Re: [U-Boot] [PATCH v3 09/15] env: Support multiple environments
On 02/07/2018 21:18, York Sun wrote:
On 02/07/2018 12:43 AM, Maxime Ripard wrote:
On Tue, Jan 30, 2018 at 11:02:49PM +0000, York Sun wrote:
On 01/30/2018 12:16 PM, York Sun wrote:
On 01/30/2018 11:40 AM, York Sun wrote:
On 01/30/2018 12:19 AM, Simon Goldschmidt wrote:
On 23.01.2018 21:16, Maxime Ripard wrote: > Now that we have everything in place to support multiple environment, let's > make sure the current code can use it. > > The priority used between the various environment is the same one that was > used in the code previously. > > At read / init times, the highest priority environment is going to be > detected,
Does priority handling really work here? Most env drivers seem to ignore the return value of env_import and may thus return success although importing the environment failed (only reading the data from the device succeeded).
This is from reading the code, I haven't had a chance to test this, yet.
It is broken on my LS1043ARDB with simply NOR flash. I am trying to determine what went wrong.
I found the problem. The variable "env_load_location" is static. It is probably not write-able during booting from flash. It is expected to be set during ENVOP_INIT. But if I print this variable, it has ENVL_UNKNOWN. I can make it work by moving env_load_location to global data structure.
That would work for me.
That being said, this addition of multiple environments really slows down the booting process for me. I see every time env_get_char() is called, env_driver_lookup() runs. A simple call of env_get_f() gets slowed down dramatically. I didn't find out where the most time is spent yet.
Does anyone else experience this unbearable slowness?
I found the problem. In patch #3 in this series, the default get_char() was dropped so there is no driver for a plain NOR flash. A quick (and maybe dirty) fix is this
diff --git a/env/env.c b/env/env.c index edfb575..210bae2 100644 --- a/env/env.c +++ b/env/env.c @@ -159,7 +159,7 @@ int env_get_char(int index) int ret;
if (!drv->get_char)
continue;
return *(uchar *)(gd->env_addr + index); if (!env_has_inited(drv->location)) continue;
And this too.
If you agree with this fix (actually revert your change earlier), I can send out a patch.
I still think we should get rid of the 'get_char' callback for the env drivers. While that could have made sense for some boards before the conversion to multiple environments (although I doubt that, as the environment is *not* checked for validity in this call), its meaning is totally lost when having multiple env drivers active.
The whole purpose of multiple env drivers is that we select a valid driver in the 'load' callback. How could we possibly know that the 'get_char' callback of the highest prio env driver is what we want?
I'd rather make 'env_get_char' weak and let boards decide if they really want this behaviour.
A quick search through the current code base shows me *no* usage of 'get_char' in nvram.c (CONFIG_SYS_NVRAM_ACCESS_ROUTINE is never defined) and only 7 defconfigs that use ENV_IS_IN_EEPROM:
imx31_phycore_defconfig imx31_phycore_eet_defconfig km_kirkwood_128m16_defconfig km_kirkwood_defconfig km_kirkwood_pci_defconfig mgcoge3un_defconfig portl2_defconfig
Are these seven boards worth keeping this feature?
Simon
With this temporary fix, my flash chip works again and I can boot all the way up in a timely manner. I still don't like to call env_driver_lookup() thousands of times to get a simple env variable.
Can Maxime post a quick post soon?
Given that you already made all the debugging, and the patches, and I have no way to test, I guess it would make more sense if you did it :)
Yes, I have tested on my boards. I will send out this patch.
York
On 01/30/2018 12:19 AM, Simon Goldschmidt wrote: > On 23.01.2018 21:16, Maxime Ripard wrote: >> Now that we have everything in place to support multiple environment, let's >> make sure the current code can use it. >> >> The priority used between the various environment is the same one that was >> used in the code previously. >> >> At read / init times, the highest priority environment is going to be >> detected, > > Does priority handling really work here? Most env drivers seem to ignore > the return value of env_import and may thus return success although > importing the environment failed (only reading the data from the device > succeeded). > > This is from reading the code, I haven't had a chance to test this, yet.
Actually I am not a big fun to using global data. It increases size for everybody. But I don't see a way you can save the variable before relocation.
if (!drv->get_char)
continue;
And this too.
Simon,
Adding multiple environments seems to be an improvement. But this fell through the cracks. I don't know if other boards also read env before relocation. All my boards reads hwconfig before relocation. Having to create a new function for all of them doesn't look appealing to me.
York
On 01/30/2018 11:40 AM, York Sun wrote: > On 01/30/2018 12:19 AM, Simon Goldschmidt wrote: >> On 23.01.2018 21:16, Maxime Ripard wrote: >>> Now that we have everything in place to support multiple environment, let's >>> make sure the current code can use it. >>> >>> The priority used between the various environment is the same one that was >>> used in the code previously. >>> >>> At read / init times, the highest priority environment is going to be >>> detected, >> Does priority handling really work here? Most env drivers seem to ignore >> the return value of env_import and may thus return success although >> importing the environment failed (only reading the data from the device >> succeeded). >> >> This is from reading the code, I haven't had a chance to test this, yet. > It is broken on my LS1043ARDB with simply NOR flash. I am trying to > determine what went wrong. > I found the problem. The variable "env_load_location" is static. It is probably not write-able during booting from flash. It is expected to be set during ENVOP_INIT. But if I print this variable, it has ENVL_UNKNOWN. I can make it work by moving env_load_location to global data structure.
if (!drv->get_char)
continue;
And this too.
Simon,
The change I proposed would be to restore the old behavior but kick out the byte-by-byte reading from eeprom and nvram. My understanding was you are using flash and were reading from environment in ram, not in nvram or eeprom.
Simon
Goldschmidt Simon
Simon Goldschmidt
York Sun
