000 , Size = 0x01000000. 9 - Base 0xf2000000 , Size = 0x00100000. 10 - Base 0xf4000000 , Size = 0x01000000. 11 - Base 0xf2100000 , Size = 0x00100000. 12 - Base 0xf1000000 , Size = 0x00100000. 13 - Base 0xf8000000 , Size = 0x00200000. 14 - Base 0xf0000000 , Size = 0x01000000. 27 - Base 0xf5000000 , Size = 0x00100000. 28 - Base 0xf5100000 , Size = 0x00100000. 29 - Base 0xf5200000 , Size = 0x00100000. mvPncVirtBase = 0xc8400000 o 3 Giga ports supported o Giga PON port is #2: - 8 TCONTs supported o NETA acceleration mode 4 o BM supported: short buffer size is 256 bytes o PnC supported o HWF supported o PMT supported o RX Queue support: 8 Queues * 512 Descriptors o TX Queue support: 8 Queues * 3072 Descriptors o Receive checksum offload supported o Transmit checksum offload supported o Driver ERROR statistics enabled o Driver INFO statistics enabled o Driver DEBUG statistics enabled o Proc tool API enabled o Switch support enabled o IGMP special processing support
o Loading Switch QuarterDeck driver o Internal GE PHY Connected to Switch Port 0 Detected o Setting Switch CPU port (port #4) for 1000 Full with FC o Disable disconnected switch port (port #5) and force link down o Disable disconnected switch port (port #6) and force link down o Loading network interface(s)
o Port 0 is connected to Linux netdevice o Using UBoot netconfig string net_config_str: 0 o Working in External Switch mode giga p=0: mtu=1500, mac=c0d61f72 o mii0, ifindex = 1, GbE port = 0
o Warning: GbE port 1 is not connected to PHY/RGMII/Switch, skipping initializ ation
o Port 2 is connected to Linux netdevice pon p=2: mtu=1500, mac=c0d61f72 o mii1, ifindex = 2, GbE port = 2
e100: Intel(R) PRO/100 Network Driver, 3.5.17-k2-NAPI e100: Copyright(c) 1999-2006 Intel Corporation NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $ Using Hamming 1-bit ECC for NAND device NAND device: Manufacturer ID: 0x20, Chip ID: 0x75 (ST Micro NAND 32MiB 3,3V 8-bi t) Scanning device for bad blocks Using static partition definition Creating 8 MTD partitions on "nand_mtd": 0x00000000-0x02000000 : "whole flash" 0x00000000-0x00080000 : "u-boot" 0x01a40000-0x01ac0000 : "parameter tags" 0x00080000-0x00d00000 : "kernel0" 0x01c00000-0x02000000 : "middleware" 0x01ac0000-0x01c00000 : "usercfg" 0x00d00000-0x01980000 : "kernel1" 0x01980000-0x01a40000 : "others" mice: PS/2 mouse device common for all mice Linux telephony interface: v1.00 Loading Marvell vpapi device
Sorry for me english :( I'm in poland. Thansk for you help.
Dawid Partyka - Safe-lock.net
