[PATCH 0/5] sandbox: repair compile and run-time for OF_EMBED case
This patch-set repairs ability to use sandbox with CONFIG_OF_EMBED=y.
For now, to use OF_EMBED, the following must be done 1) sandbox64_defconfig should have: ``` -CONFIG_OF_LIVE=y +CONFIG_OF_EMBED=y ```
2) On sandbox when CONFIG_OF_EMBED=y, the u-boot process can't start due to: ``` Bloblist at b000 not found (err=-2) initcall failed at call 000000000011829c (err=-2: No such file or \ directory) ### ERROR ### Please RESET the board ### ``` So, it is natural desire to disable CONFIG_BLOBLIST just to test sandbox with OF_EMBED=y (disable it one way or another): ``` config SANDBOX - select BLOBLIST + select BLOBLIST if SOME_NON_EXISTING_OPTION ```
3) As a result, having such changes (CONFIG_OF_EMBED=y && CONFIG_BLOBLIST=n) leads to the link & run-time errors, being fixed by this patch series.
Signed-off-by: Evgeny Bachinin EABachinin@salutedevices.com --- Tested: * locally with aforementioned options applied * CI - https://github.com/u-boot/u-boot/pull/704 * No regression
--- Evgeny Bachinin (5): sandbox: fix bloblist_finish() linker error if BLOBLIST=n test: sandbox: fix invalid_use_of_IF_ENABLED_INT if BLOBLIST=n test: sandbox: fix link error with do_ut_bloblist if BLOBLIST=n test: sandbox: fix link error with do_ut_bootm if BLOBLIST=n sandbox: set retval early in board_fdt_blob_setup()
arch/sandbox/cpu/cpu.c | 2 +- include/bloblist.h | 7 +++++++ test/cmd_ut.c | 2 ++ test/lib/kconfig.c | 10 ++++++---- 4 files changed, 16 insertions(+), 5 deletions(-) --- base-commit: 3073246d1be682071d8b3d07d06c2484907aed60 change-id: 20241120-sandbox_repair_of_embed-2188465eb22b
Having CONFIG_OF_EMBED=y && CONFIG_BLOBLIST=n leads to the link error: ``` ld: /tmp/ccwtRVty.ltrans0.ltrans.o: in function `state_uninit': arch/sandbox/cpu/state.c:508: undefined reference to `bloblist_finish' ```
Fixes: 1c52fcca72b ("sandbox: Write out bloblist when exiting") Signed-off-by: Evgeny Bachinin EABachinin@salutedevices.com --- include/bloblist.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/bloblist.h b/include/bloblist.h index ff32d3fecfd4e0474aa4047d1ae6421536570ec6..f999391f74bfd21098198bdd24dbb898a17320fd 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -357,6 +357,7 @@ int bloblist_new(ulong addr, uint size, uint flags, uint align_log2); */ int bloblist_check(ulong addr, uint size);
+#if CONFIG_IS_ENABLED(BLOBLIST) /** * bloblist_finish() - Set up the bloblist for the next U-Boot part * @@ -366,6 +367,12 @@ int bloblist_check(ulong addr, uint size); * Return: 0 */ int bloblist_finish(void); +#else +static inline int bloblist_finish(void) +{ + return 0; +} +#endif /* BLOBLIST */
/** * bloblist_get_stats() - Get information about the bloblist
On Mon, 2 Dec 2024 at 06:46, Evgeny Bachinin EABachinin@salutedevices.com wrote:
Having CONFIG_OF_EMBED=y && CONFIG_BLOBLIST=n leads to the link error: ``` ld: /tmp/ccRVty.ltrans40.ltrans.o: in function `lib_test_is_enabled': test/lib/kconfig.c:24: undefined reference to \ `invalid_use_of_IF_ENABLED_INT' ld: test/lib/kconfig.c:26: undefined reference to \ `invalid_use_of_CONFIG_IF_ENABLED_INT' ```
Fixes: 29784d62ede ("test: Add some tests for kconfig.h") Signed-off-by: Evgeny Bachinin EABachinin@salutedevices.com --- test/lib/kconfig.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/test/lib/kconfig.c b/test/lib/kconfig.c index 0c463bb794a5e1f9f2db995d544bd723f5e59ca0..a3645abf9464785461c7250260c816e6bca03193 100644 --- a/test/lib/kconfig.c +++ b/test/lib/kconfig.c @@ -21,10 +21,12 @@ static int lib_test_is_enabled(struct unit_test_state *uts) ut_asserteq(0, CONFIG_IS_ENABLED(OF_PLATDATA)); ut_asserteq(0, CONFIG_IS_ENABLED(_UNDEFINED));
- ut_asserteq(0xb000, - IF_ENABLED_INT(CONFIG_BLOBLIST_FIXED, CONFIG_BLOBLIST_ADDR)); - ut_asserteq(0xb000, - CONFIG_IF_ENABLED_INT(BLOBLIST_FIXED, BLOBLIST_ADDR)); + if (IS_ENABLED(CONFIG_BLOBLIST)) { + ut_asserteq(0xb000, IF_ENABLED_INT(CONFIG_BLOBLIST_FIXED, + CONFIG_BLOBLIST_ADDR)); + ut_asserteq(0xb000, CONFIG_IF_ENABLED_INT(BLOBLIST_FIXED, + BLOBLIST_ADDR)); + }
/* * This fails if CONFIG_TEST_KCONFIG_ENABLE is not enabled, since the
This defeats the test, of course, but I suppose that is fine.
ut_asserteq(0xb000,
ut_asserteq(0xb000,
BLOBLIST_ADDR));
} /* * This fails if CONFIG_TEST_KCONFIG_ENABLE is not enabled, since the
-- 2.34.1
Having CONFIG_OF_EMBED=y && CONFIG_BLOBLIST=n leads to the link error: ``` ld: /tmp/ccwtRVty.ltrans28.ltrans.o:(.data.rel+0x4b0): undefined \ reference to `do_ut_bloblist' ```
Fixes: 6ea5df39e8d ("test: Only enable bloblist test when supported") Signed-off-by: Evgeny Bachinin EABachinin@salutedevices.com --- test/cmd_ut.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 195b7ea50accde470a739771e058c1d664df3f0b..842c2c3e7f65eb9fe017fa1949eb2390be171487 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -104,8 +104,10 @@ static struct cmd_tbl cmd_ut_sub[] = { "", ""), #endif #ifdef CONFIG_SANDBOX +#if CONFIG_IS_ENABLED(BLOBLIST) U_BOOT_CMD_MKENT(bloblist, CONFIG_SYS_MAXARGS, 1, do_ut_bloblist, "", ""), +#endif U_BOOT_CMD_MKENT(bootm, CONFIG_SYS_MAXARGS, 1, do_ut_bootm, "", ""), #endif #ifdef CONFIG_CMD_ADDRMAP
-- 2.34.1
Having CONFIG_OF_EMBED=y && CONFIG_BLOBLIST=n leads to the link error: ``` ld: /tmp/ccwtRVty.ltrans28.ltrans.o:(.data.rel+0x4e8): undefined \ reference to `do_ut_bootm' ```
Fixes: fe158657a5b ("test: inconsistent bootm tests") Signed-off-by: Evgeny Bachinin EABachinin@salutedevices.com --- test/cmd_ut.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 842c2c3e7f65eb9fe017fa1949eb2390be171487..a14dbf4ca5e571a872585ff11bfe7adae3f4edf3 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -107,9 +107,9 @@ static struct cmd_tbl cmd_ut_sub[] = { #if CONFIG_IS_ENABLED(BLOBLIST) U_BOOT_CMD_MKENT(bloblist, CONFIG_SYS_MAXARGS, 1, do_ut_bloblist, "", ""), -#endif U_BOOT_CMD_MKENT(bootm, CONFIG_SYS_MAXARGS, 1, do_ut_bootm, "", ""), #endif +#endif #ifdef CONFIG_CMD_ADDRMAP U_BOOT_CMD_MKENT(addrmap, CONFIG_SYS_MAXARGS, 1, do_ut_addrmap, "", ""), #endif
Hi Evgeny,
Are you sure? I don't see that one. The bootm test should not relate to bloblist.
This is what I see:
buildman -a OF_EMBED -a ~BLOBLIST --bo sandbox Building current source for 1 boards (1 thread, 32 jobs per thread) sandbox: + sandbox +===================== WARNING ====================== +CONFIG_OF_EMBED is enabled. This option should only +be used for debugging purposes. Please use +CONFIG_OF_SEPARATE for boards in mainline. +See doc/develop/devicetree/control.rst for more info. +==================================================== + +Some CONFIG adjustments did not take effect. This may be because +the request CONFIGs do not exist or conflict with others. +Failed adjustments: +~BLOBLIST CONFIG_BLOBLIST=y 0 0 1 /1 sandbox Completed: 1 total built, 1 newly), duration 0:00:11, rate 0.09
Fixes: fe158657a5b ("test: inconsistent bootm tests") Signed-off-by: Evgeny Bachinin <EABachinin@salutedevices.com> --- test/cmd_ut.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 842c2c3e7f65eb9fe017fa1949eb2390be171487..a14dbf4ca5e571a872585ff11bfe7adae3f4edf3 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -107,9 +107,9 @@ static struct cmd_tbl cmd_ut_sub[] = { #if CONFIG_IS_ENABLED(BLOBLIST) U_BOOT_CMD_MKENT(bloblist, CONFIG_SYS_MAXARGS, 1, do_ut_bloblist, "", ""), -#endif U_BOOT_CMD_MKENT(bootm, CONFIG_SYS_MAXARGS, 1, do_ut_bootm, "", ""), #endif +#endif #ifdef CONFIG_CMD_ADDRMAP U_BOOT_CMD_MKENT(addrmap, CONFIG_SYS_MAXARGS, 1, do_ut_addrmap, "", ""), #endif -- 2.34.1
Regards, SImon
Hi, Simon. See below, please
On Fri, Dec 06, 2024 at 08:31:22AM -0700, Simon Glass wrote:
Hi Evgeny,
I've double checked - reproduced on v2024.10. There we had in test/Makefile: ``` ifneq ($(CONFIG_$(SPL_)BLOBLIST),) obj-$(CONFIG_$(SPL_)CMDLINE) += bootm.o endif ``` So do_ut_bootm() was not built if BLOBLIST=n
We do not see "undefined reference to `do_ut_bootm'" on v2025.01-rc3 due to this patch: 7f8b8c5abc2 ("bootm: test: Move test into boot") It made bootm.o dependant on CONFIG_SANDBOX and independent from BLOBLIST.
And because aforementioned patch fixes the issue, I'm going to get rid of this current patch.
This is what I see:
Just a side note: I am not familiar with buildman yet, but it seems, it can not set up CONFIG_BLOBLIST=n because BLOBLIST is selected by 'select'.
JFYI, I'm going to extend the patch series by new patch to make BLOBLIST selectable from menuconfig for sandbox via 'imply'.
0 0 1 /1 sandbox
Regards, SImon
-- Best Regards, Evgeny Bachinin
Hi Evgeny,
On Tue, 17 Dec 2024 at 02:11, Evgeny Bachinin eabachinin@salutedevices.com wrote:
Hi Evgeny,
This is what I see:
That's right.
OK good.
0 0 1 /1 sandbox
Regards, SImon
Bug: nobody sets 'ret' to non-error value inside board_fdt_blob_setup() in case, when gd->fdt_blob has been initialized before calling the board_fdt_blob_setup() (say, due to CONFIG_OF_EMBED=y)
Reproduced with CONFIG_OF_EMBED=y && BLOBLIST=n. ``` $ ./u-boot initcall: 0000000000078e05 (relocated to 000061138d2c7e05) initcall: 0000000000117b12 (relocated to 000061138d366b12) fdtdec_setup(): gd->fdt_blob = dtb_dt_embedded() fdtdec_setup(): gd->fdt_blob = board_fdt_blob_setup(&ret);
board_fdt_blob_setup():380 ret:-2 gd->fdt_blob:0x61138d4db310 if (gd->fdt_blob) return (void *)gd->fdt_blob;
initcall failed at call 0000000000117b12 (err=-2: No such file \ or directory) ### ERROR ### Please RESET the board ### ```
Patch moves code, zeroizing the 'ret', before checking the fdt_blob.
Fixes: d8289e7dfe5 ("sandbox: fdt: Avoid overwriting an existing fdt") Signed-off-by: Evgeny Bachinin EABachinin@salutedevices.com --- arch/sandbox/cpu/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index d1c4dcf0764fb37ec99585a3db16fa34c3a54dac..7e93377e87e75b0fb92a8cf139b4a731a88a6a7b 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -377,10 +377,10 @@ void *board_fdt_blob_setup(int *ret) int err; int fd;
+ *ret = 0; if (gd->fdt_blob) return (void *)gd->fdt_blob; blob = map_sysmem(CONFIG_SYS_FDT_LOAD_ADDR, 0); - *ret = 0; if (!state->fdt_fname) { err = setup_auto_tree(blob); if (!err)
Hi Evgeny,
$ ./u-boot initcall: 0000000000078e05 (relocated to 000061138d2c7e05) initcall: 0000000000117b12 (relocated to 000061138d366b12) fdtdec_setup(): gd->fdt_blob = dtb_dt_embedded() fdtdec_setup(): gd->fdt_blob = board_fdt_blob_setup(&ret); board_fdt_blob_setup():380 ret:-2 gd->fdt_blob:0x61138d4db310 if (gd->fdt_blob) return (void *)gd->fdt_blob; initcall failed at call 0000000000117b12 (err=-2: No such file \ or directory) ### ERROR ### Please RESET the board ###
-- 2.34.1
But note for the future we have:
https://patchwork.ozlabs.org/project/uboot/patch/20241102174944.412088-2-sjg...
Hi, Simon, see below
On Fri, Dec 06, 2024 at 08:31:36AM -0700, Simon Glass wrote:
Hi Evgeny,
-- 2.34.1
Thanks for pointing me!
Could you advise me? Should I abandon this patch from v2 patch-set?
Hi Evgeny,
On Tue, 17 Dec 2024 at 01:59, Evgeny Bachinin eabachinin@salutedevices.com wrote:
Hi Evgeny,
-- 2.34.1
I believe it should be fixed, but see what you think.
Hi Evgeny,
- sandbox64_defconfig should have:
- On sandbox when CONFIG_OF_EMBED=y, the u-boot process can't start
due to:
- As a result, having such changes (CONFIG_OF_EMBED=y &&
Tested:
- locally with aforementioned options applied
- CI - https://github.com/u-boot/u-boot/pull/704
- No regression
Thanks for looking at this.
You could add a test for ~OF_EMBED in test/py/tests/test_sandbox_opts.py if you want to keep this working in future.
Hello, Simon.
On Fri, Dec 06, 2024 at 12:19:42PM -0700, Simon Glass wrote:
Hi Evgeny,
due to:
Tested:
- No regression
I did not know about this. Thank you, will do.
Evgeny Bachinin
Evgeny Bachinin
