[PATCH] Output information about device look up failure.
In the case of error while device look up (e.g. wrong interface type was specified) put a message about it even if debug was not enable.
Signed-off-by: Nikita Ermakov coffe92@gmail.com --- disk/part.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/disk/part.c b/disk/part.c index 8982ef3bae..280e3e4f42 100644 --- a/disk/part.c +++ b/disk/part.c @@ -513,7 +513,10 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str, /* Look up the device */ dev = blk_get_device_by_str(ifname, dev_str, dev_desc); if (dev < 0) + { + printf("** Look up for the device %s %s failed **\n", ifname, dev_str); goto cleanup; + }
/* Convert partition ID string to number */ if (!part_str || !*part_str) {
Dear Nikita,
goto cleanup;printf("** Look up for the device %s %s failed **\n", ifname, dev_str);
Please see my other patch instead.
You are using incorrect brace style, and I think your error message is a bit misleading - "look up failed" sounds like some internal error, the reason of which is still unclear. We should instead say clearly the the given device type is not supported/known in the given configuration.
Thanks.
Nikita Ermakov
