[PATCH] travis/gitlab/azure: Ensure we use python3 always
When running our tests there are some cases where as part of the Python 2.7 to Python 3.6 migration we didn't force Python 3.6 to be used as everything wasn't yet migrated. Now that everything is, make sure to tell virtualenv to use python3. In the case of Travis this is best done by making the tools test happen after the main tests so that it will already have been run in all cases, TEST_PY_TOOLS is a subset of TEST_PY_BD.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 2 +- .gitlab-ci.yml | 4 ++-- .travis.yml | 18 ++++++++---------- 3 files changed, 11 insertions(+), 13 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 052c3aa278b5..c22095830c0c 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -123,7 +123,7 @@ jobs: git config --global user.name "Azure Pipelines" git config --global user.email bmeng.cn@gmail.com export USER=azure - virtualenv /tmp/venv + virtualenv -p /usr/bin/python3 /tmp/venv . /tmp/venv/bin/activate pip install pyelftools export UBOOT_TRAVIS_BUILD_DIR=/tmp/.bm-work/sandbox_spl diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index e20a789ac150..d486e72042fb 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -72,7 +72,7 @@ build all 64bit ARM platforms: tags: [ 'all' ] stage: world build script: - - virtualenv /tmp/venv + - virtualenv -p /usr/bin/python3 /tmp/venv - . /tmp/venv/bin/activate - pip install pyelftools - ret=0; @@ -157,7 +157,7 @@ Run binman, buildman, dtoc and patman testsuites: - git config --global user.name "GitLab CI Runner"; git config --global user.email trini@konsulko.com; export USER=gitlab; - virtualenv /tmp/venv; + virtualenv -p /usr/bin/python3 /tmp/venv; . /tmp/venv/bin/activate; pip install pyelftools; export UBOOT_TRAVIS_BUILD_DIR=/tmp/.bm-work/sandbox_spl; diff --git a/.travis.yml b/.travis.yml index 3991eb7716fb..23c181e8d377 100644 --- a/.travis.yml +++ b/.travis.yml @@ -133,16 +133,6 @@ script: cp ~/grub_x64.efi $UBOOT_TRAVIS_BUILD_DIR/; cp ~/grub2-arm/usr/lib/grub2/arm-efi/grub.efi $UBOOT_TRAVIS_BUILD_DIR/grub_arm.efi; cp ~/grub2-arm64/usr/lib/grub2/arm64-efi/grub.efi $UBOOT_TRAVIS_BUILD_DIR/grub_arm64.efi; - if [[ -n "${TEST_PY_TOOLS}" ]]; then - PYTHONPATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt" - PATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH}" - ./tools/binman/binman --toolpath ${UBOOT_TRAVIS_BUILD_DIR}/tools test && - ./tools/patman/patman --test && - ./tools/buildman/buildman -t && - PYTHONPATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt" - PATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH}" - ./tools/dtoc/dtoc -t; - fi; if [[ "${TEST_PY_BD}" != "" ]]; then virtualenv -p /usr/bin/python3 /tmp/venv; . /tmp/venv/bin/activate; @@ -154,6 +144,14 @@ script: if [[ $ret -ne 0 ]]; then exit $ret; fi; + if [[ -n "${TEST_PY_TOOLS}" ]]; then + export PYTHONPATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt"; + export PATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH}"; + ./tools/binman/binman --toolpath ${UBOOT_TRAVIS_BUILD_DIR}/tools test && + ./tools/patman/patman --test && + ./tools/buildman/buildman -t && + ./tools/dtoc/dtoc -t; + fi; fi
matrix:
