Re: [U-Boot] [PATCH] * mpc8313erdb.dts: Fixed eTSEC interrupt assignment.
On Wed, 9 Sep 2009 15:28:01 -0500 Kumar Gala galak@kernel.crashing.org wrote:
On Sep 9, 2009, at 1:22 PM, Scott Wood wrote:
On Fri, Sep 04, 2009 at 12:31:25PM +0200, Roland Lezuo wrote:
The following patch is needed to correctly assign the IRQs for the gianfar driver on the MPC8313ERDB-revc boards. ERR and TX are swapped as well as the interrupt lines for the two devices.
And it will incorrectly assign them on older revisions of the chip.
We really should have a u-boot fixup based on SVR.
Roland, is it possible for you to test this u-boot patch?:
From 44c73137acf20626e930e3f4142e60054d8bd46f Mon Sep 17 00:00:00 2001
From: Kim Phillips kim.phillips@freescale.com Date: Mon, 12 Oct 2009 10:51:20 -0500 Subject: [PATCH] mpc83xx: mpc8313 - handle erratum IPIC1 (TSEC IRQ number swappage)
mpc8313e erratum IPIC1 swapped TSEC interrupt ID numbers on rev. 1 h/w (see AN3545). The base device tree in use has rev. 1 ID numbers, so if on Rev. 2 (and higher) h/w, we fix them up here.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- cpu/mpc83xx/fdt.c | 39 +++++++++++++++++++++++++++++++++++++++ 1 files changed, 39 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc83xx/fdt.c b/cpu/mpc83xx/fdt.c index 13443cb..daf73a6 100644 --- a/cpu/mpc83xx/fdt.c +++ b/cpu/mpc83xx/fdt.c @@ -69,6 +69,45 @@ void ft_cpu_setup(void *blob, bd_t *bd) defined(CONFIG_HAS_ETH2) || defined(CONFIG_HAS_ETH3) ||\ defined(CONFIG_HAS_ETH4) || defined(CONFIG_HAS_ETH5) fdt_fixup_ethernet(blob); +#ifdef CONFIG_MPC8313 + /* + * mpc8313e erratum IPIC1 swapped TSEC interrupt ID numbers on rev. 1 + * h/w (see AN3545). The base device tree in use has rev. 1 ID numbers, + * so if on Rev. 2 (and higher) h/w, we fix them up here + */ + if (REVID_MAJOR(immr->sysconf.spridr) >= 2) { + int nodeoffset, path; + const char *prop; + + nodeoffset = fdt_path_offset(blob, "/aliases"); + if (nodeoffset >= 0) { +#if defined(CONFIG_HAS_ETH0) + prop = fdt_getprop(blob, nodeoffset, "ethernet0", NULL); + if (prop) { + u32 tmp[] = { 32, 0x8, 33, 0x8, 34, 0x8 }; + + path = fdt_path_offset(blob, prop); + prop = fdt_getprop(blob, path, "interrupts", 0); + if (prop) + fdt_setprop(blob, path, "interrupts", + &tmp, sizeof(tmp)); + } +#endif +#if defined(CONFIG_HAS_ETH1) + prop = fdt_getprop(blob, nodeoffset, "ethernet1", NULL); + if (prop) { + u32 tmp[] = { 35, 0x8, 36, 0x8, 37, 0x8 }; + + path = fdt_path_offset(blob, prop); + prop = fdt_getprop(blob, path, "interrupts", 0); + if (prop) + fdt_setprop(blob, path, "interrupts", + &tmp, sizeof(tmp)); + } +#endif + } + } +#endif #endif
do_fixup_by_prop_u32(blob, "device_type", "cpu", 4,
Kim Phillips
