[U-Boot] pull request: u-boot-uniphier/master
Hi Tom,
Please pull u-boot-uniphier/master.
The following changes since commit 012681b1fa822492bb8fdc5c2dd3d24d6092e110:
am33xx, spl, siemens: enable debug uart output again (2015-05-28 08:18:25 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to fcb2525d373f7a5bab213e8a89681bd3b7d09c44:
ARM: UniPhier: add pin mux setting for NAND CS1 of PH1-Pro4 (2015-05-31 02:56:02 +0900)
---------------------------------------------------------------- Masahiro Yamada (11): ARM: UniPhier: replace <asm/io.h> with <linux/io.h> ARM: UniPhier: update the vendor name of UniPhier in Kconfig ARM: UniPhier: use 32 bit register access for debug UART setting ARM: UniPhier: remove unnecessary cache coherency code ARM: UniPhier: remove meaningless CONFIG_SPL_BUILD ifdefs ARM: UniPhier: move CONFIG_SYS_TEXT_BASE to Kconfig ARM: UniPhier: set MACH_PH1_PRO4 as default SoC ARM: UniPhier: enable CONFIG_NET_RANDOM_ETHADDR ARM: UniPhier: update DDR PHY register map for PH1-Pro5 ARM: UniPhier: fix pin mux setting for USB port 2 of PH1-sLD8 ARM: UniPhier: add pin mux setting for NAND CS1 of PH1-Pro4
Kconfig | 2 +- arch/arm/Kconfig | 5 ++++- arch/arm/mach-uniphier/Kconfig | 7 +++---- arch/arm/mach-uniphier/board_late_init.c | 5 ++--- arch/arm/mach-uniphier/cache_uniphier.c | 6 ++---- arch/arm/mach-uniphier/cmd_ddrphy.c | 5 ++--- arch/arm/mach-uniphier/cpu_info.c | 5 ++--- arch/arm/mach-uniphier/ddrphy_training.c | 9 ++------- arch/arm/mach-uniphier/include/mach/ddrphy-regs.h | 11 +++++++---- arch/arm/mach-uniphier/include/mach/debug-uart.S | 7 +++---- arch/arm/mach-uniphier/include/mach/led.h | 5 ++--- arch/arm/mach-uniphier/include/mach/sbc-regs.h | 4 ++-- arch/arm/mach-uniphier/include/mach/sg-regs.h | 4 ++-- arch/arm/mach-uniphier/lowlevel_init.S | 24 +----------------------- arch/arm/mach-uniphier/memconf.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/bcu_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/pinctrl.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/sbc_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/sg_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/umc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/boot-mode.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/pinctrl.c | 7 ++++--- arch/arm/mach-uniphier/ph1-pro4/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/sbc_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/sg_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/umc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/pinctrl.c | 9 ++++----- arch/arm/mach-uniphier/ph1-sld8/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-sld8/umc_init.c | 4 ++-- arch/arm/mach-uniphier/reset.c | 5 ++--- arch/arm/mach-uniphier/support_card.c | 6 ++---- arch/arm/mach-uniphier/timer.c | 5 ++--- configs/ph1_ld4_defconfig | 3 +++ configs/ph1_pro4_defconfig | 4 +++- configs/ph1_sld8_defconfig | 3 +++ drivers/i2c/Kconfig | 6 +++--- drivers/i2c/i2c-uniphier-f.c | 6 ++---- drivers/i2c/i2c-uniphier.c | 6 ++---- drivers/serial/Kconfig | 5 +++-- drivers/serial/serial_uniphier.c | 6 ++---- drivers/usb/host/Kconfig | 10 ++++------ drivers/usb/host/ehci-uniphier.c | 6 ++---- drivers/usb/host/xhci-uniphier.c | 5 ++--- include/configs/uniphier.h | 8 +++----- 56 files changed, 131 insertions(+), 183 deletions(-)
On Sun, May 31, 2015 at 03:05:17AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
