[PATCH] xilinx: Consolidate zynqmp_mmio_read/write in zynqmp_firmware.h
zynqmp_mmio_read/write() are firmware provided hooks that's why use only zynqmp_firmware.h for function declaration.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/mach-versal-net/include/mach/sys_proto.h | 2 -- arch/arm/mach-versal/include/mach/sys_proto.h | 2 -- arch/arm/mach-zynqmp/include/mach/sys_proto.h | 3 --- arch/arm/mach-zynqmp/mp.c | 1 + drivers/clk/clk_zynqmp.c | 1 + include/zynqmp_firmware.h | 1 + 6 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-versal-net/include/mach/sys_proto.h b/arch/arm/mach-versal-net/include/mach/sys_proto.h index a20cf02712bd..23374d10a6b4 100644 --- a/arch/arm/mach-versal-net/include/mach/sys_proto.h +++ b/arch/arm/mach-versal-net/include/mach/sys_proto.h @@ -7,5 +7,3 @@ #include <linux/build_bug.h>
void mem_map_fill(void); - -int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value); diff --git a/arch/arm/mach-versal/include/mach/sys_proto.h b/arch/arm/mach-versal/include/mach/sys_proto.h index 433f9ba07c77..757bd873fbee 100644 --- a/arch/arm/mach-versal/include/mach/sys_proto.h +++ b/arch/arm/mach-versal/include/mach/sys_proto.h @@ -13,5 +13,3 @@ enum { void initialize_tcm(bool mode); void tcm_init(u8 mode); void mem_map_fill(void); - -int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value); diff --git a/arch/arm/mach-zynqmp/include/mach/sys_proto.h b/arch/arm/mach-zynqmp/include/mach/sys_proto.h index c6733ed1bbe7..ede00d73fe0c 100644 --- a/arch/arm/mach-zynqmp/include/mach/sys_proto.h +++ b/arch/arm/mach-zynqmp/include/mach/sys_proto.h @@ -48,9 +48,6 @@ enum {
unsigned int zynqmp_get_silicon_version(void);
-int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value); -int zynqmp_mmio_read(const u32 address, u32 *value); - void initialize_tcm(bool mode); void mem_map_fill(void); #if defined(CONFIG_SYS_MEM_RSVD_FOR_MMU) || defined(CONFIG_DEFINE_TCM_OCM_MMAP) diff --git a/arch/arm/mach-zynqmp/mp.c b/arch/arm/mach-zynqmp/mp.c index b06c867e57f6..4c514258ba69 100644 --- a/arch/arm/mach-zynqmp/mp.c +++ b/arch/arm/mach-zynqmp/mp.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <log.h> +#include <zynqmp_firmware.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> #include <asm/io.h> diff --git a/drivers/clk/clk_zynqmp.c b/drivers/clk/clk_zynqmp.c index be0ee50e0e4f..8320d4918462 100644 --- a/drivers/clk/clk_zynqmp.c +++ b/drivers/clk/clk_zynqmp.c @@ -12,6 +12,7 @@ #include <linux/bitops.h> #include <clk-uclass.h> #include <clk.h> +#include <zynqmp_firmware.h> #include <asm/arch/sys_proto.h> #include <dm.h> #include <linux/err.h> diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index c56ad3f92067..18a87d274954 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -454,6 +454,7 @@ int zynqmp_pm_set_sd_config(u32 node, enum pm_sd_config_type config, u32 value); int zynqmp_pm_set_gem_config(u32 node, enum pm_gem_config_type config, u32 value); int zynqmp_pm_is_function_supported(const u32 api_id, const u32 id); +int zynqmp_mmio_read(const u32 address, u32 *value); int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value);
/* Type of Config Object */
pá 23. 6. 2023 v 14:52 odesílatel Michal Simek michal.simek@amd.com napsal:
2.36.1
Applied. M
Michal Simek
Michal Simek
