[PATCH 1/1] avb: honor CONFIG_SYS_64BIT_LBA
The size of lbaint_t depends on CONFIG_SYS_64BIT_LBA defined in common.h. common.h should always be included as first include.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- common/avb_verify.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/common/avb_verify.c b/common/avb_verify.c index 0520a71455..6d11e31687 100644 --- a/common/avb_verify.c +++ b/common/avb_verify.c @@ -4,6 +4,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <common.h> #include <avb_verify.h> #include <blk.h> #include <cpu_func.h>
Did you find a problem here, by inspection? If so, OK, I'll take this for master. Otherwise, please drop common.h from the file and see what includes it needs directly, given that -next has the CONFIG symbol in question migrated to Kconfig and so solves the overall problem.
You already merged 054de212cef6 ("disk: honor CONFIG_SYS_64BIT_LBA"). I looked for other uses of blk.h without prior inclusion of common.h.
Migration to Kconfig does not move the definition of CONFIG_SYS_64BIT_LBA into blk.h but keeps it in common.h. So the correct size of lbaint_t will still depend on including common.h.
Best regards
Heinrich
*/ +#include <common.h> #include <avb_verify.h> #include <blk.h> #include <cpu_func.h>
Wait, I don't follow, sorry. Can you please reproduce the problem you have, on next? CONFIG_SYS_64BIT_LBA is defined in Kconfig in next, so it will always be defined (or not) before any header is used because of -include.
And as a follow-up, nothing should be using <common.h> as it's only including other headers, so files and headers should include what they need directly.
diff --git a/common/avb_verify.c b/common/avb_verify.c index 0520a71455..6d11e31687 100644 --- a/common/avb_verify.c +++ b/common/avb_verify.c @@ -4,6 +4,7 @@ * SPDX-License-Identifier: GPL-2.0+ */ +#include <common.h> #include <avb_verify.h> #include <blk.h> #include <cpu_func.h>
GCC is called with -include ./include/linux/kconfig.h which includes generated/autoconf.h defining CONFIG_SYS_64BIT_LBA.
Please, drop the patch.
Best regards
Heinrich
