[v5 1/3] Watchdog: introduce ARM SBSA watchdog driver
According to Server Base System Architecture (SBSA) specification, the SBSA Generic Watchdog has two stage timeouts: the first signal (WS0) is for alerting the system by interrupt, the second one (WS1) is a real hardware reset. More details about the hardware specification of this device: ARM DEN0029B - Server Base System Architecture (SBSA)
This driver can operate ARM SBSA Generic Watchdog as a single stage In the single stage mode, when the timeout is reached, your system will be reset by WS1. The first signal (WS0) is ignored.
Signed-off-by: Zhao Qiang qiang.zhao@nxp.com Signed-off-by: Biwen Li biwen.li@nxp.com Reviewed-by: Stefan Roese sr@denx.de --- Change in v5: - add header file linux/err.h
Change in v4: - remove unused variable load_value
Change in v3: - add description - remove empty line
Change in v2: - fix copyright
MAINTAINERS | 1 + drivers/watchdog/Kconfig | 9 +++ drivers/watchdog/Makefile | 1 + drivers/watchdog/sbsa_gwdt.c | 131 +++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 142 insertions(+) create mode 100644 drivers/watchdog/sbsa_gwdt.c
diff --git a/MAINTAINERS b/MAINTAINERS index 2a281a9..92bbf1c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -689,6 +689,7 @@ M: Priyanka Jain priyanka.jain@nxp.com S: Maintained T: git https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriq.git F: drivers/watchdog/sp805_wdt.c +F: drivers/watchdog/sbsa_gwdt.c
I2C M: Heiko Schocher hs@denx.de diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index bf06180..6d5c4fc 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -163,6 +163,15 @@ config WDT_SANDBOX can be probed and supports all of the methods of WDT, but does not really do anything.
+config WDT_SBSA + bool "SBSA watchdog timer support" + depends on WDT + help + Select this to enable SBSA watchdog timer. + This driver can operate ARM SBSA Generic Watchdog as a single stage. + In the single stage mode, when the timeout is reached, your system + will be reset by WS1. The first signal (WS0) is ignored. + config WDT_SP805 bool "SP805 watchdog timer support" depends on WDT diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 519bbd3..0f0b2eb 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -27,6 +27,7 @@ obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o obj-$(CONFIG_WDT_MT7621) += mt7621_wdt.o obj-$(CONFIG_WDT_MTK) += mtk_wdt.o obj-$(CONFIG_WDT_OMAP3) += omap_wdt.o +obj-$(CONFIG_WDT_SBSA) += sbsa_gwdt.o obj-$(CONFIG_WDT_SP805) += sp805_wdt.o obj-$(CONFIG_WDT_STM32MP) += stm32mp_wdt.o obj-$(CONFIG_WDT_TANGIER) += tangier_wdt.o diff --git a/drivers/watchdog/sbsa_gwdt.c b/drivers/watchdog/sbsa_gwdt.c new file mode 100644 index 0000000..2eae431 --- /dev/null +++ b/drivers/watchdog/sbsa_gwdt.c @@ -0,0 +1,131 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Watchdog driver for SBSA + * + * Copyright 2020 NXP + */ + +#include <asm/io.h> +#include <common.h> +#include <dm/device.h> +#include <dm/fdtaddr.h> +#include <dm/read.h> +#include <linux/bitops.h> +#include <linux/err.h> +#include <watchdog.h> +#include <wdt.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* SBSA Generic Watchdog register definitions */ +/* refresh frame */ +#define SBSA_GWDT_WRR 0x000 + +/* control frame */ +#define SBSA_GWDT_WCS 0x000 +#define SBSA_GWDT_WOR 0x008 +#define SBSA_GWDT_WCV 0x010 + +/* refresh/control frame */ +#define SBSA_GWDT_W_IIDR 0xfcc +#define SBSA_GWDT_IDR 0xfd0 + +/* Watchdog Control and Status Register */ +#define SBSA_GWDT_WCS_EN BIT(0) +#define SBSA_GWDT_WCS_WS0 BIT(1) +#define SBSA_GWDT_WCS_WS1 BIT(2) + +struct sbsa_gwdt_priv { + void __iomem *reg_refresh; + void __iomem *reg_control; +}; + +static int sbsa_gwdt_reset(struct udevice *dev) +{ + struct sbsa_gwdt_priv *priv = dev_get_priv(dev); + + writel(0, priv->reg_refresh + SBSA_GWDT_WRR); + + return 0; +} + +static int sbsa_gwdt_start(struct udevice *dev, u64 timeout, ulong flags) +{ + struct sbsa_gwdt_priv *priv = dev_get_priv(dev); + u32 clk; + + /* + * it work in the single stage mode in u-boot, + * The first signal (WS0) is ignored, + * the timeout is (WOR * 2), so the WOR should be configured + * to half value of timeout. + */ + clk = get_tbclk(); + writel(clk / 2 * timeout, + priv->reg_control + SBSA_GWDT_WOR); + + /* writing WCS will cause an explicit watchdog refresh */ + writel(SBSA_GWDT_WCS_EN, priv->reg_control + SBSA_GWDT_WCS); + + return 0; +} + +static int sbsa_gwdt_stop(struct udevice *dev) +{ + struct sbsa_gwdt_priv *priv = dev_get_priv(dev); + + writel(0, priv->reg_control + SBSA_GWDT_WCS); + + return 0; +} + +static int sbsa_gwdt_expire_now(struct udevice *dev, ulong flags) +{ + sbsa_gwdt_start(dev, 0, flags); + + return 0; +} + +static int sbsa_gwdt_probe(struct udevice *dev) +{ + debug("%s: Probing wdt%u (sbsa-gwdt)\n", __func__, dev->seq); + + return 0; +} + +static int sbsa_gwdt_ofdata_to_platdata(struct udevice *dev) +{ + struct sbsa_gwdt_priv *priv = dev_get_priv(dev); + + priv->reg_control = (void __iomem *)dev_read_addr_index(dev, 0); + if (IS_ERR(priv->reg_control)) + return PTR_ERR(priv->reg_control); + + priv->reg_refresh = (void __iomem *)dev_read_addr_index(dev, 1); + if (IS_ERR(priv->reg_refresh)) + return PTR_ERR(priv->reg_refresh); + + return 0; +} + +static const struct wdt_ops sbsa_gwdt_ops = { + .start = sbsa_gwdt_start, + .reset = sbsa_gwdt_reset, + .stop = sbsa_gwdt_stop, + .expire_now = sbsa_gwdt_expire_now, +}; + +static const struct udevice_id sbsa_gwdt_ids[] = { + { .compatible = "arm,sbsa-gwdt" }, + {} +}; + +U_BOOT_DRIVER(sbsa_gwdt) = { + .name = "sbsa_gwdt", + .id = UCLASS_WDT, + .of_match = sbsa_gwdt_ids, + .probe = sbsa_gwdt_probe, + .priv_auto_alloc_size = sizeof(struct sbsa_gwdt_priv), + .ofdata_to_platdata = sbsa_gwdt_ofdata_to_platdata, + .ops = &sbsa_gwdt_ops, +};
Add watchdog node which is sbsa into lx2160a dtsi
Signed-off-by: Zhao Qiang qiang.zhao@nxp.com --- Change in v5: - none
Change in v4: - none
Change in v3: - none
Change in v2: - none
arch/arm/dts/fsl-lx2160a.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/fsl-lx2160a.dtsi b/arch/arm/dts/fsl-lx2160a.dtsi index 1789da8..a2421f6 100644 --- a/arch/arm/dts/fsl-lx2160a.dtsi +++ b/arch/arm/dts/fsl-lx2160a.dtsi @@ -204,6 +204,13 @@ #interrupt-cells = <2>; };
+ watchdog@23a0000 { + compatible = "arm,sbsa-gwdt"; + reg = <0x0 0x23a0000 0 0x1000>, + <0x0 0x2390000 0 0x1000>; + timeout-sec = <30>; + }; + usb0: usb3@3100000 { compatible = "fsl,layerscape-dwc3"; reg = <0x0 0x3100000 0x0 0x10000>;
Enable support to compile SBSA driver.
configs/lx2160aqds_tfa_defconfig | 3 +++ configs/lx2160ardb_tfa_defconfig | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index 712957d..9626700 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y CONFIG_CMD_CACHE=y CONFIG_MP=y CONFIG_OF_CONTROL=y @@ -82,4 +83,6 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index a5c78d2..8cbe034 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y CONFIG_CMD_CACHE=y CONFIG_MP=y CONFIG_OF_CONTROL=y @@ -76,4 +77,6 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y
Biwen Li
