[U-Boot] [PATCH 1/2] mpc83xx: Fix ipic structure definition
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- arch/powerpc/include/asm/immap_83xx.h | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_83xx.h b/arch/powerpc/include/asm/immap_83xx.h index cc0293a..8e2a551 100644 --- a/arch/powerpc/include/asm/immap_83xx.h +++ b/arch/powerpc/include/asm/immap_83xx.h @@ -154,7 +154,7 @@ typedef struct ipic83xx { u32 siprr_d; /* System Internal Interrupt Group D Priority Register */ u32 simsr_h; /* System Internal Interrupt Mask Register - High */ u32 simsr_l; /* System Internal Interrupt Mask Register - Low */ - u8 res1[4]; + u32 sicnr; /* System Internal Interrupt Control Register */ u32 sepnr; /* System External Interrupt Pending Register */ u32 smprr_a; /* System Mixed Interrupt Group A Priority Register */ u32 smprr_b; /* System Mixed Interrupt Group B Priority Register */ @@ -163,14 +163,14 @@ typedef struct ipic83xx { u32 sersr; /* System Error Status Register */ u32 sermr; /* System Error Mask Register */ u32 sercr; /* System Error Control Register */ - u8 res2[4]; + u8 res1[4]; u32 sifcr_h; /* System Internal Interrupt Force Register - High */ u32 sifcr_l; /* System Internal Interrupt Force Register - Low */ u32 sefcr; /* System External Interrupt Force Register */ u32 serfr; /* System Error Force Register */ u32 scvcr; /* System Critical Interrupt Vector Register */ u32 smvcr; /* System Management Interrupt Vector Register */ - u8 res3[0x98]; + u8 res2[0x98]; } ipic83xx_t;
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- arch/powerpc/cpu/mpc83xx/interrupts.c | 447 ++++++++++++++++++++++++++++++-- arch/powerpc/include/asm/mpc83xx_irq.h | 72 +++++ 2 files changed, 499 insertions(+), 20 deletions(-) create mode 100644 arch/powerpc/include/asm/mpc83xx_irq.h
diff --git a/arch/powerpc/cpu/mpc83xx/interrupts.c b/arch/powerpc/cpu/mpc83xx/interrupts.c index 446af27..5661421 100644 --- a/arch/powerpc/cpu/mpc83xx/interrupts.c +++ b/arch/powerpc/cpu/mpc83xx/interrupts.c @@ -26,17 +26,385 @@ #include <common.h> #include <command.h> #include <mpc83xx.h> +#include <asm/io.h> +#include <asm/mpc83xx_irq.h> #include <asm/processor.h>
DECLARE_GLOBAL_DATA_PTR;
+/* + * Some ipic code copied from the linux 2.6 kernel: + * /arch/powerpc/sysdev/ipic.* + * /arch/powerpc/include/asm/ipic.h + */ +static struct ipic_info_t ipic_info[] = { + [1] = { + .mask = IPIC_SIMSR_H, + .bit = 16, + }, + [2] = { + .mask = IPIC_SIMSR_H, + .bit = 17, + }, + [3] = { + .mask = IPIC_SIMSR_H, + .bit = 18, + }, + [4] = { + .mask = IPIC_SIMSR_H, + .bit = 19, + }, + [5] = { + .mask = IPIC_SIMSR_H, + .bit = 20, + }, + [6] = { + .mask = IPIC_SIMSR_H, + .bit = 21, + }, + [7] = { + .mask = IPIC_SIMSR_H, + .bit = 22, + }, + [8] = { + .mask = IPIC_SIMSR_H, + .bit = 23, + }, + [IPIC_INT_UART1] = { + .mask = IPIC_SIMSR_H, + .bit = 24, + }, + [IPIC_INT_UART2] = { + .mask = IPIC_SIMSR_H, + .bit = 25, + }, + [IPIC_INT_SEC] = { + .mask = IPIC_SIMSR_H, + .bit = 26, + }, + [IPIC_INT_1588_1] = { + .mask = IPIC_SIMSR_H, + .bit = 27, + }, + [IPIC_INT_1588_2] = { + .mask = IPIC_SIMSR_H, + .bit = 28, + }, + [IPIC_INT_I2C1] = { + .mask = IPIC_SIMSR_H, + .bit = 29, + }, + [IPIC_INT_I2C2] = { + .mask = IPIC_SIMSR_H, + .bit = 30, + }, + [IPIC_INT_SPI] = { + .mask = IPIC_SIMSR_H, + .bit = 31, + }, + [IPIC_INT_IRQ1] = { + .ack = IPIC_SEPNR, + .mask = IPIC_SEMSR, + .bit = 1, + }, + [IPIC_INT_IRQ2] = { + .ack = IPIC_SEPNR, + .mask = IPIC_SEMSR, + .bit = 2, + }, + [IPIC_INT_IRQ3] = { + .ack = IPIC_SEPNR, + .mask = IPIC_SEMSR, + .bit = 3, + }, + [IPIC_INT_IRQ4] = { + .ack = IPIC_SEPNR, + .mask = IPIC_SEMSR, + .bit = 4, + }, + [21] = { + .ack = IPIC_SEPNR, + .mask = IPIC_SEMSR, + .bit = 5, + }, + [22] = { + .ack = IPIC_SEPNR, + .mask = IPIC_SEMSR, + .bit = 6, + }, + [23] = { + .ack = IPIC_SEPNR, + .mask = IPIC_SEMSR, + .bit = 7, + }, + [IPIC_INT_TSEC1_TX] = { + .mask = IPIC_SIMSR_H, + .bit = 0, + }, + [IPIC_INT_TSEC1_RX] = { + .mask = IPIC_SIMSR_H, + .bit = 1, + }, + [IPIC_INT_TSEC1_ERR] = { + .mask = IPIC_SIMSR_H, + .bit = 2, + }, + [IPIC_INT_TSEC2_TX] = { + .mask = IPIC_SIMSR_H, + .bit = 3, + }, + [IPIC_INT_TSEC2_RX] = { + .mask = IPIC_SIMSR_H, + .bit = 4, + }, + [IPIC_INT_TSEC2_ERR] = { + .mask = IPIC_SIMSR_H, + .bit = 5, + }, + [IPIC_INT_USB_DR] = { + .mask = IPIC_SIMSR_H, + .bit = 6, + }, + [39] = { + .mask = IPIC_SIMSR_H, + .bit = 7, + }, + [40] = { + .mask = IPIC_SIMSR_H, + .bit = 8, + }, + [41] = { + .mask = IPIC_SIMSR_H, + .bit = 9, + }, + [42] = { + .mask = IPIC_SIMSR_H, + .bit = 10, + }, + [43] = { + .mask = IPIC_SIMSR_H, + .bit = 11, + }, + [44] = { + .mask = IPIC_SIMSR_H, + .bit = 12, + }, + [45] = { + .mask = IPIC_SIMSR_H, + .bit = 13, + }, + [46] = { + .mask = IPIC_SIMSR_H, + .bit = 14, + }, + [47] = { + .mask = IPIC_SIMSR_H, + .bit = 15, + }, + [IPIC_INT_IRQ0] = { + .ack = IPIC_SEPNR, + .mask = IPIC_SEMSR, + .bit = 0, + }, + [IPIC_INT_RTC_SEC] = { + .mask = IPIC_SIMSR_L, + .bit = 0, + }, + [IPIC_INT_PIT] = { + .mask = IPIC_SIMSR_L, + .bit = 1, + }, + [IPIC_INT_PCI] = { + .mask = IPIC_SIMSR_L, + .bit = 2, + }, + [67] = { + .mask = IPIC_SIMSR_L, + .bit = 3, + }, + [IPIC_INT_RTC_ALR] = { + .mask = IPIC_SIMSR_L, + .bit = 4, + }, + [IPIC_INT_MU] = { + .mask = IPIC_SIMSR_L, + .bit = 5, + }, + [IPIC_INT_SBA] = { + .mask = IPIC_SIMSR_L, + .bit = 6, + }, + [IPIC_INT_DMA] = { + .mask = IPIC_SIMSR_L, + .bit = 7, + }, + [IPIC_INT_GTM4] = { + .mask = IPIC_SIMSR_L, + .bit = 8, + }, + [IPIC_INT_GTM8] = { + .mask = IPIC_SIMSR_L, + .bit = 9, + }, + [IPIC_INT_GPIO] = { + .mask = IPIC_SIMSR_L, + .bit = 10, + }, + [75] = { + .mask = IPIC_SIMSR_L, + .bit = 11, + }, + [IPIC_INT_DDR] = { + .mask = IPIC_SIMSR_L, + .bit = 12, + }, + [IPIC_INT_LBC] = { + .mask = IPIC_SIMSR_L, + .bit = 13, + }, + [IPIC_INT_GTM2] = { + .mask = IPIC_SIMSR_L, + .bit = 14, + }, + [IPIC_INT_GTM6] = { + .mask = IPIC_SIMSR_L, + .bit = 15, + }, + [IPIC_INT_PMC] = { + .mask = IPIC_SIMSR_L, + .bit = 16, + }, + [81] = { + .mask = IPIC_SIMSR_L, + .bit = 17, + }, + [82] = { + .mask = IPIC_SIMSR_L, + .bit = 18, + }, + [83] = { + .mask = IPIC_SIMSR_L, + .bit = 19, + }, + [IPIC_INT_GTM3] = { + .mask = IPIC_SIMSR_L, + .bit = 20, + }, + [IPIC_INT_GTM7] = { + .mask = IPIC_SIMSR_L, + .bit = 21, + }, + [86] = { + .mask = IPIC_SIMSR_L, + .bit = 22, + }, + [87] = { + .mask = IPIC_SIMSR_L, + .bit = 23, + }, + [88] = { + .mask = IPIC_SIMSR_L, + .bit = 24, + }, + [89] = { + .mask = IPIC_SIMSR_L, + .bit = 25, + }, + [IPIC_INT_GTM1] = { + .mask = IPIC_SIMSR_L, + .bit = 26, + }, + [IPIC_INT_GTM5] = { + .mask = IPIC_SIMSR_L, + .bit = 27, + }, + [92] = { + .mask = IPIC_SIMSR_L, + .bit = 28, + }, + [93] = { + .mask = IPIC_SIMSR_L, + .bit = 29, + }, + [94] = { + .mask = IPIC_SIMSR_L, + .bit = 30, + }, +}; + +static inline u32 ipic_read(u32 reg) +{ + immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; + return in_be32((u32 *)&immr->ipic + (reg >> 2)); +} + +static inline void ipic_write(u32 reg, u32 value) +{ + immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; + out_be32((u32 *)&immr->ipic + (reg >> 2), value); +} + +#define MAKE_MASK(bit) (1 << (31 - (bit))) + +static void ipic_unmask_irq(u32 irq) +{ + u32 temp; + + temp = ipic_read(ipic_info[irq].mask); + temp |= MAKE_MASK(ipic_info[irq].bit); + ipic_write(ipic_info[irq].mask, temp); +} + +static void ipic_mask_irq(u32 irq) +{ + u32 temp; + + temp = ipic_read(ipic_info[irq].mask); + temp &= ~MAKE_MASK(ipic_info[irq].bit); + ipic_write(ipic_info[irq].mask, temp); +} + +static void ipic_ack_irq(u32 irq) +{ + u32 temp; + + if (ipic_info[irq].ack) { + temp = MAKE_MASK(ipic_info[irq].bit); + ipic_write(ipic_info[irq].ack, temp); + } +} + +static void ipic_mask_irq_and_ack(u32 irq) +{ + ipic_mask_irq(irq); + ipic_ack_irq(irq); +} + +u32 ipic_get_irq(void) +{ + int irq; + + #define IPIC_SIVCR_VECTOR_MASK 0x7f + irq = ipic_read(IPIC_SIVCR) & IPIC_SIVCR_VECTOR_MASK; + + /* 0 --> no irq is pending */ + + return irq; +} + +/* + * End code copied from Linux + */ + struct irq_action { interrupt_handler_t *handler; void *arg; ulong count; };
-int interrupt_init_cpu (unsigned *decrementer_count) +static struct irq_action irq_handlers[NR_IRQS]; + +int interrupt_init_cpu(unsigned *decrementer_count) { volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR;
@@ -54,44 +422,83 @@ int interrupt_init_cpu (unsigned *decrementer_count) * Handle external interrupts */
-void external_interrupt (struct pt_regs *regs) +void external_interrupt(struct pt_regs *regs) { -} + int irq, unmask = 1;
+ irq = ipic_get_irq();
-/* - * Install and free an interrupt handler. - */ + ipic_mask_irq_and_ack(irq);
-void -irq_install_handler (int irq, interrupt_handler_t * handler, void *arg) -{ -} + if (irq_handlers[irq].handler != NULL) { + (*irq_handlers[irq].handler) (irq_handlers[irq].arg); + } else { + printf("\nBogus External Interrupt IRQ %d\n", irq); + /* + * turn off the bogus interrupt, otherwise it + * might repeat forever + */ + unmask = 0; + }
+ enable_interrupts();
-void irq_free_handler (int irq) -{ + if (unmask) + ipic_unmask_irq(irq); }
-void timer_interrupt_cpu (struct pt_regs *regs) +/* + * timer_interrupt - gets called when the decrementer overflows, + * with interrupts disabled. + */ +void timer_interrupt_cpu(struct pt_regs *regs) { /* nothing to do here */ return; }
-#if defined(CONFIG_CMD_IRQ) - -/* ripped this out of ppc4xx/interrupts.c */ - /* - * irqinfo - print information about PCI devices + * Install and free an interrupt handler. */
-void -do_irqinfo(cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char * const argv[]) +void irq_install_handler(int irq, interrupt_handler_t *handler, void *arg) +{ + if (irq < 0 || irq >= NR_IRQS) { + printf("irq_install_handler: bad irq number %d\n", irq); + return; + } + + if (irq_handlers[irq].handler != NULL) + printf("irq_install_handler: 0x%08lx replacing 0x%08lx\n", + (ulong) handler, (ulong) irq_handlers[irq].handler); + + irq_handlers[irq].handler = handler; + irq_handlers[irq].arg = arg; + + ipic_unmask_irq(irq); +} + + +void irq_free_handler(int irq) { + if (irq < 0 || irq >= NR_IRQS) { + printf("irq_free_handler: bad irq number %d\n", irq); + return; + } + + ipic_mask_irq(irq); + + irq_handlers[irq].handler = NULL; + irq_handlers[irq].arg = NULL; }
+ +#if defined(CONFIG_CMD_IRQ) +void do_irqinfo(cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char *argv[]) +{ +} #endif + + diff --git a/arch/powerpc/include/asm/mpc83xx_irq.h b/arch/powerpc/include/asm/mpc83xx_irq.h new file mode 100644 index 0000000..28804b7 --- /dev/null +++ b/arch/powerpc/include/asm/mpc83xx_irq.h @@ -0,0 +1,72 @@ +#ifndef _MPC83xx_IRQ_H +#define _MPC83xx_IRQ_H + +#define NR_IRQS 128 + +/* + * Some ipic code copied from the linux 2.6 kernel: + * /arch/powerpc/sysdev/ipic.* + * /arch/powerpc/include/asm/ipic.h + */ +#define IPIC_SICFR 0x00 /* System Global Interrupt Configuration Register */ +#define IPIC_SIVCR 0x04 /* System Global Interrupt Vector Register */ +#define IPIC_SIPNR_H 0x08 /* System Internal Interrupt Pending Register (HIGH) */ +#define IPIC_SIPNR_L 0x0C /* System Internal Interrupt Pending Register (LOW) */ +#define IPIC_SIMSR_H 0x20 /* System Internal Interrupt Mask Register (HIGH) */ +#define IPIC_SIMSR_L 0x24 /* System Internal Interrupt Mask Register (LOW) */ +#define IPIC_SEPNR 0x2C /* System External Interrupt Pending Register */ +#define IPIC_SEMSR 0x38 /* System External Interrupt Mask Register */ + +struct ipic_info_t { + u8 ack; /* pending register offset from base if the irq + supports ack operation */ + u8 mask; /* mask register offset from base */ + u8 bit; /* register bit position (as per doc) + bit mask = 1 << (31 - bit) */ +}; + + +/* + * This list is specific to the mpc8313e for now. + */ +#define IPIC_INT_UART1 (0x09) +#define IPIC_INT_UART2 (0x0A) +#define IPIC_INT_SEC (0x0B) +#define IPIC_INT_1588_1 (0x0C) +#define IPIC_INT_1588_2 (0x0D) +#define IPIC_INT_I2C1 (0x0E) +#define IPIC_INT_I2C2 (0x0F) +#define IPIC_INT_SPI (0x10) +#define IPIC_INT_IRQ1 (0x11) +#define IPIC_INT_IRQ2 (0x12) +#define IPIC_INT_IRQ3 (0x13) +#define IPIC_INT_IRQ4 (0x14) +#define IPIC_INT_TSEC1_TX (0x20) +#define IPIC_INT_TSEC1_RX (0x21) +#define IPIC_INT_TSEC1_ERR (0x22) +#define IPIC_INT_TSEC2_TX (0x23) +#define IPIC_INT_TSEC2_RX (0x24) +#define IPIC_INT_TSEC2_ERR (0x25) +#define IPIC_INT_USB_DR (0x26) +#define IPIC_INT_IRQ0 (0x30) +#define IPIC_INT_RTC_SEC (0x40) +#define IPIC_INT_PIT (0x41) +#define IPIC_INT_PCI (0x42) +#define IPIC_INT_RTC_ALR (0x44) +#define IPIC_INT_MU (0x45) +#define IPIC_INT_SBA (0x46) +#define IPIC_INT_DMA (0x47) +#define IPIC_INT_GTM4 (0x48) +#define IPIC_INT_GTM8 (0x49) +#define IPIC_INT_GPIO (0x4A) +#define IPIC_INT_DDR (0x4C) +#define IPIC_INT_LBC (0x4D) +#define IPIC_INT_GTM2 (0x4E) +#define IPIC_INT_GTM6 (0x4F) +#define IPIC_INT_PMC (0x50) +#define IPIC_INT_GTM3 (0x54) +#define IPIC_INT_GTM7 (0x55) +#define IPIC_INT_GTM1 (0x5A) +#define IPIC_INT_GTM5 (0x5B) + +#endif /* _MPC83xx_IRQ_H */
Dear Joe Hershberger,
In message 1317856455-30829-2-git-send-email-joe.hershberger@ni.com you wrote:
Checkpatch says:
total: 0 errors, 5 warnings, 560 lines checked
Please clean up and resubmit. Thanks.
Checkpatch says:
Hi Wolfgang,
Done. Sorry about that... figured that it would be an exception since it was copied from Linux.
Best, -Joe
In message CANr=Z=YVvLY+05xYmkESzYV+257bOwSxjFHpP5FSvQXUarjcRQ@mail.gmail.com you wrote:
Checkpatch says:
Please clean up and resubmit. =A0Thanks.
If needed, the kernel code should be cleaned up in sync.
BTW: if this is copied from Linux, then you failed to provide exact reference - see bullet # 4 at http://www.denx.de/wiki/view/U-Boot/Patches#Attributing_Code_Copyrights_Sign
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- Changes for v2: Changes for v3:
diff --git a/arch/powerpc/include/asm/immap_83xx.h b/arch/powerpc/include/asm/immap_83xx.h index 8d4c9cb..d6becc9 100644 --- a/arch/powerpc/include/asm/immap_83xx.h +++ b/arch/powerpc/include/asm/immap_83xx.h @@ -154,7 +154,7 @@ typedef struct ipic83xx { u32 siprr_d; /* System Internal Interrupt Group D Priority Register */ u32 simsr_h; /* System Internal Interrupt Mask Register - High */ u32 simsr_l; /* System Internal Interrupt Mask Register - Low */ - u8 res1[4]; + u32 sicnr; /* System Internal Interrupt Control Register */ u32 sepnr; /* System External Interrupt Pending Register */ u32 smprr_a; /* System Mixed Interrupt Group A Priority Register */ u32 smprr_b; /* System Mixed Interrupt Group B Priority Register */ @@ -163,14 +163,14 @@ typedef struct ipic83xx { u32 sersr; /* System Error Status Register */ u32 sermr; /* System Error Mask Register */ u32 sercr; /* System Error Control Register */ - u8 res2[4]; + u8 res1[4]; u32 sifcr_h; /* System Internal Interrupt Force Register - High */ u32 sifcr_l; /* System Internal Interrupt Force Register - Low */ u32 sefcr; /* System External Interrupt Force Register */ u32 serfr; /* System Error Force Register */ u32 scvcr; /* System Critical Interrupt Vector Register */ u32 smvcr; /* System Management Interrupt Vector Register */ - u8 res3[0x98]; + u8 res2[0x98]; } ipic83xx_t;
Some core ipic code from Linux - commit bbf25010f1a6b761914430f5fca081ec8c7accd1
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- Changes for v2: - Shorten some lines containing constants copied from Linux Changes for v3: - Explicitly identify the Linux commit that ipic source came from
+ +#if defined(CONFIG_CMD_IRQ) +void do_irqinfo(cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char *argv[]) +{ +} #endif + + diff --git a/arch/powerpc/include/asm/mpc83xx_irq.h b/arch/powerpc/include/asm/mpc83xx_irq.h new file mode 100644 index 0000000..fc77134 --- /dev/null +++ b/arch/powerpc/include/asm/mpc83xx_irq.h @@ -0,0 +1,72 @@ +#ifndef _MPC83xx_IRQ_H +#define _MPC83xx_IRQ_H + +#define NR_IRQS 128 + +/* + * Some ipic code copied from the linux 2.6 kernel: + * /arch/powerpc/sysdev/ipic.* + * /arch/powerpc/include/asm/ipic.h + */ +#define IPIC_SICFR 0x00 /* System Global Interrupt Configuration Reg */ +#define IPIC_SIVCR 0x04 /* System Global Interrupt Vector Register */ +#define IPIC_SIPNR_H 0x08 /* System Internal Interrupt Pending Reg (HIGH) */ +#define IPIC_SIPNR_L 0x0C /* System Internal Interrupt Pending Reg (LOW) */ +#define IPIC_SIMSR_H 0x20 /* System Internal Interrupt Mask Reg (HIGH) */ +#define IPIC_SIMSR_L 0x24 /* System Internal Interrupt Mask Reg (LOW) */ +#define IPIC_SEPNR 0x2C /* System External Interrupt Pending Register */ +#define IPIC_SEMSR 0x38 /* System External Interrupt Mask Register */ + +struct ipic_info_t { + u8 ack; /* pending register offset from base if the irq + supports ack operation */ + u8 mask; /* mask register offset from base */ + u8 bit; /* register bit position (as per doc) + bit mask = 1 << (31 - bit) */ +}; + + +/* + * This list is specific to the mpc8313e for now. + */ +#define IPIC_INT_UART1 (0x09) +#define IPIC_INT_UART2 (0x0A) +#define IPIC_INT_SEC (0x0B) +#define IPIC_INT_1588_1 (0x0C) +#define IPIC_INT_1588_2 (0x0D) +#define IPIC_INT_I2C1 (0x0E) +#define IPIC_INT_I2C2 (0x0F) +#define IPIC_INT_SPI (0x10) +#define IPIC_INT_IRQ1 (0x11) +#define IPIC_INT_IRQ2 (0x12) +#define IPIC_INT_IRQ3 (0x13) +#define IPIC_INT_IRQ4 (0x14) +#define IPIC_INT_TSEC1_TX (0x20) +#define IPIC_INT_TSEC1_RX (0x21) +#define IPIC_INT_TSEC1_ERR (0x22) +#define IPIC_INT_TSEC2_TX (0x23) +#define IPIC_INT_TSEC2_RX (0x24) +#define IPIC_INT_TSEC2_ERR (0x25) +#define IPIC_INT_USB_DR (0x26) +#define IPIC_INT_IRQ0 (0x30) +#define IPIC_INT_RTC_SEC (0x40) +#define IPIC_INT_PIT (0x41) +#define IPIC_INT_PCI (0x42) +#define IPIC_INT_RTC_ALR (0x44) +#define IPIC_INT_MU (0x45) +#define IPIC_INT_SBA (0x46) +#define IPIC_INT_DMA (0x47) +#define IPIC_INT_GTM4 (0x48) +#define IPIC_INT_GTM8 (0x49) +#define IPIC_INT_GPIO (0x4A) +#define IPIC_INT_DDR (0x4C) +#define IPIC_INT_LBC (0x4D) +#define IPIC_INT_GTM2 (0x4E) +#define IPIC_INT_GTM6 (0x4F) +#define IPIC_INT_PMC (0x50) +#define IPIC_INT_GTM3 (0x54) +#define IPIC_INT_GTM7 (0x55) +#define IPIC_INT_GTM1 (0x5A) +#define IPIC_INT_GTM5 (0x5B) + +#endif /* _MPC83xx_IRQ_H */
On Tue, 11 Oct 2011 21:46:05 -0500 Joe Hershberger joe.hershberger@ni.com wrote:
commit bbf25010f1a6b761914430f5fca081ec8c7accd1 Author: Linus Torvalds torvalds@woody.linux-foundation.org Date: Tue Oct 9 13:31:38 2007 -0700
Linux 2.6.23
...any particular reason to pull in such an old version?
- Some ipic code copied from the linux 2.6 kernel:
- /arch/powerpc/sysdev/ipic.*
- /arch/powerpc/include/asm/ipic.h
And why hasn't the Freescale copyright info been retained???
- This list is specific to the mpc8313e for now.
it shouldn't have to be. How is this list used outside of interrupts.c?
Is it possible to avoid the list altogether somehow? Use an embedded device tree? See doc/README.fdt-control.
Kim
Hi Kim,
On Thu, Nov 3, 2011 at 3:48 PM, Kim Phillips kim.phillips@freescale.com wrote:
Linux 2.6.23
That was the current version when I implemented the interrupt support.
Oversight. Sorry.
Simply because I didn't audit every other SoC in the family to determine how to make it generic.
Perhaps that is a good long-term approach. I'm not sure I'm up for that retrofit just now. ;)
Thanks, -Joe
On Mon, 7 Nov 2011 20:08:49 -0600 Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Kim,
Linux 2.6.23
well it would have worked back then ;). A lot of vectors for the later 83xx SoCs have been added in upstream linux since then.
understood. Dropping this table is important because of things like TSEC IRQ numbers changing in between revisions of the 8313 (see commit 7120c88 (which doubles as a good example of how to extract the IRQ numbers from the device tree :)).
Kim
On Wed, Oct 5, 2011 at 6:14 PM, Joe Hershberger joe.hershberger@ni.com wrote:
Where's the patch description? You need to explain how this patch works.
On Wed, 5 Oct 2011 18:14:14 -0500 Joe Hershberger joe.hershberger@ni.com wrote:
applied after adding siprr_{b,c} and sepcr for completeness.
Kim
participants (5)
Joe Hershberger
Joe Hershberger
Kim Phillips
Tabi Timur-B04825
