[PATCH v2 0/5] board: ti: j721e: Enable I2C and EEPROM
This series enable I2C and EEPROM support on J721e common processor board.
Logs: https://pastebin.ubuntu.com/p/HTrQk3VnZm/
Changes since v1: - Fixed board_is_j721e_som() to use the right apis.
Andreas Dannenberg (3): ti: common: board_detect: Handle EEPROM probe more gracefully board: ti: j721e: Use EEPROM-based board detection arm64: dts: k3-j721e-common-proc-board: Fully enable wkup_i2c0 use
Lokesh Vutla (1): board: ti: j721e: Print board name and version during boot
Vignesh Raghavendra (1): configs: j721e_evm_a72_defconfig: Enable I2C and EEPROM support
.../k3-j721e-common-proc-board-u-boot.dtsi | 8 + arch/arm/dts/k3-j721e-common-proc-board.dts | 15 + .../arm/mach-k3/include/mach/j721e_hardware.h | 3 + arch/arm/mach-k3/j721e_init.c | 3 + board/ti/common/board_detect.c | 11 +- board/ti/common/board_detect.h | 9 + board/ti/j721e/Kconfig | 7 + board/ti/j721e/evm.c | 264 ++++++++++++++++++ configs/j721e_evm_a72_defconfig | 4 + 9 files changed, 323 insertions(+), 1 deletion(-)
Use dm_i2c_probe() rather than i2c_get_chip() when trying to access board-detection EEPROM devices. This has the advantage of more gracefully handling the case when the EEPROM is not present by allowing to exit the function early rather than failing and outputting an error message on the I2C transactions that follow.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/common/board_detect.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index 564d2f7046..cf6bd02698 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -91,7 +91,7 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, rc = uclass_get_device_by_seq(UCLASS_I2C, bus_addr, &bus); if (rc) return rc; - rc = i2c_get_chip(bus, dev_addr, 1, &dev); + rc = dm_i2c_probe(bus, dev_addr, 0, &dev); if (rc) return rc;
The TI J721E EVM system on module (SOM), the common processor board, and the associated daughtercards have on-board I2C-based EEPROMs containing board config data. Use the board detection infrastructure to do the following:
1) Parse the J721E SOM EEPROM and populate items like board name, board HW and SW revision as well as board serial number into the TI common EEPROM data structure residing in SRAM scratch space 2) Check for presence of daughter card(s) by probing associated I2C addresses used for on-board EEPROMs containing daughter card-specific data. If such a card is found, parse the EEPROM data such as for additional Ethernet MAC addresses and populate those into U-Boot accordingly 3) Dynamically apply daughter card DTB overlays to the U-Boot (proper) DTB during SPL execution 4) Dynamically create an U-Boot ENV variable called name_overlays during U-Boot execution containing a list of daugherboard-specific DTB overlays based on daughercards found to be used during Kernel boot.
This patch adds support for the J721E system on module boards containing the actual SoC ("J721EX-PM2-SOM", accessed via CONFIG_EEPROM_CHIP_ADDRESS), the common processor board ("J7X-BASE-CPB"), the Quad-Port Ethernet Expansion Board ("J7X-VSC8514-ETH"), the infotainment board ("J7X-INFOTAN-EXP") as well as for the gateway/Ethernet switch/industrial expansion board ("J7X-GESI-EXP").
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- .../arm/mach-k3/include/mach/j721e_hardware.h | 3 + arch/arm/mach-k3/j721e_init.c | 3 + board/ti/common/board_detect.c | 9 + board/ti/common/board_detect.h | 9 + board/ti/j721e/Kconfig | 7 + board/ti/j721e/evm.c | 251 ++++++++++++++++++ 6 files changed, 282 insertions(+)
diff --git a/arch/arm/mach-k3/include/mach/j721e_hardware.h b/arch/arm/mach-k3/include/mach/j721e_hardware.h index 8d429772b5..ead136ed63 100644 --- a/arch/arm/mach-k3/include/mach/j721e_hardware.h +++ b/arch/arm/mach-k3/include/mach/j721e_hardware.h @@ -46,4 +46,7 @@ #define CTRLMMR_LOCK_KICK1 0x0100c #define CTRLMMR_LOCK_KICK1_UNLOCK_VAL 0xd172bc5a
+/* MCU SCRATCHPAD usage */ +#define TI_SRAM_SCRATCH_BOARD_EEPROM_START CONFIG_SYS_K3_MCU_SCRATCHPAD_BASE + #endif /* __ASM_ARCH_J721E_HARDWARE_H */ diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index 4758739266..8d562e4cbe 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -119,6 +119,9 @@ void board_init_f(ulong dummy) preloader_console_init(); #endif
+ /* Perform EEPROM-based board detection */ + do_board_detect(); + #if defined(CONFIG_CPU_V7R) && defined(CONFIG_K3_AVS0) ret = uclass_get_device_by_driver(UCLASS_MISC, DM_GET_DRIVER(k3_avs), &dev); diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index cf6bd02698..289dff5e12 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -472,6 +472,15 @@ int __maybe_unused ti_i2c_eeprom_am6_get_base(int bus_addr, int dev_addr) return ret; }
+bool __maybe_unused board_ti_k3_is(char *name_tag) +{ + struct ti_am6_eeprom *ep = TI_AM6_EEPROM_DATA; + + if (ep->header == TI_DEAD_EEPROM_MAGIC) + return false; + return !strncmp(ep->name, name_tag, AM6_EEPROM_HDR_NAME_LEN); +} + bool __maybe_unused board_ti_is(char *name_tag) { struct ti_common_eeprom *ep = TI_EEPROM_DATA; diff --git a/board/ti/common/board_detect.h b/board/ti/common/board_detect.h index a45d8961b9..52f0eb2070 100644 --- a/board/ti/common/board_detect.h +++ b/board/ti/common/board_detect.h @@ -310,6 +310,15 @@ int __maybe_unused ti_i2c_eeprom_am6_get_base(int bus_addr, int dev_addr); */ bool board_ti_is(char *name_tag);
+/** + * board_ti_k3_is() - Board detection logic for TI K3 EVMs + * @name_tag: Tag used in eeprom for the board + * + * Return: false if board information does not match OR eeprom wasn't read. + * true otherwise + */ +bool board_ti_k3_is(char *name_tag); + /** * board_ti_rev_is() - Compare board revision for TI EVMs * @rev_tag: Revision tag to check in eeprom diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index 88097df653..e56dc53bfa 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -11,6 +11,8 @@ config TARGET_J721E_A72_EVM bool "TI K3 based J721E EVM running on A72" select ARM64 select SOC_K3_J721E + select BOARD_LATE_INIT + imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS
config TARGET_J721E_R5_EVM @@ -23,6 +25,7 @@ config TARGET_J721E_R5_EVM select SPL_RAM select K3_J721E_DDRSS imply SYS_K3_SPL_ATF + imply TI_I2C_BOARD_DETECT
endchoice
@@ -37,6 +40,8 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "j721e_evm"
+source "board/ti/common/Kconfig" + endif
if TARGET_J721E_R5_EVM @@ -53,4 +58,6 @@ config SYS_CONFIG_NAME config SPL_LDSCRIPT default "arch/arm/mach-omap2/u-boot-spl.lds"
+source "board/ti/common/Kconfig" + endif diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 51b121ce05..7327c96b31 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -9,10 +9,21 @@
#include <common.h> #include <init.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> +#include <asm/gpio.h> #include <asm/io.h> #include <spl.h> #include <asm/arch/sys_proto.h>
+#include "../common/board_detect.h" + +#define board_is_j721e_som() (board_ti_k3_is("J721EX-PM1-SOM") || \ + board_ti_k3_is("J721EX-PM2-SOM")) + +/* Max number of MAC addresses that are parsed/processed per daughter card */ +#define DAUGHTER_CARD_NO_OF_MAC_ADDR 8 + DECLARE_GLOBAL_DATA_PTR;
int board_init(void) @@ -81,3 +92,243 @@ int ft_board_setup(void *blob, bd_t *bd) return ret; } #endif + +int do_board_detect(void) +{ + int ret; + + ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, + CONFIG_EEPROM_CHIP_ADDRESS); + if (ret) + pr_err("Reading on-board EEPROM at 0x%02x failed %d\n", + CONFIG_EEPROM_CHIP_ADDRESS, ret); + + return ret; +} + +static void setup_board_eeprom_env(void) +{ + char *name = "j721e"; + + if (do_board_detect()) + goto invalid_eeprom; + + if (board_is_j721e_som()) + name = "j721e"; + else + printf("Unidentified board claims %s in eeprom header\n", + board_ti_get_name()); + +invalid_eeprom: + set_board_info_env_am6(name); +} + +static void setup_serial(void) +{ + struct ti_am6_eeprom *ep = TI_AM6_EEPROM_DATA; + unsigned long board_serial; + char *endp; + char serial_string[17] = { 0 }; + + if (env_get("serial#")) + return; + + board_serial = simple_strtoul(ep->serial, &endp, 16); + if (*endp != '\0') { + pr_err("Error: Can't set serial# to %s\n", ep->serial); + return; + } + + snprintf(serial_string, sizeof(serial_string), "%016lx", board_serial); + env_set("serial#", serial_string); +} + +/* + * Declaration of daughtercards to probe. Note that when adding more + * cards they should be grouped by the 'i2c_addr' field to allow for a + * more efficient probing process. + */ +static const struct { + u8 i2c_addr; /* I2C address of card EEPROM */ + char *card_name; /* EEPROM-programmed card name */ + char *dtbo_name; /* Device tree overlay to apply */ + u8 eth_offset; /* ethXaddr MAC address index offset */ +} ext_cards[] = { + { + 0x51, + "J7X-BASE-CPB", + "", /* No dtbo for this board */ + 0, + }, + { + 0x52, + "J7X-INFOTAN-EXP", + "", /* No dtbo for this board */ + 0, + }, + { + 0x52, + "J7X-GESI-EXP", + "", /* No dtbo for this board */ + 5, /* Start populating from eth5addr */ + }, + { + 0x54, + "J7X-VSC8514-ETH", + "", /* No dtbo for this board */ + 1, /* Start populating from eth1addr */ + }, +}; + +static bool daughter_card_detect_flags[ARRAY_SIZE(ext_cards)]; + +const char *board_fit_get_additionnal_images(int index, const char *type) +{ + int i, j; + + if (strcmp(type, FIT_FDT_PROP)) + return NULL; + + j = 0; + for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { + if (daughter_card_detect_flags[i]) { + if (j == index) { + /* + * Return dtbo name only if populated, + * otherwise stop parsing here. + */ + if (strlen(ext_cards[i].dtbo_name)) + return ext_cards[i].dtbo_name; + else + return NULL; + }; + + j++; + } + } + + return NULL; +} + +static int probe_daughtercards(void) +{ + char mac_addr[DAUGHTER_CARD_NO_OF_MAC_ADDR][TI_EEPROM_HDR_ETH_ALEN]; + bool eeprom_read_success; + struct ti_am6_eeprom ep; + u8 previous_i2c_addr; + u8 mac_addr_cnt; + int i; + int ret; + + /* Mark previous I2C address variable as not populated */ + previous_i2c_addr = 0xff; + + /* No EEPROM data was read yet */ + eeprom_read_success = false; + + /* Iterate through list of daughtercards */ + for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { + /* Obtain card-specific I2C address */ + u8 i2c_addr = ext_cards[i].i2c_addr; + + /* Read card EEPROM if not already read previously */ + if (i2c_addr != previous_i2c_addr) { + /* Store I2C address so we can avoid reading twice */ + previous_i2c_addr = i2c_addr; + + /* Get and parse the daughter card EEPROM record */ + ret = ti_i2c_eeprom_am6_get(CONFIG_EEPROM_BUS_ADDRESS, + i2c_addr, + &ep, + (char **)mac_addr, + DAUGHTER_CARD_NO_OF_MAC_ADDR, + &mac_addr_cnt); + if (ret) { + debug("%s: No daughtercard EEPROM at 0x%02x found %d\n", + __func__, i2c_addr, ret); + eeprom_read_success = false; + /* Skip to the next daughtercard to probe */ + continue; + } + + /* EEPROM read successful, okay to further process. */ + eeprom_read_success = true; + } + + /* Only continue processing if EEPROM data was read */ + if (!eeprom_read_success) + continue; + + /* Only process the parsed data if we found a match */ + if (strncmp(ep.name, ext_cards[i].card_name, sizeof(ep.name))) + continue; + + printf("Detected: %s rev %s\n", ep.name, ep.version); + daughter_card_detect_flags[i] = true; + +#ifndef CONFIG_SPL_BUILD + int j; + /* + * Populate any MAC addresses from daughtercard into the U-Boot + * environment, starting with a card-specific offset so we can + * have multiple ext_cards contribute to the MAC pool in a well- + * defined manner. + */ + for (j = 0; j < mac_addr_cnt; j++) { + if (!is_valid_ethaddr((u8 *)mac_addr[j])) + continue; + + eth_env_set_enetaddr_by_index("eth", + ext_cards[i].eth_offset + j, + (uchar *)mac_addr[j]); + } +#endif + } +#ifndef CONFIG_SPL_BUILD + char name_overlays[1024] = { 0 }; + + for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { + if (!daughter_card_detect_flags[i]) + continue; + + /* Skip if no overlays are to be added */ + if (!strlen(ext_cards[i].dtbo_name)) + continue; + + /* + * Make sure we are not running out of buffer space by checking + * if we can fit the new overlay, a trailing space to be used + * as a separator, plus the terminating zero. + */ + if (strlen(name_overlays) + strlen(ext_cards[i].dtbo_name) + 2 > + sizeof(name_overlays)) + return -ENOMEM; + + /* Append to our list of overlays */ + strcat(name_overlays, ext_cards[i].dtbo_name); + strcat(name_overlays, " "); + } + + /* Apply device tree overlay(s) to the U-Boot environment, if any */ + if (strlen(name_overlays)) + return env_set("name_overlays", name_overlays); +#endif + + return 0; +} + +int board_late_init(void) +{ + setup_board_eeprom_env(); + setup_serial(); + + /* Check for and probe any plugged-in daughtercards */ + probe_daughtercards(); + + return 0; +} + +void spl_board_init(void) +{ + probe_daughtercards(); +}
Print the board name and ver along with the DT Model.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/j721e/evm.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 7327c96b31..aa2240b852 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -106,6 +106,19 @@ int do_board_detect(void) return ret; }
+int checkboard(void) +{ + struct ti_am6_eeprom *ep = TI_AM6_EEPROM_DATA; + + if (do_board_detect()) + /* EEPROM not populated */ + printf("Board: %s rev %s\n", "J721EX-PM1-SOM", "E2"); + else + printf("Board: %s rev %s\n", ep->name, ep->version); + + return 0; +} + static void setup_board_eeprom_env(void) { char *name = "j721e";
Make the wkup_i2c0 module usable across all stages of U-Boot by adding the needed definitions including the associated pinmux definitions.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- .../dts/k3-j721e-common-proc-board-u-boot.dtsi | 8 ++++++++ arch/arm/dts/k3-j721e-common-proc-board.dts | 15 +++++++++++++++ 2 files changed, 23 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 9291e57e25..e54b2a7e70 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -311,3 +311,11 @@ reg-names = "gmii-sel"; }; }; + +&wkup_i2c0_pins_default { + u-boot,dm-spl; +}; + +&wkup_i2c0 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/k3-j721e-common-proc-board.dts b/arch/arm/dts/k3-j721e-common-proc-board.dts index c978cabd13..f4366f9f87 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board.dts +++ b/arch/arm/dts/k3-j721e-common-proc-board.dts @@ -77,3 +77,18 @@ voltage-ranges = <1800 1800 3300 3300>; ti,driver-strength-ohm = <50>; }; + +&wkup_pmx0 { + wkup_i2c0_pins_default: wkup-i2c0-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xf8, PIN_INPUT_PULLUP, 0) /* (J25) WKUP_I2C0_SCL */ + J721E_WKUP_IOPAD(0xfc, PIN_INPUT_PULLUP, 0) /* (H24) WKUP_I2C0_SDA */ + >; + }; +}; + +&wkup_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; +};
Enable I2C and EEPROM related configs for A72 SPL/U-Boot.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/j721e_evm_a72_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index daa661384d..c92d49005e 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -21,6 +21,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y @@ -34,6 +35,7 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y CONFIG_CMD_REMOTEPROC=y @@ -65,6 +67,8 @@ CONFIG_CLK_TI_SCI=y CONFIG_DMA_CHANNELS=y CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_MISC=y
Merged into u-boot-ti
Thanks and regards, Lokesh
Changes since v1:
Lokesh Vutla
