[U-Boot] [PATCH v9 24/28] armv8/ls2085aqds: NAND boot support
This adds NAND boot support for LS2085AQDS, using SPL framework. Details of forming NAND image can be found in README.
Signed-off-by: Scott Wood scottwood@freescale.com Signed-off-by: York Sun yorksun@freescale.com
Changes in v9: Update README for QDS NAND boot offset, page size, block size. Fix nand block size in QDS board header file.
Changes in v8: Update README to match the example for QDS NAND boot.
Changes in v7: Move NAND boot instruction to fsl-lsch3/README. Update board setting to put RCW and u-boot in different NAND block.
Changes in v6: None Changes in v5: Update LS2085AQDS README to include instructions to form NAND image
Changes in v4: Update MAINTAINERS file
arch/arm/Kconfig | 1 + arch/arm/cpu/armv8/fsl-lsch3/README | 38 +++++++++++ arch/arm/cpu/armv8/fsl-lsch3/soc.c | 48 +++++++++++++ arch/arm/cpu/armv8/{u-boot.lds => u-boot-spl.lds} | 74 +++++++++------------ arch/arm/include/asm/arch-fsl-lsch3/config.h | 9 +++ arch/arm/lib/crt0_64.S | 7 ++ board/freescale/ls2085aqds/MAINTAINERS | 1 + board/freescale/ls2085aqds/ddr.c | 4 ++ common/spl/spl.c | 2 +- common/spl/spl_nand.c | 2 +- configs/ls2085aqds_nand_defconfig | 4 ++ drivers/misc/fsl_ifc.c | 12 ++++ drivers/mtd/nand/fsl_ifc_spl.c | 2 +- include/configs/ls2085a_common.h | 29 ++++++++ include/configs/ls2085aqds.h | 50 ++++++++++++-- 15 files changed, 232 insertions(+), 51 deletions(-) copy arch/arm/cpu/armv8/{u-boot.lds => u-boot-spl.lds} (57%) create mode 100644 configs/ls2085aqds_nand_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6ba4b8d..f73541c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -652,6 +652,7 @@ config TARGET_LS2085AQDS bool "Support ls2085aqds" select ARM64 select ARMV8_MULTIENTRY + select SUPPORT_SPL help Support for Freescale LS2085AQDS platform The LS2085A Development System (QDS) is a high-performance diff --git a/arch/arm/cpu/armv8/fsl-lsch3/README b/arch/arm/cpu/armv8/fsl-lsch3/README index 4f36e2a..15a1549 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/README +++ b/arch/arm/cpu/armv8/fsl-lsch3/README @@ -95,3 +95,41 @@ mcboottimeout: MC boot timeout in milliseconds. If this variable is not defined
mcmemsize: MC DRAM block size. If this variable is not defined, the value CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE will be assumed. + +Booting from NAND +------------------- +Booting from NAND requires two images, RCW and u-boot-with-spl.bin. +The difference between NAND boot RCW image and NOR boot image is the PBI +command sequence. Below is one example for PBI commands for QDS which uses +NAND device with 2KB/page, block size 128KB. + +1) CCSR 4-byte write to 0x00e00404, data=0x00000000 +2) CCSR 4-byte write to 0x00e00400, data=0x1800a000 +The above two commands set bootloc register to 0x00000000_1800a000 where +the u-boot code will be running in OCRAM. + +3) Block Copy: SRC=0x0107, SRC_ADDR=0x00020000, DEST_ADDR=0x1800a000, +BLOCK_SIZE=0x00014000 +This command copies u-boot image from NAND device into OCRAM. The values need +to adjust accordingly. + +SRC should match the cfg_rcw_src, the reset config pins. It depends + on the NAND device. See reference manual for cfg_rcw_src. +SRC_ADDR is the offset of u-boot-with-spl.bin image in NAND device. In + the example above, 128KB. For easy maintenance, we put it at + the beginning of next block from RCW. +DEST_ADDR is fixed at 0x1800a000, matching bootloc set above. +BLOCK_SIZE is the size to be copied by PBI. + +RCW image should be written to the beginning of NAND device. Example of using +u-boot command + +nand write <rcw image in memory> 0 <size of rcw image> + +To form the NAND image, build u-boot with NAND config, for example, +ls2085aqds_nand_defconfig. The image needed is u-boot-with-spl.bin. +The u-boot image should be written to match SRC_ADDR, in above example 0x20000. + +nand write <u-boot image in memory> 200000 <size of u-boot image> + +With these two images in NAND device, the board can boot from NAND. diff --git a/arch/arm/cpu/armv8/fsl-lsch3/soc.c b/arch/arm/cpu/armv8/fsl-lsch3/soc.c index 17700ef..ca00108 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/soc.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/soc.c @@ -6,8 +6,13 @@
#include <common.h> #include <fsl_ifc.h> +#include <nand.h> +#include <spl.h> #include <asm/arch-fsl-lsch3/soc.h> #include <asm/io.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR;
static void erratum_a008751(void) { @@ -18,8 +23,51 @@ static void erratum_a008751(void) #endif }
+static void erratum_rcw_src(void) +{ +#if defined(CONFIG_SPL) + u32 __iomem *dcfg_ccsr = (u32 __iomem *)DCFG_BASE; + u32 __iomem *dcfg_dcsr = (u32 __iomem *)DCFG_DCSR_BASE; + u32 val; + + val = in_le32(dcfg_ccsr + DCFG_PORSR1 / 4); + val &= ~DCFG_PORSR1_RCW_SRC; + val |= DCFG_PORSR1_RCW_SRC_NOR; + out_le32(dcfg_dcsr + DCFG_DCSR_PORCR1 / 4, val); +#endif +} + void fsl_lsch3_early_init_f(void) { erratum_a008751(); + erratum_rcw_src(); init_early_memctl_regs(); /* tighten IFC timing */ } + +#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong dummy) +{ + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + arch_cpu_init(); + board_early_init_f(); + timer_init(); + env_init(); + gd->baudrate = getenv_ulong("baudrate", 10, CONFIG_BAUDRATE); + + serial_init(); + console_init_f(); + dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + board_init_r(NULL, 0); +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_NAND; +} +#endif diff --git a/arch/arm/cpu/armv8/u-boot.lds b/arch/arm/cpu/armv8/u-boot-spl.lds similarity index 57% copy from arch/arm/cpu/armv8/u-boot.lds copy to arch/arm/cpu/armv8/u-boot-spl.lds index 4c12222..4df339c 100644 --- a/arch/arm/cpu/armv8/u-boot.lds +++ b/arch/arm/cpu/armv8/u-boot-spl.lds @@ -5,80 +5,68 @@ * (C) Copyright 2002 * Gary Jennejohn, DENX Software Engineering, garyj@denx.de * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Aneesh V aneesh@ti.com + * * SPDX-License-Identifier: GPL-2.0+ */
+MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE, + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") OUTPUT_ARCH(aarch64) ENTRY(_start) SECTIONS { - . = 0x00000000; - - . = ALIGN(8); - .text : - { + .text : { + . = ALIGN(8); *(.__image_copy_start) CPUDIR/start.o (.text*) *(.text*) - } + } >.sram
- . = ALIGN(8); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + .rodata : { + . = ALIGN(8); + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } >.sram
- . = ALIGN(8); .data : { + . = ALIGN(8); *(.data*) - } + } >.sram
- . = ALIGN(8); - - . = .; - - . = ALIGN(8); .u_boot_list : { + . = ALIGN(8); KEEP(*(SORT(.u_boot_list*))); - } - - . = ALIGN(8); + } >.sram
- .image_copy_end : - { + .image_copy_end : { + . = ALIGN(8); *(.__image_copy_end) - } - - . = ALIGN(8); - - .rel_dyn_start : - { - *(.__rel_dyn_start) - } - - .rela.dyn : { - *(.rela*) - } - - .rel_dyn_end : - { - *(.__rel_dyn_end) - } - - _end = .; + } >.sram
- . = ALIGN(8); + .end : { + . = ALIGN(8); + *(.__end) + } >.sram
.bss_start : { + . = ALIGN(8); KEEP(*(.__bss_start)); - } + } >.sdram
.bss : { *(.bss*) . = ALIGN(8); - } + } >.sdram
.bss_end : { KEEP(*(.__bss_end)); - } + } >.sdram
/DISCARD/ : { *(.dynsym) } /DISCARD/ : { *(.dynstr*) } diff --git a/arch/arm/include/asm/arch-fsl-lsch3/config.h b/arch/arm/include/asm/arch-fsl-lsch3/config.h index 403b2ef..77c20ab 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/config.h +++ b/arch/arm/include/asm/arch-fsl-lsch3/config.h @@ -130,6 +130,15 @@ #define CCI_MN_DVM_DOMAIN_CTL 0x200 #define CCI_MN_DVM_DOMAIN_CTL_SET 0x210
+/* Device Configuration */ +#define DCFG_BASE 0x01e00000 +#define DCFG_PORSR1 0x000 +#define DCFG_PORSR1_RCW_SRC 0xff800000 +#define DCFG_PORSR1_RCW_SRC_NOR 0x12f00000 + +#define DCFG_DCSR_BASE 0X700100000ULL +#define DCFG_DCSR_PORCR1 0x000 + /* Supplemental Configuration */ #define SCFG_BASE 0x01fc0000 #define SCFG_USB3PRM1CR 0x000 diff --git a/arch/arm/lib/crt0_64.S b/arch/arm/lib/crt0_64.S index 7756396..bf4ca99 100644 --- a/arch/arm/lib/crt0_64.S +++ b/arch/arm/lib/crt0_64.S @@ -61,13 +61,18 @@ ENTRY(_main) /* * Set up initial C runtime environment and call board_init_f(0). */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) + ldr x0, =(CONFIG_SPL_STACK) +#else ldr x0, =(CONFIG_SYS_INIT_SP_ADDR) +#endif sub x0, x0, #GD_SIZE /* allocate one GD above SP */ bic sp, x0, #0xf /* 16-byte alignment for ABI compliance */ mov x18, sp /* GD is above SP */ mov x0, #0 bl board_init_f
+#if !defined(CONFIG_SPL_BUILD) /* * Set up intermediate environment (new sp and gd) and call * relocate_code(addr_moni). Trick here is that we'll return @@ -110,4 +115,6 @@ clear_loop:
/* NOTREACHED - board_init_r() does not return */
+#endif /* !CONFIG_SPL_BUILD */ + ENDPROC(_main) diff --git a/board/freescale/ls2085aqds/MAINTAINERS b/board/freescale/ls2085aqds/MAINTAINERS index 74b3721..fbed672 100644 --- a/board/freescale/ls2085aqds/MAINTAINERS +++ b/board/freescale/ls2085aqds/MAINTAINERS @@ -5,3 +5,4 @@ F: board/freescale/ls2085aqds/ F: board/freescale/ls2085a/ls2085aqds.c F: include/configs/ls2085aqds.h F: configs/ls2085aqds_defconfig +F: configs/ls2085aqds_nand_defconfig diff --git a/board/freescale/ls2085aqds/ddr.c b/board/freescale/ls2085aqds/ddr.c index 6cd5e8b..8d71ae1 100644 --- a/board/freescale/ls2085aqds/ddr.c +++ b/board/freescale/ls2085aqds/ddr.c @@ -147,9 +147,13 @@ phys_size_t initdram(int board_type) { phys_size_t dram_size;
+#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) + return fsl_ddr_sdram_size(); +#else puts("Initializing DDR....using SPD\n");
dram_size = fsl_ddr_sdram(); +#endif
return dram_size; } diff --git a/common/spl/spl.c b/common/spl/spl.c index cd75bbc..6d5cb0e 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -113,7 +113,7 @@ __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) typedef void __noreturn (*image_entry_noargs_t)(void);
image_entry_noargs_t image_entry = - (image_entry_noargs_t) spl_image->entry_point; + (image_entry_noargs_t)(unsigned long)spl_image->entry_point;
debug("image entry point: 0x%X\n", spl_image->entry_point); image_entry(); diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index b7801cb..b8c369d 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -91,7 +91,7 @@ void spl_nand_load_image(void) sizeof(*header), (void *)header); spl_parse_image_header(header); nand_spl_load_image(CONFIG_SYS_NAND_U_BOOT_OFFS, - spl_image.size, (void *)spl_image.load_addr); + spl_image.size, (void *)(unsigned long)spl_image.load_addr); nand_deselect(); } #endif diff --git a/configs/ls2085aqds_nand_defconfig b/configs/ls2085aqds_nand_defconfig new file mode 100644 index 0000000..446206a --- /dev/null +++ b/configs/ls2085aqds_nand_defconfig @@ -0,0 +1,4 @@ +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND" +CONFIG_SPL=y ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_LS2085AQDS=y diff --git a/drivers/misc/fsl_ifc.c b/drivers/misc/fsl_ifc.c index 45d299c..a33efdb 100644 --- a/drivers/misc/fsl_ifc.c +++ b/drivers/misc/fsl_ifc.c @@ -168,13 +168,25 @@ void init_final_memctl_regs(void) #ifdef CONFIG_SYS_CSPR0_FINAL set_ifc_cspr(IFC_CS0, CONFIG_SYS_CSPR0_FINAL); #endif +#ifdef CONFIG_SYS_AMASK0_FINAL + set_ifc_amask(IFC_CS0, CONFIG_SYS_AMASK0); +#endif #ifdef CONFIG_SYS_CSPR1_FINAL set_ifc_cspr(IFC_CS1, CONFIG_SYS_CSPR1_FINAL); #endif #ifdef CONFIG_SYS_AMASK1_FINAL set_ifc_amask(IFC_CS1, CONFIG_SYS_AMASK1_FINAL); #endif +#ifdef CONFIG_SYS_CSPR2_FINAL + set_ifc_cspr(IFC_CS2, CONFIG_SYS_CSPR2_FINAL); +#endif +#ifdef CONFIG_SYS_AMASK2_FINAL + set_ifc_amask(IFC_CS2, CONFIG_SYS_AMASK2); +#endif #ifdef CONFIG_SYS_CSPR3_FINAL set_ifc_cspr(IFC_CS3, CONFIG_SYS_CSPR3_FINAL); #endif +#ifdef CONFIG_SYS_AMASK3_FINAL + set_ifc_amask(IFC_CS3, CONFIG_SYS_AMASK3); +#endif } diff --git a/drivers/mtd/nand/fsl_ifc_spl.c b/drivers/mtd/nand/fsl_ifc_spl.c index 2fb9fb1..fccbfb5 100644 --- a/drivers/mtd/nand/fsl_ifc_spl.c +++ b/drivers/mtd/nand/fsl_ifc_spl.c @@ -66,7 +66,7 @@ static inline void nand_wait(uchar *buf, int bufnum, int page_size) { struct fsl_ifc_runtime *ifc = runtime_regs_address(); u32 status; - u32 eccstat[4]; + u32 eccstat[8]; int bufperpage = page_size / 512; int bufnum_end, i;
diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 44c6845..9bc3869 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -28,7 +28,11 @@ #define CONFIG_ARCH_MISC_INIT
/* Link Definitions */ +#ifdef CONFIG_SPL +#define CONFIG_SYS_TEXT_BASE 0x80400000 +#else #define CONFIG_SYS_TEXT_BASE 0x30100000 +#endif
#ifdef CONFIG_EMU #define CONFIG_SYS_NO_FLASH @@ -47,7 +51,9 @@ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */
+#ifndef CONFIG_SPL #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ +#endif #ifndef CONFIG_SYS_FSL_DDR4 #define CONFIG_SYS_FSL_DDR3 /* Use DDR3 memory */ #define CONFIG_SYS_DDR_RAW_TIMING @@ -272,4 +278,27 @@ unsigned long get_dram_size_to_hide(void);
#define CONFIG_PANIC_HANG /* do not reset board on panic */
+#define CONFIG_SPL_BSS_START_ADDR 0x80100000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_MAX_SIZE 0x16000 +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_STACK (CONFIG_SYS_FSL_OCRAM_BASE + 0x9ff0) +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_TEXT_BASE 0x1800a000 + +#define CONFIG_SYS_NAND_U_BOOT_DST 0x80400000 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80200000 +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) + #endif /* __LS2_COMMON_H */ diff --git a/include/configs/ls2085aqds.h b/include/configs/ls2085aqds.h index d54c731..cf87da8 100644 --- a/include/configs/ls2085aqds.h +++ b/include/configs/ls2085aqds.h @@ -147,10 +147,12 @@ unsigned long get_board_ddr_clk(void); #define QIXIS_LBMAP_SHIFT 0 #define QIXIS_LBMAP_DFLTBANK 0x00 #define QIXIS_LBMAP_ALTBANK 0x04 +#define QIXIS_LBMAP_NAND 0x09 #define QIXIS_RST_CTL_RESET 0x31 #define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 #define QIXIS_RCFG_CTL_RECONFIG_START 0x21 #define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_RCW_SRC_NAND 0x107 #define QIXIS_RST_FORCE_MEM 0x01
#define CONFIG_SYS_CSPR3_EXT (0x0) @@ -176,6 +178,43 @@ unsigned long get_board_ddr_clk(void); FTIM2_GPCM_TWP(0x3E)) #define CONFIG_SYS_CS3_FTIM3 0x0
+#if defined(CONFIG_SPL) && defined(CONFIG_NAND) +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR0_CSPR_EARLY +#define CONFIG_SYS_CSPR1_FINAL CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR1_CSPR_EARLY +#define CONFIG_SYS_CSPR2_FINAL CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK_EARLY +#define CONFIG_SYS_AMASK2_FINAL CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 + +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET (896 * 1024) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SPL_PAD_TO 0x20000 +#define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) +#define CONFIG_SYS_NAND_U_BOOT_SIZE (512 * 1024) +#else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY #define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR @@ -204,6 +243,12 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3
+#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x2000 +#endif + /* Debug Server firmware */ #define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR #define CONFIG_SYS_DEBUG_SERVER_FW_ADDR 0x580D00000ULL @@ -249,11 +294,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
-#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x2000 - #define CONFIG_FSL_MEMAC #define CONFIG_PCI /* Enable PCIE */ #define CONFIG_PCIE_LAYERSCAPE /* Use common FSL Layerscape PCIe code */
Enable NAND boot support using SPL framework. To boot from NAND, either use DIP switches on board, or "qixis_reset nand" command. Details of forming NAND image can be found in README.
Changes in v9: Update README to add nand page size and block size.
Changes in v8: Update README to add example for RDB NAND boot.
Changes in v6: None Changes in v5: Fix signed-off-by signature Update LS2085ARDB README to include instructions to form NAND image
arch/arm/Kconfig | 1 + arch/arm/cpu/armv8/fsl-lsch3/README | 13 +++++++++++ board/freescale/ls2085ardb/MAINTAINERS | 1 + board/freescale/ls2085ardb/ddr.c | 4 ++++ configs/ls2085ardb_nand_defconfig | 4 ++++ include/configs/ls2085ardb.h | 40 ++++++++++++++++++++++++++++---- 6 files changed, 58 insertions(+), 5 deletions(-) create mode 100644 configs/ls2085ardb_nand_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f73541c..cf291c8 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -663,6 +663,7 @@ config TARGET_LS2085ARDB bool "Support ls2085ardb" select ARM64 select ARMV8_MULTIENTRY + select SUPPORT_SPL help Support for Freescale LS2085ARDB platform. The LS2085A Reference design board (RDB) is a high-performance diff --git a/arch/arm/cpu/armv8/fsl-lsch3/README b/arch/arm/cpu/armv8/fsl-lsch3/README index 15a1549..37f07fb 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/README +++ b/arch/arm/cpu/armv8/fsl-lsch3/README @@ -133,3 +133,16 @@ The u-boot image should be written to match SRC_ADDR, in above example 0x20000. nand write <u-boot image in memory> 200000 <size of u-boot image>
With these two images in NAND device, the board can boot from NAND. + +Another example for RDB boards, + +1) CCSR 4-byte write to 0x00e00404, data=0x00000000 +2) CCSR 4-byte write to 0x00e00400, data=0x1800a000 +3) Block Copy: SRC=0x0119, SRC_ADDR=0x00080000, DEST_ADDR=0x1800a000, +BLOCK_SIZE=0x00014000 + +nand write <rcw image in memory> 0 <size of rcw image> +nand write <u-boot image in memory> 80000 <size of u-boot image> + +Notice the difference from QDS is SRC, SRC_ADDR and the offset of u-boot image +to match board NAND device with 4KB/page, block size 512KB. diff --git a/board/freescale/ls2085ardb/MAINTAINERS b/board/freescale/ls2085ardb/MAINTAINERS index 436039f..d5cce40 100644 --- a/board/freescale/ls2085ardb/MAINTAINERS +++ b/board/freescale/ls2085ardb/MAINTAINERS @@ -5,3 +5,4 @@ F: board/freescale/ls2085ardb/ F: board/freescale/ls2085a/ls2085ardb.c F: include/configs/ls2085ardb.h F: configs/ls2085ardb_defconfig +F: configs/ls2085ardb_nand_defconfig diff --git a/board/freescale/ls2085ardb/ddr.c b/board/freescale/ls2085ardb/ddr.c index 6cd5e8b..8d71ae1 100644 --- a/board/freescale/ls2085ardb/ddr.c +++ b/board/freescale/ls2085ardb/ddr.c @@ -147,9 +147,13 @@ phys_size_t initdram(int board_type) { phys_size_t dram_size;
return dram_size; } diff --git a/configs/ls2085ardb_nand_defconfig b/configs/ls2085ardb_nand_defconfig new file mode 100644 index 0000000..39ba8c5 --- /dev/null +++ b/configs/ls2085ardb_nand_defconfig @@ -0,0 +1,4 @@ ++S:CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND" ++S:CONFIG_SPL=y ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_LS2085ARDB=y diff --git a/include/configs/ls2085ardb.h b/include/configs/ls2085ardb.h index 0a5873b..ae5c2a9 100644 --- a/include/configs/ls2085ardb.h +++ b/include/configs/ls2085ardb.h @@ -139,11 +139,13 @@ unsigned long get_board_sys_clk(void); #define QIXIS_LBMAP_SHIFT 0 #define QIXIS_LBMAP_DFLTBANK 0x00 #define QIXIS_LBMAP_ALTBANK 0x04 +#define QIXIS_LBMAP_NAND 0x09 #define QIXIS_RST_CTL_RESET 0x31 #define QIXIS_RST_CTL_RESET_EN 0x30 #define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 #define QIXIS_RCFG_CTL_RECONFIG_START 0x21 #define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_RCW_SRC_NAND 0x119 #define QIXIS_RST_FORCE_MEM 0x01
#define CONFIG_SYS_CSPR3_EXT (0x0) @@ -169,6 +171,33 @@ unsigned long get_board_sys_clk(void); FTIM2_GPCM_TWP(0x3E)) #define CONFIG_SYS_CS3_FTIM3 0x0
+#if defined(CONFIG_SPL) && defined(CONFIG_NAND) +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR_EARLY +#define CONFIG_SYS_CSPR2_FINAL CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 + +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET (2048 * 1024) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SPL_PAD_TO 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_OFFS (1024 * 1024) +#define CONFIG_SYS_NAND_U_BOOT_SIZE (512 * 1024) +#else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY #define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR @@ -187,6 +216,12 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3
+#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x2000 +#endif + /* Debug Server firmware */ #define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR #define CONFIG_SYS_DEBUG_SERVER_FW_ADDR 0x580D00000ULL @@ -232,11 +267,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
York Sun
