[U-Boot] [PATCH v2] arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load
The 4.2.2 gcc in the ELDK42 release doesn't like the direct SP load using a constant in tegra2_start. Change it to use a load thru another reg using mov sp, %0 : : "r"(CONST).
Tested on my Seaboard T20-A03, U-Boot loads and runs OK. Also compiled all tegra2 builds with both gcc 4.2.2 and 4.4.1 OK.
Signed-off-by: Tom Warren twarren@nvidia.com --- V2: Change 4 mov/orr's to single mov sp as per Marek Vasut
arch/arm/cpu/armv7/tegra2/ap20.c | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/tegra2/ap20.c b/arch/arm/cpu/armv7/tegra2/ap20.c index 4c44bb3..f0450f4 100644 --- a/arch/arm/cpu/armv7/tegra2/ap20.c +++ b/arch/arm/cpu/armv7/tegra2/ap20.c @@ -298,11 +298,11 @@ void tegra2_start(void) writel(0xC0, &pmt->pmt_cfg_ctl);
/* - * If we are ARM7 - give it a different stack. We are about to - * start up the A9 which will want to use this one. - */ - asm volatile("ldr sp, =%c0\n" - : : "i"(AVP_EARLY_BOOT_STACK_LIMIT)); + * If we are ARM7 - give it a different stack. We are about to + * start up the A9 which will want to use this one. + */ + asm volatile("mov sp, %0\n" + : : "r"(AVP_EARLY_BOOT_STACK_LIMIT));
start_cpu((u32)_start); halt_avp();
- asm volatile("mov sp, %0\n"
- : : "r"(AVP_EARLY_BOOT_STACK_LIMIT));
start_cpu((u32)_start); halt_avp(); -- 1.7.7.1
Ack? Nak? Can I get some love here?
Albert/Wolfgang - did anyone try this to ensure that it really fixes the 6 Tegra2 failures?
Tom
Tested on gcc 4.6, sorry I don't have the compiler that fails.
Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
Tom _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Tom Warren
