[U-Boot] [PATCH] mtd: nand: let the raw NAND devices be compiled upon selection
Today way is to rely on CMD_NAND to be selected and from the root Makefile compile what is in drivers/mtd/nand/raw.
While this will work most of the time with decent configurations, it is better to also compile this subsystem upon simple request in the configuration. Otherwise, a user not selecting CMD_NAND but selecting NAND and any of the controller drivers will not see their build. Fix this weird situation by adding a single line in the nand/ directory Kconfig file.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- drivers/mtd/nand/Makefile | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index a358bc680e..2c33447995 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -2,4 +2,5 @@
nandcore-objs := core.o bbt.o obj-$(CONFIG_MTD_NAND_CORE) += nandcore.o +obj-$(CONFIG_NAND) += raw/ obj-$(CONFIG_MTD_SPI_NAND) += spi/
On Thu, Oct 11, 2018 at 3:05 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
But we even source raw Kconfig path, isn't it? and also how about remove this from root Makefile?
Hi Jagan,
Jagan Teki jagan@amarulasolutions.com wrote on Tue, 23 Oct 2018 16:40:05 +0530:
What do you mean by "we even source raw Kconfig path"? It was not sourced before this modification unless CMD_NAND was selected.
I agree we should also remove this link between a path being compiled and a CMD_* symbol in the root Makefile. It will probably produce a lot of errors though. I'll try when I'll have some time.
Thanks, Miquèl
On Mon, Oct 29, 2018 at 2:37 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Jagan,
OK, but If it can't fire any issue as of now, may be we do full cleanup later.
Hi Jagan,
Miquel Raynal miquel.raynal@bootlin.com wrote on Mon, 29 Oct 2018 10:07:28 +0100:
Hi Jagan,
Yet another patch you ignored. All these are real fixes, not just some kind of sandbox leisure, please consider this change.
Thanks, Miquèl
On Mon, Apr 08, 2019 at 11:52:31AM +0200, Miquel Raynal wrote:
Hi Jagan,
Hi Jagan,
Yes, what's going on here? Thanks!
Hi Miquel,
On Mon, Apr 8, 2019 at 3:22 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Jagan,
Hi Jagan,
1) Did I ignore any patches from you?
2) This change I just commented before and I think the same is handling on your cleanup series, If I'm not wrong?
Jagan.
Jagan,
Jagan Teki jagan@amarulasolutions.com wrote on Mon, 8 Apr 2019 17:28:18 +0530:
Hi Miquel,
Hi Jagan,
Hi Jagan,
- Did I ignore any patches from you?
* [PATCH] mtd: nand: let the raw NAND devices be compiled upon selection -> 11/10/2018: Sent on the ML -> 23/10/2018-05/11/2018: you want something cleaner, I tell you I will do it soon but for now the issue should be fixed. -> 08/04/2019: Ping from me because the other series is still not applied, the quick fix neither, the bug is still there.
* [PATCH v4 00/25] MTD defconfigs/Kconfigs/Makefiles heavy cleanup -> 09/12/2018: v4 sent on the ML with all comments addressed -> 20/02/2019: Ping from Vignesh -> 20/02/2019: Ping from me -> 06/03/2019: Ping from me -> 17/03/2019: Ping from me -> 17/03/2019: Ping from Tom -> 19/03/2019: You answer: "Yes, it's late from my end, will have a look at and comment asap." -> 08/04/2019: Ping from me
* [PATCH 1/2] mtd: fix mtd_oobavail() incoherent returned value * [PATCH 2/2] mtd: fix Coverity integer handling issue -> 16/10/2018: Coverity issues reported by Tom privately -> 18/11/2018: Fixes sent on the ML (both for Linux and U-Boot). For your defense, you were not in Cc of the patches but they are marked 'New' in Patchwork and assigned to you. -> 03/12/2018: Fixes applied in Linux -> 08/04/2018: Ping from me
- This change I just commented before and I think the same is
When there is a bug, the usual handling procedure is: 1/ fix the bug so that users are not bothered, 2/ if the fix is not elegant enough then a rework of the faulty section is engaged.
History:
We discovered after applying my "SPI-NAND support (third batch)" 13th version from the 01/10/2018 that under certain circumstances the raw NAND core could be missing because of the game of the select/depends on properties. It was a compile-time issue only.
Because I want the selection to be easier for the user, I fixed it with the current patch. This is the quick fix sent the 11/10/2018 addressing situation 1/.
We agreed that it could be useful to rework the entire Makefile/Kconfig soup in the MTD layer. So this is why I wrote on my spare time and send the full cleanup series. This is the deepest rework sent the 29/10/2018 (v2), the 05/12/2018 (v3) and the 09/12/2018 (v4) addressing situation 2/.
Regards, Miquèl
Jagan Teki
Miquel Raynal
